Hyster Challenger H14.00-18.00XM-12 H14.00-18.00XM-12EC A214 Parts Manual 1452617 2022
Brand: Hyster
Type of Machine: Forklift
Model: Hyster Challenger H14.00-18.00XM-12 H14.00-18.00XM-12EC A214 Forklift
Part Number: 1452617
Publication Date: 2022
Number of Pages: 822 Pages
Frame
GENERAL TRUCK
FLOOR PLATES AND COVERS EMPTY CONTAINER HANDLER
FLOOR PLATES AND COVERS FORK LIFT TRUCK - PAGE 1 OF 2
FLOOR PLATES AND COVERS FORK LIFT TRUCK - PAGE 2 OF 2
OPERATOR COMPARTMENT WITHOUT CAB
OPERATOR COMPARTMENT WITH CAB - PAGE 1 OF 3
OPERATOR COMPARTMENT WITH CAB - PAGE 2 OF 3
OPERATOR COMPARTMENT WITH CAB - PAGE 3 OF 3
DOORS
HOOD EMPTY CONTAINER HANDLER
HOOD FORK LIFT TRUCK
HEATER
HEATER CONTROL
WINDSHIELD WASHER
COUNTERWEIGHTS
FENDERS EMPTY CONTAINER HANDLER
SEAT HIGH BACK - KAB (→ S/N A214E02193C)
SEAT ASSEMBLY HIGH BACK - KAB (S/N A214E02194C →)
SUSPENSION SEAT GRAMMER HIGH BACK - PAGE 1 OF 2
SUSPENSION SEAT GRAMMER HIGH BACK - PAGE 2 OF 2
LABELS INTERIOR
LABELS EXTERIOR - EMPTY CONTAINER HANDLER
LABELS EXTERIOR - FORK LIFT TRUCK
ENGINES
ENGINE ASSEMBLY
AIR INTAKE HEATER TIER I ENGINE
CAM FOLLOWER COVER TIER I ENGINE
FRONT DRIVE GEAR COVER TIER I ENGINE
FUEL DRAIN TIER I ENGINE
THERMOSTAT TIER I ENGINE
ALTERNATOR TIER I ENGINE
COVER AND SEAL TIER I ENGINE
FAN DRIVE TIER I ENGINE
FUEL FILTER TIER I ENGINE
LIFT PUMP TIER I ENGINE
FUEL SHUT-OFF VALVE TIER I ENGINE
LIFTING BRACKET TIER I ENGINE
OIL COOLER TIER I ENGINE
OIL LEVEL GAUGE TIER I ENGINE
OIL FILLER ARRANGEMENT TIER I ENGINE
STARTER TIER I ENGINE
AIR INTAKE CONNECTION TIER I ENGINE
THERMOSTAT HOUSING TIER I ENGINE
VALVE COVER TIER I ENGINE
HEATER PLUMBING TIER I ENGINE
WATER INLET CONNECTION TIER I ENGINE
WATER OUTLET CONNECTION TIER I ENGINE
WATER PUMP TIER I ENGINE
CYLINDER BLOCK TIER II ENGINE
CYLINDER HEAD TIER II ENGINE
PISTON AND CONNECTING ROD TIER II ENGINE
CRANKSHAFT AND MAIN BEARINGS TIER II ENGINE
ROCKER LEVERS TIER II ENGINE
CAMSHAFT TIER II ENGINE
INJECTOR TIER II ENGINE
VALVE TAPPET TIER II ENGINE
ENGINE CONTROL SYSTEM TIER II ENGINE
VIBRATION DAMPER TIER II ENGINE
FRONT GEAR TRAIN COVER TIER II ENGINE
FLYWHEEL HOUSING TIER II ENGINE
BREATHER PLUMBING TIER II ENGINE
OIL PAN TIER II ENGINE
OIL LEVEL GAUGE TIER II ENGINE
OIL PUMP TIER II ENGINE
CRANKCASE BREATHER TIER II ENGINE
FLYWHEEL TIER I AND TIER II ENGINES
THERMOSTAT TIER II ENGINE
AIR COMPRESSOR PLUMBING TIER II ENGINE (S/N A214E01954A →)
