Hitachi Sumitomo Crane SCX700-2 Operator Technical Part Manual
- Download this document, you need 2725 Gallons
Brand: Hitachi Sumitomo
Type of Machine: Crane
Type of Manual: Operator Manual, Technical Manual, Part Manual, Electric Diagram, Hydraulic Diagram
Model: Hitachi Sumitomo SCX700-2 Crane
Crawler Crane SCX700-2 Electrical Hydraulic Diagram
SCX700-2 Battery Harness 1-2.pdf (1 Page)
SCX700-2 Battery Harness Harness 2-2.pdf (1 Page)
SCX700-2 Boom Dericking Rotation Detection Sensor Third Drum Lock Harness.pdf (1 Page)
SCX700-2 Boom Harness 1-2.pdf (1 Page)
SCX700-2 Boom Harness 2-2.pdf (1 Page)
SCX700-2 Cab Harness 1-2.pdf (1 Page)
SCX700-2 Cab Harness 2-2.pdf (1 Page)
SCX700-2 Can Harness.pdf (1 Page)
SCX700-2 Controller Earth.pdf (1 Page)
SCX700-2 Electrical Diagram (MC2-A).pdf (1 Page)
SCX700-2 Electrical Diagram.pdf (1 Page)
SCX700-2 Front Rear Drum Lock Slipping Harness.pdf (1 Page)
SCX700-2 Gantry Retract Harness.pdf (1 Page)
SCX700-2 Harness Boom Second Overhoist.pdf (1 Page)
SCX700-2 Hydraulic Diagram.pdf (1 Page)
SCX700-2 Left Stand Panel Harness 1-2.pdf (1 Page)
SCX700-2 Left Stand Panel Harness 2-2.pdf (1 Page)
SCX700-2 Right Stand Harness 2-2.pdf (1 Page)
SCX700-2 Right Stand Panel Harness 1-2.pdf (1 Page)
SCX700-2 Right Unit Harness.pdf (1 Page)
SCX700-2 Side Overhead Panel Harness.pdf (1 Page)
SCX700-2 Terminal Box (Crane).pdf (1 Page)
SCX700-2 Terminal Box (Tower).pdf (1 Page)
SCX700-2 Terminal Box (Upperstructrure).pdf (1 Page)
SCX700-2 Terminal Box (Upperstructure).pdf (1 Page)
SCX700-2 Third Drum Harness 1-2.pdf (1 Page)
SCX700-2 Third Drum Harness 2-2.pdf (1 Page)
SCX700-2 Travel Pilot Pressure Sensor Harness.pdf (1 Page)
Crawler Crane SCX700-2 Parts Catalog
P24X-E1-1.pdf (174 Pages)
Pump
Motor
Valve ; Control
Valve ; Pilot
Valve ; Check
Cylinder
Etc.
Parts Index
P24Y-1-1.PDF (537 Pages)
Lower
Lower Frame
Slewing Bearing
Extension Beam
Lubricate Piping (slewing Bearing)
Center Joint
Retract Equipment
Crawler Frame
Take-up Tumbler
Upper Roller
Lower Roller
Crawler Shoe
Travel Device
Track-link
Step (crawler)
Retract Piping
Travel Piping (lower Frame)
Slewing Frame
Slewing Frame
Gantry (1)
Gantry (2)
Gantry (3)
Hanger
Lubricate Piping (gantry)
Gantry Cyl.piping
Control Valve (gantry)
Control Valve (slewing)
Valve (brake)
Slewing Piping
Brake Selecting Piping
Brake Cooling Piping
Drum Lock (front)
Drum Lock (rear)
Drum Lock (derricking)
Drum Lock Lubricate Piping
Guide Roller
Drum Cover
Frame Cover
Rope Guide
Electric Parts ( Slewing Frame)
Terminal Box
Counterweight
Counterweight Support
Weight
Winch
Drum Support (1)
Drum Support (2)
Slewing Mechanism
Drum Revolution Sensor
Right Unit
Bed (right)
Fuel Tank
Fuel Piping
Control Valve (1)
Control Valve (2)
Pump Piping
Hose Silencer
Drum Piping
Boom Derricking Piping
Lower Piping
Return Piping (right)
Drain Piping
Pilot Parts (R-1)
Pilot Parts (R-2)
Pilot Parts (R-3)
Pilot Piping (1-1)
Pilot Piping (1-2)
Polot Piping (2-1)
Polot Piping (2-2)
Pilot Piping (R-1)
Pilot Piping (R-2)
Pilot Piping (R-3)
Pilot Piping (l)
Pilot Piping (b)
Pilot Piping (w)
Right House Support
Right House (1)
Right House (2)
