Hitachi Hybrid Excavator ZH200-A ZX200LC-A ZX210-A ZX210LC-A Parts Catalog EN JP
Language: English, Japanese
Brand: Hitachi
Type of Machine: Hybrid Excavator
Model: Hitachi ZH200-A ZX200LC-A ZX210-A ZX210LC-A Hybrid Excavator
Engine: ISUZU 4HK1-XYSA07 Engine
List of Files:
ZH200-A Series ISUZU 4HK1-XYSA07 Engine Parts Catalog 4HK1-XYSA07-4.pdf (Pages: 128)
ZH200-A Series ISUZU 4HK1-XYSA07 Engine Parts Catalog 4HK1-XYSA07-8.pdf (Pages: 136)
ZH200-A ZH200LC-A Equipment Components Parts Catalog PDCF-E1-1.pdf (Pages: 132)
ZH200-A ZH200LC-A Parts Catalog PDCF-1-1.pdf (Pages: 433)
ZH200-A ZX200LC-A ZX210-A ZX210LC-A Equipment Components Parts Catalog PDCF-E1-2.pdf (Pages: 189)
ZH200-A ZX200LC-A ZX210-A ZX210LC-A Parts catalog PDCF-1-2.pdf (Pages: 521)
Detail Content:
COVER
MEMORANDUM
FOREWORD
CONTENTS
ENGINE
005: ENGINE GASKET KIT (1/2)
005: ENGINE GASKET KIT (2/2)
010: CYLINDER HEAD COVER
011: CYLINDER HEAD (1/2)
011: CYLINDER HEAD (2/2)
012: CYLINDER BLOCK (1/2)
012: CYLINDER BLOCK (2/2)
013: OIL PAN AND LEVEL GAUGE (1/2)
013: OIL PAN AND LEVEL GAUGE (2/2)
014: CAMSHAFT AND VALVE (1/2)
014: CAMSHAFT AND VALVE (2/2)
015: CRANKSHAFT,PISTON AND FLYWHEEL (1/2)
015: CRANKSHAFT,PISTON AND FLYWHEEL (2/2)
020: TIMING GEAR CASE AND FLYWHEEL HOUSING (1/2)
020: TIMING GEAR CASE AND FLYWHEEL HOUSING (2/2)
025: INLET MANIFOLD
027: EXHAUST MANIFOLD
028: VENTILATION SYSTEM
030: WATER PUMP AND CORROSION RESISTOR
031: THERMOSTAT AND HOUSING
032: WATER PIPING; ENGINE
033: FAN AND FAN BELT (1/2)
033: FAN AND FAN BELT (2/2)
036: TURBOCHARGER SYSTEM (1/2)
036: TURBOCHARGER SYSTEM (2/2)
040: FUEL INJECTION SYSTEM (1/3)
040: FUEL INJECTION SYSTEM (2/3)
040: FUEL INJECTION SYSTEM (3/3)
041: FUEL FILTER AND BRACKET
042: FUEL PUMP AND PIPE
050: OIL COOLER AND OIL FILTER
051: OIL PUMP AND OIL STRAINER
052: OIL AND VACUUM PIPING; ENGINE
057: EMISSION PIPING
060: ENGINE ELECTRICAL CONTROL PARTS (1/2)
060: ENGINE ELECTRICAL CONTROL PARTS (2/2)
065: STARTER
066: GENERATOR
086: MISCELLANEOUS PARTS; INJECTION PUMP
110: RADIATOR
220: MANUAL TRANSMISSION ASM AND CASE
810: WIRING HARNESS AND FUSE
815: FIXING PARTS; WIRING HARNESS
825: SWITCH AND RELAY; INSTRUMENT PANEL
826: ELECTRICAL CONTROL AND OTHER PARTS
PARTS INDEX
COVER
MEMORANDUM
FOREWORD
CONTENTS
ENGINE
015: CRANKSHAFT,PISTON ANDFLYWHEEL (1/2)
015: CRANKSHAFT,PISTON ANDFLYWHEEL (2/2)
020: TIMING GEAR CASE ANDFLYWHEEL HOUSING (1/2)
020: TIMING GEAR CASE ANDFLYWHEEL HOUSING (2/2)
025: INLET MANIFOLD
028: VENTILATION SYSTEM (1/3)
028: VENTILATION SYSTEM (2/3)
028: VENTILATION SYSTEM (3/3)
030: WATER PUMP AND CORROSIONRESISTOR
032: WATER PIPING; ENGINE (1/2)
032: WATER PIPING; ENGINE (2/2)
057: EMISSION PIPING (1/2)
057: EMISSION PIPING (2/2)
060: ENGINE ELECTRICAL CONTROLPARTS (1/2)
060: ENGINE ELECTRICAL CONTROLPARTS (2/2)