ALTERNATOR MOUNTING TIER II ENGINE
FAN DRIVE TIER II ENGINE
WATER SEPARATOR TIER II ENGINE
FUEL FILTER PLUMBING TIER II ENGINE (S/N A214E01950A →)
FUEL FILTER PLUMBING TIER II ENGINE (S/N A214E01951A →)
FUEL INJECTION PUMP TIER II ENGINE
FUEL PUMP MOUNT TIER II ENGINE
LIFT PUMP TIER II
LIFT PUMP PLUMBING TIER II ENGINE
FRONT GEAR COVER TIER II ENGINE
GEAR HOUSING TIER II
AIR INTAKE CONNECTION TIER II ENGINE
AIR INTAKE HOSE TIER II ENGINE
AIR TRANSFER CONNECTION TIER II ENGINE
LIFTING BRACKET TIER II ENGINE
ENGINE OIL COOLER TIER II ENGINE
OIL FILLER ARRANGEMENT TIER II ENGINE (→ S/N A214E01950A)
OIL FILTER TIER II ENGINE
TURBOCHARGER TIER II ENGINE
RADIATOR PLUMBING TIER II ENGINE
STARTING MOTOR TIER II ENGINE
FAN PILOT SPACER TIER II ENGINE
EXHAUST MANIFOLD TIER II ENGINE
TORQUE CONVERTER OIL COOLER TIER II ENGINE
TURBOCHARGER PLUMBING TIER II ENGINE
VALVE COVER TIER II ENGINE
WATER INLET CONNECTION TIER II ENGINE
WATER OUTLET CONNECTION TIER II ENGINE
WATER PUMP TIER II ENGINE
TENSIONER TIER II ENGINE
WIRING ACCESSORIES TIER II ENGINE
AIR FILTER TIER I ENGINE
AIR FILTER FORK LIFT TRUCK - TIER II ENGINE (S/N A214E01843Z →)
AIR FILTER EMPTY CONTAINER HANDLER - TIER II ENGINE (S/N A214E01849Z →)
AIR FILTER ASSEMBLY
PRE-CLEANER ASSEMBLY
COOLING TIER I ENGINE
COOLING FORK LIFT TRUCK - TIER II ENGINE (S/N A214E01843Z →)
COOLING EMPTY CONTAINER HANDLER - TIER II ENGINE (S/N A214E01849Z →)
ENGINE MOUNT
EXHAUST EMPTY CONTAINER HANDLER - TIER I ENGINE
EXHAUST EMPTY CONTAINER HANDLER - TIER II ENGINE
EXHAUST FORK LIFT TRUCK
FUEL SYSTEM
FUEL SYSTEM TIER I ENGINE
FUEL SYSTEM TIER II ENGINE
THROTTLE TIER I ENGINE
ELECTRONIC FOOT PEDAL MOUNT TIER II ENGINE
THROTTLE PEDAL TIER I ENGINE (→ 11/2002)
THROTTLE PEDAL TIER I ENGINE (12/2002 →)
ELECTRICAL SYSTEM
ELECTRICAL CHASSIS TIER I ENGINE - PAGE 1 OF 3
ELECTRICAL CHASSIS TIER I ENGINE - PAGE 2 OF 3
ELECTRICAL CHASSIS TIER I ENGINE - PAGE 3 OF 3
ELECTRICAL CHASSIS (TIER II ENGINE) - PAGE 1 OF 4
ELECTRICAL CHASSIS (TIER II ENGINE) - PAGE 2 OF 4
ELECTRICAL CHASSIS (TIER II ENGINE) - PAGE 3 OF 4
ELECTRICAL CHASSIS (TIER II ENGINE) - PAGE 4 OF 4
INSTRUMENT PANEL PAGE 1 OF 2
INSTRUMENT PANEL PAGE 2 OF 2
CONTROL PANEL
CONTROL PANEL
LIGHT CONTROLS
LIGHTS EMPTY CONTAINER HANDLER
LIGHTS FORK LIFT TRUCK
LIGHTS ROTATING BEACON
WIRE HARNESS ATTACHMENT CONTROL - PAGE 1 OF 2 (→ S/N A214E01650)
