Hinowa Platform LIGHT LIFT 2614 Operation Manual MULL2614022401
Brand: Hinowa
Type of Machine: Platform
Type of Manual: Operator, Safety, Maintenance and Service Manual, Electric and Hydraulic Diagram
Model: Hinowa LIGHT LIFT 2614 Platform
Part Number: MULL2614022401
Publication Date: 2024
Number of Pages: 260 Pages
1. Contact
2. Preface
4. Normative reference
5. Warranty
6. Liability
7. EC Declaration Conformity
8. Technical informations
17. Wiring diagram
18. Register of inspections and repairs
Brand: Hinowa
1. Contact
2. Preface
2.1. Attention - danger
2.2. Warning
2.3. Note
3. How to use the manual4. Normative reference
5. Warranty
6. Liability
8.1. Description of the machine
8.2. Machine identification plate
8.3. Overall dimensions of the machine
8.4. Technical data
8.4.1. Technical data Diesel engine
8.4.2. Hydraulic system technical specifications
8.4.3. Electrical system technical specifications thermal engine
8.4.4. Electrical system technical specifications lithium
8.5. Terminology
8.6. General safety standards
8.7. Clothing and protective equipment
8.8. Safety valves and electrical system safety components
8.9. Fire prevention
8.10. Preventing damage caused by washing the machine
8.10.1. Cleaning the machine
8.10.2. Washing the outside of the machine
8.10.3. Cleaning the electrical system
8.10.4. After cleaning
8.11. Preventing damage that may be caused by the machine during work
8.12. Safety warnings
8.12.1. Generalities
8.12.2. Noise and Vibration
8.12.3. Decals on the machine
9. Safety device9.1. Battery cut-out switch
9.2. Distributor pressure relief valves
9.3. Cylinder stop valves
9.4. Alignment photocells of the aerial part
9.5. Stabilizer position micro switches
9.6. JIB position micro switch
9.7. Ropes integrity micro switch
9.8. Basket load sensor
9.9. Control protection
9.10. Spirit and electronic level
9.11. Pin locking bolts and nuts
9.12. Safety device electronic control board
9.13. Booms position sensors
9.14. Outrigger joint lock pins
9.15. Ballast weights
10. Instruments and controls10.1. Remote control
10.1.1. Display
10.1.2. Joystick
10.1.3. Push buttons
10.2. Radio control (optional)
10.2.1. Joystick
10.2.2. Buttons
10.3. Foot switch (optional)
10.4. Control position
10.4.1. Control position in the basket
10.4.2. Control position at the ground
10.4.3. Radio control station (optional)
10.4.4. Emergency control position
10.4.5. Maintenance control position
10.5. SkyGuardTM or SkyLineTM system (optional)
11. Emergency device11.1. Emergency stop button
11.2. Hand pump
11.3. Solenoid valves for emergency descent
11.4. Safety device bypass key
11.5. Emergency position controls
11.5.1. Selection panel, emergency stop and starting
11.5.2. Aerial part hydraulic distributor
11.5.3. Tracked undercarriage hydraulic distributor
12. Using the machine12.1. Safety standards to adopt before using the platform
12.1.1. Risk of electrocution
12.1.2. Danger due to atmospheric conditions
12.1.3. Danger due to the work area
12.2. Procedures for correct use
12.2.1. Summary table of operator safety standards
12.3. Working area
12.4. Use of the elevating work platform (MEWP)
12.4.1. Preliminary checks before starting work
12.4.2. Starting the Petrol/Diesel engine
12.4.3. Starting the electric motor
12.4.4. Starting the engines (thermal and lithium) on BiEnergy machines
12.4.5. Stopping the engine/motor
12.4.6. Stopping the motor Lithium version
12.4.7. Transport and stabilisation position
12.4.8. Travel
12.4.9. JIB boom movement for travel
12.4.10. Parking the machine on a slope or on uneven ground
12.4.11. Stabilising and levelling the machine
12.4.12. Automatic lowering and raising of the stabilisers
12.4.13. Track extension
12.4.14. Moving the basket
12.4.15. Manually levelling of the basket
12.4.16. Fibreglass basket
12.5. Aerial part emergency manoeuvres
