Hitachi Hybrid Excavator ZH200-6 ZH200LC-6 Parts Catalog EN JP
Language: English, Japanese
Brand: Hitachi
Type of Machine: Hybrid Excavator
Model: Hitachi ZH200-6 ZH200LC-6 Hybrid Excavator
List of Files:
ZH200-6 ZH200LC-6 Equipment Coponents Parts Catalog PDFXA0-E1-1.pdf (Pages: 169)
ZH200-6 ZH200LC-6 Parts Catalog PDFXA0-1-1.pdf (Pages: 491)
Detail Content:
COVER
MEMORANDUM
FOREWORD
CONTENTS
PUMP
PUMP DEVICE
TRANSMISSION (PUMP)
PUMP;UNIT
REGULATOR;PUMP (1)
REGULATOR;PUMP (2)
REGULATOR;PUMP (3)
PUMP;GEAR
MOTOR
SWING DEVICE
T.MISSION (SWING)
MOTOR;OIL (SWING)
TRAVEL DEVICE (1/2)
TRAVEL DEVICE (2/2)
VALVE
VALVE;CONTROL (1/5)
VALVE;CONTROL (2/5)
VALVE;CONTROL (3/5)
VALVE;CONTROL (3/5)
VALVE;CONTROL (4/5)
VALVE;CONTROL (5/5)
VALVE;CONTROL (ADDITIONAL PUMP)(OPEN)
BODY
VALVE;CONTROL (ADDITIONAL PUMP)(CLOSE)
VALVE;PILOT (FRONT, SWING)
VALVE;PILOT (TRAVEL)
VALVE;SHUTTLE (1/5)
VALVE;SHUTTLE (2/5)
VALVE;SHUTTLE (3/5)
VALVE;SHUTTLE (4/5)
VALVE;SHUTTLE (5/5)
VALVE;SHUTTLE
VALVE;STOP
VALVE;PILOT
VALVE;SOLENOID (3 SECTION)
VALVE;SOLENOID (3 SECTION)(ARM AND BUCKET CONTROL)
VALVE;SOLENOID (5 SECTION)
VALVE;SOLENOID (BREAKER RELIEF)
VALVE;SELECTOR (3WAY VALVE)
VALVE;SELECTOR (4WAY MULTI)
VALVE;RELIEF
VALVE;LOCK
VALVE;SOLENOID (BUCKET LOCK)
VALVE;SOLENOID (ATTACHMENT RELIEF)
VALVE;SOLENOID (FLOW RATE SELECTOR)
VALVE;CHECK
JOINT;CENTER
JOINT;CENTER
CYLINDER
CYL.;BOOM (R)
CYL.;BOOM (L)
CYL.;BOOM (R)(WITH HOSE RUPTURE VALVE)
VALVE;HOLDING (R)(BOOM)
CYL.;BOOM (L)(WITH HOSE RUPTURE VALVE)
VALVE;HOLDING (L)(BOOM)
CYL.;ARM
CYL.;ARM (WITH HOSE RUPTURE VALVE)
VALVE;HOLDING (ARM)
CYL.;BUCKET
PARTS INDEX
COVER
MEMORANDUM
FOREWORD
ILLUSTRATION CONTENTS
PERIODIC REPLACEMENT PARTS
FILTER, ELEMENT, BELT PARTS
BUCKET PARTS
FRAME, COVER
FRAME
SWING BEARING SUPPORT (UPPERSTRUCTURE)
BOOM FOOT PIN
CENTER JOINT SUPPORT (UPPERSTRUCTURE)
COUNTERWEIGHT
COUNTERWEIGHT SUPPORT
COVER (1)
DOOR LOCK (1)
COVER (2)
COVER (3)
COVER (4)
COVER (5)
COVER (6)
DOOR (COVER (6))
COVER (COVER (6))
COVER (7)
COVER (8)
ENGINE COVER PARTS
ENGINE COVER (L)
ENGINE COVER (R)
ENGINE COVER (CENTER)
RADIATOR COVER
COVER;UNDER
HANDRAIL
TOOL BOX COVER
TOOL BOX (UPPER)
TOOL BOX (LOWER)
ANTI-SLIP COVER (COVER (2))
ANTI-SLIP COVER (COVER (3))
ANTI-SLIP COVER (TOOL BOX)