WIRE HARNESS ATTACHMENT CONTROL - PAGE 2 OF 2 (→ S/N A214E01650)
WIRE HARNESS ATTACHMENT CONTROL (S/N A214E01651 ↔ S/N A214E01806)
WIRE HARNESS ATTACHMENT CONTROL SWITCH (S/N A214E01807 →)
WIRE HARNESS ATTACHMENT CONTROL SWITCH (S/N A214E02078B ↔ S/N A214E02193C)
WIRE HARNESS ATTACHMENT CONTROL SWITCH (S/N A214E02194C →)
WIRE HARNESS ATTACHMENT LIGHTS (S/N A214E01807 →)
WIRE HARNESS CAB (→ S/N A214E01797)
WIRE HARNESS CAB (S/N A214E01798 →)
WIRE HARNESS CARRIAGE CONTROL SWITCH (S/N A214E01403 →)
WIRE HARNESS CHASSIS - EMPTY CONTAINER HANDLER
WIRE HARNESS CHASSIS - FORK LIFT TRUCK
WIRE HARNESS ENGINE (→ S/N A214E01718)
WIRE HARNESS ENGINE (S/N A214E01719 →)
WIRE HARNESS ENGINE - TIER II
WIRE HARNESS FRONT END EQUIPMENT - EMPTY CONTAINER HANDLER (→ S/N A214E01806)
WIRE HARNESS FRONT END EQUIPMENT - EMPTY CONTAINER HANDLER (S/N A214E01807 ↔ S/N A214E02077B)
WIRE HARNESS FRONT END EQUIPMENT (S/N A214B02078B →)
WIRE HARNESS FRONT END EQUIPMENT - FORK LIFT TRUCK
WIRE HARNESS FRONT LIGHTS
WIRE HARNESS HYDRAULIC - EMPTY CONTAINER HANDLER (→ S/N A214E01806)
WIRE HARNESS HYDRAULIC - EMPTY CONTAINER HANDLER (S/N A214E01807 →)
WIRE HARNESS HYDRAULIC - FORK LIFT TRUCK (→ S/N A214E01806Y)
WIRE HARNESS HYDRAULIC - FORK LIFT TRUCK (S/N A214E01807Y →)
WIRE HARNESS MODULE (→ S/N A214E01797)
WIRE HARNESS MODULE (S/N A214E01798 →)
WIRE HARNESS OPERATOR COMPARTMENT (TIER I) - PAGE 1 OF 2
WIRE HARNESS OPERATOR COMPARTMENT (TIER I) - PAGE 2 OF 2
WIRE HARNESS OPERATOR COMPARTMENT (TIER II) - PAGE 1 OF 2 (S/N A214E01843Z → (FLT)) (S/N A214E01849Z → (ECH))
WIRE HARNESS OPERATOR COMPARTMENT (TIER II) - PAGE 2 OF 2 (S/N A214E01843Z → (FLT)) (S/N A214E01849Z → (ECH))
WIRE HARNESS OPERATOR COMPARTMENT TO MAST LIGHT JUMPER - FORK LIFT TRUCK
WIRE HARNESS REAR LIGHT
WIRE HARNESS ROTATING BEACON
WIRE HARNESS STEERING POD
WIRE HARNESS SWITCH LIGHTS
WIRE HARNESS SWITCH - WARNING
WIRE HARNESS TRANSMISSION
WIRE HARNESS TRANSMISSION (→ S/N A214E01615)
WIRE HARNESS TRANSMISSION (S/N A214E01616 ↔ S/N A214E002194C)
WIRE HARNESS TRANSMISSION (S/N A214E02194C →)
WIRE HARNESS TURN SIGNAL
WIRE HARNESS WINDSHIELD WASHER
WIRE HARNESS WORK LIGHTS
WIRE HARNESS WORK LIGHTS - EMPTY CONTAINER HANDLER
WIRE HARNESS WORK LIGHTS - FORK LIFT TRUCK
WIRE HARNESS WORK LIGHTS EXTENSION - FORK LIFT TRUCK
WIRE HARNESS SELECTOR VALVE
WIRE HARNESS HYDRAULIC OIL COOLER
