Hitachi Hybrid Excavator ZH200-5A Parts Catalog EN JP
Language: English, Japanese
Brand: Hitachi
Type of Machine: Hybrid Excavator
Model: Hitachi ZH200-5A Hybrid Excavator
Engine: ISUZU 4HK1-XKSA03 Engine
List of Files:
ZH200-5A Eqipment Components Parts Catalog PDFM90-E1-1.pdf (Pages: 119)
ZH200-5A Parts Catalog PDFM90-1-1.pdf (Pages: 365)
ZH200-5A ZX225US-5A Series ISUZU 4HK1-XKSA03 Engine Parts Catalog 4HK1-XKSA03-6.pdf (Pages: 130)
ZH200-5A ZX225US-5A Series ISUZU 4HK1-XKSA03 Engine Parts Catalog 4HK1-XKSA03-7.pdf (Pages: 130)
Detail Content:
COVER
MEMORANDUM
FOREWORD
CONTENTS
PUMP
PUMP DEVICE
T. MISSION (PUMP)
PUMP;UNIT
REGULATOR;PUMP (1)
REGULATOR;PUMP (2)
REGULATOR;PUMP (3)
PUMP;GEAR
MOTOR
SWING DEVICE
T.MISSION (SWING)
MOTOR;OIL (SWING)
TRAVEL DEVICE
MOTOR;OIL (TRAVEL)
VALVE;BRAKE
VALVE;RELIEF
VALVE
VALVE;CONTROL (1/5)
VALVE;CONTROL (2/5)
VALVE;CONTROL (3/5)
VALVE;CONTROL (4/5)
VALVE;CONTROL (5/5)
VALVE;PILOT (FRONT, SWING)
VALVE;PILOT (TRAVEL)
VALVE;SHUTTLE (1/5)
VALVE;SHUTTLE (2/5)
VALVE;SHUTTLE (3/5)
VALVE;SHUTTLE (4/5)
VALVE;SHUTTLE (5/5)
VALVE;SOLENOID (1 SECTION)
VALVE;SOLENOID (2 SECTION)
VALVE;SOLENOID (3 SECTION)
VALVE;SOLENOID (5 SECTION)
VALVE;RELIEF
VALVE;LOCK
JOINT;CENTER
JOINT;CENTER
CYLINDER
CYL.;BOOM (R)
CYL.;BOOM (L)
CYL.;ARM
CYL.;BUCKET
PARTS INDEX
COVER
MEMORANDUM
FOREWORD
ILLUSTRATION CONTENTS
CONTENTS
PRIODIC REPLACEMENT PARTS
FILTER, ELEMENT, BELT PARTS
BUCKET PARTS
FRAME, COVER
FRAME
SWING BEARING SUPPORT (UPPERSTRUCTURE)
BOOM FOOT PIN
CENTER JOINT SUPPORT (UPPERSTRUCTURE)
COUNTERWEIGHT
COUNTERWEIGHT SUPPORT
COVER (1)
DOOR LOCK (1)
COVER (2)
COVER (2)(PRE-CLEANER)
COVER (3)
COVER (4)
COVER (5)
COVER (6)
COVER (7)
COVER (8)
ENGINE COVER
RADIATOR COVER
UNDER COVER
TOOL BOX COVER
TOOL BOX
ANTI SLIP COVER (2)
ANTI SLIP COVER (3)
ANTI SLIP COVER (TOOL BOX)
ANTI SLIP COVER (FUEL TANK)
ENGINE
ENGINE
ENGINE SUPPORT
OIL FILTER PIPING
INTER COOLER PIPING
RADIATOR
RADIATOR SUPPORT
EXPANSION TANK
COOLER PIPING
COOLER PARTS
RADIATOR (COOLER)
AIR CLEANER
ELEMENT (INNER)
AIR CLEANER SUPPORT
AIR CLEANER PARTS
PRE-CLEANER
PRE-CLEANER PARTS
MUFFLER
FUEL TANK
FUEL TANK SUPPORT
