Hitachi Excavator ZX330-5G ZX330LC-5G ZX350H-5G Parts Catalog
Hitachi Excavator ZX330-5G ZX330LC-5G ZX350H-5G ZX360H-5G Parts Catalog
Brand: Hitachi
Type of Machine: Excavator
Model: Hitachi ZX330-5G ZX330LC-5G ZX350H-5G ZX360H-5G
The Hitachi ZX360H-5G uses many of the same parts as the ZX350H-5G, since both models are based on the same machine platform
List of Files:
ZX330-5G Engine Parts Catalog 6HK1-XQA03-13.pdf (162 Pages)
Index
COVER
MEMORANDUM
FOREWORD
CONTENTS
ENGINE
005: ENGINE GASKET KIT (1/3)
005: ENGINE GASKET KIT (2/3)
005: ENGINE GASKET KIT (3/3)
010: CYLINDER HEAD COVER
011: CYLINDER HEAD
012: CYLINDER BLOCK (1/2)
012: CYLINDER BLOCK (2/2)
013: OIL PAN AND LEVEL GAUGE(1/2)
013: OIL PAN AND LEVEL GAUGE(2/2)
014: CAMSHAFT AND VALVE (1/2)
014: CAMSHAFT AND VALVE (2/2)
015: CRANKSHAFT,PISTON ANDFLYWHEEL
020: TIMING GEAR CASE ANDFLYWHEEL HOUSING (1/2)
020: TIMING GEAR CASE ANDFLYWHEEL HOUSING (2/2)
025: INLET MANIFOLD
027: EXHAUST MANIFOLD
028: VENTILATION SYSTEM
030: WATER PUMP AND CORROSIONRESISTOR (1/2)
030: WATER PUMP AND CORROSIONRESISTOR (2/2)
031: THERMOSTAT AND HOUSING
032: WATER PIPING; ENGINE
033: FAN AND FAN BELT
036: TURBOCHARGER SYSTEM
037: TURBOCHARGER (1/2)
037: TURBOCHARGER (2/2)
040: FUEL INJECTION SYSTEM (1/3)
040: FUEL INJECTION SYSTEM (2/3)
040: FUEL INJECTION SYSTEM (3/3)
041: FUEL FILTER AND BRACKET
042: FUEL PUMP AND PIPE
050: OIL COOLER AND OIL FILTER(1/2)
050: OIL COOLER AND OIL FILTER(2/2)
051: OIL PUMP AND OIL STRAINER
052: OIL AND VACUUM PIPING;ENGINE (1/2)
052: OIL AND VACUUM PIPING;ENGINE (2/2)
060: ENGINE ELECTRICAL CONTROLPARTS
061: BATTERY AND ENGINEELECTRICAL PARTS
065: STARTER
066: GENERATOR
066: GENERATOR
080: INJECTION PUMP
081: GOVERNOR; INJECTION PUMP(1/2)
081: GOVERNOR; INJECTION PUMP(2/2)
084: FEED PUMP; INJECTION PUMP
085: AUTO TIMER; INJECTION PUMP
087: COUPLING; INJECTION PUMP
101: ACCELERATOR PEDAL ANDCONTROL
110: RADIATOR
145: WATER SEDIMENTER; FUEL
901: TOOLS
PARTS INDEX
ZX330-5G ZX330LC-5G ZX350H-5G Equipment Components Parts Catalog PDDEF0-E1-5.pdf (205 Pages)
Index
COVER
MEMORANDUM
FOREWORD
CONTENTS
PARTS INDEX
ZX330-5G ZX330LC-5G ZX350H-5G Parts Catalog PDDEF0-1-5.pdf (530 Pages)
Index
COVER
MEMORANDUM
FOREWORD
ILLUSTRATION CONTENTS
CONTENTS
FRAME, COVER
FRAME
FRAME PARTS
BOOM FOOT PIN
CENTER JOINT SUPPORT (UPPERSTRUCTURE)
