Hitachi Excavator EX75UR-5 EX75US-5 Technical Manual (Troubleshooting) TT197E-00
Brand: Hitachi
Type of Machine: Excavator
Type of Manual: Technical Manual (Troubleshooting), Electric and Hydraulic Diagrams
Model: Hitachi EX75UR-5 EX75US-5 Excavator
Part Number: TT197E-00
Number of Pages: 250 Pages
INTRODUCTION
SAFETY
SECTION 4 OPERATIONAL PERFORMANCE TEST
Brand: Hitachi
INTRODUCTION
SAFETY
GROUP 1 Introduction
OPERATIONAL PERFORMANCE TESTS
PREPARATION FOR PERFORMANCE TESTS
GROUP 2 Standard
OPERATIONAL PERFORMANCE STANDARD TABLE
MAIN PUMP P-Q DIAGRAM
SENSOR ACTIVATING RANGE
GROUP 3 Engine Test
ENGINE SPEED
ENGINE COMPRESSION PRESSURE
VALVE CLEARANCE
NOZZLE CHECK
INJECTION TIMING
GROUP 4 Excavator Test
TRAVEL SPEED
TRACK REVOLUTION SPEED
MISTRACK CHECK
TRAVEL MOTOR LEAKAGE
SWING SPEED
SWING FUNCTION DRIFT CHECK
SWING MOTOR LEAKAGE
MAXIMUM SWINGABLE SLANT ANGLE
SWING BEARING PLAY
HYDRAULIC CYLINDER CYCLE TIME
DIG FUNCTION DRIFT CHECK
CONTROL LEVER OPERATING FORCE
CONTROL LEVER STROKE
BOOM RAISE/SWING COMBINED OPERATION CHECK
GROUP 5 Component Test
PRIMARY PILOT PRESSURE
SECONDARY PILOT PRESSURE
MAIN RELIEF VALVE SET PRESSURE
OVERLOAD RELIEF VALVE SET PRESSURE
MAIN PUMP FLOW RATE MEASUREMENT
SWING MOTOR DRAINAGE
TRAVEL MOTOR DRAINAGE
GROUP 6 Adjustment
ENGINE SPEED ADJUSTMENT AND ENGINE LEARNING
BOOM LOWERING METHOD WHEN ENGINE STALLING
CHECK OF GOVERNOR LEVER AND FUEL CUT LEVER POSITION
ASSEMBLY AND ADJUSTMENT OF LINK FOR ARM ANGLE SENSOR (EX75UR-5)
INITIAL SETTING OF THE ANGLE SENSOR (EX75UR-5)
INITIALIZING THE DEPTH LIMIT CONTROL SYSTEM (EX75UR-5)
SECTION 5 TROUBLESHOOTINGGROUP 1 General
INTRODUCTION
DIAGNOSTIC PROCEDURES
Dr.EX OPERATION
MAIN CONTROLLER FAULT CODE LIST
AUTO-MARCCINO CONTROL UNIT FAULT CODE LIST (EX75UR-5)
MAIN CONTROLLER MONITORING FUNCTION
AUTO-MARCCINO CONTROL UNIT MONI-TORING FUNCTION (EX75UR-5)
Dr.EX SPECIAL FUNCTION (Service Mode) (EX75UR-5)
GROUP 2 Component Layout
MAIN COMPONENTS
ELECTRICAL SYSTEM (OVERVIEW)
ELECTRICAL SYSTEM (Monitor and Switches)
PUMP DEVICE
SWING DEVICE
TRAVEL DEVICE
COMPONENT IN CONTROL VALVE
GROUP 3 Troubleshooting A
TROUBLESHOOTING A PROCEDURE
FAULT CODE 01
FAULT CODE 07
GROUP 4 Troubleshooting B
TROUBLESHOOTING B PROCEDURE
RELATIONSHIP BETWEEN MACHINE SYMPTOMS AND PROBLEM PARTS
CORRELATION BETWEEN TROUBLE SYMPTOMS AND PART FAILURES
ENGINE SYSTEM TROUBLESHOOTING