FUEL PIPING (WITH WARM UP SYSTEM, WATER SEPARATOR)
HYDRAULIC SYSTEM
PUMP DEVICE
PUMP DEVICE SUPPORT
CONTROL VALVE
CONTROL VALVE SUPPORT
SWING DEVICE
SWING DEVICE SUPPORT
OIL TANK SUPPORT
OIL TANK (WITH INDICATOR)
HYDRAULIC PIPING
SUCTION PIPING
DELIVERY PIPING
RETURN PIPING (1)
RETURN PIPING (2)
DRAIN PIPING
HYDRAULIC PIPING (MAIN)
MAIN PIPING (1)
MAIN PIPING (2)
MAIN PIPING (3)
MAIN PIPING (4)
BOOM BOTTOM PIPING
SIDE BRANCH PIPING
HYDRAULIC PIPING (PILOT)
SOLENOID VALVE (1 SECTION)
SOLENOID VALVE (2 SECTION)
SOLENOID VALVE (3 SECTION)
SOLENOID VALVE (5 SECTION)
PILOT PIPING (1)
PILOT PIPING (2)
PILOT PIPING (3)
PILOT PIPING (4)
PILOT PIPING (5)
PILOT PIPING (6)
PILOT PIPING (7)
PILOT PIPING (8)
PILOT PIPING (9)
PILOT PIPING (10-1)
PILOT PIPING (10-2)
ELECTRIC SYSTEM
ELECTRIC PARTS (1)
ELECTRIC PARTS (BATTERY DISCONNECT SWITCH)
ELECTRIC PARTS (2)
ELECTRIC PARTS (3)
ELECTRIC PARTS (4)
ELECTRIC PARTS (5-1)
SWITCH BOX
ELECTRIC PARTS (5-2)
ELECTRIC PARTS (UNIT)
ELECTRIC PARTS (OIL TANK)
POWER CONTROL UNIT
POWER CONTROL UNIT SUPPORT
CAPACITOR UNIT SUPPORT
START SWITCH
BOOM LIGHT HARNESS
BOOM LIGHT (R)
ENGINE CONTROLLER
ENGINE STOP SWITCH
CONTROLLER (MC)
CONTROLLER (HCU)
MONITOR CONTROLLER
HORN
REAR CAMERA
AUX PARTS
WINDOW WASHER
CAB
CAB (STEEL ROOF)(WITH FRONT GUARD SEAT)(MOBILE COMMUNICATIONS)
CAB (1)
CAB (2)
DOOR
CAB (3)
CAB (4)
CAB (5)
CAB (6)
CAB (7)
LAMP HARNESS (CAB)
CAB GUARD (ON FRONT)
CAB GUARD (UNDER FRONT)
CAB GROUP (1)
CAB GROUP (2)
CAB MIRROR
FIRE EXTINGIUSHER PARTS (CAB)
WITHOUT ANCHOR BOLT PARTS
SUNVISOR (RIGHT WINDOW)
FLOOR PARTS
CONTROL LEVER (FRONT, SWING)
PILOT VALVE (FRONT,SWING)
CONTROL LEVER (TRAVEL)
PILOT VALVE (TRAVEL)
PEDAL (R)
PEDAL (L)
LOCK LEVER
CONSOLE
CONSOLE COVER
RIGHT COVER
RADIO (AM/FM)
REAR BOX
FLOOR PLATE
FLOOR PARTS (1)
FLOOR PARTS (2)
SUSPENSION SEAT PARTS
SUSPENSION SEAT
SEAT STAND
STAND PARTS
STAND COVER
FLOOR MAT
AIR CONDITIONER, HEATER
AIR CONDITIONER (1)
AIR CONDITIONER UNIT
AIR CONDITIONER (2)
AIR CONDITIONER (3)
AIR CONDITIONER (4)
CONDENSER UNIT
COMPRESSOR
HEATER PIPING
DUCT (WITH AIR CONDITIONER)
UNDERCARRIAGE
TRACK FRAME
TRACK GUARD (X2)
STEP
ADDITIONAL STEP
SWING BEARING
