Momed80
150
35,046
Hitachi Sumitomo Crane SCX300 Parts Catalog EN JP
Language: English, Japanese
Brand: Hitachi Sumitomo
Type of Machine: Crawler Crane
Model: Hitachi Sumitomo SCX300 Crane
List of Files:
P22A-1-1 EN JP.pdf (319 Pages)
Frame
Frame
Brake Cover
Counterweight
Gantry
Hanger (Gantry)
Bed
Rope Guide (Drum)
Reserve Tank
Air Cleaner
Muffler
Bypass Filter (Engine Oil)
Fuel Device
Pump Device
Winch
Drum Shaft
Clutch
Transmission (Hoist)
Boom Hoist Device
Swing Device
Hydraulic Parts
Oil Tank
Pump Pipings (1)
Pump Pipings (2)
Pump Pipings (3)
Return Pipings (1)
Return Pipings (2)
Swing Pipings
Hoist Pipings
Boom Hoist Pipings
Travel Piping (Upperstructure)
Controls
Engine Control Lever
Hoist, Travel, Boom Hoist & Clutch Lever
Swing Lever
Main Brake
Aux. Brake
Brake Lever:Main Hoist (1)
Brake Lever:Main Hoist (2)
Brake Lever:Aux. Hoist (1)
Brake Lever:Aux. Hoist (2)
Brake Lock
Drum Lock
Swing Lock
Pilot Pipings (1)
Pilot Pipings (2)
Pilot Pipings (3)
Pilot Pipings (4)
Pilot Pipings (5-1)
Pilot Pipings (5-2)
Pilot Pipings (5-3)
Control Box (R)
Control Box (L)
Guard Panel
Radio
Electric Parts
Lubricate Pipings (Swing Bearing)
Lubricate Pipings (Gantry)
Cab Group
Cab (1/2)
Cab (2/2)
Cover (1)
Cover (2)
Cover (3)
Engine Cover
Frame Cover
Under Cover
Car Heater
Heater Unit
Track
Track Frame
Travel Device
Front Idler
Adjuster
Upper Roller
Lower Roller
Track-Link 660
Track-Link 760
Center Joint
Travel Pipings
Crane Front
Lower Boom
Upper Boom
Boom Insert 3m
Boom Insert 6m
Boom Stop
Bridle
Aux. Jib
Hook Overhoist Prevention Device (Crane, Aux. Jib)
Boom Overhoist Prevention Device (Sensor)
Boom Angle Indicater
Moment Limiter
Hook 30t (D-Type) <22m>
Hook 15t (D-Type) <22m>
Hook 5t (D-Type)
Crane Ropes
Aux. Jib Ropes
Cramshell Parts
Clamshell Bucket 1.2
Clamshell Bucket 1.0
Clamshell Bucket 0.8
Hydraulic Ic-Type Tagline
Drum Ass'y (Hydraulic-Type Tagline)
Tagline Pipings
Rope Guide (Clamshell)
Optional Parts
Under Cover (Extra)
Swing Alarm Device
Car Cooler
Cooler Unit
Speaker
Drum Cooler
Tools And Spare Parts
Tools
Spare Parts
Name-Plate
Name-Plate (Japanese)
Name-Plate (English)
Parts Index
P22B-E1-1 EN.pdf (140 Pages)
Pump
Pump, Piston
Box, Gear
Gear, Drive
Pump, Double
Control Section
Cover, Regulator
Valve, Throttle
Cover, Q-Max
Control Part
Rotary Group (D)
Rotary Group (I)
Spring, Control
Pump, Piston
Cover Part
Rotary Group
Shaft Part
Pump, Gear
Valve, Relief
Pump, Gear
Motor, Oil
Motor, Plunger
Valve, Brake
T. Mission
Boom Hoist Device
Motor, Oil
Valve, Brake
Motor, Plunger (Swing)
Motor, Oil (Travel)
Valve, Brake
Valve, Relief
T. Mission (Travel)
Motor, Oil (Tagline)
Valve, Control
Valve, Control
Valve, Pilot
Valve, Pilot
Valve
Valve, Solenoid
Valve, Shuttle
Valve, Relief
Cylinder
Cyl.; Oil
Etc.
Accumulator
Joint, Rotary
Parts Index
Parts Index
