Hitachi Hybrid Excavator ZH120-6 Parts Catalog EN JP
Language: English, Japanese
Brand: Hitachi
Type of Machine: Excavator
Model: Hitachi ZH120-6 Hybrid Excavator
List of Files:
ZH120-6 Eqipment Components Parts Catalog PDA1A0-E1-1.pdf (Pages: 207)
ZH120-6 Parts Catalog PDA1A0-1-2.pdf (Pages: 580)
Detail Content:
COVER
MEMORANDUM
FOREWORD
CONTENTS
PUMP
PUMP DEVICE (WITHOUT BLADE)
PUMP;UNIT
REGULATOR;PUMP (1)
REGULATOR;PUMP (2)
PUMP;GEAR
PUMP DEVICE (WITH BLADE)
REGULATOR;PUMP (1)
REGULATOR;PUMP (2)
PUMP;GEAR
PUMP DEVICE (WITH ADDITIONAL PUMP)
PUMP;GEAR
MOTOR
SWING DEVICE
TRANSMISSION (SWING)
MOTOR;OIL (SWING)
VALVE;BRAKE
TRAVEL DEVICE
MOTOR;OIL (TRAVEL)
VALVE;BRAKE
VALVE;RELIEF
VALVE
VALVE;CONTROL (1/7)
VALVE;CONTROL (2/7)
VALVE;CONTROL (3/7)
VALVE;CONTROL (4/7)
VALVE;CONTROL (5/7)
VALVE;CONTROL (6/7)
VALVE;CONTROL (7/7)
VALVE;CONTROL (1/2)
VALVE;CONTROL (2/2)
VALVE;CONTROL (BLADE,PTO)
VALVE;CONTROL (ADDITIONAL PUMP)(CLOSE)
VALVE;CONTROL (ADDITIONAL PUMP)(OPEN)
VALVE;PILOT (FRONT, SWING)
VALVE;PILOT (TRAVEL)
VALVE;PILOT (AUX.)
VALVE;SOLENOID
VALVE;SOLENOID (1 SECTION)
VALVE;SOLENOID
VALVE;SOLENOID (BLEAKER, CRUSHER)
VALVE;SOLENOID (FLOW RATE SELECTOR)
VALVE;SOLENOID (BUCKET LOCK)
VALVE;SOLENOID
VALVE;SOLENOID
VALVE;SOLENOID
VALVE;SHUTTLE (1/5)
VALVE;SHUTTLE (2/5)
VALVE;SHUTTLE (3/5)
VALVE;SHUTTLE (4/5)
VALVE;SHUTTLE (5/5)
VALVE;SHUTTLE
VALVE;SHUTTLE
VALVE;SHUTTLE
VALVE;LOCK
VALVE;SELECTOR (3 WAY VALVE)
VALVE;SELECTOR
VALVE;RELIEF
VALVE;RELIEF
VALVE;CHECK
VALVE;STOP
VALVE
JOINT;CENTER
JOINT;CENTER (WITHOUT BLADE)
JOINT;CENTER (WITH BLADE)
CYLINDER
CYL.;BOOM (R)
CYL.;BOOM (R)(WITH HOSE RUPTURE VALVE)(MONO-BOOM)
VALVE;HOLDING (R)(MONO-BOOM)
CYL.;BOOM (L)
CYL.;BOOM (L)(WITH HOSE RUPTURE VALVE)(ML-CRANE)
VALVE;HOLDING (L)(BOOM)
CYL.;ARM (WITH HOSE RUPTURE VALVE)(MONO-BOOM)
VALVE;HOLDING (ARM)
CYL.;ARM (MONO-BOOM)
CYL.;BUCKET
CYL.;BLADE (R)
CYL.;BLADE (L)
PARTS INDEX
COVER
MEMORANDUM
FOREWORD
ILLUSUTRATION CONTENTS
CONTENTS
PERIODIC REPLACEMENT PARTS
FILTER, ELEMENT, BELT PARTS
BUCKET PARTS
FRAME, COVER
FRAME
SWING BEARING PARTS (UPPERSTRUCTURE)
BOOM FOOT PIN (ML-CRANE)
CENTER JOINT PARTS (UPPERSTRUCTURE)(WITHOUT BLADE)
CENTER JOINT PARTS (UPPERSTRUCTURE)(WITH BLADE)
COUNTERWEIGHT (2.4t)
COUNTERWEIGHT (2.6t)