ANTI SLIP COVER (FUEL TANK)
ENGINE
ENGINE
ENGINE SUPPORT
INTERCOOLER PIPING
RADIATOR
RADIATOR SUPPORT
COOLER PIPING (1)
COOLER PIPING (2)
COOLER PARTS (1)
RADIATOR (COOLER)(1)
COOLER PARTS (2)
AIR CLEANER
ELEMENT (INNER)
AIR CLEANER SUPPORT
AIR CLEANER PARTS
MUFFLER PARTS
FUEL TANK
FUEL TANK SUPPORT
FUEL PIPING
HYDRAULIC SYSTEM
PUMP DEVICE
PUMP DEVICE SUPPORT
CONTROL VALVE
CONTROL VALVE SUPPORT
SWING DEVICE
SWING DEVICE SUPPORT
OIL TANK
OIL TANK (WITH INDICATOR)
OIL TANK PARTS (WITH INDICATOR)
OIL TANK SUPPORT
HYDRAULIC PIPING
SUCTION PIPING
DELIVERY PIPING
RETURN PIPING(1)
RETURN PIPING(2)
DRAIN PIPING
HYDRAULIC PIPING (MAIN)
MAIN PIPING (1)
MAIN PIPING (2)
MAIN PIPING (3)
MAIN PIPING (4)
BOOM BOTTOM PIPING
SIDE BRANCH PIPING
HYDRAULIC PIPING (PILOT)
SOLENOID VALVE (3 SECTION)
SOLENOID VALVE (3 SECTION)(ARM AND BUCKET CONTROL)
SOLENOID VALVE (5 SECTION)
PILOT PIPING (1)
PILOT PIPING (2)
PILOT PIPING (3)
PILOT PIPING (4)
PILOT PIPING (5)
PILOT PIPING (6)
PILOT PIPING (7)
PILOT PIPING (8)
PILOT PIPING (9)
PILOT PIPING (10)
ELECTRIC SYSTEM
ELECTRIC PARTS (1)
ELECTRIC PARTS (2)
ELECTRIC PARTS (3)
ELECTRIC PARTS (4)
ELECTRIC PARTS (5)
SWITCH BOX
ELECTRIC PARTS (UNIT)
POWER UNIT
POWER CONTROL UNIT
ENGINE CONTROLLER
ENGINE STOP SWITCH
DATA CONVERTER PARTS
CONTROLLER (MC)
CONTROLLER (HCU)
MONITOR CONTROLLER
FRONT HEAD LAMP PARTS (2 LAMP)(FLOOR)
FRONT HEAD LAMP PARTS (4 LAMP)(FLOOR)
REAR HEAD LAMP PARTS (FLOOR)
HORN
REAR CAMERA
WINDOW WASHER
CAB
CAB (STEEL ROOF)(WITH FRONT GUARD SEAT)(MOBILE COMMUNICATIONS)
CAB (1)
CAB (2)
DOOR
CAB (3)
CAB (4)
CAB (5)
CAB (5)(LAMINATED GLASS)
CAB (6)
CAB (7)
LAMP HARNESS (CAB)
CAB (POLYCARBONATE ROOF)(SATELLITE COMMUNICATIONS)
CAB (6)(POLYCARBONATE ROOF)
ANTENNA (SATELLITE COMMUNICATIONS)
ROTATING BEACON PARTS
CAB GUARD (CEILING)
CAB GUARD (ON FRONT, UNDER FRONT)
CAB GUARD (ON FRONT, UNDER FRONT)(VERTICAL BAR TYPE)
CAB GUARD (OPG LEVELⅡ TOP)
CAB GUARD (OPG LEVELⅡ FRONT)
CAB GROUP (1)
CAB GROUP (2)
CAB MIRROR
ANCHOR BOLT
FRONT HEAD LAMP, RAIN GUARD SUPPORT
FLOOR PARTS
CONTROL LEVER (FRONT, SWING)
PILOT VALVE (FRONT, SWING)
CONTROL LEVER (TRAVEL)
PILOT VALVE (TRAVEL)
PEDAL (R)
PEDAL (L)
LOCK LEVER
CONSOLE
CONSOLE COVER
RIGHT COVER
RADIO (AM/FM)
