Hyundai
86
176,834
Hitachi Excavator ZX130-7H ZX130LCN-7H Parts Catalog EN JP
Language: English, Japanese
Brand: Hitachi
Type of Machine: Excavator
Model: Hitachi ZX130-7H ZX130LCN-7H Excavator
List of Files:
ZX130-7H ZX130LCN-7H Equipment Component Parts Catalog PDHD90-E1-1.pdf (194 Pages):
MEMORANDUM
FOREWORD
CONTENTS
PARTS INDEX
ZX130-7H ZX130LCN-7H Parts Catalog PDHD90-1-1 EN JP.pdf (552 Pages):
FILTER, ELEMENT, BELT PARTS
BUCKET PARTS
CAB RELATED PARTS
FRAME
SWING BEARING SUPPORT (UPPERSTRUCTURE)
BOOM FOOT PIN
CENTER JOINT SUPPORT (UPPERSTRUCTURE)(WITH BLADE)
COUNTERWEIGHT
COVER (1)
COVER (2)
COVER (3)
COVER (4)
COVER (5)
ENGINE COVER
RADIATOR COVER
UNDER COVER
UNDER COVER (t=6mm)
TOOL BOX COVER
ANTI-SLIP COVER (TOOL BOX)
ANTI-SLIP COVER (FUEL TANK)
HANDRAIL
ENGINE
ENGINE SUPPORT
OIL FILTER PIPING
INTERCOOLER PIPING
RADIATOR
RADIATOR SUPPORT
EXPANSION TANK
AIR CLEANER (WITHOUT PRE-CLEANER)
AIR CLEANER SUPPORT
AIR CLEANER (WITH PRE-CLEANER)
PRE-CLEANER
MUFFLER PARTS
FUEL TANK
FUEL TANK SUPPORT
FUEL PIPING (WITH WATER SEPARATOR)
UREA WATER TANK PARTS
UREA WATER TANK PIPING
PUMP DEVICE
PUMP DEVICE (WITH BLADE)
PUMP DEVICE (WITH ADDITIONAL GEAR PUMP)
PUMP DEVICE SUPPORT
CONTROL VALVE
CONTROL VALVE SUPPORT
SWING DEVICE
SWING DEVICE SUPPORT
OIL TANK
OIL TANK (WITH INDICATOR)
OIL TANK PARTS (WITH INDICATOR)
OIL TANK SUPPORT
SUCTION PIPING
DELIVERY PIPING
RETURN PIPING (1)
RETURN PIPING (2)
RETURN PIPING (WITH BLADE)
DRAIN PIPING
MAIN PIPING (1)
MAIN PIPING (2)
MAIN PIPING (3)
MAIN PIPING (4)
MAIN PIPING (5)
MAIN PIPING (1)(WITH BLADE)
MAIN PIPING (2)(WITH BLADE)
BOOM BOTTOM PIPING
SIDE BRANCH PIPING
SOLENOID VALVE (1 SECTION)
SOLENOID VALVE (2 SECTION)
SOLENOID VALVE (4 SECTION)
PILOT PIPING (1)
PILOT PIPING (2)
PILOT PIPING (3)
PILOT PIPING (4)
PILOT PIPING (5)
PILOT PIPING (6)
PILOT PIPING (7)
PILOT PIPING (8)
PILOT PIPING (9)
PILOT PIPING (10)
PILOT PIPING (1)(WITH BLADE)
PILOT PIPING (2)(WITH BLADE)
ELECTRIC PARTS (1)
ELECTRIC PARTS (2)
ELECTRIC PARTS (3)
ELECTRIC PARTS (4)
ELECTRIC PARTS (5-1)
ELECTRIC PARTS (5-2)
ELECTRIC PARTS (5-3)
ELECTRIC PARTS (6)
ELECTRIC PARTS (7)
ELECTRIC PARTS (QUICK COUPLER)
ELECTRIC PARTS (QUICK COUPLER)(PLUG)
START SWITCH
SWITCH (QUICK COUPLER)
BOOM LIGHT (R)(WITH LIGHT COVER (L,R))
ENGINE CONTROL UNIT
ENGINE STOP SWITCH
AERIAL ANGLE CONTROL UNIT
