Hyundai
86
176,684
Hitachi Excavator EX1200-6 Technical Manual (Operational Principle) TO18J-E-00
Brand: Hitachi
Type of Machine: Excavator
Type of Manual: Technical Manual(Operational Principle)
Model: Hitachi EX1200-6 Excavator
Part Number: TO18J-E-00
Publication Date: 2008
Number of Pages: 314 Pages
SECTION 1 GENERAL
Group 1 Specifications​
Specifications​
Working Range (Backhoe)​
Working Range (BE Backhoe)​
Working Range (Loading Shovel)​
Group 2 Component Layout​
Main Component Layout​
Pump Device​
Control Valve​
Utility Box​
Inside of Cab​
Battery Box​
Engine​
Radiator​
Group 3 Component Specifications​
Engine​
Engine Accessories​
Hydraulic Devices​
Electrical Equipment​
SECTION 2 SYSTEM
Group 1 Controller​
Outline​
CAN: Controller Area Network (Network Provided for Machine)​
MC: Main Controller​
ECM: Engine Control Module​
DLU: Data Logging Unit​
ICF: Information Controller​
Monitor Unit​
Group 2 Control System​
Outline​
Engine Control​
Pump Control​
Valve Control​
Other Controls​
Group 3 Hydraulic System​
Outline​
Pilot Circuit​
Main Circuit​
Transmission Oil Cooling Circuit​
Group 4 Electrical System​
Outline​
Main Circuit​
Electric Power Circuit (Key Switch: OFF)​
Accessory Circuit (Key Switch: ACC)​
Starting Circuit (Key Switch: START)​
Charging Circuit (Key Switch: ON)​
Surge Voltage Prevention Circuit​
Pilot Shut-Off Circuit (Key Switch: ON)​
Security Lock Circuit​
Engine Stop Circuit (Key Swith: OFF)​
Security Horn Circuit​
Work Light Circuit​
SECTION 3 COMPONENT OPERATION
Group 1 Pump Device​
Outline​
Main Pump, Fan Pump​
Regulator for Main Pump​
Regulator for Fan Pump​
Pumps 1, 2, 3 Control Solenoid Valves,Fan Pump Control Solenoid Valve​
Pilot Pump, Pump Transmission OilCirculation Pump​
Pump Delivery Pressure Sensor​
Pump Regulator Pressure (Flow RateControl Pressure) Sensor​
Group 2 Swing Device​
Outline​
Swing Reduction Gear​
Swing Motor​
Swing Parking Brake​
Valve Unit​
Group 3 Control Valve​
Outline​
Hydraulic Circuit​
Main Relief Valve​
Overload Relief Valve (With Make-Up Function)​
Boom Overload Relief Control Valve​
Flow Combiner Valve​
Anti-Drift Valve​
Regenerative Valve​
Flow Rate Control Valve​
Group 4 Pilot Valve​
Outline​
Operation​
Shockless Function (Only for Travel Pilot Valve)​
Group 5 Travel Device​
Outline​
Travel Reduction Gear​
Travel Motor​
Travel Brake Valve​
Parking Brake​
Group 6 Signal Control Valve​
Outline​
Pilot Port​
Shuttle Valve​
Shockless Valve​
Arm Flow Rate Control ValveControl Spool,Flow Combiner Valve Control Spool,Swing Parking Brake Release Spool​
Group 7 Other (Upperstructure)​
Pilot Shut-Off Solenoid Valve​
4-Spool Solenoid Valve Unit​
Pilot Relief Valve​
Shockless Valve​
Accumulator​
Oil Cooler Fan Motor​
Auto-Lubrication System​
Distribution Valve​
Group 8 Other (Undercarriage)​
Swing Bearing​
Center Joint​
Track Adjuster​
SERVICE MANUAL REVISION REQUEST FORM