065: STARTER
066: GENERATOR
086: MISCELLANEOUS PARTS;INJECTION PUMP
110: RADIATOR
220: MANUAL TRANSMISSION ASMAND CASE
825: SWITCH AND RELAY;INSTRUMENT PANEL
826: ELECTRICAL CONTROL ANDOTHER PARTS
PARTS INDEX
COVER
MEMORANDUM
FOREWORD
CONTENTS
PUMP
PUMP DEVICE
T. MISSION (PUMP)
PUMP;UNIT
REGULATOR;PUMP
REGULATOR;PUMP
REGULATOR;PUMP
PUMP;GEAR
MOTOR
SWING DEVICE
T.MISSION (SWING)
MOTOR;OIL (SWING)
TRAVEL DEVICE
MOTOR;OIL (TRAVEL)
VALVE;BRAKE
VALVE;RELIEF
VALVE
VALVE;CONTROL (1/5)
VALVE;CONTROL (2/5)
VALVE;CONTROL (3/5)
VALVE;CONTROL (4/5)
VALVE;CONTROL (5/5)
VALVE;PILOT (FRONT,SWING)
VALVE;PILOT (TRAVEL)
VALVE;SOLENOID
VALVE;SOLENOID
VALVE;SOLENOID
VALVE;SHUTTLE (1/5)
VALVE;SHUTTLE (2/5)
VALVE;SHUTTLE (3/5)
VALVE;SHUTTLE (4/5)
VALVE;SHUTTLE (5/5)
VALVE;SELECTOR
VALVE;RELIEF
VALVE;LOCK
VALVE;SOLENOID
JOINT;CENTER
JOINT;CENTER
CYLINDER
CYL.;BOOM (R)
CYL.;BOOM (L)
YL.;BOOM (R)(ML CRANE)
VALVE;HOLDING (R)(BOOM)
CYL.;BOOM (L)(ML CRANE)
VALVE;HOLDING (L)(BOOM)
CYL.;ARM
CYL.;ARM (ML CRANE)
VALVE;HOLDING (ARM)
CYL.;BUCKET
PARTS INDEX
MEMORANDUM
FOREWORD
ILLUSTRATION CONTENTS
CONTENTS
FRAME,COVER
FRAME
SWING BEARING PARTS (FRAME)
BOOM FOOT PIN
CENTER JOINT PARTS (UPPERSTRUCTURE)
COUNTERWEIGHT
COVER (1)
DOOR LOCK (1)
COVER (2)
COVER (3)
COVER (4)
COVER (5)
COVER (6)
COVER (7)
COVER (8)
ENGINE COVER
DOOR LOCK (2)
RADIATOR COVER
UNDER COVER
TOOL BOX
ANTI SLIP COVER (1)
ANTI SLIP COVER (2)
ANTI SLIP COVER (TOOL BOX)
ANTI SLIP COVER (FUEL TANK)
ENGINE
ENGINE
ENGINE SUPPORT
OIL FILTER PIPING
INTERCOOLER PIPING
RADIATOR
RADIATOR SUPPORT
COOLER PARTS
RADIATOR (COOLER)
COOLER PIPING
RESERVE TANK
AIR CLEANER
ELEMENT (INNER)
AIR CLEANER SUPPORT
AIR CLEANER PARTS
MUFFLER
FUEL TANK
FUEL TANK SUPPORT
FUEL PIPING
HYDRAULIC SYSTEM
PUMP DEVICE
PUMP DEVICE SUPPORT
CONTROL VALVE
CONTROL VALVE SUPPORT
SWING DEVICE
SWING DEVICE SUPPORT
OIL TANK
OIL TANK SUPPORT
HYDRAULIC PIPING
SUCTION PIPING
DELIVERY PIPING
RETURN PIPING (1)
RETURN PIPING (2)
DRAIN PIPING
HYDRAULIC PIPING (MAIN)
MAIN PIPING (1)
MAIN PIPING (2)
MAIN PIPING (3)
MAIN PIPING (4)
BOOM BOTTOM PIPING
SIDE BRANCH PIPING
HYDRAULIC PIPING (PILOT)
SOLENOID VALVE (2 SECTION)
SOLENOID VALVE (3 SECTION)
SOLENOID VALVE (5 SECTION)
PILOT PIPING (1)
PILOT PIPING (2)
PILOT PIPING (3)
PILOT PIPING (4)
PILOT PIPING (5)
PILOT PIPING (6)
PILOT PIPING (7)
PILOT PIPING (8)
PILOT PIPING (9)
PILOT PIPING (10-1)
PILOT PIPING (10-2)
ELECTRIC SYSTEM
ELECTRIC PARTS (1)
ELECTRIC PARTS (2)
ELECTRIC PARTS (3)
ELECTRIC PARTS (4)
ELECTRIC PARTS (5-1)
SWITCH BOX
ELECTRIC PARTS (5-2)
ELECTRIC PARTS (COOLER)
UNIT
POWER CONTROL UNIT SUPPORT
CAPACITOR UNIT SUPPORT
START SWITCH
ENGINE STOP SWITCH
MOBILE COMMUNICATIONS TERMINAL
CONTROLLER (MCZ)
CONTROLLER (HCU)
CONTROLLER (DSZ)
ADD. FUSE
FRONT HEAD LAMP (2 LAMP)(FLOOR)