COVER (1)
COVER (2)
DOOR LOCK (1)
COVER (3)
COVER (4)
COVER (5)
ENGINE COVER
DOOR LOCK (2)
RADIATOR COVER
UNDER COVER
UNDER COVER (t=6mm)
TOOL BOX COVER
TOOL BOX COVER (FOR SIDE CAMERA)
TOOL BOX COVER (FOR PERIPHERAL ENVIROMENT VISUAL RECOGNITION DEVICE)
ANTI SLIP COVER (TOOL BOX)
ANTI SLIP COVER (FUEL TANK)
HANDRAIL
HANDRAIL
ENGINE
ENGINE
ENGINE SUPPORT
INTERCOOLER PIPING
RADIATOR
RADIATOR SUPPORT
EXPANSION TANK
AIR CLEANER (WITHOUT PRE-CREANER)
AIR CREANER (WITH PRE-CREANER)
ELEMENT (INNER)
PRE-CLEANER
AIR CLEANER SUPPORT
MUFFLER PARTS
FUEL TANK
FUEL TANK SUPPORT
FUEL PIPING (WITH WARM UP SYSTEM, WATER SEPARATOR)
HYDRAULIC SYSTEM
PUMP DEVICE (WITH ADDITIONAL GEAR PUMP)
PUMP DEVICE SUPPORT
CONTROL VALVE
CONTROL VALVE SUPPORT
SWING DEVICE
SWING DEVICE SUPPORT
OIL TANK
OIL TANK SUPPORT
ACCUMULATOR
ACCUMULATOR PARTS
PUMP PIPING
HYDRAULIC PIPING
SUCTION PIPING
DELIVERY PIPING
RETURN PIPING (1)
RETURN PIPING (2)
RETURN PIPING (WITH BLADE)
DRAIN PIPING
HYDRAULIC PIPING (MAIN)
MAIN PIPING (1)
MAIN PIPING (2)
MAIN PIPING (3)
MAIN PIPING (4)
MAIN PIPING (5)
MAIN PIPING (WITH BLADE)(1)
MAIN PIPING (WITH BLADE)(2)
BOOM BOTTOM PIPING
SIDE BRANCH PIPING
HYDRAULIC PIPING (PILOT)
SOLENOID VALVE (1 SECTION)
SOLENOID VALVE (5 SECTION)
PILOT PIPING (1)
PILOT PIPING (2)
PILOT PIPING (3)
PILOT PIPING (4)
PILOT PIPING (5)
PILOT PIPING (6)
PILOT PIPING (7)
PILOT PIPING (8)
PILOT PIPING (9)
PILOT PIPING (10)
PILOT PIPING (WITH BLADE)(1)
PILOT PIPING (WITH BLADE)(2)
ELECTRIC SYSTEM
ELECTRIC PARTS (1)
ELECTRIC PARTS (2)
ELECTRIC PARTS (2)(LED)
ELECTRIC PARTS (3)
ELECTRIC PARTS (4)
ELECTRIC PARTS (5-1)
ELECTRIC PARTS (5-2)
START SWITCH
START SWITCH (NS KEY)
KEY (IMMOBILIZER)
DATA CONVERTER PARTS
BOOM LIGHT HARNESS
BOOM LIGHT (R)(WITH LIGHT COVER)
BOOM LIGHT(RIGHT)(WITH LIGHT COVER)(LED)
ENGINE CONTROL UNIT
ENGINE STOP SWITCH
AERIAL ANGLE CONTROL UNIT
AERIAL ANGLE SWITCH
AERIAL ANGLE PARTS
MOBILE COMMUNICATIONS TERMINAL
SATELLITE COMMUNICATIONS TERMINAL
CONTROLLER (MC)
MONITOR CONTROLLER
FRONT HEAD LAMP PARTS (2 LAMP)(FLOOR)
FRONT HEAD LAMP PARTS (4 LAMP)(FLOOR)
FRONT HEAD LAMP (2 LAMP WITH RAIN GUARD UPPER)
FRONT HEAD LAMP (2 LAMP WITH RAIN GUARD UNDER)
FRONT HEAD LAMP (4 LAMP WITH RAIN GUARD UPPER)
