Martin Welker
104
230,310
Hitachi Excavators ZX85USB-6 3TNV 3TN 4TNV 4TN Series Engine Manual
Brand: Hitachi, Yanmar
Type of Manual: Engine Manual, Technical Manual, Workshop Manual
Model: Yanmar 3TNV 3TN 4TNV 4TN Series For Hitachi ZX85USB-6
List of Files:
-Technical Manual
Revision+Information_ETDEP-EN-02(18-Dec-2024).xlsx
ZX85USB-6 3TNV 3TN 4TNV 4TN Series Engine Manual (Technical Manual ETDEP-EN-02(27-Dec-2023).pdf
Cover
Troubleshooting
Dtc (Diagnostic Trouble Codes) General Description
Method And Procedure Of Failure Diagnosis
-Workshop Manual
Revision+Information_EWDEP-EN-02(18-Dec-2024).xlsx
ZX85USB-6 3TNV 3TN 4TNV 4TN Series Engine Manual (Workshop Manual) EWDEP-EN-02(27-Dec-2023).pdf
Cover
Table of Contents
Introduction
HITACHI CONSTRUCTION MACHINERY WARRAANTIES
HITACHI CONSTRUCTION MACHINERY Warranty
Safety
Safety Statements
Safety Precautions
General Service Information
Component Identification
Location of Labels
Emission Control Regulations
Emission Control Labels
Engine Family
Function of Major Engine Components
Function of Cooling System Components
Main Electronic Control Components and Features
Installation Position of Sensors
Diesel Fuel
Engine Lubricating Oil
Engine Coolant
Specifications
Principal Engine Specifications
Engine Service Standards
Tightening Torques for Standard Bolts and Nuts
Abbreviations and Symbols
Unit Conversions
Periodic Maintenance
Before You Begin Servicing
Introduction
Periodic Maintenance Schedule
Periodic Maintenance Procedures
INTRODUCTION
Cylinder Head Specifications
Camshaft and Timing Gear Train Specifications
Crankshaft and Piston Specifications
Cylinder Block Specifications
Special Torque Chart
Special Service Tools
Measuring Instruments
Measuring and Adjusting Valve Clearance
Crankshaft and Camshaft Components
EGR System
Intake Throttle
Exhaust Throttle
Fuel System
System Structure
Fuel System Specifications
Fuel System Diagram
Fuel System Components
INTRODUCTION
Cooling System Diagram
Engine Coolant Pump Components
Engine Coolant System Check
Engine Coolant Pump
Lubrication System
Introduction
Oil Pump Service Information
Lubrication System Diagram
Checking Engine Lubricating Oil Pressure
Oil Pump Components
Turbocharger
Introduction
Specifications
Troubleshooting
Turbocharger Components
Turbocharger Component Functions
Periodic Inspection
Removal and Installation of Turbocharger
Cleaning Procedure
Starter Motor
INTRODUCTION
Starter Motor Information
Starter Motor Specifications
Starter Motor Troubleshooting
Starter Motor Components
Starter Motor
Introduction
Dynamo and Alternator Information
Alternator Specifications
Dynamo Specifications
Alternator Troubleshooting
Alternator Components
Alternator Wiring Diagram
Alternator Standard Output
Dynamo Component Location
Dynamo Wiring Diagram
Operation of Dynamo
Dynamo Standard Output
Testing of Dynamo
Dynamo
Electronic Control System
Introduction
System Structure
HOW TO REMOVE AND REATTACH THE DIESEL PARTICULATE FILTER (DPF)
SF and DPF Maintenance Kit
Troubleshooting of Electronic Control System
Replacement of Components
Hardware Modification for De-Tier
Electronic Control Harness Connections
Electric Wiring
Electric Wiring Precautions
Electrical Wire Resistance
Battery Cable Resistance
Electrical Wire Sizes - Voltage Drop
Conversion of AWG to European Standards
Failure Diagnosis
Troubleshooting by Measuring Compression Pressure
Measured Value and Troubleshooting
Quick Reference Table for Troubleshooting