COUNTERWEIGHT
COVER (1)
COVER (2)
ANTI-SLIP COVER (2)
COVER (2)(WITH PRE-CLEANER)
ANTI-SLIP COVER (2)(WITH PRE-CLEANER)
COVER (3)
ANTI-SLIP COVER (3)
COVER (4)
COVER (5)
COVER (6)
ANTI-SLIP COVER (6)
COVER (7)
COVER (7)(TROPICAL)
COVER (8)
COVER (8)(LINE FILTER)
TOOL BOX COVER
ANTI-SLIP COVER (TOOL BOX)
ANTI-SLIP COVER (FUEL TANK)
ENGINE COVER
RADIATOR COVER
UNDER COVER
UNDER COVER (t=6.0mm)
ENGINE
ENGINE
ENGINE SUPPORT
OIL FILTER PIPING
INTERCOOLER PIPING
RADIATOR
RADIATOR SUPPORT
RESERVE TANK
AIR CLEANER
ELEMENT (INNER)
AIR CLEANER SUPPORT
AIR CLEANER PARTS
PRE-CLEANER
PRE-CLEANER PARTS
MUFFLER
FUEL TANK
FUEL TANK (FLASHING CIRCUIT)
FUEL TANK SUPPORT
FUEL PIPING
HYDRAULIC SYSTEM
PUMP DEVICE
PUMP DEVICE SUPPORT
CONTROL VALVE
CONTROL VALVE SUPPORT
SWING DEVICE
SWING DEVICE SUPPORT
OIL TANK
OIL TANK
OIL TANK PARTS (WITH INDICATOR)
OIL TANK SUPPORT
HYDRAULIC PIPING
SUCTION PIPING
DELIVERY PIPING
RETURN PIPING (1)
RETURN PIPING (2)
DRAIN PIPING
HYDRAULIC PIPING (MAIN)
MAIN PIPING (1)
MAIN PIPING (2)
MAIN PIPING (3)
MAIN PIPING (4)
BOOM BOTTOM PIPING
HYDRAULIC PIPING (PILOT)
SOLENOID VALVE (3 SPOOL)
PILOT PIPING (1)
PILOT PIPING (2)
PILOT PIPING (3)
PILOT PIPING (4-1)
PILOT PIPING (4-2)
PILOT PIPING (5)
PILOT PIPING (6)
PILOT PIPING (7)
PILOT PIPING (8)
PILOT PIPING (9)
PILOT PIPING (10)
ELECTRIC SYSTEM
ELECTRIC PARTS (1)
ELECTRIC PARTS (2)
ELECTRIC PARTS (3)
ELECTRIC PARTS (4)
ELECTRIC PARTS (5)
ELECTRIC PARTS (6)
BATTERY
START SWITCH
ENGINE STOP SWITCH
MOBILE COMMUNICATIONS TERMINAL
SATELLITE COMMUNICATIONS TERMINAL
ELECTRIC CONTROL PARTS
CONTROLLER (SMCZ)
MONITOR CONTROLLER
ADD. FUSE PARTS
FRONT HEAD LAMP (2 LAMP)(FLOOR)
FRONT HEAD LAMP (2 LAMP WITH RAIN GUARD UPPER)
REAR HEAD LAMP (CAB)
REAR HEAD LAMP PARTS (FLOOR)
BRACKET (ADDITIONAL RELAY)
BOOM LIGHT HARNESS
BOOM LIGHT (R)
AUTO ENGINE CONTROL
ENGINE CONTROL MOTOR (AUTO ENGINE CONTROL)
ENGINE STOP CABLE (AUTO ENGINE CONTROL)
ENGINE CONTROL UNIT
HORN
REAR CAMERA
WITHOUT REAR CAMERA PARTS
SWING MOTION ALARM DEVICE
TRAVEL MOTION ALARM DEVICE
WINDOW WASHER
CAB
CAB (STEEL ROOF)(WITH FRONT GUARD SEAT)(MOBILE COMMUNICATIONS)
CAB (STEEL ROOF)(WITH FRONT GUARD SEAT)(SATELLITE COMMUNICATIONS)
CAB (STEEL ROOF)(WITHOUT FRONT GUARD SEAT)(MOBILE COMMUNICATIONS)
CAB (STEEL ROOF)(WITHOUT FRONT GUARD SEAT)(SATELLITE COMMUNICATIONS)