Insulator (1)
Insulator (2)
Electric Parts (right)
Window Washer
Under Cover (right)
Left Unit
Radiator Parts
Radiator
Pump Unit
Suction Piping
Return Piping (left)
Pilot Parts (l)
Bed (left)
Tank Unit (1)
Tank Unit (2)
Engine (1)
Engine (2)
Left House Support (1)
Left House Support (2)
Mirror
Left HOUSE(1)
Left House (2)
Left House (3)
Air-con.parts (left)
Electric Parts (LEFT)(1)
Electric Parts (LEFT)(2)
Under Cover (left)
Insulator
Fan Guard
Piping Filter
Cab (1)
Cab (2)
Cab (3)
Brake Pedal (front,rear)
Brake Control
Back Mirror
Floor Plate
Control Lever (left)
Lever (with Switch)
Console Box
Control Lever (right)
Rear Stand
Rear Cover
Operator's Seat
Safety Lever
Air Conditioner
Moment Limiter
Swing Lock
Head Light
Cushion (cab Lower)
Electric Parts (CAB)(1)
Electric Parts (CAB)(2)
Controller
Switch Panel
Crane Attachment
Upper Boom
Electric Parts (upper)
Hook Overhoist Prevention Device (crane)
Lower Boom
Bridle
Boom Overhoist Prevention Device
Boom Angle Indicator
Electric Parts (lower)
Middle Boom 3m
Middle Boom 6m
Middle Boom 6m (b)
Middle Boom 9m
Middle Boom 9m (b)
Guide Roller (crane)
Boom Parts
Back Stopper
Short Jib
Hook Overhoist Prevention Device (short Jib,crane Jib,tower)
Bucket Short Jib
Guide Sheave Parts
Bucket Overhoist Prevention Device
Moment Limiter Parts
70t Hook (a)
70t Hook (b)
40t Hook (a)
40t Hook (b)
20t Hook
7t Hook
7t Hook (light Weight 40kg)
7t Hook (light Weight 125kg)
Pendant Rope 3m
Pendant Rope 6m
Pendant Rope 9m
Crane Jib (upper)
Crane Jib (lower)
Jib Mast
Middle Crane Jib 4.5m
Crane Ropes
Crane Jib Ropes
Tower Attatiment
Tower (upper)
Guide Roller (tower)
Boom Stopper (crane,tower)
Tower Jib (upper)
Tower Jib (lower)
Jib Stop
Swing Lever
Tower Jib Overhoist,secondary Overhoist Prevention Device
Tower Jib Position Indicator Device
Swing Lever Overhoist Prevention Device
Middle Boom 3m (b)
Tower Jib Hanger
Tower Jib Bridle
Tower Jib Coupler
Rope Parts
Tower Jib Reel Parts
Wirering Parts
Coupler Monitor Switch
Tower Rail
Tower Anemometer
Tower Overhoist Device
Bridle Guide Roller
Tower Piping
Name-plate (tower)
Middle Tower Jib 3m
Middle Tower Jib 6m
Tower Crane Ropes
Third Drum
Third Drum
Drum Lock (third Drum)
Drum Lock Lubricate Piping (third Drum)
Brake Pedal (third Drum)
Drum Cover (third Drum)
Rope Guide (third Drum)
Upper Boom Parts (third Drum)
Main Piping (third Drum)
Pilot Piping (third DRUM)(1)
Pilot Piping (third DRUM)(2)
Pilot Piping (third DRUM)(3)
Brake Piping (third Drum)
Third Lever Parts
Third Drum Piping (relief)
Hydraulic-type Tagline
Tagline Piping
Drum
Jack-up Unit
Jack-up Piping (main PIPING)(1)
Jack-up Piping (main PIPING)(2)
Sling Rope (jack-up)
Jack-up Unit
Side Crowd Mechanisum
Level Gauge (lower)
Jack-up Piping (cyl.piping)
Electric Parts (jack-up)
Others
Skywalk (lower)
Skywalk (upper)
Skywalk 3m
Skywalk 6m
Skywalk 9m
Catwalk (r)
Catwalk (l)
Accel.pedal
Fuel Filling Device
Stanchion (l)
Stanchion (s)
Sling Rope (side Frame,counterweight)
Buffer (upper)
Buffer (lower)
Drum Rope Guide
Lower Boom Load
Ml Mood Select Switch
Control Box
Upper Window Guard
Shoe Take-up Unit (right)
Take-up Cyl.