REAR BOX (12V POWER SUPPLY)
POWER UNIT (12V)
FLOOR PLATE
FLOOR PARTS (1)
FLOOR PARTS (2)
RIGID SEAT PARTS (KAB)
SEAT (KAB)
HEATER SEAT PARTS
SEAT STAND
STAND PARTS
STAND COVER
FLOOR MAT
FLOOR CARPET
ML-LEVEL
AIR CONDITIONER, HEATER
AIR CONDITIONER (1)
AIR CONDITIONER UNIT
AIR CONDITIONER (2)
AIR CONDITIONER (3)
AIR CONDITIONER (4)
CONDENSER UNIT
HEATER PIPING
HEATER PIPING (LITHIUM-ION BATTERY WARM-UP PIPING)
DUCT (WITH AIR CONDITIONER)
EXPANSION TANK
UNDERCARRIAGE
TRACK FRAME
TRACK GUARD (X2)
STEP
SWING BEARING
SWING BEARING SUPPORT (UNDERCARRIAGE)
TRAVEL DEVICE
TRAVEL DEVICE SUPPORT
TRACK SPRING
FRONT IDLER
ADJUSTER
UPPER ROLLER
LOWER ROLLER
LOWER ROLLER SUPPORT
TRACK LINK
CENTER JOINT
CENTER JOINT SUPPORT (TRACK)
TRAVEL PIPING
TRAVEL MOTOR COVER
FRONT-END ATTACHMENTS
BOOM 5.68m (WITH BREAKER, CRUSHER, HOSE RUPTURE VALVE, ML-CRANE SEAT)
BOOM PARTS
ARM 2.91m
ARM 2.91m (WITH BREAKER, CRUSHER, ASSIST PIPING, ML-CRANE SEAT)
ARM PARTS
A LINK
B LINK
BUCKET 0.8m3 (JIS 94)
BUCKET 0.8m3 (JIS 94)(WITH FOOK)
BUCKET 0.91m3 (JIS 94)
BUCKET 0.8m3 (JIS 94)(REINFORCEMENT)
BUCKET 0.8m3 (JIS 94)(WITH FOOK)(REINFORCEMENT)
BUCKET 0.91m3 (JIS 94)(REINFORCEMENT)
H BUCKET 0.8m3 (JIS 94)
H BUCKET 0.8m3 (JIS 94)(SIDE-PIN TOOTH)
SLOPE-FINISHING BLADE
FRONT PIPING (BOOM)
FRONT PIPING (ARM)
LUBRICATE PIPING
BOOM CYLINDER (R)
BOOM CYLINDER (L)
BOOM CYLINDER (R)(WITH HOSE RUPTURE VALVE)
BOOM CYLINDER (L)(WITH HOSE RUPTURE VALVE)
ARM CYLINDER
ARM CYLINDER (WITH HOSE RUPTURE VALVE)
BUCKET CYLINDER
HOSE RUPTURE VALVE PIPING (BOOM)(1)
HOSE RUPTURE VALVE PIPING (BOOM)(2)
HOSE RUPTURE VALVE PIPING (ARM)(1)
HOSE RUPTURE VALVE PIPING (ARM)(2)
BREAKER, CRUSHER PARTS
MAIN PIPING (BREAKER, CRUSHER)
PILOT PIPING (BREAKER, CRUSHER)
CONTROL PEDAL (BREAKER, CRUSHER)
BREAKER, CRUSHER PIPING (BOOM)
BREAKER, CRUSHER PIPING (ARM)
NPK COMMON PIPING
COMMON PIPING EXCEPT NPK
RELIEF VALVE (CRUSHER)
SOLENOID VALVE (FLOW RATE SELECTOR)
ASSIST PIPING
ADDITIONAL PUMP (1)
ADDITIONAL PUMP (2)
ADDITIONAL GEAR PUMP PARTS
PILOT PIPING (ADDITIONAL GEAR PUMP)
ACCUMULATOR
CONTROL PEDAL (ASSIST PIPING)
ASSIST PIPING (BOOM)
ASSIST PIPING (ARM)
ML-CRANE PARTS
BUCKET LOCK VALVE
ANGLE SENSOR (1)
ANGLE SENSOR (2)
ANGLE SENSOR PARTS
ROTATING BEACON (ML-CRANE)
ETC.