12.5.1. Activation of emergency descent from the basket
12.5.2. Operating the machine from the emergency control position on the ground if the operator is taken ill
12.5.3. Emergency descent in the case where the stabilisers are accidentally retracted
12.5.4. Emergency descent controlled from the ground using the hand pump in the event of faults on all energy supply systems
12.5.5. Emergency operation of the undercarriage in the event of movements of the aerial part
12.5.6. Emergency operations on the carriage: moving the platform stabilisers using the hand pump to allow the machine to be transported
12.6. Electrical connection of remote control
12.7. Recharging the battery
12.7.1. Battery charging Petrol/Diesel engine
12.7.2. Charging Lithium batteries
12.8. Main intended uses of the platform
12.8.1. Systems
12.8.2. Closed environments
12.8.3. Pruning
12.8.4. Repair and maintenance of roofing and gutters
12.8.5. Painting, sand‑blasting and plastering
12.8.6. Use in marine environments
13. Maintenance13.1. Safety instructions for greasing and lubrication
13.1.1. Table of recommended lbrificants
13.1.2. Greasing points
13.1.3. Greasing the telescopic boom
13.2. Safety instructions for maintenance operations
13.3. Maintenance control position with remote control from the ground
13.4. Periodical maintenance intervals
13.5. Electric motor maintenance
13.6. Inspection and maintenance intervals
13.6.1. A‑ Daily inspections before starting
13.6.2. B- Periodical inspections
13.6.3. C- Annual inspections
13.6.4. D- Structural inspection
13.6.5. E- Maintenance
13.7. General periodical checks
13.8. Maintenance on rubber tracks
13.8.1. Rubber tracks tension check
13.8.2. Tensioning rubber track
13.8.3. Removing rubber track
13.8.4. Installing rubber track
13.9. Checking tightness of nuts and bolts
13.10. Hydraulic oil level check
13.11. Checking for leaks in the hydraulic system
13.12. Checking the condition of the filter cartridge
13.13. Checking that all the plates are present on the machine and intact
13.14. Checking the operating pressures in the hydraulic system
13.15. Checking extension ropes
13.15.1. Checking wear and deformation of ropes and pulleys
13.15.2. Three‑monthly inspection
13.15.3. Ropes Tension Adjustment Procedure
13.16. Check the tension of the extension cables
13.16.1. Five-yearly inspection
13.17. Checking wear of the telescopic arm slide blocks
13.18. Battery Petrol/Diesel engine: maintenance - replacement - disposal
13.19. Battery pack maintenance operating specifications
13.19.1. Handling in dangerous conditions
13.20. Servicing the engine thermic version
13.21. Start-up of the machine after maintenance
14. Safety standards for transport14.1. Removing the basket
14.2. Loading and unloading the machine on transport vehicles using ramps
14.3. Lifting the machine
14.3.1. Lifting the machine using a forklift
14.3.2. Lifting the machine using ropes or chains
14.4. Transporting the machine
15. Service menu on the remote control15.1. Input menu
15.2. Language menù
15.3. Errors menu
15.4. Working hours menu
15.5. Joystick menu
16. Hydraulic system17. Wiring diagram
- Hinowa Boom Lift LL1775-5CP442C3 Parts Manual
- Hinowa Boom Lift LL1775-593442CI Parts Manual
- Hinowa Boom Lift LL2010-313992CM Parts Manual
- Hinowa Mini Dumper HS701-16211200 Parts Catalog
- Hinowa Boom Lift LL20MK3-2H3B7200 Parts Manual
- Hinowa Boom Lift LL1775-5CP442C5 Parts Manual
- Hinowa Boom Lift LL1775-593442CM Parts Manual
- Hinowa Boom Lift LL2010-319992C2 Parts Manual
- Hinowa Mini Dumper HS701-16211400 Parts Catalog
- Hinowa Boom Lift LL1775-5CP442CD Parts Manual
- Hinowa Boom Lift LL1775-593448CM Parts Manual
- Hinowa Boom Lift LL2010-319992C4 Parts Manual
- Hinowa Boom Lift LL20MK3-2H3B9200 Parts Manual
- Hinowa Boom Lift LL1775-5CP442D3 Parts Manual
- Hinowa Boom Lift LL1775-14143200 Parts Manual