FRONT HEAD LAMP (2 LAMP WITH RAIN-GUARD UPPER)
REAR HEAD LAMP (CAB)
REAR HEAD LAMP (FLOOR)
BRACKET (ADDITIONAL RELAY)
BOOM LIGHT HARNESS
BOOM LIGHT (R)
ENGINE CONTROL UNIT
HORN
REAR CAMERA
WINDOW WASHER
AUX PARTS
CAB
CAB (MOBILE COMMUNICATIONS)
CAB (1)(MOBILE COMMUNICATIONS)
CAB (2)
DOOR
CAB (3)
CAB (4)
CAB (5)
CAB (6)
CAB (7)
CAB (MOBILE COMMUNICATIONS)(WITH FRONT HEAD LAMP HARNESS)
CAB (MOBILE COMMUNICATIONS)(WITH GUARD SEAT)
CAB (4)(WITH OPG LEVEL Ⅱ TOP GUARD)
CAB (8)
CAB (MOBILE COMMUNICATIONS)(WITH UPPER AND LOWER FRONT GUARD)
CAB (9)
CAB (MOBILE COMMUNICATIONS)(WITH FULL GUARD)
CAB (10)
CAB GROUP (1)
CAB GROUP (2)
ANCHOR BOLT
CAB MIRROR
SUNVISOR (RIGHT WINDOW)
RAIN GUARD
FRONT HEAD LAMP,RAIN GUARD SUPPORT
FLOOR PARTS
CONTROL LEVER (FRONT, SWING)
PILOT PIPING (FRONT,SWING)
CONTROL LEVER (TRAVEL)
PILOT VALVE (TRAVEL)
PEDAL (R)
PEDAL (L)
LOCK LEVER
CONSOLE
CONSOLE COVER
RIGHT COVER
RADIO (AM/FM)
REAR BOX (AIR-CONDITIONER)
FLOOR PLATE
FLOOR PARTS (1)
FLOOR PARTS (2)
SEAT PARTS
SEAT
SUSPENSION SEAT PARTS
SUSPENSION SEAT
AIR-SUSPENSION SEAT PARTS (WITH HEATER)
AIR-SUSPENSION SEAT (WITH HEATER)(1)
AIR-SUSPENSION SEAT (WITH HEATER)(2)
HEATER SEAT PARTS
SEAT STAND
STAND PARTS
STAND COVER
STAND COVER (SUSPENSION)
FLOOR MAT
FLOOR CARPET
AIR CONDITIONER、HEATER
AIR-CONDITIONER (1)
AIR-CONDITIONER UNIT
AIR-CONDITIONER (2)
AIR-CONDITIONER (3)
AIR-CONDITIONER (4-1)
AIR-CONDITIONER (4-2)
CONDENSER UNIT
COMPRESSOR
HEATER PIPING
DUCT
UNDERCARRIAGE
TRACK FRAME
TRACK GUARD (X2)
TRACK GUARD (X4)
ADDITIONAL STEP
SWING BEARING
SWING BEARING PARTS (TRACK FRAME)
TRAVEL DEVICE
TRAVEL DEVICE SUPPORT
TRACK SPRING
FRONT IDLER
ADJUSTER
UPPER ROLLER
LOWER ROLLER
LOWER ROLLER SUPPORT
TRACK-LINK
TRACK-LINK
PAD CRAWLER B600mm (SEPARATE-TYPE)
CENTER JOINT
CENTER JOINT SUPPORT (TRACK)
TRAVEL PIPING
TRAVEL PIPING
TRAVEL MOTOR COVER
FRONT-END ATTACHMENTS
BOOM
BOOM PARTS
ARM
ARM PARTS
A LINK
A LINK (WITH HOOK)
B LINK
BUCKET 0.51m3 (JIS 94)
BUCKET 0.8m3 (JIS 94)
BUCKET 0.91m3 (JIS 94)
BUCKET 1.1m3 (JIS 94)
H BUCKET 0.8m3 (JIS 94)(SIDE-PIN TOOTH)
SLOPE FINISHING BUCKET
V-TYPE BUCKET 0.4m3 (JIS 94)
FRONT PIPING (BOOM)
FRONT PIPING (ARM)
BOOM CYLINDER (R)
BOOM CYLINDER (L)
ARM CYLINDER
BUCKET CYLINDER
LUBRICATE PIPING
ML CRANE PARTS
BOOM FOOT PIN (ML CRANE)
COUNTERWEIGHT (ML CRANE)
BOOM (ML CRANE)
BOOM PARTS (ML CRANE)
ARM (ML CRANE)
ML LINK
BOOM CYLINDER (R)(ML CRANE)
BOOM CYLINDER (L)(ML CRANE)
ARM CYLINDER (ML CRANE)
BUCKET LOCK VALVE
ARM HOLDING VALVE PIPING (1)
ARM HOLDING VALVE PIPING (2)
BOOM HOLDING VALVE PIPING (1)
BOOM HOLDING VALVE PIPING (2)
ANGLE SENSOR (ML CRANE)
ML LEVEL
ROTATING BEACON (ML CRANE)
ROTATING BEACON PARTS (ML CRANE)
NAME-PLATE (ML CRANE)
BREAKER, CRUSHER PARTS
CONTROL PEDAL (BREAKER, CRUSHER)
FLOOR MAT (BREAKER)
ETC.
