Hitachi Excavators ZX85US-6 ZX85USB-6 Operators Manual ENMDEQ-EN1-2
Brand: Hitachi
Type of Machine: Excavators
Type of Manual: Operators Manual, Maintenance Manual
Model: Hitachi ZX85US-6 ZX85USB-6 Excavator
Serial Number: ZX85US-6 090001 and up, ZX85USB-6 110001 and up
Part Number: ENMDEQ-EN1-2
Publication Date: 2021
Number of Pages: 492 Pages
INTRODUCTION
SECTION AND GROUP CONTENTS
CONTENTS
MACHINE NUMBERS
SAFETY
Recognize Safety Information
Understand Signal Words
Follow Safety Instructions
Prepare for Emergencies
Wear Protective Clothing
Protect Against Noise
Inspect Machine
General Precautions for the Cab
Use Handholds and Steps
Adjust the Operator's Seat
Ensure Safety Before Rising from or Leaving Operator's Seat
Fasten Your Seat Belt
Move and Operate Machine Safely
Start the Engine Only from Operator's Seat
Jump Starting
Keep Riders off Machine
Precautions for Operations
Perform Job Site Risk Assessment Beforehand
Install OPG Guard
Restriction of Attachment Installation
Provide Signals for Jobs Involving Multiple Machines
Confirm Direction of Machine Travel
Drive the Machine Safely
Avoid Injury from Rollaway Accidents
Avoid Accidents from Reversing and Swing Operation
Keep People Clear from Working Area
Never Position the Bucket Over Anyone
Avoid Undercutting
Avoid Tipping
Never Undercut a High Bank
Dig with Caution
Caution with an Overhead Obstacle
Avoid Power Lines
Precautions for Lightning
Object Handling
Protect Against Flying Debris and Falling Object
Park Machine Safely
Handle Fluids Safely−Avoid Fires
Transport Safely
Practice Safe Maintenance
Warn Others of Service Work
Support Machine Properly
Stay Clear of Moving Parts
Prevent Parts from Flying
Avoid Injury from Attachment Falling Accident
Prevent Burns
Replace Rubber Hoses Periodically
Avoid High-Pressure Fluids
Prevent Fires
Evacuating in Case of Fire
Beware of Exhaust Fumes
Precautions for Welding and Grinding
Avoid Applying Heat to Lines Containing Flammable Fluids
Precautions for Handling Accumulator and Gas Damper
Beware of Asbestos and Silica Dust and Other Contamination
Prevent Battery Explosions
Service Air Conditioning System Safely
Dispose of Waste Properly
Never Ride Attachment
Notes for Muffler Filter
Precautions for Communication Terminal
Precautions for Communication Terminal Equipment
Notes on Protection of Operator's Station when the Machine Rolls Over
VISIBILITY MAP
SAFETY SIGNS
NAME OF COMPONENTS
Name of Components
GETTING ON AND OFF THE MACHINE
OPERATOR'S STATION
Muffler Filter
ECU (Engine Control Unit)
Name of Components
Multi Function Monitor
Default Setting
Basic Screen
How to Use Screens
Security Functions (Optional)
Alarm Screen
Description of Alarms
DTC Code List
DTC Code List (NCD System)
DTC Code List (PCD System)
Muffler Filter
Main Menu
Air Conditioner
Radio
Mail (Optional)
Setting Menu
Date and Time
Auto Shut-Down
Muffler Filter Regeneration Inhibited
Password Change (Optional)
Sub Meter
Rear View Camera Monitor
Brightness Adjustment
Language Settings
List of Display Languages
Unit Selection
Display Item Selection (Rear View Camera OFF)
Main Menu Sequence Change
Information Menu
Operation Information
Maintenance
Monitoring
Switch Panel
Switch Panel (for Options)
Key Switch
Horn Switch
Electrical Control Main Switch (Optional)
Cigar Lighter
Cab Light Switch
Installing a Fire Extinguisher (Optional)
Pilot Control Shut-Off Lever
Engine Stop Switch
Fuse Box
Auto Air Conditioner
Tips for Optimal Air Conditioner Usage
AM/FM Radio Operation
Audio Input
Cab Door Release Lever
Opening/Closing and Removing Cab Inside Window
Opening Upper Front Window
Removing and Storing Lower Front Window
Using the Side Window
Using the Overhead Window (Clear Hatch) (ZX85US-6) (Optional)
Emergency Exit
Adjusting Operator's Seat
Console Height Adjustment
Installation and Adjustment of Mirrors
Seat Belt
Battery Disconnect Switch (Optional)
BREAK-IN
New Machine Break-in
OPERATING THE ENGINE
Inspect Machine Daily Before Starting
Before Starting the Engine
Starting the Engine
Check Instruments After Starting
Using the Booster Battery
Stopping the Engine
