Hitachi Wheel Loader ZW160-7 ZW160PL-7 Parts Catalog PNTL50-1-1 2022 EN JP
Language: English, Japanese
Brand: Hitachi
Type of Machine: Wheel Loader
Model: Hitachi ZW160-7 ; ZW160PL-7 Wheel Loader
Serial Number: NTL50, NTL51 - 500101~
Engine: Cummins B4.5 Engine
Part Number: PNTL50-1-1
Publication Date: 2022
Number of Pages: 493 Pages
Cover
Memorandum
Foreword
Illustration Contents
Contents
Periodic Replacement Parts
Filter, Element, Belt Parts
Bucket Parts
Bulb, Lens Parts
Engine Support
Drain Piping
Cooling Device (1)
Cooling Device (2)
Cooling Device Parts
Radiator Piping
Fan Pump
Fan Piping (1)
Fan Piping (Reverse)
Fuel Piping
Exhaust Device (1)
Exhaust Device (2)
Air Intake Device
Pre Creaner (Sy-Klone)
Pre-Cleaner (Turbo2)
Urea Water Tank
Urea Water Tank Piping (1)
Urea Water Tank Piping (2)
Air Cleaner Parts (Inside Intake Type)
Power Train
Transmission Piping
Hst Pump
Hst Motor
Hst Piping (1)
Hst Piping (2)
Hst Piping (3)
Propeller Shaft
Axle Support
Front Axle (Lsd)
Rear Axle (Lsd)
Front Axle (Tpd)
Rear Axle (Tpd)
Tire Parts
Radial Tire (Michelin)(20.5r25-L3)
Radial Tire (Bridgestone)(20.5r25-L3)
Radial Tire (Michelin)(20.5r25-L5-Xldd2a)
Radial Tire (Michelin)(20.5r25-L5-Xmined2)
Radial Tire (Michelin)(20.5r25-L3 Spare Tire With Rim)
Snow Tire (Michelin)(20.5r25-L2)
Snow Tire (Michelin)(20.5r25-L2 Spare Tire With Rim)
Front Frame (With Lifting Lug)
Front Frame (Parallel Link)
Rear Frame (With Lifting Lug)
Frame Parts (1)
Frame Parts (2)
Frame Parts (3)
Under Guard (Front)
Under Guard (Rear)
Counterweight
Counterweight (Parallel Link)
Counterweight Support
Engine Cover
Engine Cover Support
Radiator Cover (Cap)
Rear Grille
Side Panel (1)
Side Panel (2)
Side Panel (3)
Side Panel (4)
Dust Screen
Gas Spring (With Full Rear Fender)
Gas Spring (With Rear Fender)
Fender
Full Rear Fender
Floor Board (1)
Floor Board (2)
Mud Guard
Front Frame Cover
Cab Parts
Cab (1)
Cab (2)
Cab (3)
Cab (4)
Cab (5)
Cab (6)
Cab Group
Front Console (1)
Front Console (2)
Steering Wheel
Steering Column
Right Console Slider
Rear Console (1)
Rear Console (2)
Air Conditioner (1)
Air Conditioner Unit
Air Conditioner (2)
Compressor
Duct (Cab)(1)
Duct (Cab)(2)
A/C Control Panel
Floor Mat
Cover (Mat)
Mat (Floor Plate)
Cover (Floor Plate)
Room Mirror
Sunvisor (Roll Type)
Switch Panel
Switch Panel Cap
Air Suspension Seat (Cloth)(With Heater)(With Headrest)(Grammer)
Seat Base (1)
Seat Base (2)
Air Filter (Double)
Air Filter With Pre-Cleaner
Radio
Floor Plate (1)
Floor Plate (2)
Floor Plate Parts
Floor Parts (Floor Plate)
Floor Parts (Rear Console)
Floor Parts (Drink Holder)
Rearview Mirror (With Heater)
Washer Tank
Electric System
Multi-Function Lever (3 Spool)
Multi-Function Lever (4 Spool)
Work Lever Cover (Multi-Function)
Electric Parts (Right Console)(1)
Electric Parts (Right Console)(2)
Cover (Right Console)(1)
Cover (Right Console)(2)
Controller Bracket (Grammer)
Controller Cover (Grammer)
Bellcrank Sensor
Bellcrank Sensor (Parallel Link)
Lift Arm Automatic Leveler System
Lift Arm Automatic Leveler System (Parallel Link)
Horn
Front Head Lamp
Head Light Support
Electric Parts (Front)
Electric Parts (Front)(Parallel Link)
Electric Parts (Rear)(1)
Electric Parts (Rear)(2)
Electric Parts (Rear)(3)
Electric Parts (Rear)(4)
Electric Parts (Rear)(5)
Electric Parts (Rear)(6)
Electric Parts (Rear)(7)
Electric Parts (Rear)(8)
Electric Parts (Clip)(Rear)
Battery Switch
Battery
Large Capacity Battery
Rear Combination Lamp (Led)
Rear Head Lamp
Rear Head Lamp (Led)
Rear Head Lamp (High Brightness Led)
Buzzer (Rear Obstacle Detection System)
Back Buzzer (Loud Type)
Plug Mount (Rear Obstacle Detection System Less)
Emergency Steering Sw
Electric Parts (Emergency Steering)
Electric Parts (Side Camera)
Electric Parts (Aerial Angle)
Controller (Aerial Angle)
Electric Parts (Front Console)(1)
Electric Parts (Front Console)(2)
Electric Parts (Front Console)(3)
Electric Parts (Floor)(1)
Electric Parts (Floor)(2)
Electric Parts (Rear Console)(1)
