Martin Welker
104
230,792
Hitachi Hybrid Excavator ZH210-A ZH210LC-A Operators Manual ENMDCF-1-2
Brand: Hitachi
Type of Machine: Hybrid Excavator
Model: Hitachi ZH210-A ZH210LC-A Hybrid Excavator
Serial Number: 020001 and up
Part Number: ENMDCF-1-2
Publication Date: 2020
Number of Pages: 386 Pages
ENMDCF-1-2
INTRODUCTION
INDEX
MACHINE NUMBERS
SAFETY
Recognize Safety Information
Understand Signal Words
Follow Safety Instructions
Prepare for Emergencies
Wear Protective Clothing
Protect Against Noise
Inspect Machine
General Precautions for Cab
Use Handholds and Steps
Adjust the Operator's Seat
Ensure Safety Before Rising from or Leaving Operator’s Seat
Fasten Your Seat Belt
Move and Operate Machine Safely
Operate Only from Operator's Seat
Jump Starting
Keep Riders off Machine
Precautions for Operations
Investigate Job Site Beforehand
Install OPG Guard
Provide Signals for Jobs Involving Multiple Machines
Confirm Direction of Machine to Be Driven
Drive Machine Safely
Avoid Injury from Rollaway Accidents
Avoid Injury from Back-Over and Swing Accidents
Keep Person Clear from Working Area
Never Position Bucket Over Anyone
Avoid Undercutting
Avoid Tipping
Never Undercut a High Bank
Dig with Caution
Operate with Caution
Avoid Power Lines
Precautions for Lightning
Object Handling
Protect Against Flying Debris
Park Machine Safely
Handle Fluids Safely−Avoid Fires
Transport Safely
Practice Safe Maintenance
Warn Others of Service Work
Support Machine Properly
Stay Clear of Moving Parts
Prevent Parts from Flying
Store Attachments Safely
Prevent Burns
Replace Rubber Hoses Periodically
Avoid High-Pressure Fluids
Prevent Fires
Evacuating in Case of Fire
Beware of Exhaust Fumes
Precautions for Welding and Grinding
Avoid Applying Heat to Lines Containing Flammable Fluids
Precautions for Handling Accumulator and Gas Damper
Beware of Asbestos and Silicon Dust and Other Contamination
Prevent Battery Explosions
Service Air Conditioning System Safely
Dispose of Waste Properly
Never Ride Attachment
Precautions for Communication Terminal
Precaution for Communication Terminal Equipment
Precautions for Hybrid Excavator
SAFETY SIGNS
COMPONENTS NAME
Components Name
Configuration of Hybrid System
GETTING ON/OFF THE MACHINE
OPERATOR'S STATION
Cab Features (Std. Model)
Multi Function Monitor
Default Setting
Basic Screen
How to Use Screens
Security Functions (Optional)
Alarm Occurrence Screen
Remedy
Main Menu
Air Conditioner
Radio
Work Mode
Mail (Optional)
Setting Menu
Date and Time
Attachment Adjust
Attachment Name Input
Auto Shut-Down
Password Change (Optional)
Sub Meter
Rear View Camera Monitor
Brightness Adjustment
Language Settings
Lists of Display Language
Unit Selection
Display Item Selection (Rear View Camera OFF)
Main Menu Sequence Change
Information Menu
Operation
Maintenance
Monitoring
Fuel Consumption Monitor
Energy Monitor
Switch Panel
Switch Panel (for Optional Equipments)
Key Switch
Power Boost Switch
Horn Switch
Cigar Lighter
Cab Light Switch
Installing Fire Extinguisher (Optional)
Pilot Control Shut-Off Lever
Engine Stop Switch
Fuse Box
Auto Air Conditioner
Tips for Optimal Air Conditioner Usage
AM/FM Radio Operation
Cab Door Release Lever
Opening/Closing and Removing Cab Inside Window
Opening Upper Front Window
Removing and Storing Lower Front Window
Opening Side Windows
Opening/Closing Overhead Window
Opening/Closing Overhead Window (Clear Hatch: If Equipped)
Emergency Exit
Adjusting the Seat
Adjusting Operator's Seat (Optional)
Console Height Adjustment
Installation and Adjustment of Mirrors
Seat Belt
BREAK-IN
Break-in Operation for New Machine
OPERATING THE ENGINE
Inspect Machine Daily Before Starting
Before Starting Engine
Starting the Engine
Check Instruments After Starting
Using Booster Batteries
Stopping the Engine
DRIVING THE MACHINE
Travel Levers and Pedals
Travel Mode Switch
Travel Alarm (Optional)
Operating on Soft Ground
Raise One Track Using Boom and Arm
Towing Machine a Short Distance
Operating In Water or Mud
Parking the Machine On Slopes
Parking the Machine
OPERATING THE MACHINE
Control Lever (ISO Pattern)
Attachment Pedal (Hydraulic Breaker) (Optional)
Attachment Pedal (Hydraulic Crusher) (Optional)
Warming Up Operation
Engine Speed Control
Auto-Idle
Auto Shut-Down
Work Mode
Power Boost Switch
Power Mode
Operating Backhoe
Shovel
Grading Operation
Do Not Strike the Ground with Bucket Teeth
Avoid Hammer Work
Avoid Abusive Operation
Avoid Side Load the Bucket
Do not use wide track shoes on rough ground
Hydraulic Breaker, Hydraulic Crusher and Quick Coupler
Piping for Breaker and Crusher (Optional)
Operational Procedures for Stop Valves and Selection Valve
Secondary Relief Pressure Adjustment
Precautions for Breaker Operation
Change Hydraulic Oil and Replace Full-Flow Filter Element
Precautions for Crusher Operation
Attachment Connection Parts
Precaution For Arm Roll-In/Bucket Roll-In Combined Operation
Shackle Hole Usage
How to Lower Boom In Case of Emergency and When Engine Stops
Precautions for After Operations
TRANSPORTING
Transporting by Road
Loading/Unloading on a Trailer
Fastening Machine for Transporting
Unloading
Lifting Machine
MAINTENANCE
Correct Maintenance and Inspection Procedures
Check the Hour Meter Regularly
Preparations for Inspection and Maintenance
Hood and Access Covers
Daily Check
Daily Check (Hybrid Devices)
Maintenance Guide
Periodic Replacement of Parts
Kind of Oils
A. Greasing
B. Engine
C. Transmission
D. Hydraulic System
Inspection and Maintenance of Hydraulic Equipment
E. Fuel System
F. Air Cleaner
G. Cooling System
H. Electrical System
I. Miscellaneous
MAINTENANCE UNDER SPECIAL ENVIRONMENTAL CONDITIONS
Maintenance Under Special Environmental Conditions
STORAGE
Storing the Machine
TROUBLESHOOTING
Troubleshooting
SPECIFICATIONS
Specifications
Working Ranges (Grouser shoe)
Shoe Types and Applications
Bucket Types and Applications
INDEX