4 WAY MULTI LEVER
4 WAY MULTI LEVER PIPING
GREASE GUN HOLDER
TOOLS
TOOLS
NAME-PLATE
NAME-PLATE (1)
NAME-PLATE (2)
NAME-PLATE (3)
PARTS INDEX
COVER
MEMORANDUM
FOREWORD
CONTENTS
PUMP
PUMP DEVICE
T. MISSION (PUMP)
PUMP;UNIT
PUMP;UNIT
PUMP;UNIT
REGULATOR;PUMP
REGULATOR;PUMP
REGULATOR;PUMP
PUMP;GEAR
MOTOR
SWING DEVICE
T.MISSION (SWING)
MOTOR;OIL (SWING)
TRAVEL DEVICE
MOTOR;OIL (TRAVEL)
VALVE;BRAKE
VALVE;RELIEF
VALVE
VALVE;CONTROL (1/5)
VALVE;CONTROL (2/5)
VALVE;CONTROL (3/5)
VALVE;CONTROL (4/5)
VALVE;CONTROL (5/5)
VALVE;CONTROL
BODY
VALVE;PILOT (ASSIST PIPING
VALVE;SOLENOID
VALVE;SOLENOID
VALVE;SHUTTLE (1/5)
VALVE;SHUTTLE (2/5)
VALVE;SHUTTLE (3/5)
VALVE;SHUTTLE (4/5)
VALVE;SHUTTLE (5/5)
VALVE;SHUTTLE
VALVE;SOLENOID
VALVE;SOLENOID (FLOW RATE SELECTOR)
VALVE;SOLENOID
VALVE;SELECTOR
VALVE;SELECTOR
VALVE;RELIEF
VALVE;LOCK
VALVE;SOLENOID
VALVE;CHECK
JOINT;CENTER
JOINT;CENTER
CYLINDER
CYL.;BOOM (R)
CYL.;BOOM (L)
CYL.;BOOM (R)(WITH HOSE RUPTURE VALVE)
CYL.;BOOM (L)(WITH HOSE RUPTURE VALVE)
CYL.;BOOM (R)(ML CRANE)
CYL.;ARM
CYL.;ARM (ML CRANE)
VALVE;HOLDING (ARM)
CYL.;ARM (ML CRANE)
VALVE;HOLDING (ARM)
CYL.;BUCKET
PARTS INDEX
COVER
MEMORANDUM
FOREWORD
CONTENTS
FRAME, COVER
FRAME
BOOM FOOT PIN
COUNTERWEIGHT
COVER (1)
DOOR LOCK (1)
COVER (2)
COVER (2)(WITH PRE-CLEANER)
COVER (3)
COVER (4)
COVER (5)
COVER (6)
COVER (7)
COVER (7)(TROPICAL)
COVER (8)
ENGINE COVER
DOOR LOCK (2)
DOOR LOCK
RADIATOR COVER
UNDER COVER
UNDERCOVER (HEAVY DUTY TYPE)(t=6.0mm)
TOOL BOX
ANTI SLIP COVER (1)
ANTI SLIP COVER (2)
ENGINE
ENGINE
ENGINE SUPPORT
OIL FILTER PIPING
INTERCOOLER PIPING
RADIATOR
RADIATOR SUPPORT
COOLER PARTS
RADIATOR (COOLER)
COOLER PIPING
RESERVE TANK
AIR CLEANER
ELEMENT (INNER)
AIR CLEANER SUPPORT
AIR CLEANER PARTS
MUFFLER
PRE-CLEANER
PRE-CLEANER PARTS
FUEL TANK
FUEL TANK SUPPORT
FUEL PIPING
HYDRAULIC SYSTEM
PUMP DEVICE
PUMP DEVICE SUPPORT
CONTROL VALVE
SWING DEVICE
OIL TANK
OIL TANK (WITH INDICATOR)
OIL TANK SUPPORT
HYDRAULIC PIPING
SUCTION PIPING
DELIVERY PIPING
RETURN PIPING (1)
RETURN PIPING (2)
DRAIN PIPING
MAIN PIPING (1)
MAIN PIPING (2)
MAIN PIPING (3)
MAIN PIPING (4)
BOOM BOTTOM PIPING
SIDE BRANCH PIPING
PILOT PIPING (1)
PILOT PIPING (2)
PILOT PIPING (3)
PILOT PIPING (4)
PILOT PIPING (5)
PILOT PIPING (6)
PILOT PIPING (7)
PILOT PIPING (8)
PILOT PIPING (9)
PILOT PIPING (10-1)
PILOT PIPING (10-2)
ELECTRIC SYSTEM
ELECTRIC PARTS (1)
ELECTRIC PARTS (2)
ELECTRIC PARTS (3)
ELECTRIC PARTS (4)
SWITCH BOX
ELECTRIC PARTS (OIL TANK)
ELECTRICAL POWER UNIT
START SWITCH
ENGINE STOP SWITCH
SATELLITE COMMUNICATIONS TERMINAL
CONTROLLER (MC)
CONTROLLER (HCU)
