Hitachi Mining Excavator EX5600-7P Cummins FCO Workshop Manual
- Download this document, you need 6500 Gallons
Brand: Hitachi
Type of Machine: Mining Excavator
Type of Manual: Workshop Manual
Model: Hitachi EX5600-7P (Cummins FCO) Mining Excavator
List of Files:
EX5500Series_Wear_Gauge_List.pdf (1 Page)
EX5600-7P Workshop Manual WKGF90-EN-00(20250611).pdf (1459 Pages):
To The Reader
Additional References
Manual Composition
Page Number
Trademark
Safety Alert Symbol and Headline Notations
Units Used
Symbol and Abbreviation
Recognize Safety Information
Understand Signal Words
Follow Safety Instructions
Prepare for Emergencies
Wear Appropriate Clothing
Protect Against Noise
Inspect Machine
General Precautions for the Cab
Use Handrail and Stepss
Adjust the Operator's Seat
Ensure Safety Before Leaving or Standing up from Operator’s Seat
Fasten Your Seat Belt
Move and Operate Machine Safely
Start the Engine Only from Operator's Seat
Handle Starting Aids Safely
Jump Starting
Keep Riders off Machine
Precautions for Operations
Perform Job Site Risk Assessment Beforehand
Install OPG (Operator Protective Guard)
Restriction of Attachment Installation
Provide Signals for Jobs Involving Multiple Machines
Confirm Direction of Machine Travel
Drive Machine Safely
Avoid Injury from Rollaway Accidents
Avoid Accidents from Reversing and Swing Operation
Keep People Clear from Working Area
Never Position the Bucket Over Anyone
Avoid Undercutting
Avoid Tipping
Never Undercut a High Bank
Dig with Caution
Caution with an Overhead Obstacle
Avoid Power Lines
Precautions for Lightning
Lifting Application
Protect Against Flying Debris and Falling Object
Park Machine Safely
Handle Fluids Safely−Avoid Fires
Practice Maintenance Safely
Warn Others of Service Work
Support Machine Properly
Stay Clear of Moving Parts
Prevent Parts from Flying
Avoid Injury from Attachment Falling Accident
Prevent Burns
Replace Rubber Hoses Periodically
Avoid High-Pressure Fluids
Prevent Fires
Evacuating in Case of Fire
Beware of Exhaust Fumes
Precautions for Welding and Grinding
Avoid Heating near Pressurized Fluid Lines
Avoid Applying Heat to Lines Containing Flammable Fluids
Precautions for Handling Accumulator and Gas Damper
Beware of Asbestos and Silica Dust and Other Contamination
Prevent Battery Explosions
Service Air Conditioning System Safely
Dispose of Waste Properly
Never Ride Attachment
Precautions for Communication Terminal
Precaution for Communication Terminal Equipment
Precaution for WIU (Wireless Interface Unit) Communication Equipment
Machine Fire Suppression
Before Returning the Machine to the Customer
Precautions
Tightening
Painting
Bleeding Air
Releasing Pressure
Preparation
Upperstructure
Undercarriage
Front Attachment (Backhoe)
Front Attachment (Loading Shovel)
Cab Bed
Counterweight
Engine Unit
Pump Device
Control Valve
Other Valves
Swing Device
Hydraulic Oil Tank
Lift Cylinder (Fast-Filling System)
Lift Cylinder (Folding Stairway)
Swing Bearing
Travel Device
Travel Brake Valve
Drive Tumbler
Center Joint
Adjuster Cylinder
Front Idler
Upper and Lower Rollers
Track
Accumulator
Welding Repair Procedure
Front Attachment
Cylinder
Bushing
Angle Sensor
Other Valves
Front Attachment
Cylinder
Bushing
Angle Sensor
Other Valves
Brand: Hitachi
List of Files:
To The Reader
Manual Composition
Page Number
Trademark
Units Used
Inspect Machine
Jump Starting
Avoid Undercutting
Avoid Tipping
Dig with Caution
Avoid Power Lines
Lifting Application
Park Machine Safely
Prevent Burns
Prevent Fires
Precautions
Tightening
Painting
Bleeding Air
Releasing Pressure
Preparation
Upperstructure
Undercarriage
Cab Bed
Counterweight
Engine Unit
Pump Device
Control Valve
Other Valves
Swing Device
Hydraulic Oil Tank
Swing Bearing
Travel Device
Travel Brake Valve
Drive Tumbler
Center Joint
Adjuster Cylinder
Front Idler
Track
Accumulator
Front Attachment
Cylinder
Bushing
Angle Sensor
Other Valves
Front Attachment
Cylinder
Bushing
Angle Sensor
Other Valves
- Hitachi EX120-2 Excavator Parts Catalog
- Hitachi EX200-2 Service Manual
- Hitachi Excavator ZX240-3 to ZX250LCK-3 Parts Catalog P1V1-1-1 EN JP
- Hitachi Zaxis 200,225,230 Class Hydraulic Circuit Diagram
- Hitachi EX 750 -5 EX 800 H-5 Full Service Manual
- Hitachi Zaxis 200,225,240,270-3 Service Manual
- Hitachi WIN DR Technical Manual (a PC version Dr.ZX)
- Hitachi ZAXIS ZX330-3 TO ZX350-3 Parts Manual
- Isuzu Industrial Diesel Engine 4JJ1X/4-6HK1X/6WG1X Tier3
- Hitachi Zaxis 200-3 Hydraulic Excavator Technical Manual
- Hitachi Zaxis 70,70LC Hydraulic Circuit Diagram
- Hitachi EX200-3 Excavator Parts Catalog
- Hitachi Hydraulic Excavator ZX50 Technical Manual
- Hitachi ZW 220 - ZW 250 Wheel Loader - Workshop Manual
- Hitachi EX120 Service Manual