SWING BEARING SUPPORT (UNDERCARRIAGE)
TRAVEL DEVICE
TRAVEL DEVICE SUPPORT
TRACK SPRING
FRONT IDLER
ADJUSTER
UPPER ROLLER
LOWER ROLLER
LOWER ROLLER SUPPORT
TRACK LINK (STD TRACK)
TRACK-LINK (LC TRACK)
CENTER JOINT
CENTER JOINT SUPPORT (TRACK)
TRAVEL PIPING
TRAVEL PIPING (LC)
TRAVEL MOTOR COVER
FRONT-END ATTACHMENTS
H-BOOM 5.68m
BOOM PARTS
ARM 2.91m
ARM PARTS
A LINK
B LINK
BUCKET 0.91m3 (JIS94)(REINFORCEMET)
BUCKET 1.1m3 (JIS 94)(REINFORCEMENT)
FRONT PIPING (BOOM)
FRONT PIPING (ARM)
LUBRICATE PIPING
BOOM CYLINDER (R)
BOOM CYLINDER (L)
ARM CYLINDER
BUCKET CYLINDER
ETC.
GREASE GUN HOLDER
TOOLS
TOOLS
NAME PLATE
NAME PLATE (1)
NAME PLATE (2)
NAME PLATE (3)
PARTS INDEX
COVER
MEMORANDUM
FOREWORD
CONTENTS
ENGINE
005: ENGINE GASKET KIT (1/2)
005: ENGINE GASKET KIT (2/2)
010: CYLINDER HEAD COVER
011: CYLINDER HEAD (1/2)
011: CYLINDER HEAD (2/2)
012: CYLINDER BLOCK (1/2)
012: CYLINDER BLOCK (2/2)
013: OIL PAN AND LEVEL GAUGE
014: CAMSHAFT AND VALVE (1/2)
014: CAMSHAFT AND VALVE (2/2)
015: CRANKSHAFT,PISTON ANDFLYWHEEL (1/2)
015: CRANKSHAFT,PISTON ANDFLYWHEEL (2/2)
020: TIMING GEAR CASE AND FLYWHEELHOUSING (1/2)
020: TIMING GEAR CASE AND FLYWHEELHOUSING (2/2)
025: INLET MANIFOLD
027: EXHAUST MANIFOLD
028: VENTILATION SYSTEM
030: WATER PUMP AND CORROSIONRESISTOR
031: THERMOSTAT AND HOUSING (1/2)
031: THERMOSTAT AND HOUSING (2/2)
032: WATER PIPING; ENGINE
033: FAN AND FAN BELT (1/2)
033: FAN AND FAN BELT (2/2)
036: TURBOCHARGER SYSTEM (1/2)
036: TURBOCHARGER SYSTEM (2/2)
040: FUEL INJECTION SYSTEM (1/3)
040: FUEL INJECTION SYSTEM (2/3)
040: FUEL INJECTION SYSTEM (3/3)
041: FUEL FILTER AND BRACKET
042: FUEL PUMP AND PIPE
050: OIL COOLER AND OIL FILTER (1/2)
050: OIL COOLER AND OIL FILTER (2/2)
051: OIL PUMP AND OIL STRAINER
052: OIL AND VACUUM PIPING; ENGINE
057: EMISSION PIPING
060: ENGINE ELECTRICAL CONTROLPARTS (1/2)
060: ENGINE ELECTRICAL CONTROLPARTS (2/2)
065: STARTER
066: GENERATOR
086: MISCELLANEOUS PARTS; INJECTIONPUMP
110: RADIATOR
220: MANUAL TRANSMISSION ASM ANDCASE
810: WIRING HARNESS AND FUSE
815: FIXING PARTS; WIRING HARNESS
825: SWITCH AND RELAY; INSTRUMENTPANEL
826: ELECTRICAL CONTROL AND OTHERPARTS
PARTS INDEX
COVER