MONITOR CONTROLLER
BOOM LIGHT HARNESS
BOOM LIGHT (R)
ENGINE CONTROL UNIT
HORN
REAR CAMERA
OVER LOAD ALARM DEVICE
SWING MOTION ALARM (CAB)
SWING MOTION ALARM
TRAVEL MOTION ALARM (CAB)
TRAVEL MOTION ALARM
AUX PARTS
WINDOW WASHER
CAB
CAB (2)(CLEAR GLASS)
DOOR
CAB (3)(WITH RUBBER)
CAB (4)(WITHOUT FRONT HEAD LAMP HARNESS)
CAB (5)
CAB (6)
CAB (7)
DOOR
CAB (4)(WITH FRONT HEAD LAMP HARNESS)
CAB (4)(WITH FRONT HEAD LAMP HARNESS, GUARD)
CAB GUARD (UNDER FRONT)
CAB GUARD (ON FRONT)
CAB GUARD (CEILING)
CAB GROUP (1)
CAB GROUP (2)
ANCHOR BOLT
CAB MIRROR
RAIN GUARD
FRONT HEAD LAMP, RAIN GUARD SUPPORT
FLOOR PARTS
CONTROL LEVER (FRONT, SWING)(WITH SINGLE SWITCH)
PILOT VALVE (FRONT, SWING)
PEDAL (R)
PEDAL (L)
LOCK LEVER
CONSOLE
CONSOLE COVER
RIGHT COVER
RADIO (AM/FM)
REAR BOX (12V POWER SUPPLY)
POWER UNIT (12V)
FLOOR PLATE
FLOOR PARTS (1)
FLOOR PARTS (2)
SEAT PARTS
SEAT
SUSPENSION SEAT
HEATER SEAT PARTS
SEAT STAND
STAND PARTS
STAND COVER
FLOOR MAT
FLOOR CARPET
AIR CONDITIONER, HEATER
AIR-CONDITIONER (1)
AIR CONDITIONER UNIT
AIR-CONDITIONER (2)
AIR-CONDITIONER (3)
HEATER PIPING
DUCT
UNDERCARRIAGE
TRACK FRAME
TRACK GUARD (X2)
TRACK GUARD (X4)
FULL-LENGTH TRACK GUARD
ADDITIONAL STEP
TRACK UNDER COVER
SWING BEARING
TRAVEL DEVICE
TRACK SPRING
FRONT IDLER
ADJUSTER
UPPER ROLLER
LOWER ROLLER
TRACK-LINK
TRACK-LINK
CENTER JOINT
TRAVEL PIPING
TRAVEL PIPING
TRAVEL MOTOR COVER
BOOM
BOOM PARTS
ARM
ARM PARTS
A LINK
A LINK (WITH HOOK)
B LINK
B LINK (H TYPE)
FRONT PIPING (BOOM)
FRONT PIPING (ARM)
BOOM CYLINDER (R)
BOOM CYLINDER (L)
BOOM CYLINDER (R)(WITH HOSE RUPTURE VALVE)
BOOM CYLINDER (L)(WITH HOSE RUPTURE VALVE)
ARM CYLINDER
ARM CYLINDER (WITH HOSE RUPTURE VALVE)
BUCKET CYLINDER
LUBRICATE PIPING
HOSE RUPTURE VALVE PIPING (BOOM)(1)
HOSE RUPTURE VALVE PIPING (BOOM)(2)
HOSE RUPTURE VALVE PIPING (ARM)(1)
HOSE RUPTURE VALVE PIPING (ARM)(2)
ASSIST PIPING
ADD. GEAR PUMP (1)
ADD. GEAR PUMP (2)
ADD. GEAR PUMP PARTS
PILOT PIPING (ADD. GEAR PUMP)
ASSIST PIPING (BOOM)
ASSIST PIPING (ARM)
CONTROL PEDAL (ASSIST PIPING)
FLOOR MAT (ASSIST PIPING)
ACCUMULATOR
ML CRANE PARTS
BOOM (ML CRANE)
ARM (ML CRANE)
ML LINK
BUCKET LOCK VALVE
ML LEVEL
BREAKER, CRUSHER PIPING (MAIN)
BREAKER, CRUSHER PIPING (PILOT)
BRAKER, CRUSHER PIPING (MONO-BOOM)
BRAKER, CRUSHER PIPING (MONO-BOOM)(1"x1-1/4")
BREAKER, CRUSHER PIPING (2.91m ARM)
BREAKER, CRUSHER PIPING (2.91m ARM)(1"x1-1/4")
FLOOR MAT (BREAKER)
FLOOR MAT (BREAKER+ASSIST PIPING)
NPK BREAKER PIPING
NPK COMMON PIPING (BREAKER, CRUSHER)
RELIEF VALVE
SOLENOID VALVE (FLOW RATE SELECTOR)
PILOT PIPING (FLOW RATE SELECTOR)
ETC.