4WAY MULTI-LEVER
4WAY MULTI-LEVER PIPING
AUTOMATIC FUEL FILLING DEVICE (WITH FILTER)
HIGH PERFORMANCE FILTER KIT
TOOLS
TOOLS
GREASE GUN HOLDER
NAME PLATE
NAME PLATE (1)
NAME PLATE (2)
NAME PLATE (3)
NAME PLATE (ML-CRANE)
PARTS INDEX
PARTS INDEX
Brand: Hitachi
List of Files:
Detail Content:
COVER
MEMORANDUM
FOREWORD
CONTENTS
PUMP
PUMP DEVICE
TRANSMISSION (PUMP)
PUMP;UNIT
REGULATOR;PUMP (1)
REGULATOR;PUMP (2)
REGULATOR;PUMP (3)
PUMP;GEAR
MOTOR
SWING DEVICE
T.MISSION (SWING)
MOTOR;OIL (SWING)
TRAVEL DEVICE (1/2)
TRAVEL DEVICE (2/2)
VALVE
VALVE;CONTROL (1/5)
VALVE;CONTROL (2/5)
VALVE;CONTROL (3/5)
VALVE;CONTROL (3/5)
VALVE;CONTROL (4/5)
VALVE;CONTROL (5/5)
BODY
VALVE;SHUTTLE (1/5)
VALVE;SHUTTLE (2/5)
VALVE;SHUTTLE (3/5)
VALVE;SHUTTLE (4/5)
VALVE;SHUTTLE (5/5)
VALVE;SHUTTLE
VALVE;STOP
VALVE;PILOT
VALVE;RELIEF
VALVE;LOCK
VALVE;CHECK
JOINT;CENTER
JOINT;CENTER
CYLINDER
CYL.;BOOM (R)
CYL.;BOOM (L)
CYL.;ARM
VALVE;HOLDING (ARM)
CYL.;BUCKET
PARTS INDEX
COVER
MEMORANDUM
FOREWORD
BUCKET PARTS
FRAME, COVER
FRAME
BOOM FOOT PIN
COUNTERWEIGHT
COVER (1)
DOOR LOCK (1)
COVER (2)
COVER (3)
COVER (4)
COVER (5)
COVER (6)
DOOR (COVER (6))
COVER (COVER (6))
COVER (7)
COVER (8)
ENGINE COVER PARTS
ENGINE COVER (L)
ENGINE COVER (R)
RADIATOR COVER
COVER;UNDER
HANDRAIL
TOOL BOX COVER
TOOL BOX (UPPER)
TOOL BOX (LOWER)
ENGINE
ENGINE
ENGINE SUPPORT
INTERCOOLER PIPING
RADIATOR
RADIATOR SUPPORT
COOLER PIPING (1)
COOLER PIPING (2)
COOLER PARTS (1)
COOLER PARTS (2)
AIR CLEANER
ELEMENT (INNER)
AIR CLEANER SUPPORT
AIR CLEANER PARTS
MUFFLER PARTS
FUEL TANK
FUEL TANK SUPPORT
FUEL PIPING
HYDRAULIC SYSTEM
PUMP DEVICE
PUMP DEVICE SUPPORT
CONTROL VALVE
SWING DEVICE
OIL TANK
OIL TANK SUPPORT
HYDRAULIC PIPING
SUCTION PIPING
DELIVERY PIPING
RETURN PIPING(1)
RETURN PIPING(2)
DRAIN PIPING
MAIN PIPING (1)
MAIN PIPING (2)
MAIN PIPING (3)
MAIN PIPING (4)
BOOM BOTTOM PIPING
SIDE BRANCH PIPING
PILOT PIPING (1)
PILOT PIPING (2)
PILOT PIPING (3)
PILOT PIPING (4)
PILOT PIPING (5)
PILOT PIPING (6)
PILOT PIPING (7)
PILOT PIPING (8)
PILOT PIPING (9)
PILOT PIPING (10)
ELECTRIC SYSTEM
ELECTRIC PARTS (1)
ELECTRIC PARTS (2)
ELECTRIC PARTS (3)
ELECTRIC PARTS (4)