MEMORANDUM
FOREWORD
CONTENTS
ENGINE
020: TIMING GEAR CASE ANDFLYWHEEL HOUSING (1/2)
020: TIMING GEAR CASE ANDFLYWHEEL HOUSING (2/2)
025: INLET MANIFOLD
065: STARTER
066: GENERATOR
086: MISCELLANEOUS PARTS;INJECTION PUMP
110: RADIATOR
220: MANUAL TRANSMISSION ASMAND CASE
825: SWITCH AND RELAY;INSTRUMENT PANEL
826: ELECTRICAL CONTROL ANDOTHER PARTS
PARTS INDEX
Brand: Hitachi
List of Files:
Detail Content:
COVER
MEMORANDUM
FOREWORD
CONTENTS
PUMP
PUMP DEVICE
T. MISSION (PUMP)
PUMP;UNIT
REGULATOR;PUMP (1)
REGULATOR;PUMP (2)
REGULATOR;PUMP (3)
PUMP;GEAR
MOTOR
SWING DEVICE
T.MISSION (SWING)
MOTOR;OIL (SWING)
TRAVEL DEVICE
MOTOR;OIL (TRAVEL)
VALVE;BRAKE
VALVE;RELIEF
VALVE
VALVE;CONTROL (1/5)
VALVE;CONTROL (2/5)
VALVE;CONTROL (3/5)
VALVE;CONTROL (4/5)
VALVE;CONTROL (5/5)
VALVE;SHUTTLE (1/5)
VALVE;SHUTTLE (2/5)
VALVE;SHUTTLE (3/5)
VALVE;SHUTTLE (4/5)
VALVE;SHUTTLE (5/5)
VALVE;RELIEF
VALVE;LOCK
JOINT;CENTER
JOINT;CENTER
CYLINDER
CYL.;BOOM (R)
CYL.;BOOM (L)
CYL.;ARM
CYL.;BUCKET
PARTS INDEX
COVER
MEMORANDUM
FOREWORD
CONTENTS
BUCKET PARTS
FRAME, COVER
FRAME
BOOM FOOT PIN
COUNTERWEIGHT
COVER (1)
DOOR LOCK (1)
COVER (2)
COVER (3)
COVER (4)
COVER (5)
COVER (6)
COVER (7)
COVER (8)
ENGINE COVER
RADIATOR COVER
UNDER COVER
TOOL BOX COVER
TOOL BOX
ANTI SLIP COVER (2)
ANTI SLIP COVER (3)
ENGINE
ENGINE
ENGINE SUPPORT
OIL FILTER PIPING
INTER COOLER PIPING
RADIATOR
RADIATOR SUPPORT
EXPANSION TANK
COOLER PIPING
COOLER PARTS
RADIATOR (COOLER)
AIR CLEANER
ELEMENT (INNER)
AIR CLEANER SUPPORT
AIR CLEANER PARTS
PRE-CLEANER
PRE-CLEANER PARTS
MUFFLER
FUEL TANK
FUEL TANK SUPPORT
HYDRAULIC SYSTEM
PUMP DEVICE
PUMP DEVICE SUPPORT
CONTROL VALVE
SWING DEVICE
OIL TANK SUPPORT
HYDRAULIC PIPING
SUCTION PIPING
DELIVERY PIPING
RETURN PIPING (1)
RETURN PIPING (2)
DRAIN PIPING
MAIN PIPING (1)
MAIN PIPING (2)
MAIN PIPING (3)
MAIN PIPING (4)
BOOM BOTTOM PIPING
SIDE BRANCH PIPING
PILOT PIPING (1)
PILOT PIPING (2)
PILOT PIPING (3)
PILOT PIPING (4)
PILOT PIPING (5)
PILOT PIPING (6)
PILOT PIPING (7)
PILOT PIPING (8)
PILOT PIPING (9)
PILOT PIPING (10-1)
PILOT PIPING (10-2)
ELECTRIC SYSTEM
ELECTRIC PARTS (1)
ELECTRIC PARTS (2)
ELECTRIC PARTS (3)
ELECTRIC PARTS (4)
