Momed80
150
35,046
Hitachi Sumitomo Crane SCX700 SCX700-2 SCX700GLS Operators Technical Part Manual Diagram EN JP
Language: English, Japanese
Brand: Hitachi Sumitomo
Type of Manual: Operators Manual, Technical Manual, Part Manual, Electrical Diagram, Hydraulic Diagram,
Model: Hitachi Sumitomo SCX700 SCX700-2 SCX700GLS Crane
List of Files:
Crawler Crane SCX400 to SCX700 Technical Manual (Operational Principle) 2008
TO23K-E-00.pdf (271 Pages)
Section 1 General
Group 1 Specification
Group 2 Component Specifications
Group 3 Component Layout
Section 2 System
Group 1 Control System
Group 2 Hydraulic System
Group 3 Electrical System
Group 4 Monitor
Group 5 Control System
Group 6 Inspection And Maintenance
Section 3 Component Operation
Group 1 Pump Device
Group 2 Slewing Mechanism
Group 3 Hoisting Mechanism
Group 4 Boom Derricking Mechanism
Group 5 Control Valve
Group 6 Remote Control Valve
Group 7 Travel Mechanism
Group 8 Others (slewing Upperstructure)
Group 9 Others (base Carrier)
Group 10 Safety Mechanism
Crawler Crane SCX400 to SCX700 Technical Manual (Troubleshooting) 2009
Technical Manual TT23K-E-00B.pdf (94 Pages)
Troubleshooting / Controller (HCK-2):pump
Outline
Locations Of Controller And Valves
Layout Of Controller
Display Status Of Monitor Lamp And Error Description
Troubleshooting / Troubleshooting Controller (HCK-2)
Troubleshooting Procedure
Failure In Controller (HCK-2) System
Malfunction Of Pump Torque Calibration Control
Malfunction Of Pump Superfine Speed Control
Malfunction Of Boom Hoist Speed Control (SCX500-700: Standard, SCX400: Optional)
Malfunction Of Gradual Stop Control
Malfunction Of Hoist Third Speed Selection Control (SCX500-700 Only, Not For SCX400, No Opt Setting)
Malfunction Of Drum Speed Sensing (joy-stick Lever)
Malfunction Of Drum Speed Sensing (bi-directional Control Lever)
Malfunction Of Swing Speed Control(SCX500-700 Only, Not For SCX400, No Opt Setting)
Troubleshooting / MC2/A Controller
Troubleshooting Of MC2/A System
Inspection Of Battery Primary Line
Inspection Of Battery Secondary Line
Inspection Of Power Supply To Sensor 5-V Line
Troubleshooting Of MC2/A System Fault
(251) MC2/A Program Flow
Inspection Of Accelerator Grip Signal Line
Inspection Of Accelerator Pedal Signal Line
Inspection Of Accelerator Lever Signal Line
Inspection Of Throttle Control Signal Output
Troubleshooting Of MC2/A System Fault (about Travel Conjugated Valve)
Inspection Of Front Drum Operation Detection Signal Lline
Inspection Of Rear Drum Operation Detection Signal Line
Inspection Of Travel Detection Signal Line (1)
Inspection Of Travel Detection Signal Line (2)
Inspection Of Travel Com. Output
Cross-sectional View Of Connector
Troubleshooting / Backup Box
Outline Of Backup Box
Electrical System (outside Of Cab)
Backup Box
Technical Manual Troubleshooting TT23K-E-00A.pdf (171 Pages)
SCX400/500/550/700
Introduction
Section And Group Contents
Section 4 Operational Perf Ormance Test
Group 1 Introduction
Group 2 Standard
Group 3 Engine Test
Group 4 Machine Test
Group 5 Component Test
Section 5 Troubleshooting
Group 1 Diagnosing Procedure
Group 2 Troubleshooting (machine Operation System)
Group 3 Troubleshooting (monitor System)