ELECTRIC PARTS (5)
SWITCH BOX
POWER UNIT
POWER CONTROL UNIT
ENGINE CONTROLLER
ENGINE STOP SWITCH
CONTROLLER (MC)
CONTROLLER (HCU)
MONITOR CONTROLLER
HORN
REAR CAMERA
WINDOW WASHER
CAB
CAB (1)
CAB (2)
DOOR
CAB (3)
CAB (4)
CAB (5)
CAB (6)
CAB (7)
LAMP HARNESS (CAB)
CAB GUARD (CEILING)
CAB GROUP (1)
CAB GROUP (2)
CAB MIRROR
ANCHOR BOLT
FLOOR PARTS
PEDAL (R)
PEDAL (L)
LOCK LEVER
CONSOLE
CONSOLE COVER
RIGHT COVER
RADIO (AM/FM)
POWER UNIT (12V)
FLOOR PLATE
FLOOR PARTS (1)
FLOOR PARTS (2)
SEAT (KAB)
HEATER SEAT PARTS
SEAT STAND
STAND PARTS
STAND COVER
FLOOR MAT
FLOOR CARPET
ML-LEVEL
AIR CONDITIONER (1)
AIR CONDITIONER (2)
AIR CONDITIONER (3)
AIR CONDITIONER (4)
CONDENSER UNIT
HEATER PIPING
EXPANSION TANK
UNDERCARRIAGE
TRACK FRAME
TRACK GUARD (X2)
STEP
SWING BEARING
TRAVEL DEVICE
TRACK SPRING
FRONT IDLER
ADJUSTER
UPPER ROLLER
LOWER ROLLER
TRACK LINK
CENTER JOINT
TRAVEL PIPING
TRAVEL MOTOR COVER
BOOM PARTS
ARM 2.91m
ARM PARTS
A LINK
B LINK
FRONT PIPING (BOOM)
FRONT PIPING (ARM)
LUBRICATE PIPING
BOOM CYLINDER (R)
BOOM CYLINDER (L)
ARM CYLINDER
BUCKET CYLINDER
NPK COMMON PIPING
ASSIST PIPING
ADDITIONAL PUMP (1)
ADDITIONAL PUMP (2)
ACCUMULATOR
ASSIST PIPING (ARM)
ML-CRANE PARTS
BUCKET LOCK VALVE
ANGLE SENSOR (1)
ANGLE SENSOR (2)
ANGLE SENSOR PARTS
ETC.
4WAY MULTI-LEVER
TOOLS
TOOLS
GREASE GUN HOLDER
NAME PLATE
NAME PLATE (1)
NAME PLATE (2)
NAME PLATE (3)
PARTS INDEX
PARTS INDEX
- Hitachi EX120-2 Excavator Parts Catalog
- Hitachi EX200-2 Service Manual
- Hitachi Excavator ZX240-3 to ZX250LCK-3 Parts Catalog P1V1-1-1 EN JP
- Hitachi Zaxis 200,225,230 Class Hydraulic Circuit Diagram
- Hitachi EX 750 -5 EX 800 H-5 Full Service Manual
- Hitachi Zaxis 200,225,240,270-3 Service Manual
- Hitachi WIN DR Technical Manual (a PC version Dr.ZX)
- Hitachi ZAXIS ZX330-3 TO ZX350-3 Parts Manual
- Isuzu Industrial Diesel Engine 4JJ1X/4-6HK1X/6WG1X Tier3
- Hitachi Zaxis 200-3 Hydraulic Excavator Technical Manual
- Hitachi Zaxis 70,70LC Hydraulic Circuit Diagram
- Hitachi EX200-3 Excavator Parts Catalog
- Hitachi Hydraulic Excavator ZX50 Technical Manual
- Hitachi ZW 220 - ZW 250 Wheel Loader - Workshop Manual
- Hitachi EX120 Service Manual
