Hyundai
86
176,834
Hitachi ZW100-6 ZW120-6 DEUTZ TCD3.6L4 Engine Parts Catalog PNSAA0-EG1-4
Brand: Hitachi
Type of Machine: Wheel Loader
Type of Manual: Engine Parts Catalog
Model: Hitachi ZW100-6 ZW120-6 Wheel Loader
Engine DEUTZ TCD3.6L4
Part Number: PNSAA0-EG1-4
Serial Number:
NSCA0,NSAA0 : 010001~
NSC60,NSA60 : 005201~
NSA20: 020001~
Publication Date: 2023
Number of Pages: 132 Pages
COVER
MEMORANDUM
FOREWORD
CONTENTS
BREATHER LINE
BLANKING PARTS
REAR END COVER
DIPSTICK
ENGINE BLOCK
BLANKING PARTS
OIL PAN
OIL FILLER TUBE
FLYWHEEL
CRANKSHAFT
V-GROOVED PULLEY
V-RIB. BELT PULLEY
CONNECTING ROD
PISTON
FASTENINGS
CYLINDER HEAD
VALVE MECHAN.COVER
IDLER GEAR
FASTENINGS
GEAR CASE
CAMSHAFT
VALVE DRIVE
LUBRICAT. OIL PUMP
OIL COOLER ASSY
BRACKET
OIL SUCTION LINE
LUBRICAT. OIL LINE
OIL RETURN LINE (1)
OIL RETURN LINE (2)
TRANSFER PIPE
FUEL INJECT. PUMP
FUEL INJECTOR
FUEL PREFILTER
FUEL FILTER
FUEL SUPPLY PUMP
RAIL
FUEL LINE
QUICK CLUTCH COUP.
SENSOR
CHARGE AIR PIPE
THROTTLE VALVE
CONTROL UNIT
VOLTAGE TRANSFORM
V-RIB. BELT PULLEY
COOLANT PUMP
COOLING WATER LINE
HOUSING
ADAPTER
BELLOW EXPAN. JOINT
BRACKET
SCREW PLUG
EXHAUST PIPE
EXHAUST PIPE
BRACKET
EGR COOLER
EGR COOLER
COOLANT PIPE
EXHAUST MANIFOLD
COOLING WATER LINE (1)
COOLING WATER LINE (2)
GASKET
TURBOCHARGER
FASTENINGS
GENERATOR MOUNTING
STARTER
BELT TENSIONER
GENERATOR
ATTACHMENT PLUG
LEVEL SWITCH
FASTENINGS
RELAY
FASTENINGS
ELECTRIC LINE
FASTENINGS
FASTENINGS
FASTENINGS
FASTENINGS
FASTENINGS
CABLE HARNESS
TACHO-GENERATOR
SENSOR
PRESSURE PICK-UP
FLYWHEEL HOUSING
GLOW PLUG
SOLENOID VALVE
CLIP
EXHAUST HOLDER
MIXING TUBE
METERING UNIT
TRANSMITTER MOUNT.
CATALYST
CATALYST
BRACKET
MOUNTING PARTS
DOSING PUMP
PLUG
CAP
PLUG
PARTS INDEX