AERIAL ANGLE PARTS
SATELLITE COMMUNICATIONS TERMINAL (IRIDIUM)
CONTROLLER (MC)
CONTROLLER (PLCU)
MONITOR CONTROLLER
FRONT HEAD LAMP (2 LAMP WITH RAIN GUARD UPPER)
FRONT HEAD LAMP (4 LAMP WITH RAIN GUARD UPPER)
FRONT HEAD LAMP (2 LAMP)(OPG TOPGUARD)
FRONT HEAD LAMP (4 LAMP)(OPG TOPGUARD)
REAR HEAD LAMP (CAB)
REAR HEAD LAMP (FLOOR)
ROTATING BEACON (CAB)
ROTATING BEACON (FLOOR)
ROTATING BEACON SUPPORT SOCKET
HORN
REAR CAMERA
TRAVEL MOTION ALARM DEVICE
TRAVEL MOTION ALARM DEVICE (CAB)
ELECTRIC TYPE CONTROL PARTS (CAB)
WINDOW WASHER
WINDOW WASHER (FRONT WINDOW)
SIDE CAMERA (LEFT)
SIDE CAMERA (RIGHT)
SIDE CAMERA PARTS
PERIPHERAL BEACON PARTS (1)
PERIPHERAL BEACON PARTS (2)
OVER LOAD ALARM DEVICE
OVER LOAD ALARM DEVICE (CAB)
MICROPHONE
WIDE VIEW WIPER HARNESS
WIDE VIEW WIPER (CURVED SURFACE LAMINATED GLASS)
OIL MONITORING SENSOR (1)
OIL MONITORING SENSOR (2)
CAB (SINGLE WIPER)
ANTENNA (IRIDIUM)
CAB (LAMINATED GLASS)(WIDE VIEW WIPER)
CAB GUARD (OPG LEVELⅡTOP)
CAB GUARD (OPG LEVELⅡFRONT)
SUNSCREEN ROLLER TYPE (FRONT WINDOW, RIGHT WINDOW)
SUNSCREEN ROLLER TYPE (REAR WINDOW)
SUNSCREEN ROLLER TYPE HOLDER
CAB GROUP (1)
CAB GROUP (2)
ANCHOR BOLT
CAB PARTS
CAB MIRROR
RAIN GUARD
FRONT HEAD LAMP, RAIN GUARD SUPPORT
HANDRAIL (CAB)
WITHOUT WIPER PARTS
AFL (AUXILIARY FUNCTION LEVER)(FRONT, SWING)(2Ch)
AFL (AUX. FUNCTION LEVER)PARTS
PILOT VALVE (FRONT, SWING)
CONTROL LEVER (TRAVEL)
PILOT VALVE (TRAVEL)
PEDAL (L)
PEDAL (R)
LOCK LEVER
CONSOLE
CONSOLE COVER
BLADE CONTROL
RIGHT COVER (1)
RIGHT COVER (2)
RADIO (AM/FM/AUX/BT/DAB)
REAR BOX (12V POWER SUPPLY)
POWER UNIT (12V)
FLOOR PLATE
FLOOR PARTS
AIR SUSPENSION SEAT PARTS (1)(WITH HEATER)(GRAMMER)
AIR SUSPENSION SEAT PARTS (2)(WITH HEATER)(GRAMMER)
SEAT STAND PARTS (CONSOLE)
HEATER SEAT PARTS
SEAT STAND
FLOOR MAT (FRONT)
FLOOR MAT (REAR)(STD)
LEVEL
AIR CONDITIONER (1)
AIR CONDITIONER (2)
AIR CONDITIONER (3)
AIR CONDITIONER (4-1)
AIR CONDITIONER (4-2)
HEATER PIPING
DUCT
DUCT (WITH AIR CONDITIONER)
TRACK FRAME (WITHOUT BLADE)(WITH UNDER COVER SEAT)
TRACK FRAME (WITH BLADE)(WITH UNDER COVER SEAT)
TRACK GUARD (X2)
TRACK GUARD (X4)
ADDITIONAL STEP
TRACK UNDER COVER
SWING BEARING
SWING BEARING PARTS (UNDERCARRIAGE)
TRAVEL DEVICE
TRAVEL DEVICE SUPPORT
TRACK SPRING
UPPER ROLLER
LOWER ROLLER
LOWER ROLLER SUPPORT
TRACK LINK 500mm TRIPLE GROUSER SHOE
