Hyundai
86
176,834
Hitachi 6WG1 Tier 2 Engine Manual
Brand: Hitachi
Type of Manual: Engine Manual
Model: Hitachi 6WG1 Tier 2 Engine
Applicable Model ZX870-5G, ZX870LC-5G, ZX870H-5G, ZX870LCH-5G, ZX870LCR-5G
Number of Pages: 253 Pages
General Repair Instruction​
Illustration Arrows​
Abbreviations Charts​
Nut and Bolt Angular Tightening Method​
Standard Bolt Torque Specifications​
Recommended Thread Locking Agents​
Main Data and Specification​
Performance Curve​
Engine External Drawing​
Service Standard​
Special Tools​
Troubleshooting​
Lubricant Application​
Sealant Application​
Service Information
Identification​
Lubrication System​
Fuel System​
Cooling System​
Valve Clearance Adjustment​
Compression Pressure Measurement​
Recommended Lubricants​
Engine Oil Viscosity Chart​
Engine Mechanical
Service Precautions​
General Description​
Fan Center​
Turbocharger​
Exhaust Manifold​
Inlet Manifold​
Water Pump​
Alternator​
Oil Cooler​
Injection Pump​
Coupling Assembly​
Cylinder Head​
Rocker Arm and Shaft Assembly​
Camshaft​
Timing Gears​
Flywheel Housing​
Oil Pan​
Piston​
Crankshaft​
Crank Pulley​
Flywheel​
Cylinder Block​
Engine Cooling
Water Pump​
Thermostat​
Engine Fuel
Fuel Filter​
Injection Nozzle Holder​
Injection Pump​
Injection Nozzle Holder-Tow-Stage Injection Type​
Starting and Charging
Alternator​
Starter Motor​
Engine Lubrication
Service Precaution​
Oil Pump​
Oil Cooler​
Engine Induction
Service Precaution​
Turbocharger​