SWITCH BOX
POWER CONTROL UNIT
START SWITCH
BOOM LIGHT HARNESS
BOOM LIGHT (R)
ENGINE CONTROLLER
ENGINE STOP SWITCH
CONTROLLER (MC)
CONTROLLER (HCU)
MONITOR CONTROLLER
HORN
REAR CAMERA
AUX PARTS
WINDOW WASHER
CAB
CAB (1)
CAB (2)
DOOR
CAB (3)
CAB (4)
CAB (5)
CAB (6)
CAB (7)
LAMP HARNESS (CAB)
CAB GROUP (1)
CAB GROUP (2)
CAB MIRROR
FLOOR PARTS
PEDAL (R)
PEDAL (L)
LOCK LEVER
CONSOLE
CONSOLE COVER
RIGHT COVER
RADIO (AM/FM)
REAR BOX
FLOOR PLATE
FLOOR PARTS (1)
FLOOR PARTS (2)
SUSPENSION SEAT
SEAT STAND
STAND PARTS
STAND COVER
FLOOR MAT
AIR CONDITIONER (1)
AIR CONDITIONER (2)
AIR CONDITIONER (3)
AIR CONDITIONER (4)
CONDENSER UNIT
COMPRESSOR
HEATER PIPING
UNDERCARRIAGE
TRACK FRAME
TRACK GUARD (X2)
STEP
ADDITIONAL STEP
SWING BEARING
TRAVEL DEVICE
TRACK SPRING
FRONT IDLER
ADJUSTER
UPPER ROLLER
LOWER ROLLER
CENTER JOINT
TRAVEL PIPING
TRAVEL PIPING (LC)
TRAVEL MOTOR COVER
H-BOOM 5.68m
BOOM PARTS
ARM 2.91m
ARM PARTS
A LINK
B LINK
FRONT PIPING (BOOM)
FRONT PIPING (ARM)
LUBRICATE PIPING
BOOM CYLINDER (R)
BOOM CYLINDER (L)
ARM CYLINDER
BUCKET CYLINDER
ETC.
GREASE GUN HOLDER
TOOLS
TOOLS
NAME PLATE
NAME PLATE (1)
NAME PLATE (2)
NAME PLATE (3)
PARTS INDEX
COVER
MEMORANDUM
FOREWORD
CONTENTS
ENGINE
025: INLET MANIFOLD
065: STARTER
066: GENERATOR
110: RADIATOR
PARTS INDEX
COVER
MEMORANDUM
FOREWORD
CONTENTS
ENGINE
025: INLET MANIFOLD
065: STARTER
066: GENERATOR
110: RADIATOR
PARTS INDEX
- Hitachi EX120-2 Excavator Parts Catalog
- Hitachi EX200-2 Service Manual
- Hitachi Excavator ZX240-3 to ZX250LCK-3 Parts Catalog P1V1-1-1 EN JP
- Hitachi Zaxis 200,225,230 Class Hydraulic Circuit Diagram
- Hitachi EX 750 -5 EX 800 H-5 Full Service Manual
- Hitachi Zaxis 200,225,240,270-3 Service Manual
- Hitachi WIN DR Technical Manual (a PC version Dr.ZX)
- Hitachi ZAXIS ZX330-3 TO ZX350-3 Parts Manual
- Isuzu Industrial Diesel Engine 4JJ1X/4-6HK1X/6WG1X Tier3
- Hitachi Zaxis 200-3 Hydraulic Excavator Technical Manual
- Hitachi Zaxis 70,70LC Hydraulic Circuit Diagram
- Hitachi EX200-3 Excavator Parts Catalog
- Hitachi Hydraulic Excavator ZX50 Technical Manual
- Hitachi ZW 220 - ZW 250 Wheel Loader - Workshop Manual
- Hitachi EX120 Service Manual