LIGHT BAR AND MOUNT TWISTLOCK MODULE - CAB
TRANSMISSION
TRANSMISSION ATTACHING PARTS
TRANSMISSION MOUNT AND ATTACHING PARTS
TRANSMISSION ATTACHING PARTS OIL FILTER
TRANSMISSION HYDRAULIC LINES
TRANSMISSION INPUT SHAFT
TRANSMISSION TORQUE CONVERTER
TRANSMISSION CONTROL VALVE ATTACHING PARTS
TRANSMISSION CONTROL VALVE (→ S/N A214E01615)
TRANSMISSION CONTROL VALVE (S/N A214E01616 →)
TRANSMISSION CLUTCH PACK - REVERSE AND FIRST GEAR - PAGE 1 OF 3
TRANSMISSION CLUTCH PACK - FORWARD AND SECOND GEAR - PAGE 2 OF 3
TRANSMISSION CLUTCH PACK - THIRD GEAR - PAGE 3 OF 3
TRANSMISSION SHIFT LEVER
TRANSMISSION INCHING PEDAL (→ S/N A214E01615)
TRANSMISSION INCHING VALVE (→ S/N A214E01615)
Drive Axle
DRIVE AXLE
DRIVE AXLE
DIFFERENTIAL ASSEMBLY
PARK BRAKE
BRAKE ASSEMBLY DISC (→ S/N A214E01995B (H14.00-16.00XM FLT)) (S/N A214E02034A → (H18.00-20.00XM FLT)) (S/N A214E02001B → (H14.00-16.00XM ECH))
DRIVE SHAFT
STEERING SYSTEM
STEERING HOUSING AND CONTROL UNIT
STEERING HYDRAULICS EMPTY CONTAINER HANDLER
STEERING HYDRAULICS FORK LIFT TRUCK
STEERING CYLINDER
STEERING CYLINDER OPTIONAL
STEERING PUMP
STEERING CONTROL BLOCK VALVE (→ 10/2003)
STEERING AXLE
BRAKE SYSTEM
BRAKE LINES EMPTY CONTAINER HANDLER
BRAKE LINES FORK LIFT TRUCK (→ S/N A214E01765Y)
BRAKE LINES FORK LIFT TRUCK (S/N A214E01766Y →)
BRAKE PEDAL LINKAGE EMPTY CONTAINER HANDLER
BRAKE PEDAL LINKAGE FORK LIFT TRUCK (→ S/N A214E01765Y)
BRAKE PEDAL LINKAGE FORK LIFT TRUCK (S/N A214E01766Y →)
BRAKE CHECK VALVE EMPTY CONTAINER HANDLER (→ S/N A214E01572)
BRAKE CHECK VALVE FORK LIFT TRUCK (→ S/N A214E01572)
BRAKE SYSTEM POWER BRAKE VALVE
HYDRAULIC SYSTEM
HYDRAULIC LINES SUPPLY AND RETURN - EMPTY CONTAINER HANDLER
OIL COOLER AND ATTACHING PARTS EMPTY CONTAINER HANDLER - TIER II ENGINE
OIL COOLER AND ATTACHING PARTS FORK LIFT TRUCK - TIER II ENGINE
HYDRAULIC LINES SUPPLY AND RETURN - FORK LIFT TRUCK (→ S/N A214E01842Z)
HYDRAULIC LINES SUPPLY AND RETURN - FORK LIFT TRUCK (S/N A214E01843Z →)
HYDRAULIC LINES CONTROL VALVE (→ S/N A214E01806)
HYDRAULIC LINES CONTROL VALVE (S/N A214E01807 →)
HYDRAULIC LINES AUXILIARY - FORK LIFT TRUCK
HYDRAULIC LINES LIFT - FORK LIFT TRUCK
HYDRAULIC CONTROL
HYDRAULIC CONTROL
HYDRAULIC CONTROL VALVE - ATTACHING PARTS
HYDRAULIC CONTROL VALVE - MAIN
HYDRAULIC DIRECTIONAL CONTROL VALVE - EMPTY CONTAINER HANDLER
HYDRAULIC SOLENOID VALVE ATTACHING PARTS LIFT AND LOWERING INTERRUPT - EMPTY CONTAINER HANDLER (S/N A214E01752X →)