Group 4 Electrical System Inspection
Crawler Crane SCX400 to CX650 Technical Manual Safety Device
WHT0111-101.pdf (102 Pages)
Construction & Features
Overview
Components
Controller System Outline Chart
Procedure (trouble Shooting For System)
Safety Device Layout For En
Crane Safety System Diagram
Function Principle (HCS-8 Autostop Controller For En Region) EN13000-2004 Regulation Acceptable Safety Device
Function Principle (HCS-8 Autostop Controller For Rossia Region) EN13000 Regulation Acceptable Safety Device Before 2003
Function Principle (HCS-8 Autostop Controller For En Region) EN13000 Regulation Acceptable Safety Device Before 2003
Function Principle (HCS-8 Autostop Controller For Rossia Region) EN13000-2004 Regulation Acceptable Safety Device
Function Of Safety Device (tower Crane)
Profile Of HSC-8 (auto Stop Controller)
Description Of Led (status Indication Lamps)
(188)Moment Limiter Mode Selector
Moment Limiter (HL-9A)
Overview Of Moment Limiter (HL-9, HL-9A)
Arithmetic Unit Panel (HL-9A)
Assembly Of Boom Angle Detector
Cx/scx Safety Devices
Load Detector (HL-9, HL-9A)
Outline Dimension Of Load Sensor (HL-9, HL-9A)
Load Sensor
Digital Display Functions
Inspection Checklist
Inspection Method (HL-9A)
Check List Of HL-9A Moment Limiter
How To Adjust
When & What To Adjust
Adjustment & Check Of Angle Sensor
Adjustment & Check Of Monitoring Angle Sensor
Adjustment Of Loading Factor Meter
Moment Limiter (HL-9)
Arithmetic Unit Panel (HL-9)
Computing Unit Panel Drawing (HL-9)
HL-9
Digital Display Function (HL-9)
Inspection Method
Precision Check
Check List Of HL-9 Moment Limiter
How To Adjust
Troubleshooting Guide
Troubleshooting
Error Display (same For HL-9 And HL-9A)
Error Code E05
Error Code E20
Error Code E21
Error Code E22
Error Code E23
Error Code E30
Error Code E31
Error Code E40, E42
Error Code E50
Error Code E51
Error Code E52
Error Code E54
Remodeling Procedure
Crawler Crane SCX400 SCX500 SCX700 Technical Manual (Operational Principle) 2009
TO23K-EN-00.pdf (310 Pages)
Section 2 System
Contents
Group 4 Monitor
Contents
Group 1 Pump Mechanism
Outline
Slewing Motor
Slewing Brake
Slewing Reduction Gear
Outline
Main Hoist Motor
Foot Brake
Hoisting Brake
Hoisting Drum
Counterbalance Valve
Outline
Boom Derricking Motor
Boom Derricking Brake (wet-type Spring Set Hydraulic Released Multi-disc Brake)
Boom Derricking Brake Valve
Reduction Gear
Outline
Hydraulic Circuit
Main Relief Valve
Holding Check Valve
Make-up Valve (main/aux. Hoist Slow, Third Drum)
Outline
Operation
Outline (option)
Operation
Group 7 Travel Device
Outline
Travel Reduction Gear
Travel Motor
Travel Brake Valve
Outline (CX500)
Travel Motor (CX500)
Travel Brake Valve
Travel Motor Swash Plate Tilt Angle Control
Travel Motor (CX350)
Pilot Shut-off Valve
Accumulator
8-Spool Solenoid Valve
Hydraulic Oil Tank
Outline
Slewing Ring
Track Adjuster
Center Joint
Side Frame Cylinder
Overhoist Prevention Mechanism
Hoist Drum Lock
Slewing Brake
Slewing Alarm Mechanism
Crawler Crane SCX700 Serial No 000701~ Parts Catalog 2007 EN JP
P23K-1-1 EN JP.pdf (812 Pages)
Frame
Main Frame [std ]
Main Frame [eu ]
Swing Bearing
Brake Cover
Frame Cover
Rope Guide
Counterweight