FRONT HEAD LAMP (4 LAMP WITH RAIN GUARD UNDER)
REAR HEAD LAMP (CAB)
REAR HEAD LAMP PARTS (FLOOR)
PERIPHERAL BEACON PARTS (FLOOR)
PERIPHERAL BEACON SWITCH (LED)
HORN
REAR CAMERA
AUX PARTS
WINDOW WASHER (FRONT WINDOW)
SIDE CAMERA MONITOR
SIDE CAMERA PARTS
USB PORT
CAB
CAB (STEEL ROOF)(WITH FRONT GUARD SEAT)(MOBILE COMMUNICATIONS)
CAB (1)
CAB (2)
DOOR
CAB (3)
CAB (4)
CAB (5)
CAB (5)(LAMINATED GLASS)
CAB (6)
CAB (7)
LAMP HARNESS
CAB (STEEL ROOF)(WITH FRONT GUARD SEAT)(SATELLITE COMMUNICATIONS)
ANTENNA (SATELLITE COMMUNICATIONS)
CAB GUARD (CEILING)(OPG LEVEL Ⅰ TOP)
SUNVISOR
HANDRAIL (CAB)
HANDRAIL (CAB)(WITH REAR LAMP BRACKET)
CAB GROUP (1)
CAB GROUP (2)
ANCHOR BOLT
CAB MIRROR
RAIN GUARD
FRONT HEAD LAMP, RAIN GUARD SUPPORT
FLOOR PARTS
AFL (AUXILIARY FUNCTION LEVER)(2Ch)(FRONT, SWING)
AFL (AUX. FUNCTION LEVER)(2Ch)PARTS
CONTROL LEVER (FRONT, SWING)(WITH TRIPLE SWITCH)
PILOT VALVE (FRONT, SWING)
CONTROL LEVER (TRAVEL)
PILOT VALVE (TRAVEL)
PEDAL (R)
PEDAL (L)
LOCK LEVER
CONSOLE
CONSOLE COVER (WITHOUT BLADE)
CONSOLE COVER (WITH BLADE)
BLADE CONTROL
RIGHT COVER
RADIO (AM/FM)
REAR BOX (12V POWER SUPPLY)
POWER UNIT (12V)
FLOOR PLATE
FLOOR PARTS (1)
FLOOR PARTS (2)
SUSPENSION SEAT (KAB)
SUSPENSION SEAT PARTS (KAB)
SUSPENSION SEAT PARTS (WITH HEATER)(KAB)
SUSPENSION SEAT (WITH HEATER)(KAB)
RIGID SEAT PARTS (KAB)
SEAT (KAB)
HEATER SEAT PARTS
SEAT STAND
STAND PARTS
STAND COVER (SUSPENSION SEAT PARTS)
STAND COVER (RIGID SEAT)
FLOOR MAT
AIR CONDITIONER, HEATER
AIR CONDITIONER (1)
AIR CONDITIONER UNIT
AIR CONDITIONER (2)
AIR-CONDITIONER (3)
AIR CONDITIONER (4)
CONDENSER UNIT
HEATER PIPING
DUCT (WITH AIR CONDITIONER)
UNDERCARRIAGE
TRACK FRAME (WITHOUT BLADE)
TRACK FRAME (WITHOUT BLADE)(WITH SEAT FOR UNDER COVER)
TRACK FRAME (WITH BLADE)
TRACK GUARD (X2)
TRACK GUARD (X4)
STEP
ADDITIONAL STEP
TRACK UNDER COVER
SWING BEARING
SWING BEARING PARTS
TRAVEL DEVICE
TRAVEL DEVICE SUPPORT
FRONT IDLER
ADJUSTER
UPPER ROLLER
LOWER ROLLER
LOWER ROLLER SUPPORT
TRACK-LINK
PAD CRAWLER B500mm (SEPARATE TYPE)
RUBBER PAD (CITY PAD)
RUBBER PAD (MT PAD)
CENTER JOINT (WITHOUT BLADE)
CENTER JOINT (WITH BLADE)
CENTER JOINT SUPPORT (TRACK)
BLADE PIPING
TRAVEL PIPING
TRAVEL MOTOR COVER
BLADE (BOLT ON CUTTING-EDGE)
WIDE BLADE (BOLT ON CUTTING-EDGE)