CAB GUARD (UNDER FRONT)
CAB GUARD (ON FRONT)
CAB GROUP (1)
CAB GROUP (2)
ANCHOR BOLT
WITHOUT ANCHOR BOLT PARTS
CAB MIRROR
SUNVISOR (RIGHT WINDOW)
FRONT HEAD LAMP, RAIN GUARD SUPPORT
FLOOR PARTS
CONTROL LEVER (FRONT, SWING)
CONTROL LEVER (FRONT, SWING)(WITH SINGLE SWITCH)
CONTROL LEVER (FRONT, SWING)(WITH TRIPLE SWITCH)
PILOT VALVE (FRONT, SWING)
CONTROL LEVER (TRAVEL)
PILOT VALVE (TRAVEL)
PEDAL (R)
PEDAL (L)
LOCK LEVER
CONSOLE
CONSOLE COVER
RIGHT COVER
RADIO (AM/FM)
REAR BOX
REAR BOX (12V POWER SUPPLY)
POWER UNIT (12V)
FLOOR PLATE
FLOOR PARTS (1)
FLOOR PARTS (2)
SEAT PARTS (KAB)
SUSPENSION SEAT PARTS (KAB)
SUSPENSION SEAT PARTS (WITHOUT SEAT BELT)(KAB)
AIR SUSPENSION SEAT PARTS (WITH HEATER)(GRAMMER)
AIR SUSPENSION SEAT PARTS (WITH HEATER)(WITHOUT SEAT BELT)(GRAMMER)
HEATER SEAT PARTS
SEAT STAND (1)
SEAT STAND (2)
STAND PARTS
FLOOR MAT
FLOOR CARPET
AIR CONDITIONER
AIR CONDITIONER (1)
AIR CONDITIONER (2)
AIR CONDITIONER (3)
AIR CONDITIONER (4-1)
AIR CONDITIONER (4-2)
HEATER PIPING
DUCT (WITH AIR CONDITIONER)
DUCT (WITHOUT AIR CONDITIONER)
WITHOUT AIR CONDITIONER PARTS
UNDERCARRIAGE
TRACK FRAME
TRACK FRAME
TRACK GUARD
FULL-LENGTH TRACK GUARD
STEP
ADDITIONAL STEP
TRACK UNDER COVER
SWING BEARING
SWING BEARING PARTS
TRAVEL DEVICE
TRAVEL DEVICE SUPPORT
TRACK SPRING
UPPER ROLLER
LOWER ROLLER (LC)
LOWER ROLLER (STD)
LOWER ROLLER SUPPORT
TRACK-LINK
TRACK-LINK
CENTER JOINT
CENTER JOINT SUPPORT (TRACK)
TRAVEL PIPING
TRAVEL PIPING
TRAVEL MOTOR COVER
FRONT-END ATTACHMENTS
BOOM 6.4m
BOOM 6.4m (WITH BREAKER, BOOM RIGHT SIDE LIGHT SEAT)
BOOM 6.4m
BOOM PARTS
BOOM PIPING
LUBRICATE PIPING
ARM 2.33m
ARM 2.33m (WITH BREAKER PIPING SEAT)
ARM 2.67m
ARM 3.20m
ARM 3.20m (WITH BREAKER PIPING SEAT)
ARM 4.0m
ARM PARTS
ARM PIPING
A LINK
A LINK (WELDED)
B LINK
B LINK (K TYPE)
B LINK (H TYPE)
BUCKET 1.4m3 (JIS A8403-4;2012)
BUCKET 1.4m3 (JIS A8403-4;2012)(SIDE-PIN TOOTH)
BUCKET 1.4m3 (JIS A8403-4;2012)(SUPER V TOOTH)
ROCK BUCKET 1.38m3 (JIS A8403-4;2012)(SUPER V TOOTH)
ROCK BUCKET 1.38m3 (JIS A8403-4;2012)(SIDE-PIN TOOTH)
ROCK BUCKET 1.5m3 (JIS A8403-4;2012)(SUPER V TOOTH)
REINFORCEMENT BUCKET 1.4m3 (JIS A8403-4;2012)
BUCKET 2.0m3 (JIS A8403-4;2012)(SUPER V TOOTH)(REINFORCEMENT TYPE)
ROCK BUCKET 2.0m3 (JIS A8403-4;2012)(SUPER V TOOTH)
BOOM CYLINDER (R)
BOOM CYLINDER (R)
BOOM CYLINDER (L)
BOOM CYLINDER (L)
