Hitachi Excavator ZX110 to ZX135UR Technical Manual (Operational Principle) TO187-E-04
Brand: Hitachi
Type of Machine: Excavator
Type of Manual: Technical Manual (Operational Principle)
Model: Hitachi ZX110, ZX125US, ZX110M, ZX135US, ZX120, ZX135UR, ZX130, ZX130LCN Excavator
Part Number: TO187-E-04
Number of Pages: 318 Pages
SECTION 1 GENERAL
Brand: Hitachi
SECTION 1 GENERAL
Specifications
SPECIFICATIONS
WORKING RANGES
Component Layout
MAIN COMPONENT LAYOUT
ELECTRICAL COMPONENT LAYOUT (Overview)
ELECTRICAL SYSTEM (Relays and Related Equipment)
ELECTRICAL SYSTEM (Monitors and Switches)
PUMP DEVICE
SWING DEVICE
CONTROL VALVE
SIGNAL CONTROL VALVE
SOLENOID VALVE UNIT
8-UNIT SOLENOID VALVE UNIT
BLADE CONTROL VALVE
POSITIONING CONTROL VALVE
TRAVEL DEVICE
Component Specifications
ZAXIS110/110M/125US/135UR
ZAXIS120/130/130LCN/135US
SECTION 2 SYSTEMControl System
OUTLINE
ENGINE CONTROL
PUMP CONTROL
VALVE CONTROL
OTHER CONTROLS
Front Control System
OUTLINE
FRONT MOVEMENT CONTROL
OUTLINE
PILOT CIRCUIT
MAIN CIRCUIT
OUTLINE
MAIN CIRCUIT
ELECTRIC POWER CIRCUIT (KEY SWITCH: OFF)
INDICATOR LIGHT CHECK CIRCUIT (KEY SWITCH: ON)
ACCESSORY CIRCUIT
PREHEAT CIRCUIT (KEY SWITCH: ON /START)
STARTING CIRCUIT (KEY SWITCH:START)
CHARGING CIRCUIT (KEY SWITCH: ON)
ENGINE STOP CIRCUIT
SERGE VOLTAGE PREVENTION CIRCUIT
SECTION 3 COMPONENT OPERATIONPump Device
OUTLINE
MAIN PUMP
REGULATOR
SOLENOID VALVE
BLADE PUMP (ZAXIS135UR ONLY) PILOT PUMP
N SENSOR (ENGINE SPEED SENSOR)
PUMP DELIVERY PRESSURE SENSOR
PUMP CONTROL PRESSURE SENSOR
Swing Device
OUTLINE
SWING REDUCTION GEAR
SWING MOTOR
SWING PARKING BRAKE
VALVE UNIT
Control Valve
OUTLINE
HYDRAULIC CIRCUIT
FLOW COMBINER VALVE
MAIN RELIEF VALVE
OVERLOAD RELIEF VALVE
REGENERATIVE VALVE
ANTI-DRIFT VALVE
FLOW RATE CONTROL VALVE
BYPASS SHUT-OUT VALVE
AUXILIARY FLOW COMBINING VALVE
Pilot Valve
OUTLINE
OPERATION
Travel Device
OUTLINE
TRAVEL REDUCTION GEAR
TRAVEL MOTOR
PARKING BRAKE
TRAVEL MODE CONTROL
TRAVEL BRAKE VALVE
Signal Control Valve
OUTLINE
PILOT PORT
SHUTTLE VALVE
SHOCKLESS VALVE
PUMP 1 AND PUMP 2 FLOW RATE CONTROL VALVES
BUCKET FLOW RATE CONTROL VALVE CONTROL SPOOL, FLOW COMBINER VALVE CONTROL SPOOL, SWING PARKING BRAKE RELEASE SPOOL
Others (Upperstructure)
PILOT SHUT-OFF VALVE
SOLENOID VALVE UNIT
OFFSET ANTI-DRIFT VALVE (ZAXIS 135UR ONLY)
HOLDING VALVE
PILOT RELIEF VALVE
EC MOTOR
Others (Undercarriage)
SWING BEARING
CENTER JOINT
TRACK ADJUSTER
SERVICE MANUAL REVISION REQUEST FORM
- Hitachi EX120-2 Excavator Parts Catalog
- Hitachi EX200-2 Service Manual
- Hitachi Excavator ZX240-3 to ZX250LCK-3 Parts Catalog P1V1-1-1 EN JP
- Hitachi Zaxis 200,225,230 Class Hydraulic Circuit Diagram
- Hitachi EX 750 -5 EX 800 H-5 Full Service Manual
- Hitachi Zaxis 200,225,240,270-3 Service Manual
- Hitachi WIN DR Technical Manual (a PC version Dr.ZX)
- Hitachi ZAXIS ZX330-3 TO ZX350-3 Parts Manual
- Isuzu Industrial Diesel Engine 4JJ1X/4-6HK1X/6WG1X Tier3
- Hitachi Zaxis 200-3 Hydraulic Excavator Technical Manual
- Hitachi Zaxis 70,70LC Hydraulic Circuit Diagram
- Hitachi EX200-3 Excavator Parts Catalog
- Hitachi Hydraulic Excavator ZX50 Technical Manual
- Hitachi ZW 220 - ZW 250 Wheel Loader - Workshop Manual
- Hitachi EX120 Service Manual