Counterweight (4TH)
Gantry (1)[STD ]
Gantry (1)[EU ]
Gantry (2)
Hanger (gantry)
Cab Bed
Engine Bed
Lubricate Piping (swing Bearing)
Lubricate Piping (gantry)
Engine Support
Oil Filter
Air Cleaner
Muffler
Radiator Parts
Fuel Piping
Pump Device
Winch
Hoist Device Group
Hoist Device
Boom Hoist Device
Swing Device
Hydraulic Parts
Oil Tank
Pump Piping
Control Valve Piping (1-1)
Control Valve Piping (1-2)
Control Valve Piping (2-1)[STD ]
Control Valve Piping (2-1)[EU ]
Control Valve Piping (2-2)[STD ]
Control Valve Piping (2-2)[EU ]
Control Valve Piping (2-3)[STD ]
Control Valve Piping (2-3)[EU ]
Control Valve Piping (2-4)[STD ]
Control Valve Piping (2-5)[STD ]
Control Valve Piping (2-6)[STD ]
Control Valve Piping (3)
Return Piping (1)
Return Piping (2)
Swing Piping
Hoist Piping
Boom Hoist Piping
Travel Piping (upperstructure)[std ]
Travel Piping (upperstructure)[eu ]
Controls
Floor Parts [std ]
Floor Parts [eu ]
Main Stand [std ]
Tilt Device [std ]
Tilt Device [eu ]
Left Stand [std ]
Left Stand [eu ]
Right Stand [std ]
Front Right Stand [eu ]
Rear Right Stand [eu ]
Rear Stand [std ]
Rear Stand [eu ]
Main Hoist,aux.hoist,boom Hoist Lever [std ]
Grip (main Hoist)[std ]
Grip (aux.hoist)[std ]
Swing Lever (1)[STD ]
Swing Lever (2)[STD ]
Control Lever (right)[eu ]
Grip (r)[eu ]
Control Lever (left)[eu ]
Grip (l)[eu ]
Accelerator,speed Control Lever
Travel Lever [std ]
Travel Lever [eu ]
Swing Lock (1)[STD ]
Swing Lock (1)[EU ]
Swing Lock (2)
Safety Lock Lever [std ]
Safety Lock Lever [eu ]
Accelerator Pedal
Accelerator Pedal (sensor)
Brake Pedal (main Hoist)
Brake Pedal (aux.hoist)
Brake Lock (main Hoist)[std ]
Brake Lock (aux.hoist)[std ]
Brake Band
Brake Unit
Drum Lock (main Hoist,aux.hoist)
Drum Lock (boom Hoist)
Pilot Piping (pump)
Pilot Piping (1)
Pilot Piping (2-1)
Pilot Piping (2-2)[STD ]
Pilot Piping (2-2)[EU ]
Pilot Piping (2-3)[STD ]
Pilot Piping (2-3)[EU ]
Pilot Piping (3-1)[STD ]
Pilot Piping (3-1)[EU ]
Pilot Piping (3-2)
Pilot Piping (3-3)
Pilot Piping (4-1)
Pilot Piping (4-2)
Pilot Piping (4-3)
Pilot Piping (4-4)[STD ]
Pilot Piping (4-4)[EU ]
Pilot Piping (5-1)
Pilot Piping (5-2)
Pilot Piping (6)[STD ]
Pilot Piping (6)[EU ]
Pilot Piping (7-1)[STD ]
Pilot Piping (7-2)[STD ]
Pilot Piping (7)[EU ]
Pilot Piping (8)[STD ]
Pilot Piping (8)[EU ]
Pilot Piping (9-1)[STD ]
Pilot Piping (9-1)[EU ]
Pilot Piping (9-2)[STD ]
Pilot Piping (9-2)[EU ]
Pilot Piping (l)[eu ]
Pilot Piping (solenoid)[eu ]
Gauge Panel
Control Panel [std ]
Switch Panel [std ]
Switch Panel [eu ]
Electric Parts (left Stand)[std ]
Electric Parts (left Stand)[eu ]
Electric Parts (right Stand)[std ]
Electric Parts (rear Right Stand)[eu ]
Electric Parts (engine Bed)
Electric Parts (cab Bed)[std ]
Electric Parts (cab Bed)[eu ]
Head Light
Wire Harness [std ]
Wire Harness [eu ]
Wire Harness (floor)[std ]
Wire Harness (floor)[eu ]
Voice Alarm Device [std ]
Swing Alarm Device [eu ]
Drum Revolution Sensor [std ]
Drum Cover [eu ]
Switch Box [eu ]
Brake Pedal Switch [eu ]
Cab Group (1)
Cab Group (2)[STD ]
Cab Group (2)[EU ]
Cab (1/2)
Cab (2/2)
Rear Cover
Seat [std ]
Seat [eu ]
Cover (1)
Mirror (1)
Mirror (2)
Cover (2)
Cover (3)
Cover (4)
Cover (5)
Anti-skid Tape
Window Washer