BOOM CYLINDER (R)(WITH HOSE RUPTURE VALVE)
BOOM CYLINDER (L)(WITH HOSE RUPTURE VALVE)
ARM CYLINDER
ARM CYLINDER
ARM CYLINDER (WITH HOSE RUPTURE VALVE)
HOSE RUPTURE VALVE PIPING (BOOM)
HOSE RUPTURE VALVE PIPING (1)(ARM)
HOSE RUPTURE VALVE PIPING (2)(ARM)
BUCKET CYLINDER
BUCKET CYLINDER
BREAKER, CRUSHER PARTS
BREAKER, CRUSHER PIPING (MAIN)
BREAKER, CRUSHER PIPING (PILOT)
LINE FILTER
CONTROL PEDAL (BREAKER, CRUSHER)
FLOOR MAT (BREAKER)
FLOOR CARPET (BREAKER)
BREAKER, CRUSHER PIPING (BOOM)
BREAKER, CRUSHER PIPING (ARM 2.33m)
BREAKER, CRUSHER PIPING (ARM 2.67m)
BREAKER, CRUSHER PIPING (ARM 3.2m)
BREAKER, CRUSHER PIPING (ARM 4.0m)
NPK BREAKER PIPING
HSB BREAKER PIPING
NPK COMMON PIPING (BREAKER, CRUSHER)
HSB COMMON PIPING (BREAKER, CRUSHER)
PILOT PIPING (FLOW RATE SELECTOR)
RELIEF VALVE
ETC.
ELECTRIC GREASE GUN
AUTO FUEL FILLING DEVICE
AUTO FUEL FILLING DEVICE (FLASHING CIRCUIT)
VALVE BALL
HIGH PERFORMANCE FILTER KIT
TOOLS
TOOLS
NAME-PLATE
NAME PLATE (1)
NAME PLATE (2)
NAME PLATE (3)
PARTS INDEX
PARTS INDEX
Brand: Hitachi
List of Files:
Index
COVER
MEMORANDUM
FOREWORD
CONTENTS
ENGINE
011: CYLINDER HEAD
025: INLET MANIFOLD
065: STARTER
066: GENERATOR
066: GENERATOR
080: INJECTION PUMP
110: RADIATOR
901: TOOLS
PARTS INDEX
Index
COVER
MEMORANDUM
FOREWORD
CONTENTS
PARTS INDEX
Index
COVER
MEMORANDUM
FOREWORD
CONTENTS
FRAME, COVER
FRAME
FRAME PARTS
BOOM FOOT PIN
COUNTERWEIGHT
COVER (1)
COVER (2)
ANTI-SLIP COVER (2)
COVER (3)
ANTI-SLIP COVER (3)
COVER (4)
COVER (5)
COVER (6)
ANTI-SLIP COVER (6)
COVER (7)
COVER (7)(TROPICAL)
COVER (8)
TOOL BOX COVER
ENGINE COVER
RADIATOR COVER
UNDER COVER
ENGINE
ENGINE
ENGINE SUPPORT
OIL FILTER PIPING
INTERCOOLER PIPING
RADIATOR
RADIATOR SUPPORT
RESERVE TANK
AIR CLEANER
ELEMENT (INNER)
AIR CLEANER SUPPORT
AIR CLEANER PARTS
PRE-CLEANER
PRE-CLEANER PARTS
MUFFLER
FUEL TANK
FUEL TANK SUPPORT
FUEL PIPING
HYDRAULIC SYSTEM
PUMP DEVICE
PUMP DEVICE SUPPORT
CONTROL VALVE
SWING DEVICE
OIL TANK
OIL TANK
OIL TANK SUPPORT
HYDRAULIC PIPING
SUCTION PIPING
DELIVERY PIPING
RETURN PIPING (1)
RETURN PIPING (2)
DRAIN PIPING
MAIN PIPING (1)
MAIN PIPING (2)
MAIN PIPING (3)
MAIN PIPING (4)
BOOM BOTTOM PIPING
PILOT PIPING (1)
PILOT PIPING (2)
PILOT PIPING (3)
PILOT PIPING (4-1)
PILOT PIPING (4-2)
PILOT PIPING (5)
PILOT PIPING (6)
PILOT PIPING (7)
PILOT PIPING (8)
PILOT PIPING (9)