FRONT-END ATTACHMENTS
(MONO BOOM)
BOOM 4.60m (WITH FRONT PIPING, BOOM RIGHT SIDE LIGHT, HOSE RUPTURE VALVE, ML CRANE SEAT
BOOM 4.60m (WITH BREAKER, BOOM RIGHT SIDE LIGHT, HOSE RUPTURE, ML CLANE SEAT)
BOOM 4.60m (WITH ML-CRANE, BOOM RIGHT SIDE LIGHT SEAT)
BOOM PARTS (BOOM)
ARM 2.52m (WITH ML-CRANE SEAT)
ARM 2.52m (WITH BREAKER, CRUSHER, ML-CRANE, ASSIST PIPING SEAT)
K-ARM 2.52m (WITH BREAKER, CRUSHER, ML-CRANE, ASSIST PIPING SEAT)
ARM 3.01m
ARM 3.01m (WITH BREAKER, CRUSHER, ML-CRANE, ASSIST PIPING SEAT)
ARM PARTS (2.52m)
ARM PARTS (3.01m)
A LINK
A LINK (WITH HOOK)
B LINK
B LINK (HEAVY DUTY TYPE)
BUCKET 0.45m3 (JIS 94)
BUCKET 0.5m3 (JIS94)
BUCKET 0.50m3 (JIS 94)(REINFORCEMENT)
K BUCKET 0.50m3 (JIS 94)
BUCKET 0.5m3 (JIS 94)(WITH HOOK)
BUCKET 0.5m3 (JIS 94)(WITH HOOK)(REINFORCEMENT)
BUCKET 0.59m3 (JIS94)
FRONT PIPING (BOOM)
FRONT PIPING (ARM 2.52m)
FRONT PIPING (ARM 3.01m)
LUBRICATE PIPING (BOOM)
BOOM CYLINDER (R)(BOOM)
BOOM CYLINDER (R)(WITH HOSE RUPTURE VALVE)
BOOM CYLINDER (L)(BOOM)
BOOM CYLINDER (L)(WITH HOSE RUPTURE VALVE)
ARM CYLINDER (BOOM)
ARM CYLINDER (WITH HOSE RUPTURE VALVE)
BUCKET CYLINDER
HOSE RUPTURE VALVE PIPING (BOOM)(1)
HOSE RUPTURE VALVE PIPING (BOOM)(2)
HOSE RUPTURE VALVE PIPING (ARM)(1)
HOSE RUPTURE VALVE (ARM)(2)
BREAKER, CRUSHER PARTS
BREAKER, CRUSHER PIPING (MAIN)
BREAKER, CRUSHER PIPING (PILOT)
CONTROL PEDAL (BREAKER, CRUSHER)
FLOOR MAT (BREAKER)
FLOOR MAT (BREAKER+ASSIST PIPING)
BREAKER, CRUSHER PIPING (BOOM)
BREAKER, CRUSHER PIPING (ARM 2.52m)
BREAKER, CRUSHER PIPING (ARM 3.01m)
HSB COMMON PIPING
COMMON PIPING EXCEPT NPK (BOOM)
RELIEF VALVE (CRUSHER)
SOLENOID VALVE (FLOW RATE SELECTOR)
PILOT PIPING (FLOW RATE SELECTOR)
PLUG (WITHOUT BREAKER PIPING PARTS)
ASSIST PIPING
ADD. GEAR PUMP (30L)
ADDTIONAL GEAR PUMP PARTS
PILOT PIPING (ADDITIONAL GEAR PUMP)
ACCUMULATOR
PILOT PIPING (ANALOG FUNCTION LEVER)
ELECTRIC TYPE CONTROL PARTS (AFL (AUXILIARY FUNCTION LEVER), ADDITIONAL PUMP)
ELECTRIC CONTROL PARTS (1)
ELECTRIC CONTROL PARTS (2)
ASSIST PIPING (BOOM)
ASSIST PIPING (ARM 2.52m)
ASSIST PIPING (ARM 3.01m)
ML-CRANE PARTS
BOOM PARTS (ML-CRANE)
BUCKET LOCK VALVE
ROTATING BEACON (ML-CRANE)
ANGLE SENSOR (1)
ANGLE SENSOR (2)
HOSE RUPTURE VALVE PIPING (2)(BOOM)(ML-CRANE)
ML-LINK
LINK
ML-LEVEL
ETC.
