Hitachi Excavators ZX85USB-6 Parts Catalog
Language: English, Janpanese
Brand: Hitachi
Type of Machine: Excavators
Type of Manual: Parts Catalog, Components Parts Catalog, Engine Parts Catalog
Model: Hitachi ZX85USB-6 Excavators
List of Files:
ZX85USB-6 Parts Catalog PDER50-1-2.pdf
COVER
MEMORANDUM
FOREWORD
ILLUSTRATION CONTENTS
CONTENTS
PERIODIC REPLACEMENT PARTS
FILTER, ELEMENT, BELT PARTS
BUCKET PARTS
FRAME,COVER
FRAME
FRAME (2P-BOOM)
SWING POST
COUNTERWEIGHT
ADDITIONAL COUNTERWEIGHT
COUNTERWEIGHT PARTS
COVER (1)
COVER (2)
COVER (3)
MIRROR
COVER (4)
COVER (5)
COVER (6)
ENGINE COVER
RADIATOR COVER
UNDER COVER
ENGINE
ENGINE
ENGINE SUPPORT
RADIATOR
RESERVE TANK
AIR CLEANER PARTS
ELEMENT (INNER)
MUFFLER
FUEL TANK
FUEL FEED PUMP
FUEL PIPING
OIL FILTER PIPING
HYDRAULIC SYSTEM
PUMP DEVICE
PUMP DEVICE SUPPORT
CONTROL VALVE
CONTROL VALVE SUPPORT
SWING DEVICE
SWING DEVICE SUPPORT
OIL TANK (WITH INDICATOR)
OIL TANK PARTS
HYDRAULIC PIPING
SUCTION PIPING
DELIVERY PIPING
DRAIN PIPING
DRAIN PIPING
RETURN PIPING
HYDRAULIC PIPING (MAIN)
MAIN PIPING (1)
MAIN PIPING (2)
MAIN PIPING (3)
MAIN PIPING (4)
MAIN PIPING (5)
MAIN PIPING (6)
MAIN PIPING (7)
MAIN PIPING (8)
HYDRAULIC PIPING (PILOT)
SOLENOID VALVE (2 SECTION)
PILOT PIPING (1)
PILOT PIPING (2)
PILOT PIPING (3)
PILOT PIPING (4)
PILOT PIPING (5)
PILOT PIPING (6)
PILOT PIPING (7)
PILOT PIPING (8)
PILOT PIPING (9)
PILOT PIPING (10)
ELECTRIC SYSTEM
ELECTRIC PARTS (1)
ELECTRIC PARTS (2)(HALOGEN)
ELECTRIC PARTS (2)(LED)
ELECTRIC PARTS (2)(2P-BOOM)(HARNESS)
ELECTRIC PARTS (2)(2P-BOOM)(LED)
ELECTRIC PARTS (2)(2P-BOOM)(HARNESS)(LED)
ELECTRIC PARTS (3-1)
ELECTRIC PARTS (3-2)
ELECTRIC PARTS (4)
ELECTRIC PARTS (7)
ELECTRIC PARTS (8)
ELECTRIC PARTS (9)
ELECTRIC PARTS (10)
START SWITCH
BOOM LIGHT (L)(HALOGEN)
BOOM LIGHT (L)(LED)
BOOM LIGHT (R)(WITH LIGHT COVER)(HALOGEN)
BOOM LIGHT PARTS(L)(HALOGEN)
BOOM LIGHT PARTS(L)(LED)
BOOM LIGHT (R)(WITH LIGHT COVER)(LED)
ENGINE CONTROLLER SUPPORT
CONTROLLER (MC)
MONITOR CONTROLLER
ENGINE STOP SWITCH
MOBILE COMMUNICATIONS TERMINAL
FRONT HEAD LAMP (2 LAMP WITH RAIN GUARD UPPER)(HALOGEN)
FRONT HEAD LAMP (2 LAMP WITH RAIN GUARD UPPER)(LED)
FRONT HEAD LAMP (2 LAMP WITH RAIN GUARD UNDER)(HALOGEN)
FRONT HEAD LAMP (2 LAMP WITH RAIN GUARD UNDER)(LED)
REAR HEAD LAMP
REAR HEAD LAMP (LED)
ROTATING BEACON (FLOOR)
ADDTIONAL FUSE
HORN
REAR CAMERA
TRAVEL MOTION ALARM
TRAVEL MOTION ALARM (CAB)
OVER LOAD ALARM DEVICE
OVERLOAD ALARM DEVICE (WITH SWITCH)
WINDOW WASHER
BATTERY
CAB
CAB (TEMPERED GLASS)(WITH SUN VISOR)
CAB GROUP (1)
CAB GROUP (2)
ANCHOR BOLT
REAR MIRROR
REAR MIRROR
CAB RUBBER
RAIN GUARD
RAIN GUARD SUPPORT
AUX. PARTS
FLOOR PARTS
CONTROL LEVER (FRONT, SWING)
AFL(AUX FUNCTION LEVER)(FRONT, SWING)(FOR ASSIST)