4 WAY MULTI LEVER
GREASE GUN HOLDER
TOOLS
TOOLS
NAME-PLATE
NAME-PLATE (1)(JAPANESE)
NAME-PLATE (2)(JAPANESE)
NAME-PLATE (3)(JAPANESE)
NAME-PLATE (1)(OCEANIA)
NAME-PLATE (2)(OCEANIA)
NAME-PLATE (3)(OCEANIA)
PARTS INDEX
PARTS INDEX
Brand: Hitachi
List of Files:
Detail Content:
COVER
MEMORANDUM
FOREWORD
CONTENTS
ENGINE
025: INLET MANIFOLD
065: STARTER
066: GENERATOR
110: RADIATOR
PARTS INDEX
COVER
MEMORANDUM
FOREWORD
CONTENTS
ENGINE
025: INLET MANIFOLD
065: STARTER
066: GENERATOR
110: RADIATOR
PARTS INDEX
COVER
MEMORANDUM
FOREWORD
CONTENTS
PUMP
PUMP DEVICE
T. MISSION (PUMP)
PUMP;UNIT
REGULATOR;PUMP
REGULATOR;PUMP
REGULATOR;PUMP
PUMP;GEAR
MOTOR
SWING DEVICE
T.MISSION (SWING)
MOTOR;OIL (SWING)
TRAVEL DEVICE
MOTOR;OIL (TRAVEL)
VALVE;BRAKE
VALVE;RELIEF
VALVE
VALVE;CONTROL (1/5)
VALVE;CONTROL (2/5)
VALVE;CONTROL (3/5)
VALVE;CONTROL (4/5)
VALVE;CONTROL (5/5)
VALVE;SOLENOID
VALVE;SOLENOID
VALVE;SOLENOID
VALVE;SHUTTLE (1/5)
VALVE;SHUTTLE (2/5)
VALVE;SHUTTLE (3/5)
VALVE;SHUTTLE (4/5)
VALVE;SHUTTLE (5/5)
VALVE;SELECTOR
VALVE;RELIEF
VALVE;LOCK
VALVE;SOLENOID
JOINT;CENTER
JOINT;CENTER
CYLINDER
CYL.;BOOM (R)
CYL.;BOOM (L)
CYL.;ARM
CYL.;ARM (ML CRANE)
VALVE;HOLDING (ARM)
CYL.;BUCKET
PARTS INDEX
MEMORANDUM
FOREWORD
CONTENTS
FRAME,COVER
FRAME
BOOM FOOT PIN
COUNTERWEIGHT
COVER (1)
DOOR LOCK (1)
COVER (2)
COVER (3)
COVER (4)
COVER (5)
COVER (6)
COVER (7)
COVER (8)
ENGINE COVER
DOOR LOCK (2)
RADIATOR COVER
UNDER COVER
TOOL BOX
ANTI SLIP COVER (1)
ANTI SLIP COVER (2)
ENGINE
ENGINE
ENGINE SUPPORT
OIL FILTER PIPING
INTERCOOLER PIPING
RADIATOR
RADIATOR SUPPORT
COOLER PARTS
RADIATOR (COOLER)
COOLER PIPING
RESERVE TANK
AIR CLEANER
ELEMENT (INNER)
AIR CLEANER SUPPORT
AIR CLEANER PARTS
MUFFLER
FUEL TANK
FUEL TANK SUPPORT
FUEL PIPING
HYDRAULIC SYSTEM
PUMP DEVICE
PUMP DEVICE SUPPORT
CONTROL VALVE
SWING DEVICE
OIL TANK
OIL TANK SUPPORT
HYDRAULIC PIPING
SUCTION PIPING
DELIVERY PIPING
RETURN PIPING (1)
RETURN PIPING (2)
DRAIN PIPING
MAIN PIPING (1)
MAIN PIPING (2)
MAIN PIPING (3)
MAIN PIPING (4)
BOOM BOTTOM PIPING
SIDE BRANCH PIPING
PILOT PIPING (1)
PILOT PIPING (2)
PILOT PIPING (3)
PILOT PIPING (4)
PILOT PIPING (5)
PILOT PIPING (6)
PILOT PIPING (7)
PILOT PIPING (8)
PILOT PIPING (9)
PILOT PIPING (10-1)
PILOT PIPING (10-2)
ELECTRIC SYSTEM
ELECTRIC PARTS (1)
ELECTRIC PARTS (2)
ELECTRIC PARTS (3)
ELECTRIC PARTS (4)
SWITCH BOX
UNIT
START SWITCH
ENGINE STOP SWITCH
CONTROLLER (MCZ)
CONTROLLER (HCU)
CONTROLLER (DSZ)
ADD. FUSE
BOOM LIGHT HARNESS
BOOM LIGHT (R)
ENGINE CONTROL UNIT
HORN
REAR CAMERA
WINDOW WASHER
AUX PARTS
CAB
CAB (2)
DOOR
CAB (3)
CAB (4)
CAB (5)
CAB (6)
CAB (7)
CAB (8)
CAB (9)
CAB (10)
CAB GROUP (1)
CAB GROUP (2)