4WAY MULTI-LEVER
4WAY MULTI-LEVER PIPING
TOOLS
TOOLS
NAME PLATE
NAME PLATE (1)
NAME PLATE (2)
NAME-PLATE (3)
NAME PLATE (ML-CRANE)
PARTS INDEX
PARTS INDEX
Brand: Hitachi
List of Files:
Detail Content:
COVER
MEMORANDUM
FOREWORD
CONTENTS
PUMP
PUMP;UNIT
REGULATOR;PUMP (1)
REGULATOR;PUMP (2)
PUMP;GEAR
REGULATOR;PUMP (1)
REGULATOR;PUMP (2)
PUMP;GEAR
PUMP;GEAR
MOTOR
SWING DEVICE
MOTOR;OIL (SWING)
VALVE;BRAKE
TRAVEL DEVICE
MOTOR;OIL (TRAVEL)
VALVE;BRAKE
VALVE;RELIEF
VALVE
VALVE;CONTROL (1/7)
VALVE;CONTROL (2/7)
VALVE;CONTROL (3/7)
VALVE;CONTROL (4/7)
VALVE;CONTROL (5/7)
VALVE;CONTROL (6/7)
VALVE;CONTROL (7/7)
VALVE;CONTROL (1/2)
VALVE;CONTROL (2/2)
VALVE;PILOT (AUX.)
VALVE;SOLENOID
VALVE;SOLENOID
VALVE;SOLENOID
VALVE;SOLENOID
VALVE;SOLENOID
VALVE;SHUTTLE (1/5)
VALVE;SHUTTLE (2/5)
VALVE;SHUTTLE (3/5)
VALVE;SHUTTLE (4/5)
VALVE;SHUTTLE (5/5)
VALVE;SHUTTLE
VALVE;SHUTTLE
VALVE;SHUTTLE
VALVE;LOCK
VALVE;SELECTOR
VALVE;RELIEF
VALVE;RELIEF
VALVE;CHECK
VALVE;STOP
VALVE
JOINT;CENTER
CYLINDER
CYL.;BOOM (R)
CYL.;BOOM (L)
VALVE;HOLDING (ARM)
CYL.;BUCKET
CYL.;BLADE (R)
CYL.;BLADE (L)
PARTS INDEX
COVER
MEMORANDUM
FOREWORD
CONTENTS
BUCKET PARTS
FRAME, COVER
FRAME
COVER (1)
COVER (2)
DOOR LOCK (1)
COVER (3)
COVER (4)
COVER (5)
ENGINE COVER
DOOR LOCK (2)
RADIATOR COVER
UNDER COVER
UNDER COVER (t=6mm)
TOOL BOX COVER
HANDRAIL
HANDRAIL
ENGINE
ENGINE
ENGINE SUPPORT
INTERCOOLER PIPING
RADIATOR
RADIATOR SUPPORT
EXPANSION TANK
ELEMENT (INNER)
PRE-CLEANER
AIR CLEANER SUPPORT
MUFFLER PARTS
FUEL TANK
FUEL TANK SUPPORT
HYDRAULIC SYSTEM
PUMP DEVICE SUPPORT
CONTROL VALVE
SWING DEVICE
OIL TANK
OIL TANK SUPPORT
ACCUMULATOR
ACCUMULATOR PARTS
PUMP PIPING
HYDRAULIC PIPING
SUCTION PIPING
DELIVERY PIPING
RETURN PIPING (1)
RETURN PIPING (2)
DRAIN PIPING
MAIN PIPING (1)
MAIN PIPING (2)
MAIN PIPING (3)
MAIN PIPING (4)
MAIN PIPING (5)
BOOM BOTTOM PIPING
SIDE BRANCH PIPING
PILOT PIPING (1)
PILOT PIPING (2)
PILOT PIPING (3)
PILOT PIPING (4)
PILOT PIPING (5)
PILOT PIPING (6)
PILOT PIPING (7)
PILOT PIPING (8)
PILOT PIPING (9)
PILOT PIPING (10)
ELECTRIC SYSTEM
ELECTRIC PARTS (1)
ELECTRIC PARTS (2)
ELECTRIC PARTS (3)
ELECTRIC PARTS (4)
START SWITCH
KEY (IMMOBILIZER)