Mirror (boom Hoist Drum)
Under Cover
Under Cover Parts
Handrail [eu ]
Air Conditioner
Air-con.unit
Air-con.controller
Air-con.parts (1)
Air-con.parts (2)
Track
Track Frame [std ]
Track Frame [eu ]
Track Support [std ]
Track Support [eu ]
Joint Beam
Side Frame (l)[std ]
Side Frame (l)[eu ]
Side Frame (r)[std ]
Side Frame (r)[eu ]
Travel Device [std ]
Travel Device [eu ]
Front Idler [std ]
Front Idler [eu ]
Adjuster (l)[std ]
Adjuster (r)[std ]
Adjuster [eu ]
Upper Roller [std ]
Lower Roller [std ]
Roller [eu}
Track-link [std ]
Track-link 810mmG [eu ]
Track-link Guide [std ]
Track Guard [eu ]
Center Joint Group [std ]
Center Joint Group [eu ]
Center Joint
Travel Piping (l)[std ]
Travel Piping (r)[std ]
Travel Piping (l)[eu ]
Travel Piping (r)[eu ]
Side-frame Expansion And Contraction Piping [std ]
Side-frame Expansion And Contraction Piping [eu ]
Crane Front
Lower Boom,tower (lower)
Upper Boom
Boom Insert 3m
Boom Insert 6m
Boom Insert 9m
Boom Insert 9m(B)
Pendant Rope 3m
Pendant Rope 6m
Pendant Rope 9m
Boom Stopper
Bridle (boom,tower)
Lower Jib
Upper Jib
Jib Insert 4.5m
Jib Mast
Aux.jib
Hook Overhoist Prevention Device (1)(CRANE)
Hook Overhoist Prevention Device (2)(CRANE)
Hook Overhoist Prevention Device (jib,aux.jib)
Boom Overhoist Prevention Device [std ]
Boom Overhoist Prevention Device [eu ]
Boom Overlower Limiter [eu ]
Minimum Winding Sensor (1/2)[EU ]
Minimum Winding Sensor (2/2)[EU ]
Boom Angle Indicator
Moment Limiter (HL-9A)[STD ]
Moment Limiter (HL-9A)[EU ]
Moment Limiter Mode Lamp [eu ]
Wiring Parts
Aircraft Beacon (flashing Type)(crane)
Aircraft Beacon (lighting Type)(crane)
Hook 70t
Hook 70t(BOTH Hook)
Hook 40t
Hook 15t
Hook 6.5t(DOUBLE Swivel Type)
Hook 6.5t (light Weight 40kg)
Crane Ropes
Jib Ropes
Bucket Aux.jib (2 Sheaves)
Bucket Overhoist Privention Device
Switch Ass'y
Guide Sheave (bucket Aux.jib)
Tower Crane Front
Tower (upper)
Tower Insert 1.5m
Tower Insert 1.5m (with Guide Roller)
Tower Jib (upper)
Tower Jib (lower)
Tower Jib Insert 3m
Tower Jib Insert 6m
Tower Stop
Tower Jib Stop
Bridle (tower Jib)
Hanger (tower Jib)
Hanger Parts (tower Jib)
Swing Lever
Guide Roller
Coupler
Coupler Monitor Switch
Tower Guard (tower:lower)
Tower Guard (tower Insert)
Drum Spacer
Tower Piping
Hook Overhoist Prevention Device (tower Crane)
Tower Overhoist Prevention Device
Jib Overhoist Prevention Device
Swing Lever Overhoist Prevention Device
Jib Style Indicator Device
Lower Limitter
Anemometer
Aircraft Beacon (flashing Type)(tower Crane)
Aircraft Beacon (lighting Type)(tower Crane)
Electric Parts (1)
Electric Parts (2)
Aux.hoist Drum Mirror
Crawler Pad
Tower Crane Ropes
Third Drum
Hoist Device (third Drum)
Main Piping (third Drum)
Third Drum Lever
Brake Pedal (1)(THIRD Drum)
Brake Pedal (2)(THIRD Drum)
Brake Band (third Drum)
Brake Unit (third Drum)
Brake Cover (third Drum)
Brake Lock (third Drum)
Drum Lock (third Drum)
Pilot Piping (1)(THIRD Drum)
Pilot Piping (2)(THIRD Drum)
Pilot Piping (3)(THIRD Drum)
Pilot Piping (4)(THIRD Drum)
Electric Parts (third Drum)
Guide Roller (third Drum)
Rope Guide (third Drum)
Cover (third Drum)
Optional Parts
Speaker
Hydraulic-type Tagline
Drum Ass'y (hydraulic-type Tagline)