ANCHOR BOLT
CAB MIRROR
RAIN GUARD
FLOOR PARTS
PEDAL (R)
PEDAL (L)
LOCK LEVER
CONSOLE
CONSOLE COVER
RIGHT COVER
RADIO (AM/FM)
FLOOR PLATE
FLOOR PARTS (1)
FLOOR PARTS (2)
SEAT PARTS
SEAT
SUSPENSION SEAT
HEATER SEAT PARTS
SEAT STAND
STAND PARTS
STAND COVER
FLOOR MAT
FLOOR CARPET
AIR-CONDITIONER (1)
AIR-CONDITIONER (2)
AIR-CONDITIONER (3)
CONDENSER UNIT
COMPRESSOR
HEATER PIPING
DUCT
UNDERCARRIAGE
TRACK FRAME
TRACK GUARD (X2)
TRACK GUARD (X4)
ADDITIONAL STEP
SWING BEARING
TRAVEL DEVICE
TRACK SPRING
FRONT IDLER
ADJUSTER
UPPER ROLLER
LOWER ROLLER
TRACK-LINK
TRACK-LINK
CENTER JOINT
TRAVEL PIPING
TRAVEL PIPING
TRAVEL MOTOR COVER
BOOM
BOOM PARTS
ARM
ARM PARTS
A LINK
A LINK (WITH HOOK)
B LINK
FRONT PIPING (BOOM)
FRONT PIPING (ARM)
BOOM CYLINDER (R)
BOOM CYLINDER (L)
ARM CYLINDER
BUCKET CYLINDER
LUBRICATE PIPING
ML CRANE PARTS
BOOM (ML CRANE)
ARM (ML CRANE)
ML LINK
BUCKET LOCK VALVE
ML LEVEL
FLOOR MAT (BREAKER)
ETC.
4 WAY MULTI LEVER
GREASE GUN HOLDER
TOOLS
TOOLS
NAME-PLATE
NAME-PLATE (1)
NAME-PLATE (2)
NAME-PLATE (3)
PARTS INDEX
COVER
MEMORANDUM
FOREWORD
CONTENTS
PUMP
PUMP DEVICE
T. MISSION (PUMP)
PUMP;UNIT
PUMP;UNIT
PUMP;UNIT
REGULATOR;PUMP
REGULATOR;PUMP
REGULATOR;PUMP
PUMP;GEAR
MOTOR
SWING DEVICE
T.MISSION (SWING)
MOTOR;OIL (SWING)
TRAVEL DEVICE
MOTOR;OIL (TRAVEL)
VALVE;BRAKE
VALVE;RELIEF
VALVE
VALVE;CONTROL (1/5)
VALVE;CONTROL (2/5)
VALVE;CONTROL (3/5)
VALVE;CONTROL (4/5)
VALVE;CONTROL (5/5)
VALVE;CONTROL
BODY
VALVE;SOLENOID
VALVE;SOLENOID
VALVE;SHUTTLE (1/5)
VALVE;SHUTTLE (2/5)
VALVE;SHUTTLE (3/5)
VALVE;SHUTTLE (4/5)
VALVE;SHUTTLE (5/5)
VALVE;SHUTTLE
VALVE;SOLENOID
VALVE;SOLENOID
VALVE;SELECTOR
VALVE;SELECTOR
VALVE;RELIEF
VALVE;LOCK
VALVE;SOLENOID
VALVE;CHECK
JOINT;CENTER
JOINT;CENTER
CYLINDER
CYL.;BOOM (R)
CYL.;BOOM (L)
CYL.;ARM
CYL.;ARM (ML CRANE)
VALVE;HOLDING (ARM)
CYL.;ARM (ML CRANE)
VALVE;HOLDING (ARM)
CYL.;BUCKET
PARTS INDEX
COVER
MEMORANDUM
FOREWORD
CONTENTS
FRAME, COVER
FRAME
BOOM FOOT PIN
COUNTERWEIGHT
COVER (1)
DOOR LOCK (1)
COVER (2)
COVER (3)
COVER (4)
COVER (5)
COVER (6)
COVER (7)
COVER (7)(TROPICAL)
COVER (8)
ENGINE COVER
DOOR LOCK (2)
DOOR LOCK
RADIATOR COVER
UNDER COVER
TOOL BOX
ANTI SLIP COVER (1)
ANTI SLIP COVER (2)
ENGINE
ENGINE
ENGINE SUPPORT
OIL FILTER PIPING
INTERCOOLER PIPING
RADIATOR
RADIATOR SUPPORT
COOLER PARTS
RADIATOR (COOLER)
COOLER PIPING
RESERVE TANK
AIR CLEANER
ELEMENT (INNER)
AIR CLEANER SUPPORT
AIR CLEANER PARTS
MUFFLER
PRE-CLEANER
PRE-CLEANER PARTS
FUEL TANK
FUEL TANK SUPPORT
FUEL PIPING
HYDRAULIC SYSTEM
PUMP DEVICE
PUMP DEVICE SUPPORT
CONTROL VALVE
SWING DEVICE
OIL TANK
OIL TANK SUPPORT
HYDRAULIC PIPING
SUCTION PIPING
DELIVERY PIPING
RETURN PIPING (1)