ALL ACTUATOR SYSTEM TROUBLESHOOTING
FRONT ATTACHMENT SYSTEM TROUBLESHOOTING
SWING SYSTEM TROUBLESHOOTING
TRAVEL SYSTEM TROUBLESHOOTING
BLADE SYSTEM TROUBLESHOOTING
GROUP 5 Troubleshooting C
TROUBLESHOOTING C PROCEDURE (Troubleshooting for Monitor)
MALFUNCTION OF COOLANT TEMPERATURE GAUGE
MALFUNCTION OF FUEL GAUGE
MALFUNCTION OF INDICATOR LIGHT CHECK SYSTEM
MALFUNCTION OF ALTERNATOR INDICATOR
MALFUNCTION OF ENGINE OIL PRESSURE INDICATOR
MALFUNCTION OF OVERHEAT INDICATOR
MALFUNCTION OF FUEL LEVEL INDICATOR
MALFUNCTION OF AIR FILTER RESTRICTION INDICATOR
MALFUNTION OF BUZZER
MALFUNCTION OF HOUR METER
GROUP 6 Troubleshooting D
TROUBLESHOOTING D PROCEDURE (EX75UR-5)
FAULT CODE 03
FAULT CODE 05, 06
FAULT CODE 07, 08
FAULT CODE 09
FAULT CODE 11, 12, 13, 17
FAULT CODE 14, 15, 16, 19, 20, 21, 22
FAULT CODE 24
FAULT CODE 40, 41
FAULT CODE 43, 45, 47, 48
FAULT CODE 50, 51, 52, 53
FAULT CODE 60, 61, 62, 63
FAULT CODE 80, 81, 82, 83
FAULT CODE 90
FAULT CODE 91
GROUP 7 Electrical System Inspection
PRECAUTIONS FOR INSPECTION AND MAINTENANCE
INSTRUCTIONS FOR DISCONNECTING CONNECTORS
FUSE CONTINUITY TEST
FUSIBLE LINK INSPECTION
BATTERY VOLTAGE CHECK
HOW TO TROUBLESHOOTING ALTERNATOR MALFUNCTIONS
CONTINUITY CHECK
VOLTAGE AND CURRENT CHECK
CHECK BY FALSE SIGNAL
TEST HARNESS
THE ATTACHED DIAGRAM LISTEX75UR- HYDRAULIC CIRCUIT DIAGRAM
EX75US- HYDRAULIC CIRCUIT DIAGRAM
EX75UR-5 ELECTRICAL CIRCUIT DIAGRAM
EX75US-5 ELECTRICAL CIRCUIT DIAGRAM
EX75UR-5 CONNECTORS
EX75US-5 CONNECTORS
EX75UR-5 ENGINE HARNESS
EX75US-5 ENGINE HARNESS
EX75UR-5 CAB HARNESS
EX75US-5 CAB HARNESS
- Hitachi EX120-2 Excavator Parts Catalog
- Hitachi EX200-2 Service Manual
- Hitachi Excavator ZX240-3 to ZX250LCK-3 Parts Catalog P1V1-1-1 EN JP
- Hitachi Zaxis 200,225,230 Class Hydraulic Circuit Diagram
- Hitachi EX 750 -5 EX 800 H-5 Full Service Manual
- Hitachi Zaxis 200,225,240,270-3 Service Manual
- Hitachi WIN DR Technical Manual (a PC version Dr.ZX)
- Hitachi ZAXIS ZX330-3 TO ZX350-3 Parts Manual
- Isuzu Industrial Diesel Engine 4JJ1X/4-6HK1X/6WG1X Tier3
- Hitachi Zaxis 200-3 Hydraulic Excavator Technical Manual
- Hitachi Zaxis 70,70LC Hydraulic Circuit Diagram
- Hitachi EX200-3 Excavator Parts Catalog
- Hitachi Hydraulic Excavator ZX50 Technical Manual
- Hitachi ZW 220 - ZW 250 Wheel Loader - Workshop Manual
- Hitachi EX120 Service Manual