Tagline Piping (1)[STD ]
Tagline Piping (1)[EU ]
Tagline Piping (2)
Tagline Piping (3)
Rope Guide (clamshell)
Clamshell Ropes
Reversal Control Parts (main Hoist,aux.hoist,brake)
Boom Hoist Pedal
Lamination Plate (main Hoist,aux.hoist)
Fan
Extinguisher
Upper Window Guard
Buffer
Catwalk (upper Boom)
Catwalk (lower Boom)
Catwalk (3m)
Catwalk (6m)
Catwalk (9m)
Catwalk (1.5m)
Catwalk (1.5m Tower)
Catwalk (tower Upper)
Stanchion(s)
Stanchion (l)
Level
Load Table For Lower Boom
Drum Rope Guide (main Hoist)
Drum Rope Guide (aux.host)
Moment Limiter Light [std ]
Moment Limitter Light [eu ]
Side Walk
Tools And Spare Parts
Tools
Spare Parts [std ]
Spare Parts [eu ]
Name-plate
Name-plate (japanese)
Name-plate (tower)(japanese)
Parts Index
Crawler Crane SCX700 Technical Manual (Operational Principle) 2007
TO24P-E-00.pdf (236 Pages)
Section 1 General
Section 2 System
Service Manual Revision Request Form
Crawler Crane SCX700 Technical Manual (Troubleshooting) Diagram
Electrical Hydraulic Diagram TT24P-E-00.pdf (3 Pages)
Hydraulic Circuit Diagram
Connectors
Electrical Circuit Diagram
Technical Manual Troubleshooting TT24P-E-00.pdf (254 Pages)
SCX700
Introduction
Section And Groupcontents
Section 4OPERATIONALPERFORMANCE Test
Group 2 Standard
Group 3 Engine Test
Section 5TROUBLESHOOTING
Group 2 Component Layout
Group 3 Troubleshooting A
Group 4 Troubleshooting B
Group 5 Troubleshooting C
Group 6 Electrical System Inspection
The Attached Diagram List
Crawler Crane SCX700 Workshop Manual 2007
W23K-E-00.pdf (425 Pages)
Section 1 General Information
Group 1 Precautions For Disassembling And Assembling
Group 2 Tightening
Tightening Torque Specifications
Standard Torque Specifications
Piping Joint
Section 2 Superstructure
Group 1 Cab
Group 2 Counterweight
Group 3 Main Frame
Group 4 Pump Mechanism
Group 6 Swing Device
Group 7 Hoist Device
Group 8 Boom Hoist Device
Group 9 Pilot Valve
Group 10 Pilot Shut-off Valve
Group 11 Solenoid Valve
Group 12 Shuttle Valve
Group 13 Booster Valve
Section 3 Undercarriage
Group 1 Swing Bearing
Group 2 Travel Device
Group 3 Center Joint
Group 4 Track Adjuster
Group 5 Front Idler
Group 6 Upper And Lower Roller
Group 7 Track
Group 8 Side Frame Extend/retract Cylinder
Crawler Crane SCX700-2 Serial No 7149- Parts Catalog 2007 EN JA
P24Y-1-1 EN JP.PDF (537 Pages)
Lower
Lower Frame
Slewing Bearing
Extension Beam
Lubricate Piping (slewing Bearing)
Center Joint
Retract Equipment
Crawler Frame
Take-up Tumbler
Upper Roller
Lower Roller
Crawler Shoe
Travel Device
Track-link
Step (crawler)
Retract Piping
Travel Piping (lower Frame)
Slewing Frame
Slewing Frame
Gantry (1)
Gantry (2)
Gantry (3)
Hanger
Gantry Cyl.piping
Control Valve (gantry)
Control Valve (slewing)
Valve (brake)
Slewing Piping
Brake Selecting Piping
Brake Cooling Piping
Drum Lock (front)
Drum Lock (rear)
Drum Lock (derricking)
Drum Lock Lubricate Piping
Guide Roller
Drum Cover
Frame Cover
Rope Guide
Electric Parts ( Slewing Frame)
Terminal Box
Counterweight
Counterweight Support
Weight
Winch
Drum Support (1)
Drum Support (2)
Slewing Mechanism
Right Unit
Bed (right)
Fuel Piping
Control Valve (1)
Control Valve (2)
Pump Piping
Hose Silencer
Drum Piping
Boom Derricking Piping