RETURN PIPING (2)
DRAIN PIPING
MAIN PIPING (1)
MAIN PIPING (2)
MAIN PIPING (3)
MAIN PIPING (4)
BOOM BOTTOM PIPING
SIDE BRANCH PIPING
PILOT PIPING (1)
PILOT PIPING (2)
PILOT PIPING (3)
PILOT PIPING (4)
PILOT PIPING (5)
PILOT PIPING (6)
PILOT PIPING (7)
PILOT PIPING (8)
PILOT PIPING (9)
PILOT PIPING (10-1)
PILOT PIPING (10-2)
ELECTRIC SYSTEM
ELECTRIC PARTS (1)
ELECTRIC PARTS (2)
ELECTRIC PARTS (3)
ELECTRIC PARTS (4)
SWITCH BOX
START SWITCH
ENGINE STOP SWITCH
CONTROLLER (MC)
CONTROLLER (HCU)
MONITOR CONTROLLER
BOOM LIGHT HARNESS
BOOM LIGHT (R)
ENGINE CONTROL UNIT
HORN
REAR CAMERA
SWING MOTION ALARM
TRAVEL MOTION ALARM
AUX PARTS
WINDOW WASHER
CAB
DOOR
CAB (5)
CAB (6)
CAB (7)
DOOR
CAB GUARD (CEILING)
CAB GROUP (1)
CAB GROUP (2)
ANCHOR BOLT
CAB MIRROR
RAIN GUARD
FLOOR PARTS
PEDAL (R)
PEDAL (L)
LOCK LEVER
CONSOLE
CONSOLE COVER
RIGHT COVER
RADIO (AM/FM)
POWER UNIT (12V)
FLOOR PLATE
FLOOR PARTS (1)
FLOOR PARTS (2)
SEAT PARTS
SEAT
SUSPENSION SEAT
HEATER SEAT PARTS
SEAT STAND
STAND PARTS
STAND COVER
FLOOR MAT
FLOOR CARPET
AIR-CONDITIONER (1)
AIR-CONDITIONER (2)
AIR-CONDITIONER (3)
HEATER PIPING
DUCT
UNDERCARRIAGE
TRACK FRAME
TRACK GUARD (X2)
TRACK GUARD (X4)
ADDITIONAL STEP
TRACK UNDER COVER
SWING BEARING
TRAVEL DEVICE
TRACK SPRING
FRONT IDLER
ADJUSTER
UPPER ROLLER
LOWER ROLLER
TRACK-LINK
TRACK-LINK
CENTER JOINT
TRAVEL PIPING
TRAVEL PIPING
TRAVEL MOTOR COVER
BOOM
BOOM PARTS
ARM
ARM PARTS
A LINK
A LINK (WITH HOOK)
B LINK
B LINK (H TYPE)
FRONT PIPING (BOOM)
FRONT PIPING (ARM)
BOOM CYLINDER (R)
BOOM CYLINDER (L)
ARM CYLINDER
BUCKET CYLINDER
LUBRICATE PIPING
ASSIST PIPING
ADD. GEAR PUMP (1)
ADD. GEAR PUMP (2)
ASSIST PIPING (ARM)
ACCUMULATOR
ML CRANE PARTS
BOOM (ML CRANE)
ARM (ML CRANE)
ML LINK
BUCKET LOCK VALVE
ML LEVEL
FLOOR MAT (BREAKER)
NPK BREAKER PIPING
RELIEF VALVE
ETC.
4 WAY MULTI LEVER
GREASE GUN HOLDER
TOOLS
TOOLS
NAME-PLATE
PARTS INDEX
PARTS INDEX
- Hitachi EX120-2 Excavator Parts Catalog
- Hitachi EX200-2 Service Manual
- Hitachi Excavator ZX240-3 to ZX250LCK-3 Parts Catalog P1V1-1-1 EN JP
- Hitachi Zaxis 200,225,230 Class Hydraulic Circuit Diagram
- Hitachi EX 750 -5 EX 800 H-5 Full Service Manual
- Hitachi Zaxis 200,225,240,270-3 Service Manual
- Hitachi WIN DR Technical Manual (a PC version Dr.ZX)
- Hitachi ZAXIS ZX330-3 TO ZX350-3 Parts Manual
- Isuzu Industrial Diesel Engine 4JJ1X/4-6HK1X/6WG1X Tier3
- Hitachi Zaxis 200-3 Hydraulic Excavator Technical Manual
- Hitachi Zaxis 70,70LC Hydraulic Circuit Diagram
- Hitachi EX200-3 Excavator Parts Catalog
- Hitachi Hydraulic Excavator ZX50 Technical Manual
- Hitachi ZW 220 - ZW 250 Wheel Loader - Workshop Manual
- Hitachi EX120 Service Manual
