Hitachi Excavator ZX130-7H Workshop Manual WDHD60-EN-00
Brand: Hitachi
Type of Machine: Excavator
Type of Manual: Workshop Manual
Model: Hitachi ZX130-7H Excavator
Part Number: WDHD60-EN-00
Publication Date: 2023
Number of Pages: 931 Pages
INTRODUCTION
CONTENTS
GENERAL
Brand: Hitachi
INTRODUCTION
To The Reader
Additional References
Manual Composition
Page Number
Trademark
Safety Alert Symbol and Headline Notations
Units Used
SYMBOL AND ABBREVIATIONSymbol and Abbreviation
CONTRASTING LIST OF PART NAMEContrasting List of Part Name between Technical Manual and Parts Catalog
SAFETYRecognize Safety Information
Understand Signal Words
Follow Safety Instructions
Prepare for Emergencies
Wear Appropriate Clothing
Inspect Machine
General Precautions for the Cab
Use Handrail and Steps
Adjust the Operator's Seat
Ensure Safety Before Leaving or Standing up from Operator's Seat
Fasten Your Seat Belt
Move and Operate Machine Safely
Start the Engine Only from Operator's Seat
Jump Starting
Keep Riders off Machine
Precautions for Operations
Perform Job Site Risk Assessment Beforehand
Install OPG Guard
Restriction of Attachment Installation
Provide Signals for Jobs Involving Multiple Machines
Confirm Direction of Machine Travel
Drive Machine Safely
Avoid Injury from Rollaway Accidents
Avoid Accidents from Reversing and Swing Operation
Keep People Clear from Working Area
Never Position the Bucket Over Anyone
Avoid Undercutting
Avoid Tipping
Never Undercut a High Bank
Dig with Caution
Caution with an Overhead Obstacle
Avoid Power Lines
Precautions for Lightning
Object Handling
Protect Against Flying Debris and Falling Object
Park Machine Safely
Handle Fluids Safely−Avoid Fires
Transport Safely
Practice Maintenance Safely
Warn Others of Service Work
Support Machine Properly
Stay Clear of Moving Parts
Prevent Parts from Flying
Avoid Injury from Attachment Falling Accident
Prevent Burns
Replace Rubber Hoses Periodically
Avoid High-Pressure Fluids
Prevent Fires
Check for Oil Leaks:
Check for Short circuits:
Clean up Flammable Materials:
Check Key Switch:
Check Heat Shields:
Evacuating in Case of Fire
Beware of Exhaust Fumes
Precautions for Welding and Grinding
Avoid Applying Heat to Lines Containing Flammable Fluids
Precautions for Handling Accumulator and Gas Damper
Beware of Asbestos and Silica Dust and Other Contamination
Prevent Battery Explosions
Service Air Conditioning System Safely
Dispose of Waste Properly
Never Ride Attachment
Notes on Aftertreatment Device
Precautions for Communication Terminal
Precautions for Communication Terminal Equipment
Notes on Protection by Operator's Station when the Machine Rolls Over
Before Returning the Machine to the Customer
SECTION AND GROUP CONTENTSCONTENTS
GENERAL
Precautions for Disassembling and Assembling
Tightening
Painting
Bleeding Air
Preparation
MAINTENANCE STANDARDUpperstructure
Undercarriage
Front Attachment
UPPERSTRUCTURECab
Counterweight
Main Frame
Radiator Assembly
Hydraulic Oil Tank
Pump Device
Control Valve
Swing Device
Pilot Valve
Solenoid Valve
Signal Control Valve
DEF Tank
Coolant Control Valve
DEF Supply Module
UNDERCARRIAGESwing Bearing
Travel Device
Center Joint
Track Adjuster
Upper and Lower Rollers
Track
Blade Cylinder
FRONT ATTACHMENTFront Attachment
Cylinder
SERVICE MANUAL REVISION REQUEST FORM
- Hitachi EX120-2 Excavator Parts Catalog
- Hitachi EX200-2 Service Manual
- Hitachi Excavator ZX240-3 to ZX250LCK-3 Parts Catalog P1V1-1-1 EN JP
- Hitachi Zaxis 200,225,230 Class Hydraulic Circuit Diagram
- Hitachi EX 750 -5 EX 800 H-5 Full Service Manual
- Hitachi Zaxis 200,225,240,270-3 Service Manual
- Hitachi WIN DR Technical Manual (a PC version Dr.ZX)
- Hitachi ZAXIS ZX330-3 TO ZX350-3 Parts Manual
- Isuzu Industrial Diesel Engine 4JJ1X/4-6HK1X/6WG1X Tier3
- Hitachi Zaxis 200-3 Hydraulic Excavator Technical Manual
- Hitachi Zaxis 70,70LC Hydraulic Circuit Diagram
- Hitachi EX200-3 Excavator Parts Catalog
- Hitachi Hydraulic Excavator ZX50 Technical Manual
- Hitachi ZW 220 - ZW 250 Wheel Loader - Workshop Manual
- Hitachi EX120 Service Manual