Lower Piping
Return Piping (right)
Drain Piping
Pilot Parts (R-1)
Pilot Parts (R-2)
Pilot Parts (R-3)
Pilot Piping (1-1)
Pilot Piping (1-2)
Polot Piping (2-1)
Polot Piping (2-2)
Pilot Piping (R-1)
Pilot Piping (R-2)
Pilot Piping (R-3)
Pilot Piping (l)
Pilot Piping (b)
Pilot Piping (w)
Right House Support
Right House (1)
Right House (2)
Insulator (1)
Insulator (2)
Electric Parts (right)
Window Washer
Under Cover (right)
Left Unit
Radiator Parts
Pump Unit
Suction Piping
Return Piping (left)
Pilot Parts (l)
Bed (left)
Tank Unit (1)
Tank Unit (2)
Engine (1)
Engine (2)
Left House Support (1)
Left House Support (2)
Mirror
Left HOUSE(1)
Left House (2)
Left House (3)
Air-con.parts (left)
Electric Parts (LEFT)(1)
Electric Parts (LEFT)(2)
Under Cover (left)
Insulator
Fan Guard
Piping Filter
Cab (1)
Cab (2)
Cab (3)
Brake Pedal (front,rear)
Brake Control
Back Mirror
Floor Plate
Lever (with Switch)
Console Box
Rear Stand
Rear Cover
Operator's Seat
Safety Lever
Air Conditioner
Moment Limiter
Swing Lock
Head Light
Cushion (cab Lower)
Electric Parts (CAB)(1)
Electric Parts (CAB)(2)
Controller
Switch Panel
Crane Attachment
Upper Boom
Electric Parts (upper)
Hook Overhoist Prevention Device (crane)
Lower Boom
Bridle
Electric Parts (lower)
Middle Boom 3m
Middle Boom 6m
Middle Boom 6m (b)
Middle Boom 9m
Middle Boom 9m (b)
Guide Roller (crane)
Boom Parts
Back Stopper
Short Jib
Hook Overhoist Prevention Device (short Jib,crane Jib,tower)
Bucket Short Jib
Guide Sheave Parts
Bucket Overhoist Prevention Device
Moment Limiter Parts
70t Hook (a)
70t Hook (b)
40t Hook (a)
40t Hook (b)
20t Hook
7t Hook
7t Hook (light Weight 40kg)
7t Hook (light Weight 125kg)
Pendant Rope 3m
Pendant Rope 6m
Pendant Rope 9m
Crane Jib (upper)
Crane Jib (lower)
Jib Mast
Middle Crane Jib 4.5m
Crane Ropes
Crane Jib Ropes
Tower Attatiment
Tower (upper)
Guide Roller (tower)
Boom Stopper (crane,tower)
Tower Jib (upper)
Tower Jib (lower)
Jib Stop
Swing Lever
Tower Jib Overhoist,secondary Overhoist Prevention Device
Tower Jib Position Indicator Device
Middle Boom 3m (b)
Tower Jib Hanger
Tower Jib Bridle
Tower Jib Coupler
Rope Parts
Tower Jib Reel Parts
Wirering Parts
Tower Rail
Tower Anemometer
Tower Overhoist Device
Bridle Guide Roller
Tower Piping
Name-plate (tower)
Middle Tower Jib 3m
Middle Tower Jib 6m
Tower Crane Ropes
Third Drum
Third Drum
Drum Lock Lubricate Piping (third Drum)
Brake Pedal (third Drum)
Drum Cover (third Drum)
Upper Boom Parts (third Drum)
Pilot Piping (third DRUM)(1)
Pilot Piping (third DRUM)(2)
Pilot Piping (third DRUM)(3)
Brake Piping (third Drum)
Third Lever Parts
Third Drum Piping (relief)
Tagline Piping
Drum
Jack-up Unit
Jack-up Piping (main PIPING)(1)
Jack-up Piping (main PIPING)(2)
Sling Rope (jack-up)
Jack-up Unit
Side Crowd Mechanisum
Level Gauge (lower)
Jack-up Piping (cyl.piping)
Electric Parts (jack-up)
Others
Skywalk (lower)
Skywalk (upper)
Skywalk 3m
Skywalk 6m
Skywalk 9m
Catwalk (r)
Catwalk (l)
Accel.pedal
Fuel Filling Device
Stanchion (l)
Stanchion (s)
Sling Rope (side Frame,counterweight)
Buffer (upper)
Buffer (lower)
Drum Rope Guide
Lower Boom Load
Ml Mood Select Switch
Control Box
Upper Window Guard
Shoe Take-up Unit (right)
Take-up Cyl.