HYDRAULIC SOLENOID VALVE LIFT AND LOWERING INTERRUPT - EMPTY CONTAINER HANDLER (S/N A214E01752X →)
HYDRAULIC PILOT CONTROL VALVE EMPTY CONTAINER HANDLER
HYDRAULIC PILOT CONTROL SUPPLY VALVE EMPTY CONTAINER HANDLER
HYDRAULIC RELIEF VALVE TILT (→ S/N A214E02029B)
HYDRAULIC PUMP
HYDRAULIC TANK
HYDRAULIC TANK
BRAKE COOLING SYSTEM EMPTY CONTAINER HANDLER (→ S/N A214E01751)
BRAKE COOLING SYSTEM EMPTY CONTAINER HANDLER (S/N A214E01752 →)
BRAKE COOLING SYSTEM FORK LIFT TRUCK (→ S/N A214E01751)
BRAKE COOLING SYSTEM FORKLIFT TRUCK (S/N A214E01752 →)
BRAKE COOLING SYSTEM ACCUMULATOR
HYDRAULIC SYSTEM TILT CYLINDER - EMPTY CONTAINER HANDLER
HYDRAULIC SYSTEM TILT CYLINDER - FORK LIFT TRUCK
TILT CYLINDER EMPTY CONTAINER HANDLER
TILT CYLINDER FORK LIFT TRUCK
MAST-TWO STAGE VISTA
OUTER MAST TWO STAGE VISTA
INNER MAST TWO STAGE VISTA
MAIN LIFT TWO STAGE VISTA - PAGE 1 OF 2
MAIN LIFT TWO STAGE VISTA - PAGE 2 OF 2
LIFT CYLINDER H14.00-16.00XM - TWO STAGE VISTA (→ 9/2004)
LIFT CYLINDER H14.00-16.00XM - TWO STAGE VISTA (9/2004 →)
LIFT CYLINDER H18.00-20.00XM - TWO STAGE VISTA (→ 9/2004)
LIFT CYLINDER H18.00-20.00XM - TWO STAGE VISTA (9/2004 →)
HEADER HOSE TWO STAGE VISTA
MAST INSTALLATION TWO STAGE VISTA
CARRIAGE TWO STAGE VISTA
CARRIAGE WITH QUICK DISCONNECT - TWO STAGE VISTA
CARRIAGE HYDRAULIC SYSTEM - TWO STAGE VISTA
FORK POSITIONER AND SIDE-SHIFT CYLINDER TWO STAGE VISTA
SOLENOID VALVE TWO STAGE VISTA
WIRE HARNESS FRONT END EQUIPMENT - HEADER HOSES, MAST REAR
WIRE HARNESS FRONT END EQUIPMENT - HEADER HOSES, MAST FRONT
MAST WITH EMPTY CONTAINER HANDLER
OUTER MAST EMPTY CONTAINER HANDLER
INNER MAST EMPTY CONTAINER HANDLER
MAIN LIFT EMPTY CONTAINER HANDLER (→ S/N A214E01654)
MAIN LIFT EMPTY CONTAINER HANDLER (S/N A214E01655 →)
LIFT CYLINDER EMPTY CONTAINER HANDLER (→ S/N A214E01574)
LIFT CYLINDER EMPTY CONTAINER HANDLER (S/N A214E01575 →)
LIFT CYLINDER ATTACHING PARTS EMPTY CONTAINER HANDLER (→ S/N A214E02236D)
LIFT CYLINDER ATTACHING PARTS EMPTY CONTAINER HANDLER (S/N A214E02237D →)
WEAR PLATES EMPTY CONTAINER HANDLER (→ S/N A214E01806)
VERTICAL END BEAM EMPTY CONTAINER HANDLER (→ S/N A214E01806)
HYDRAULIC SYSTEM EMPTY CONTAINER HANDLER - PAGE 1 OF 2 (→ S/N A214E01806)
HYDRAULIC SYSTEM EMPTY CONTAINER HANDLER - PAGE 2 OF 2 (→ S/N A214E01806)
TWIST LOCK CYLINDER EMPTY CONTAINER HANDLER (→ S/N A214E01806)