Engine Auto-Stop in Extremely Low Temperature
DRIVING THE MACHINE
Travel Levers and Pedals
Travel Mode Switch
Travel Alarm (Optional)
Precautions for Traveling
Traveling on Soft Ground
Raising One Track Using the Boom and Arm
Towing the Machine
Operating in Water or Mud
Precautions for Traveling on Slopes
Parking the Machine on Slopes
Parking
OPERATING THE MACHINE
Control Levers (ISO Pattern)
Blade
Warming Up Operation
Engine Speed Control
Auto-Idle
Auto Shut-Down
Manual Regeneration of the Muffler Filter
Power Mode
Operating the Backhoe
Shovel
Grading Operation
Do Not Strike the Ground with Bucket Teeth
Avoid Hammer Work
Avoid Abusive Operation
Never Move an Object Sideways with the Bucket
Precautions during Blade Operation
Use the Right Shoes for the Site
Using the Shackle Hole
Lifting
Pilot Accumulator Function
Emergency Boom Lowering Procedure
Precautions for After Operations
TRANSPORTING
Transporting by Road
Loading/Unloading on a Trailer
Fastening Machine for Transporting
Unloading
Lifting the Machine
MAINTENANCE
Correct Maintenance and Inspection Procedures
Layout
Check the Hour Meter Regularly
Maintenance Guide Table
Preparation for Inspection and Maintenance
Hood and Access Covers
Maintenance Guide
Periodic Replacement of Parts
Kind of Oils
List of Consumable Parts
A. Greasing
B. Engine
C. Transmission
D. Hydraulic System
E. Fuel System
F. Air Cleaner
G. Cooling System
H. Electrical System
I. Miscellaneous
J. Muffler Filter
MAINTENANCE UNDER SPECIAL ENVIRONMENTAL CONDITIONS
STORAGE
TROUBLESHOOTING
SPECIFICATIONS
Specifications ZX85US-6
Working Ranges ZX85US-6
Shoe Types and Applications ZX85US-6
Bucket Types and Applications ZX85US-6
Specifications ZX85USB-6
Work Ranges ZX85USB-6
Shoe Types and Applications ZX85USB-6
Bucket Types and Applications ZX85USB-6
Noise Level Results
Electric Fans
The Value of the Carbon Dioxide (CO2) emissions
OPTIONAL ATTACHMENTS AND DEVICES
Hydraulic Breaker, Crusher, Quick Coupler
Control Lever
Offset Arm Front (ZX85US-6)
2-Piece Boom (ZX85USB-6)
INDEX
Brand: Hitachi
INTRODUCTION
CONTENTS
MACHINE NUMBERS
SAFETY
Inspect Machine
Jump Starting
Install OPG Guard
Avoid Undercutting
Avoid Tipping
Dig with Caution
Avoid Power Lines
Object Handling
Park Machine Safely
Transport Safely
Prevent Burns
Prevent Fires
VISIBILITY MAP
SAFETY SIGNS
NAME OF COMPONENTS
Name of Components
OPERATOR'S STATION
Muffler Filter
Name of Components
Default Setting
Basic Screen
How to Use Screens
Alarm Screen
DTC Code List
Muffler Filter
Main Menu
Air Conditioner
Radio
Mail (Optional)
Setting Menu
Date and Time
Auto Shut-Down
Sub Meter
Language Settings
Unit Selection
Information Menu
Maintenance
Monitoring
Switch Panel
Key Switch
Horn Switch
Cigar Lighter
Cab Light Switch
Engine Stop Switch
Fuse Box
Audio Input
Emergency Exit
Seat Belt
BREAK-IN
Starting the Engine
Stopping the Engine
DRIVING THE MACHINE
Travel Mode Switch
Towing the Machine
Parking
Blade
Auto-Idle
Auto Shut-Down
Power Mode
Shovel
Grading Operation
Avoid Hammer Work
Lifting
TRANSPORTING
Unloading
Lifting the Machine
MAINTENANCE
Layout
Maintenance Guide
Kind of Oils
A. Greasing
B. Engine
C. Transmission
D. Hydraulic System
E. Fuel System
F. Air Cleaner
G. Cooling System
I. Miscellaneous
J. Muffler Filter
STORAGE
TROUBLESHOOTING
SPECIFICATIONS
Noise Level Results
Electric Fans
Control Lever
INDEX
- Hitachi EX120-2 Excavator Parts Catalog
- Hitachi EX200-2 Service Manual
- Hitachi Excavator ZX240-3 to ZX250LCK-3 Parts Catalog P1V1-1-1 EN JP
- Hitachi Zaxis 200,225,230 Class Hydraulic Circuit Diagram
- Hitachi EX 750 -5 EX 800 H-5 Full Service Manual
- Hitachi Zaxis 200,225,240,270-3 Service Manual
- Hitachi WIN DR Technical Manual (a PC version Dr.ZX)
- Hitachi ZAXIS ZX330-3 TO ZX350-3 Parts Manual
- Isuzu Industrial Diesel Engine 4JJ1X/4-6HK1X/6WG1X Tier3
- Hitachi Zaxis 200-3 Hydraulic Excavator Technical Manual
- Hitachi Zaxis 70,70LC Hydraulic Circuit Diagram
- Hitachi EX200-3 Excavator Parts Catalog
- Hitachi Hydraulic Excavator ZX50 Technical Manual
- Hitachi ZW 220 - ZW 250 Wheel Loader - Workshop Manual
- Hitachi EX120 Service Manual