PILOT PIPING (10)
ELECTRIC SYSTEM
ELECTRIC PARTS (1)
ELECTRIC PARTS (2)
ELECTRIC PARTS (3)
ELECTRIC PARTS (4)
ELECTRIC PARTS (5)
ELECTRIC PARTS (6)
BATTERY
START SWITCH
ENGINE STOP SWITCH
CONTROLLER (SMCZ)
MONITOR CONTROLLER
ADD. FUSE PARTS
BOOM LIGHT HARNESS
BOOM LIGHT (R)
AUTO ENGINE CONTROL
ENGINE CONTROL UNIT
HORN
REAR CAMERA
WINDOW WASHER
CAB
CAB GROUP (1)
CAB GROUP (2)
ANCHOR BOLT
CAB MIRROR
FLOOR PARTS
PEDAL (R)
PEDAL (L)
LOCK LEVER
CONSOLE
CONSOLE COVER
RIGHT COVER
RADIO (AM/FM)
REAR BOX
POWER UNIT (12V)
FLOOR PLATE
FLOOR PARTS (1)
FLOOR PARTS (2)
SEAT PARTS (KAB)
HEATER SEAT PARTS
SEAT STAND (1)
SEAT STAND (2)
STAND PARTS
FLOOR MAT
FLOOR CARPET
AIR CONDITIONER
AIR CONDITIONER (1)
AIR CONDITIONER (2)
AIR CONDITIONER (3)
HEATER PIPING
UNDERCARRIAGE
TRACK FRAME
TRACK FRAME
TRACK GUARD
STEP
ADDITIONAL STEP
TRACK UNDER COVER
SWING BEARING
SWING BEARING PARTS
TRAVEL DEVICE
TRACK SPRING
UPPER ROLLER
LOWER ROLLER (LC)
LOWER ROLLER (STD)
TRACK-LINK
TRACK-LINK
CENTER JOINT
TRAVEL PIPING
TRAVEL PIPING
TRAVEL MOTOR COVER
BOOM 6.4m
BOOM 6.4m
BOOM PARTS
BOOM PIPING
LUBRICATE PIPING
ARM 2.33m
ARM 2.67m
ARM 3.20m
ARM 4.0m
ARM PARTS
ARM PIPING
A LINK
A LINK (WELDED)
B LINK
B LINK (K TYPE)
B LINK (H TYPE)
BOOM CYLINDER (R)
BOOM CYLINDER (R)
BOOM CYLINDER (L)
BOOM CYLINDER (L)
ARM CYLINDER
ARM CYLINDER
BUCKET CYLINDER
BUCKET CYLINDER
LINE FILTER
FLOOR MAT (BREAKER)
NPK BREAKER PIPING
HSB BREAKER PIPING
RELIEF VALVE
ETC.
ELECTRIC GREASE GUN
VALVE BALL
TOOLS
TOOLS
NAME-PLATE
NAME PLATE (1)
NAME PLATE (2)
NAME PLATE (3)
PARTS INDEX
PARTS INDEX
- Hitachi EX120-2 Excavator Parts Catalog
- Hitachi EX200-2 Service Manual
- Hitachi Excavator ZX240-3 to ZX250LCK-3 Parts Catalog P1V1-1-1 EN JP
- Hitachi Zaxis 200,225,230 Class Hydraulic Circuit Diagram
- Hitachi EX 750 -5 EX 800 H-5 Full Service Manual
- Hitachi Zaxis 200,225,240,270-3 Service Manual
- Hitachi WIN DR Technical Manual (a PC version Dr.ZX)
- Hitachi ZAXIS ZX330-3 TO ZX350-3 Parts Manual
- Isuzu Industrial Diesel Engine 4JJ1X/4-6HK1X/6WG1X Tier3
- Hitachi Zaxis 200-3 Hydraulic Excavator Technical Manual
- Hitachi Zaxis 70,70LC Hydraulic Circuit Diagram
- Hitachi EX200-3 Excavator Parts Catalog
- Hitachi Hydraulic Excavator ZX50 Technical Manual
- Hitachi ZW 220 - ZW 250 Wheel Loader - Workshop Manual
- Hitachi EX120 Service Manual