EXTENSION CYLINDER EMPTY CONTAINER HANDLER (→ S/N A214E01806)
SIDE-SHIFT CYLINDER CONTAINER HANDLING ATTACHMENT (→ S/N A214E01806)
HEADER HOSE EMPTY CONTAINER HANDLER (→ S/N A214E01807Y EXC. 01791)
HEADER HOSE EMPTY CONTAINER HANDLER (S/N A214E01808Y ↔ S/N A214E01962A INC. 01791)
HEADER HOSE EMPTY CONTAINER HANDLER (S/N A214E01963A ↔ S/N A214E02077B)
HEADER HOSE EMPTY CONTAINER HANDLER (S/N A214E02078B →)
AUXILIARY ATTACHMENTS EMPTY CONTAINER HANDLER
MAST INSTALLATION EMPTY CONTAINER HANDLER
WIRE HARNESS EMPTY CONTAINER HANDLER (→ S/N A214E01806)
WIRE HARNESS TWIST LOCK (S/N A214E01807 ↔ S/N A214E01962A)
WIRE HARNESS HOOK ATTACHMENT (S/N A214E01807 ↔ S/N A214E01962A)
WIRE HARNESS MAST (→ S/N A214E02077B)
WIRE HARNESS MAST (S/N A214E02078B →)
WIRE HARNESS FRONT END EQUIPMENT - HEADER HOSES, EMPTY CONTAINER HANDLER (S/N A214E01963A →)
OPTIONS
WHEEL AND TIRE BIAS TIRE
WHEEL AND TIRE BIAS TIRE - SIMEX AND GOODYEAR TIRES
WHEEL AND TIRE RADIAL TIRE
WHEEL AND TIRE SOLID TIRE - WITH TREAD
WHEEL AND TIRE SOLID TIRE - SMOOTH
FORKS PIN TYPE
FORKS HOOK TYPE
NUMERICAL INDEX
Brand: Hyster
Frame
GENERAL TRUCK
DOORS
HEATER
HEATER CONTROL
WINDSHIELD WASHER
COUNTERWEIGHTS
LABELS INTERIOR
ENGINES
ENGINE ASSEMBLY
LIFT PUMP TIER II
AIR FILTER ASSEMBLY
ENGINE MOUNT
FUEL SYSTEM
ELECTRICAL SYSTEM
CONTROL PANEL
CONTROL PANEL
LIGHT CONTROLS
TRANSMISSION
Drive Axle
DRIVE AXLE
DRIVE AXLE
PARK BRAKE
DRIVE SHAFT
STEERING SYSTEM
STEERING CYLINDER
STEERING PUMP
STEERING AXLE
BRAKE SYSTEM
HYDRAULIC SYSTEM
HYDRAULIC CONTROL
HYDRAULIC CONTROL
HYDRAULIC PUMP
HYDRAULIC TANK
HYDRAULIC TANK
OPTIONS
FORKS PIN TYPE
FORKS HOOK TYPE
NUMERICAL INDEX
- Hyster Forklift Parts and Service Manual CD7
- Hyster Forklift Parts and Service Manual CD2
- Hyster Forklift Parts and Service Manual CD3
- Hyster Forklift Diagrams and Schematics
- Hyster Forklift Parts and Service Manual CD4
- Hyster Forklift Parts and Service Manual CD10
- Hyster Forklift Parts and Service Manual CD9
- HYSTER Forklift H4.0 Shop Manual
- Hyster Forklift Parts and Service Manual CD6
- Hyster THREE-SPEED POWERSHIFT TRANSMISSION REPAIR Manual
- Hyster Forklift Parts and Service Manual CD5
- Hyster Forklift Parts and Service Manual CD8
- Linde Forklift 353-02D Operator Manual , SAFETY TIPS,Electric and Hydraulic circuit diagram
- Perkins Diesel Engines 1004-42(AR) 1006-60(YG) 1006-60T(YH) Repair And Maintenance Manual