Shoe Take-up Unit (left)
Shoe Take-up Piping
Name-plate
Fuel Additional Filter
Extinguisher
Drum Light (a Frame)
Drum Mirror
Aircraft Beacon (tower)(lighting Type)
Aircraft Beacon (tower)(flashing Type)
Emergency Hammer
Electric Fan
Switch Panel Cover (left)
Counterweight Sensor
Tools And Spare Parts
Tools
Spare Parts
Name-plate
Name-plate (JAPANESE)(1)
Name-plate (JAPANESE)(2)
Name-plate (JAPANESE)(3)
Anti-skid Tape
Parts Index
Crawler Crane SCX700-2 Technical Manual (Troubleshooting) Diagram
Electrical Hydraulic Diagram TT24X-E-00.pdf (29 Pages)
Technical Manual (Troubleshooting) TT24X-E-00.pdf (512 Pages)
Section 4 Operational Performance Test
Introduction
Standards
Engine Test
Crane Test
Component Test
Adjustment
Section 5 Troubleshooting
Diagnosing Procedure
Component Layout
Troubleshooting A
Troubleshooting B
Troubleshooting C
Troubleshooting D
Electrical System Inspection
Service Manual Revision Request Form
Attached Diagram List
Hydraulic Crawler Crane SCX700-2 SC070 – 7328 and Up Operators Manual 2014
24Y-EN-CO-00-001R00.pdf (221 Pages)
1 Introduction
1 Introduction
2 Manual Organization
3 Machine Serial Numbers
4 Machine Orientation
5 Recognize Safety Information
6 Safety Signs
2 Safety
1 Basic Precautions
2 Preparations For Safety Operation
3 Precautions For Operation
4 Precautions For Preparation Of Operation And Transportation
5 Precautions For Maintenance
7 Maintenance
1 Inspection And Maintenance
2 Periodic Replacement Parts
3 Inspection
4 Upper Structure Inspection
5 Inspection Of Swing Upper Structure Daily Or Every 8 Hours
6 Inspection Of Swing Upper Structure Monthly Or Every 150 Hours
7 Inspection Of Upper Structure Every 3 Months Or 500 Hours
8 Inspection Of Upper Structure Every 6 Months Or 1000 Hours
9 Lower Structure Inspection
10 Inspections Of Lower Structure Daily Or Every 8 Hours
11 Inspections Of Lower Structure Monthly Or Every 150 Hours
12 Inspections Of Lower Structure Every 3 Months Or 500 Hours
13 Every 6 Months Or 1000 Hour Inspections Of Lower Structure
14 Attachment Inspection (crane)
15 Attachment Daily Or Every 8 Hour Inspections (crane)
16 Attachment Monthly Or Every 150 Hour Inspections (crane)
17 Attachment Yearly Or Every 2000 Hour Inspections (crane)
18 Attachment Inspection (tower)
19 Attachment Daily Or Every 8 Hour Inspections (tower)
20 Attachment Monthly Or Every 150 Hour Inspections
21 Attachment 6-monthly Or Every 1000 Hour Inspections (tower)
22 Attachment Yearly Or Every 2000 Hour Inspections (tower)
23 Maintenance
24 Lubricants, Greases, And Coolant
25 Kinds Of Lubricants
26 Lubrication (coolant) Points On Swing Upper Structure
27 Lubrication Points On Lower Structure
28 Front Attachment Lubrication Points
29 Grease
30 Engine Oil
31 Fuel
32 Coolant
33 Hydraulic Oil
34 Gear Oil
35 Cleaning And Replace Filter Elements And Strainer
36 Check Electrical System
37 Maintenance For Machines Operating Under Severe Environmental Conditions
38 Storage
39 Tightening Torque
40 Adjustment
41 Adjust Front/rear/third Drums
42 Adjust Boom Hoist Drum Lock
43 Adjust Control Lever Detents
44 Adjust Shoe Sag
Pump
Motor
Valve ; Control
Valve ; Pilot
Valve ; Check
Cylinder
Etc.