AFL(AUX FUNCTION LEVER)(FRONT, SWING)(FOR BREAKER)
AFL(AUX FUNCTION LEVER)(FRONT, SWING)(2 Ch)
CONTROL LEVER (TRAVEL)
CONTROL LEVER (BLADE)
CONTROL PEDAL (BOOM SWING)
LOCK LEVER
CONSOLE COVER
RIGHT COVER
RADIO (AM/FM)
POWER UNIT (12V)
USB PORT
FLOOR PLATE
SUSPENSION SEAT
AIR-SUSPENSION SEAT
HEATER SEAT PARTS
FLOOR MAT
FLOOR MAT (LEFT SPARE PEDAL)
SPEAKER
FOOT REST
ARM REST
SEAT STAND (FOR SUSPENSION SEAT)
SEAT STAND PARTS
SHOCKLESS PARTS
REAR COVER
AIR CONDITIONER、HEATER
AIR-CONDITIONER (1)
AIR-CONDITIONER (2)
AIR-CONDITIONER (3)
AIR-CONDITIONER (4)
HEATER PARTS
HEATER PIPING
DUCT
UNDERCARRIAGE
TRACK FRAME
TRACK GUARD
TRACK UNDER COVER
SWING BEARING
GREASE-BATH COVER
GREASE-BATH SEAL
TRAVEL DEVICE
TRAVEL PIPING
TRAVEL MOTOR COVER
FRONT IDLER
ADJUSTER (RUBBER CRAWLER)
ADJUSTER (STEEL CRAWLER)
UPPER ROLLER
LOWER ROLLER
TRACK-LINK
TRACK LINK
PAD CRAWLER F450mm (SEPARATE-TYPE)
RUBBER CRAWLER
CENTER JOINT
CENTER JOINT PARTS
BLADE 2.20m
BLADE 2.47m
BLADE SUPPORT
BLADE CYLINDER
FRONT-END ATTACHMENTS
BOOM 3.67m (WITH EXTRA/ASSIST PIPING SEAT AND WORKING LIGHT (R) SEAT)
BOOM PARTS (1)
BOOM PARTS (2)
BOOM PARTS (3)
ARM 1.62m (WITH EXTRA/ASSIST PIPING SEAT)
ARM PARTS (アーム 1.62m)
ARM 2.12m (WITH EXTRA, ASSIST PIPING SEAT)
ARM 1.62m (LOWER SURFACE REINFORCED)(EXTRA, ASSIST PIPING SEAT)
ARM 2.12m (LOWER SURFACE REINFORCED)(EXTRA, ASSIST PIPING SEAT)
ARM PARTS (ARM 2.12m)
BUCKET 0.28m3 (JIS A8403-4;2012)
A LINK
B LINK
A LINK (WITH HOOK)
B LINK (REINFORCED)
FRONT PIPING (BOOM 3.67m)
BOOM CYLINDER
ARM CYLINDER
BUCKET CYLINDER
HOSE RUPTURE VALVE PIPING (BOOM)
HOSE RUPTURE VALVE PIPING (BOOM)(WITH COVER)
HOSE RUPTURE VALVE PIPING (ARM)
LUBRICATE PIPING (BOOM 3.67m)
FRONT-END ATTACHMENTS (2P-BOOM)
2P-BOOM
BOOM PARTS (2P-BOOM)
POSITIONING CYL. (WITH HOSE RUPTURE VALVE (R))
POSITIONING CYL. (WITH HOSE RUPTURE VALVE (L))
MAIN PIPING (2P-BOOM)(WITHOUT PTO PIPIMG)
PILOT PIPING (2P-BOOM)
FRONT PIPING (2P-BOOM)
LUBRICATION PIPING (2P-BOOM)
HOSE RUPTURE VALVE PIPING (POSITIONING)
BREAKER, CRUSHER PARTS
MAIN PIPING (BREAKER, CRUSHER)
MAIN PIPING (PTO)(1)
MAIN PIPING (PTO)(2)
PILOT PIPING (BREAKER, CRUSHER)
PILOT PIPING (WITHOUT PTO)
PILOT PIPING (PTO)(1)
PILOT PIPING (PTO)(2)
PILOT PIPING (PTO)(2P-BOOM)
BOOM PIPING (BREAKER, CRUSHER)(MONO-BOOM)
BOOM PIPING (BREAKER, CRUSHER)(2P-BOOM)
EXTRA PIPING (2P-BOOM)
EXTRA PIPING (ARM 1.62m)
EXTRA PIPING (ARM 2.12m)
ASSIST PIPING (BOOM 3.67m)
ASSIST PIPING (2P-BOOM)
ASSIST PIPING (ARM 1.62m)
ASSIST PIPING (ARM 2.12m)
HOSE RUPTURE VALVE PIPING (MONO-BOOM)(ARM CYLINDER)
HOSE RUPTURE VALVE PIPING (2P-BOOM)(ARM CYLINDER)
HOSE RUPTURE VALVE PIPING (2P-BOOM)(POSITIONING CYLINDER)
CONTROL PEDAL (BREAKER, CRUSHER)
HSB COMMON PIPING (BREAKER, CRUSHER)
ETC.