Electric Parts (Rear Console)(2)
Electric Parts (Rear Console)(3)
Electric Parts (Steering Column)(1)
Electric Parts (Steering Column)(2)
Accessory Socket (12v)
Accessory Socket (24v)
Electric Parts (Monitor)
12v Power Unit
Idle Stop Parts
Inertial Sensor
Sub Monitor
Switch Box
Right Side Door Sw Cover (1)
Right Side Door Sw Cover (2)
Right Side Door Sw Plug
Electric Parts (3 Spool)
Electric Parts (4 Spool)
Electric Parts (Quick Coupler)
Side Console Sw (Quick Coupler)
Relay For Quick Coupler
Start Switch
Controller (Plcu)
Controller (Mc)
Controller (Mobile Communications)
Controller (Hst)
Usb Port
Work Light (Led)(Cab Front)
Work Light (High Brightness Led)(Cab Front)
Relay For Work Light (Led)(Cab Rear)
Additional Work Light (Led)(Cab Front)
Additional Work Light (Led)(Cab Rear)
Additional Work Light (High Brightness Led)(Cab Front)
Additional Work Light (High Brightness Led)(Cab Rear)
Relay For Additional Work Light (Led)
Rotating Beacon
Without Rotating Beacon Parts
Relay For Rotating Beacon
Pump Device
Control Valve (2 Spool)
Control Valve (3 Spool)
Control Valve (4 Spool)
Control Valve (4 Spool)(Parallel Link)
Adapter (Drain Piping)
Ridecontrol
Main Piping (1)
Main Piping (2)
Main Piping (3)
Main Piping (3)(Parallel Link)
Main Piping (4)
Main Piping (4)(Parallel Link)
Main Piping (Quick Coupler)
Main Piping (2-Spool)
Main Piping (2-Spool)(Parallel Link)
Main Piping (3-Spool)
Main Piping (Quick Coupler)(Parallel Link)
Main Piping (Without Quick Coupler, Bracket For 2・3-Spool)
Plug Mount (Quick Coupler Less)(Arm)
Plug Mount (Quick Coupler Less)(Frame)
Plug Mount (Without Clamp For 2/3 Spool)
Pilot Piping (1)
Pilot Piping (2)
Pilot Piping (3)
Pilot Piping (4)(Parallel Link)
Pilot Piping (5)(Parallel Link)
Pilot Piping (6)(Without Quick Coupler)
Oil Tank
Steering Parts (Steering Cylinder)
Steering Piping (1)
Steering Piping (2)
Steering Piping (3)
Steering Piping (4)
Steering Piping (5)
Steering Piping (6)
Brake Pedal
Brake Link
Brake Piping (1)
Brake Piping (2)
Brake Piping (3)
Brake Piping (4)
Brake Piping (5)
Lubricate Piping (1)
Lubricate Piping (2)
Lubricate Piping (3)
Lubricate Piping (4)(Parallel Link)
Quick Coupler Parts
Loader Front Attachments
Lift Arm
Lift Arm (Parallel Link)
Dust Seal (Push Rod)
Dust Seal (Lift Arm)
Dust Seal (Lift Arm)(Parallel Link)
Lift Arm Cylinder
Lift Arm Parts (1)
Lift Arm Parts (1)(Parallel Link)
Lift Arm Parts (2)
Lift Arm Parts (2)(Parallel Link)
Lift Arm Parts (3)
Lift Arm Parts (3)(Parallel Link)
Bucket Cylinder
Bucket Cylinder (Parallel Link)
Bucket Cylinder Guard
Dust Seal (Bell Crank)
Dust Seal (Backet Link)(Parallel Link)
Push Rod
Dust Seal (Link)(Parallel Link)
Bell Crank
Link (Bell Crank)(Parallel Link)
Bucket Link (Right Side)(Parallel Link)
Bucket Link (Left Side)(Parallel Link)
Quick Coupler (Parallel Link)
Road Homologation
Road Homologation (Bucket Protector)
Road Homologation (Bucket)
Road Homologation (Stopper)
Road Homologation (Licence Plate)[Italy]
Road Homologation (Licence Plate)[German]
Road Homologation (Reflector)
Road Homologation (Reflector)(Full Rear Fender)
Name Plate (Ce)
Road Homologation (Speed Indication)[Italy]
Road Homologation (Speed Indication)[German]
Road Homologation (Lift Arm)[Italy]
Road Homologation (High Lift Arm)[Italy]
Road Homologation (Lift Arm)(Parallel Link)[Italy]
Tools
Tool
Tools (Grease Gun)
Name Plate
Name Plate (Name Of Company, Model Name Plate)
Name Plate (Name Of Company, Model Name Plate)(Parallel Link)
Name Plate (Front)
Name Plate (Rear)(1-1)
Name Plate (Rear)(1-2)
Name Plate (Rear)(1-1)(Parallel Link)
Name Plate (Rear)(1-2)(Parallel Link)
Name Plate (Cab)
Name Plate (Fuse Box)
Name Plate (Work Lever)
Name Plate (Battery)
Name Plate (Battery Disconnect)
Name Plate (Quick Coupler)
Name Plate (With Lifting Lug)
Name Plate (Company)(Cab Front)
Name Plate (Company)(Roof)
Name Plate (Jcmg)(Cab)
Name Plate (Jcmg)(Front)
Name Plate (Anti-Slip Tape)
Name Plate (Aerial Angle)
Parts Index
Parts Index