BOOM LIGHT HARNESS
ENGINE CONTROL UNIT
ENGINE STOP SWITCH
AERIAL ANGLE SWITCH
AERIAL ANGLE PARTS
CONTROLLER (MC)
MONITOR CONTROLLER
HORN
REAR CAMERA
AUX PARTS
SIDE CAMERA MONITOR
SIDE CAMERA PARTS
USB PORT
CAB
CAB (1)
CAB (2)
DOOR
CAB (3)
CAB (4)
CAB (5)
CAB (6)
CAB (7)
LAMP HARNESS
SUNVISOR
HANDRAIL (CAB)
CAB GROUP (1)
CAB GROUP (2)
ANCHOR BOLT
CAB MIRROR
RAIN GUARD
FLOOR PARTS
PEDAL (R)
PEDAL (L)
LOCK LEVER
CONSOLE
BLADE CONTROL
RIGHT COVER
RADIO (AM/FM)
POWER UNIT (12V)
FLOOR PLATE
FLOOR PARTS (1)
FLOOR PARTS (2)
SEAT (KAB)
HEATER SEAT PARTS
SEAT STAND
STAND PARTS
FLOOR MAT
AIR CONDITIONER (1)
AIR CONDITIONER (2)
AIR-CONDITIONER (3)
AIR CONDITIONER (4)
CONDENSER UNIT
HEATER PIPING
UNDERCARRIAGE
TRACK GUARD (X2)
TRACK GUARD (X4)
STEP
ADDITIONAL STEP
TRACK UNDER COVER
SWING BEARING
SWING BEARING PARTS
TRAVEL DEVICE
FRONT IDLER
ADJUSTER
UPPER ROLLER
LOWER ROLLER
TRACK-LINK
RUBBER PAD (MT PAD)
BLADE PIPING
TRAVEL PIPING
TRAVEL MOTOR COVER
(MONO BOOM)
BOOM PARTS (BOOM)
ARM 3.01m
ARM PARTS (2.52m)
ARM PARTS (3.01m)
A LINK
A LINK (WITH HOOK)
B LINK
FRONT PIPING (BOOM)
ARM CYLINDER (BOOM)
BUCKET CYLINDER
FLOOR MAT (BREAKER)
HSB COMMON PIPING
ASSIST PIPING
ACCUMULATOR
ML-CRANE PARTS
BUCKET LOCK VALVE
ANGLE SENSOR (1)
ANGLE SENSOR (2)
ML-LINK
LINK
ML-LEVEL
ETC.
4WAY MULTI-LEVER
TOOLS
TOOLS
NAME PLATE
NAME PLATE (1)
NAME PLATE (2)
NAME-PLATE (3)
PARTS INDEX
PARTS INDEX
- Hitachi EX120-2 Excavator Parts Catalog
- Hitachi EX200-2 Service Manual
- Hitachi Excavator ZX240-3 to ZX250LCK-3 Parts Catalog P1V1-1-1 EN JP
- Hitachi Zaxis 200,225,230 Class Hydraulic Circuit Diagram
- Hitachi EX 750 -5 EX 800 H-5 Full Service Manual
- Hitachi Zaxis 200,225,240,270-3 Service Manual
- Hitachi WIN DR Technical Manual (a PC version Dr.ZX)
- Hitachi ZAXIS ZX330-3 TO ZX350-3 Parts Manual
- Isuzu Industrial Diesel Engine 4JJ1X/4-6HK1X/6WG1X Tier3
- Hitachi Zaxis 200-3 Hydraulic Excavator Technical Manual
- Hitachi Zaxis 70,70LC Hydraulic Circuit Diagram
- Hitachi EX200-3 Excavator Parts Catalog
- Hitachi Hydraulic Excavator ZX50 Technical Manual
- Hitachi ZW 220 - ZW 250 Wheel Loader - Workshop Manual
- Hitachi EX120 Service Manual