ACCUMULATOR
PILOT PIPING (PTO VALVE, FLOW RATE SELECTOR)(MONO-BOOM)
PTO, 2-SPEED COMMON PARTS (2P-BOOM)
ELECTRIC TYPE CONTROL PARTS (FLOOR)
FLOW RATE SELECTOR PARTS (2)
WITHOUT FLOW RATE SELECTOR PARTS (MONO-BOOM)
WITHOUT FLOW RATE SELECTOR PARTS (2P-BOOM)
FLOW-RATE SELECTOR PARTS (2P-BOOM)
EXTRA PIPING (PTO)(2P-BOOM)
ELECTRIC TYPE CONTROL PARTS (AFL)(2P-BOOM)
AFL PARTS (ASSIST PIPING)
AFL PARTS (BREAKER)
AFL PARTS (2Ch)
AFL PILOT PIPING
RELIEF VALVE (BREAKER, CRUSHER)
CLAMP;PIPE (BOOM 3.67m)
CLAMP;PIPE (BOOM 3.67m)(ASSIST PIPING)
CLAMP;PIPE (2P-BOOM)
TOOLS
TOOLS
NAME PLATE
NAME PLATE (1)
NAME PLATE (2)
NAME PLATE (3)
PARTS INDEX
PARTS INDEX
ZX85US-6 ZX85USB-6 Engine Parts Catalog PDER50-EG1-3.pdf
COVER
MEMORANDUM
FOREWORD
CONTENTS
CYLINDER BLOCK
GEAR HOUSING
FLYWHEEL HOUSING AND OIL SUMP
CYLINDER HEAD AND BONNET
SUCTION MANIFOLD
EXHAUST MANIFOLD
DIESEL PARTICULATE FILTER (DPF)
CAMSHAFT AND DRIVING GEAR
CRANKSHAFT AND PISTON
LUB. OIL SYSTEM
COOLING WATER SYSTEM
FUEL SUPPLY PUMP
FUEL INJECTION VALVE
FUEL PIPE
STARTING MOTOR
GENERATOR
ELECTRONIC CONTROL UNIT (ECU)
ACCESSORY
GASKET SET
PARTS INDEX
ZX85USB-6 Equipment Components Parts Catalog PDER50-E1-2.pdf
COVER
MEMORANDUM
FOREWORD
CONTENTS
PARTS INDEX
Brand: Hitachi
List of Files:
COVER
MEMORANDUM
FOREWORD
CONTENTS
BUCKET PARTS
FRAME,COVER
FRAME
FRAME (2P-BOOM)
SWING POST
COUNTERWEIGHT
COUNTERWEIGHT PARTS
COVER (1)
COVER (2)
COVER (3)
MIRROR
COVER (4)
COVER (5)
COVER (6)
ENGINE COVER
RADIATOR COVER
UNDER COVER
ENGINE
ENGINE
ENGINE SUPPORT
RADIATOR
RESERVE TANK
AIR CLEANER PARTS
ELEMENT (INNER)
MUFFLER
FUEL TANK
FUEL FEED PUMP
FUEL PIPING
OIL FILTER PIPING
HYDRAULIC SYSTEM
PUMP DEVICE
PUMP DEVICE SUPPORT
CONTROL VALVE
SWING DEVICE
OIL TANK PARTS
HYDRAULIC PIPING
SUCTION PIPING
DELIVERY PIPING
DRAIN PIPING
DRAIN PIPING
RETURN PIPING
MAIN PIPING (1)
MAIN PIPING (2)
MAIN PIPING (3)
MAIN PIPING (4)
MAIN PIPING (5)
MAIN PIPING (6)
MAIN PIPING (7)
MAIN PIPING (8)
PILOT PIPING (1)
PILOT PIPING (2)
PILOT PIPING (3)
PILOT PIPING (4)
PILOT PIPING (5)
PILOT PIPING (6)
PILOT PIPING (7)
PILOT PIPING (8)
PILOT PIPING (9)
PILOT PIPING (10)
ELECTRIC SYSTEM
ELECTRIC PARTS (1)
ELECTRIC PARTS (4)
ELECTRIC PARTS (7)
ELECTRIC PARTS (8)
ELECTRIC PARTS (9)
ELECTRIC PARTS (10)
START SWITCH