TRACK LINK 600mm TRIPLE GROUSER SHOE
TRACK LINK 700mm TRIPLE GROUSER SHOE
TRACK LINK 500mm TRIPLE GROUSER SHOE (REINFORCED)
TRACK LINK 600mm TRIPLE GROUSER SHOE (REINFORCED)
TRACK LINK 700mm TRIPLE GROUSER SHOE (REINFORCED)
CENTER JOINT (WITHOUT BLADE)
CENTER JOINT SUPPORT (UPPERSTRUCTURE)(WITHOUT BLADE)
CENTER JOINT (WITH BLADE)
CENTER JOINT SUPPORT (TRACK)
BLADE PIPING
TRAVEL PIPING (1)
TRAVEL PIPING (2)
TRAVEL MOTOR COVER
BLADE (BOLT-ON CUTTING EDGE)
WIDE BLADE (BOLT-ON CUTTING EDGE)
COVER (WITHOUT BLADE)
BOOM 4.60m (QUICK COUPLER PIPING, MULTI BRACKET SEAT)
BOOM PARTS (MONO-BOOM)
ARM 2.52m (WITH BREAKER, ASSIST, QUICK COUPLER PIPING, MULTI BRACKET SEAT, UNDER SIDE REINFORCEMENT)
ARM 3.01m (WITH BREAKER, ASSIST, QUICK COUPLER PIPING, MULTI BRACKET SEAT, UNDER SIDE REINFORCEMENT)
ARM PARTS (2.52m)
ARM PARTS (3.01m)
BUCKET 0.52m3 (JIS A8403-4;2012)
A LINK
B LINK
B LINK (REINFORCED)
FRONT PIPING (MONO-BOOM)
FRONT PIPING (ARM 2.52m)
FRONT PIPING (ARM 3.01m)
LUBRICATE PIPING (MONO-BOOM)
BOOM CYLINDER (R)(WITH HOSE RUPTURE VALVE)
BOOM CYLINDER (L)(WITH HOSE RUPTURE VALVE)
FELT BAND
ARM CYLINDER(WITH HOSE RUPTURE VALVE)(MONO-BOOM)
BUCKET CYLINDER
BUCKET CYLINDER (QUICK COUPLER)
HOSE RUPTURE VALVE PIPING (1)(BOOM)
HOSE RUPTURE VALVE PIPING (2)(BOOM)
HOSE RUPTURE VALVE PIPING (1)(ARM)
HOSE RUPTURE VALVE PIPING (2)(ARM)(MONO-BOOM)
DRAIN PIPING (QUICK COUPLER)
DRAIN PIPING (MONO-BOOM)(QUICK COUPLER)
QUICK COUPLER PIPING (1)
QUICK COUPLER PIPING (1)(PLUG)
QUICK COUPLER PIPING (2)(MONO-BOOM)(HYDRAULIC TYPE)
QUICK COUPLER PIPING (3)(ARM 2.52m)
QUICK COUPLER PIPING (3)(ARM 3.01m)
BREAKER, CRUSHER PIPING (MAIN)
BREAKER, CRUSHER PIPING (MONO-BOOM)
BREAKER, CRUSHER PIPING (ARM 2.52m)
BREAKER, CRUSHER PIPING (ARM 3.01m)
SOLENOID VALVE (FLOW RATE SELECTOR)
COMMON PIPING EXCEPT NPK
ADDITIONAL PUMP PARTS (CLOSE)
ACCUMULATOR
MAIN PIPING (PTO/V)
PILOT PIPING (PTO/V)
PILOT PIPING (PTO/V, FLOW RATE SELECTOR)
PILOT PIPING (FLOW RATE SELECTOR)
PILOT PIPING (AFL (AUX. FUNCTION LEVER))
ELECTRIC TYPE CONTROL PARTS (1)(AFL (AUXILIARY FUNCTION LEVER), BREAKER, ADDITIONAL PUMP)
ELECTRIC TYPE CONTROL PARTS (2)(AFL (AUXILIARY FUNCTION LEVER), BREAKER, ADDITIONAL PUMP)
ASSIST PIPING (ARM 2.52m)
ASSIST PIPING (ARM 3.01m)
ASSIST PIPING (MONO-BOOM)
PLUG (FOR AFL)
TOOLS
NAME PLATE (1)
NAME PLATE (2)
NAME PLATE (3)