Parts Index
Lower
Lower Frame
Slewing Bearing
Extension Beam
Center Joint
Retract Equipment
Crawler Frame
Take-up Tumbler
Upper Roller
Lower Roller
Crawler Shoe
Travel Device
Track-link
Step (crawler)
Retract Piping
Slewing Frame
Slewing Frame
Gantry (1)
Gantry (2)
Gantry (3)
Hanger
Gantry Cyl.piping
Valve (brake)
Slewing Piping
Drum Lock (front)
Drum Lock (rear)
Guide Roller
Drum Cover
Frame Cover
Rope Guide
Terminal Box
Counterweight
Weight
Winch
Drum Support (1)
Drum Support (2)
Slewing Mechanism
Right Unit
Bed (right)
Fuel Tank
Fuel Piping
Control Valve (1)
Control Valve (2)
Pump Piping
Hose Silencer
Drum Piping
Lower Piping
Drain Piping
Pilot Parts (R-1)
Pilot Parts (R-2)
Pilot Parts (R-3)
Pilot Piping (1-1)
Pilot Piping (1-2)
Polot Piping (2-1)
Polot Piping (2-2)
Pilot Piping (R-1)
Pilot Piping (R-2)
Pilot Piping (R-3)
Pilot Piping (l)
Pilot Piping (b)
Pilot Piping (w)
Right House Support
Right House (1)
Right House (2)
Insulator (1)
Insulator (2)
Window Washer
Under Cover (right)
Left Unit
Radiator Parts
Radiator
Pump Unit
Suction Piping
Pilot Parts (l)
Bed (left)
Tank Unit (1)
Tank Unit (2)
Engine (1)
Engine (2)
Mirror
Left HOUSE(1)
Left House (2)
Left House (3)
Under Cover (left)
Insulator
Fan Guard
Piping Filter
Cab (1)
Cab (2)
Cab (3)
Brake Control
Back Mirror
Floor Plate
Lever (with Switch)
Console Box
Rear Stand
Rear Cover
Operator's Seat
Safety Lever
Air Conditioner
Moment Limiter
Swing Lock
Head Light
Cushion (cab Lower)
Controller
Switch Panel
Crane Attachment
Upper Boom
Lower Boom
Bridle
Middle Boom 3m
Middle Boom 6m
Middle Boom 6m (b)
Middle Boom 9m
Middle Boom 9m (b)
Boom Parts
Back Stopper
Short Jib
Bucket Short Jib
Guide Sheave Parts
70t Hook (a)
70t Hook (b)
40t Hook (a)
40t Hook (b)
20t Hook
7t Hook
Pendant Rope 3m
Pendant Rope 6m
Pendant Rope 9m
Crane Jib (upper)
Crane Jib (lower)
Jib Mast
Crane Ropes
Crane Jib Ropes
Tower Attatiment
Tower (upper)
Tower Jib (upper)
Tower Jib (lower)
Jib Stop
Swing Lever
Middle Boom 3m (b)
Tower Jib Hanger
Tower Jib Bridle
Tower Jib Coupler
Rope Parts
Wirering Parts
Tower Rail
Tower Anemometer
Bridle Guide Roller
Tower Piping
Name-plate (tower)
Middle Tower Jib 3m
Middle Tower Jib 6m
Tower Crane Ropes
Third Drum
Third Drum
Third Lever Parts
Tagline Piping
Drum
Jack-up Unit
Jack-up Unit
Level Gauge (lower)
Others
Skywalk (lower)
Skywalk (upper)
Skywalk 3m
Skywalk 6m
Skywalk 9m
Catwalk (r)
Catwalk (l)
Accel.pedal
Fuel Filling Device
Stanchion (l)
Stanchion (s)
Buffer (upper)
Buffer (lower)
Drum Rope Guide
Lower Boom Load
Control Box
Upper Window Guard
Take-up Cyl.
Shoe Take-up Piping
Name-plate
Extinguisher
Drum Mirror
Emergency Hammer
Electric Fan
Tools
Spare Parts
Name-plate
Anti-skid Tape
Parts Index
Introduction
Standards
Engine Test
Crane Test
Component Test
Adjustment
Component Layout
Troubleshooting A
Troubleshooting B
Troubleshooting C
Troubleshooting D
1 Introduction
1 Introduction
6 Safety Signs
2 Safety
1 Basic Precautions
7 Maintenance
3 Inspection
23 Maintenance
29 Grease
30 Engine Oil
31 Fuel
32 Coolant
33 Hydraulic Oil
34 Gear Oil
38 Storage
40 Adjustment
44 Adjust Shoe Sag
- Hitachi EX120-2 Excavator Parts Catalog
- Hitachi EX200-2 Service Manual
- Hitachi Excavator ZX240-3 to ZX250LCK-3 Parts Catalog P1V1-1-1 EN JP
- Hitachi Zaxis 200,225,230 Class Hydraulic Circuit Diagram
- Hitachi EX 750 -5 EX 800 H-5 Full Service Manual
- Hitachi Zaxis 200,225,240,270-3 Service Manual
- Hitachi WIN DR Technical Manual (a PC version Dr.ZX)
- Hitachi ZAXIS ZX330-3 TO ZX350-3 Parts Manual
- Isuzu Industrial Diesel Engine 4JJ1X/4-6HK1X/6WG1X Tier3
- Hitachi Zaxis 200-3 Hydraulic Excavator Technical Manual
- Hitachi Zaxis 70,70LC Hydraulic Circuit Diagram
- Hitachi EX200-3 Excavator Parts Catalog
- Hitachi Hydraulic Excavator ZX50 Technical Manual
- Hitachi ZW 220 - ZW 250 Wheel Loader - Workshop Manual
- Hitachi EX120 Service Manual