BOOM LIGHT (L)(LED)
CONTROLLER (MC)
MONITOR CONTROLLER
ENGINE STOP SWITCH
REAR HEAD LAMP
ADDTIONAL FUSE
HORN
REAR CAMERA
TRAVEL MOTION ALARM
WINDOW WASHER
BATTERY
CAB
CAB GROUP (1)
CAB GROUP (2)
ANCHOR BOLT
REAR MIRROR
REAR MIRROR
CAB RUBBER
RAIN GUARD
RAIN GUARD SUPPORT
AUX. PARTS
FLOOR PARTS
LOCK LEVER
CONSOLE COVER
RIGHT COVER
RADIO (AM/FM)
POWER UNIT (12V)
USB PORT
FLOOR PLATE
SUSPENSION SEAT
AIR-SUSPENSION SEAT
HEATER SEAT PARTS
FLOOR MAT
SPEAKER
FOOT REST
ARM REST
SEAT STAND PARTS
SHOCKLESS PARTS
REAR COVER
AIR-CONDITIONER (1)
AIR-CONDITIONER (2)
AIR-CONDITIONER (3)
AIR-CONDITIONER (4)
HEATER PARTS
HEATER PIPING
DUCT
UNDERCARRIAGE
TRACK FRAME
TRACK GUARD
TRACK UNDER COVER
SWING BEARING
GREASE-BATH COVER
GREASE-BATH SEAL
TRAVEL DEVICE
TRAVEL PIPING
TRAVEL MOTOR COVER
FRONT IDLER
UPPER ROLLER
LOWER ROLLER
TRACK-LINK
TRACK LINK
RUBBER CRAWLER
CENTER JOINT
CENTER JOINT PARTS
BLADE 2.20m
BLADE 2.47m
BLADE SUPPORT
BLADE CYLINDER
BOOM PARTS (1)
BOOM PARTS (2)
BOOM PARTS (3)
A LINK
B LINK
A LINK (WITH HOOK)
B LINK (REINFORCED)
BOOM CYLINDER
ARM CYLINDER
BUCKET CYLINDER
2P-BOOM
ETC.
ACCUMULATOR
AFL PARTS (BREAKER)
AFL PARTS (2Ch)
AFL PILOT PIPING
TOOLS
TOOLS
NAME PLATE
NAME PLATE (1)
NAME PLATE (2)
NAME PLATE (3)
PARTS INDEX
PARTS INDEX
COVER
MEMORANDUM
FOREWORD
CONTENTS
CYLINDER BLOCK
GEAR HOUSING
SUCTION MANIFOLD
EXHAUST MANIFOLD
LUB. OIL SYSTEM
FUEL SUPPLY PUMP
FUEL PIPE
STARTING MOTOR
GENERATOR
ACCESSORY
GASKET SET
PARTS INDEX
COVER
MEMORANDUM
FOREWORD
CONTENTS
PARTS INDEX
- Hitachi EX120-2 Excavator Parts Catalog
- Hitachi EX200-2 Service Manual
- Hitachi Excavator ZX240-3 to ZX250LCK-3 Parts Catalog P1V1-1-1 EN JP
- Hitachi Zaxis 200,225,230 Class Hydraulic Circuit Diagram
- Hitachi EX 750 -5 EX 800 H-5 Full Service Manual
- Hitachi Zaxis 200,225,240,270-3 Service Manual
- Hitachi WIN DR Technical Manual (a PC version Dr.ZX)
- Hitachi ZAXIS ZX330-3 TO ZX350-3 Parts Manual
- Isuzu Industrial Diesel Engine 4JJ1X/4-6HK1X/6WG1X Tier3
- Hitachi Zaxis 200-3 Hydraulic Excavator Technical Manual
- Hitachi Zaxis 70,70LC Hydraulic Circuit Diagram
- Hitachi EX200-3 Excavator Parts Catalog
- Hitachi Hydraulic Excavator ZX50 Technical Manual
- Hitachi ZW 220 - ZW 250 Wheel Loader - Workshop Manual
- Hitachi EX120 Service Manual