Shoe Take-up Unit (left)
Shoe Take-up Piping
Name-plate
Fuel Additional Filter
Extinguisher
Drum Light (a Frame)
Drum Mirror
Aircraft Beacon (tower)(lighting Type)
Aircraft Beacon (tower)(flashing Type)
Emergency Hammer
Electric Fan
Switch Panel Cover (left)
Counterweight Sensor
Tools
Spare Parts
Name-plate
Name-plate (JAPANESE)(1)
Name-plate (JAPANESE)(2)
Name-plate (JAPANESE)(3)
Anti-skid Tape
Parts Index
Crawler Crane SCX700E CX070-7143 and Up Operators Manual 2018
RHBE0-EN-CR-00-003R02.pdf (426 Pages)
RHBE0-EN-CR-00-001R01
Operator's Manual Contents
1 Introduction
2 Saffety
3 Components Name And Function
4 Operation
5 Assembling/disassembling
6 Transportation
7 Inspection And Maintenance
Crawler Crane SCX700GLS Serial No CX070-07001 Parts Catalog
WCABCX070-7001.pdf (295 Pages)
Hydraulic Crawler Crane SCX700 CX070-6796 and Up Operators Manual 2014
EM23K-1-2.pdf (432 Pages)
Hydraulic Crawler Crane SCX700-2 SC070-7328 and Up Operators Manual 2014
24Y-EN-CO-00-001R00.pdf (221 Pages)
1 Introduction
1 Introduction
2 Manual Organization
3 Machine Serial Numbers
4 Machine Orientation
5 Recognize Safety Information
6 Safety Signs
2 Safety
1 Basic Precautions
2 Preparations For Safety Operation
3 Precautions For Operation
4 Precautions For Preparation Of Operation And Transportation
5 Precautions For Maintenance
7 Maintenance
1 Inspection And Maintenance
2 Periodic Replacement Parts
3 Inspection
4 Upper Structure Inspection
5 Inspection Of Swing Upper Structure Daily Or Every 8 Hours
6 Inspection Of Swing Upper Structure Monthly Or Every 150 Hours
7 Inspection Of Upper Structure Every 3 Months Or 500 Hours
8 Inspection Of Upper Structure Every 6 Months Or 1000 Hours
9 Lower Structure Inspection
10 Inspections Of Lower Structure Daily Or Every 8 Hours
11 Inspections Of Lower Structure Monthly Or Every 150 Hours
12 Inspections Of Lower Structure Every 3 Months Or 500 Hours
13 Every 6 Months Or 1000 Hour Inspections Of Lower Structure
14 Attachment Inspection (crane)
15 Attachment Daily Or Every 8 Hour Inspections (crane)
16 Attachment Monthly Or Every 150 Hour Inspections (crane)
17 Attachment Yearly Or Every 2000 Hour Inspections (crane)
18 Attachment Inspection (tower)
19 Attachment Daily Or Every 8 Hour Inspections (tower)
20 Attachment Monthly Or Every 150 Hour Inspections
21 Attachment 6-monthly Or Every 1000 Hour Inspections (tower)
22 Attachment Yearly Or Every 2000 Hour Inspections (tower)
23 Maintenance
24 Lubricants, Greases, And Coolant
25 Kinds Of Lubricants
26 Lubrication (coolant) Points On Swing Upper Structure
27 Lubrication Points On Lower Structure
28 Front Attachment Lubrication Points
29 Grease
30 Engine Oil
31 Fuel
32 Coolant
33 Hydraulic Oil
34 Gear Oil
35 Cleaning And Replace Filter Elements And Strainer
36 Check Electrical System
37 Maintenance For Machines Operating Under Severe Environmental Conditions
38 Storage
39 Tightening Torque
40 Adjustment
41 Adjust Front/rear/third Drums
42 Adjust Boom Hoist Drum Lock
43 Adjust Control Lever Detents
44 Adjust Shoe Sag
