Hitachi Excavator EX1900-6 Performance Check & Troubleshooting Manual TTLA-0767-EX
Brand: Hitachi
Type of Machine: Excavator
Type of Manual: Performance Check & Troubleshooting Manual, Error Code
Model: Hitachi EX1900-6 Excavator
Part Number: TTLA-0767-EX
Number of Pages: 229 Pages
MATERIALS TOP
PERFORMANCE CHECK & TROUBLESHOOTING
SECTION 4 OPERATIONAL PERFORMANCE TEST
Brand: Hitachi
MATERIALS TOP
Group 1 Introduction
Operational Performance Test
Preparation for Performance Tests
Group 2 Standard
Operational Performance Standard Table
Main Pump P-Q Diagram
Main Pump Pi-Q Diagram
Oil Cooler Fan Motor Drive PumpP-Q Diagram
Oil Cooler Fan Motor Drive PumpPi-Q Diagram
Electric Lever
Group 3 Engine Test
Engine Speed
Group 4 Excavator Test
Travel Speed
Track Revolution Speed
Mistrack
Travel Parking Leakage
Swing Speed
Swing Function Drift
Swing Motor Leakage
Maximum Swingable Slant Angle
Swing Bearing Play
Hydraulic Cylinder Cycle Time
Dig Function Drift Check
Control Lever Operating Force
Control Lever Stroke
Boom Raise/Swing Combined Operation Check
Group 5 Component Test
Primary Pilot Pressure Check
EHC Valve Secondary Pilot Pressure
DQR Valve Secondary Pilot Pressure
Main Relief Pressure, Relief Pressure
Overload Relief Valve Set Pressure
Main Pump Flow Rate Measurement
Oil Cooler Fan Motor Drive Pump Flow Rate Measurement
Swing Motor Drainage
Travel Motor Drainage
SECTION 5 TROUBLESHOOTINGGroup 1 General
Introduction
Diagnosing Procedure
Starting Check Indication
Alarm Indication
Fault Diagnosis Indication
Automatic Snapshot Indication
Monitor And Manual Snapshot Indication
Recorded Data
Maintenance History Display
Life Data Display
Machine Information Indication
Various Setup Indication
Maintenance Setup
Group 2 Cross Reference Table
Electrical Circuit Diagram (1/3)
Electrical Circuit Diagram (2/3)
Electrical Circuit Diagram (3/3)
Hydraulic Circuit
Group 3 Component Layout
Main Components (Overview)
Around Pump
Pilot Panel (Operation Circuit)
Pilot Panel (Back of Control Valve)
Undercarriage
Fast-Filling Panel
Electrical System (Overview)
Around Radiator
Water Tank
Air Cleaner
Around Pump
Swing Device
Control Valve
Travel Device
Center Joint
EHC Valve (Main Pump Control)
EHC Valve (Electric Lever Control)
Sliding Fold-In Ladder
Auto-Lubrication Device
Group 4 Troubleshooting A
Troubleshooting A Procedure
Fault Code List
Group 5 Troubleshooting B
Troubleshooting B Procedure
How to Read Fault Codes
Fault Code for Engine
Group 6 Troubleshooting C
Troubleshooting C Procudure
Diagnosis by blinking of Indicator
Group 7 Electrical System Inspection
Precautions for Inspection and Maintenance
Instructions for Disconnecting Connectors
Battery Voltage Check
Fusible Link Inspection
Fuse Inspection
Alternator Check
Voltage Check
Check by False Signal
Continuity Check
Circuit Check by Lamp Harness
- Hitachi EX120-2 Excavator Parts Catalog
- Hitachi EX200-2 Service Manual
- Hitachi Excavator ZX240-3 to ZX250LCK-3 Parts Catalog P1V1-1-1 EN JP
- Hitachi Zaxis 200,225,230 Class Hydraulic Circuit Diagram
- Hitachi EX 750 -5 EX 800 H-5 Full Service Manual
- Hitachi Zaxis 200,225,240,270-3 Service Manual
- Hitachi WIN DR Technical Manual (a PC version Dr.ZX)
- Hitachi ZAXIS ZX330-3 TO ZX350-3 Parts Manual
- Isuzu Industrial Diesel Engine 4JJ1X/4-6HK1X/6WG1X Tier3
- Hitachi Zaxis 200-3 Hydraulic Excavator Technical Manual
- Hitachi Zaxis 70,70LC Hydraulic Circuit Diagram
- Hitachi EX200-3 Excavator Parts Catalog
- Hitachi Hydraulic Excavator ZX50 Technical Manual
- Hitachi ZW 220 - ZW 250 Wheel Loader - Workshop Manual
- Hitachi EX120 Service Manual
