Hino Truck 238 258LP 268 338 Series Workshop Manual
Brand: Hino
Type of Manual: Workshop Manual (Engine)
Model: Hino 238 258LP 268 338 Series, Equipped with J08E-VB and J08E-VC Engine
Number of Pages: 908 Pages
GENERAL INTRODUCTION
Brand: Hino
GENERAL PRECAUTIONS
IDENTIFICATION INFORMATION
HOW TO USE THIS WORKSHOP MANUAL
INTRODUCTION TO DESCRIPTIONS
PRECAUTIONS
SEALANT ON THE TAPERED SCREW FOR PIPING
METRIC INFORMATION
SPECIFIED TORQUE FOR STANDARD BOLTS AND NUTS
SPECIFIED TORQUE FOR FLANGE BOLTS AND NUTS
RECOMMENDED LUBRICANTS
INFORMATION DISPLAY
GLOSSARY
GLOSSARY OF SAE AND HINO TERMS
TERMS CONTRADISTINCTION LIST
TROUBLE SHOOTING - COMPONENTSENGINE BASIC
ENGINE ASSEMBLY
ENGINE ASSEMBLY (COMMON RAIL SYSTEM)
TURBOCHARGER (J08E)
TURBOCHARGER
ALTERNATOR (J08E: REMY 12V-130A, 135A, 180A)
ALTERNATOR
STARTER (J08E)
STARTER
AIR COMPRESSOR (J08E: 340 cm3)
AIR COMPRESSOR
CLUTCH MAIN UNIT
CLUTCH ASSEMBLY (EATON SAS1401)
CLUTCH ASSEMBLY (EATON SAS1402)
AUTOMATIC TRANSMISSION
AUTOMATIC TRANSMISSION ASSEMBLY
TRANSMISSION/TRANSFER CONTROL (EATON MANUAL TRANSMISSION)
TRANSMISSION CONTROL UNIT
TRANSMISSION/TRANSFER CONTROL (ALLISON AUTOMATIC TRANSMISSION)
PROPELLER SHAFT (SPL 100, 140)
PROPELLER SHAFT ASSEMBLY
DIFFERENTIAL CARRIER (MERITOR RS-17, 19, 21 AND 23)
DIFFERENTIAL CARRIER ASSEMBLY
BRAKE EQUIPMENT (MODELS WITH HYDRAULIC BRAKE)
SERVICE BRAKE ASSEMBLY
BRAKE EQUIPMENT (MODELS WITH FULL AIR BRAKE)
SERVICE BRAKE (HYDRAULIC BRAKE)
WHEEL BRAKE (TYPE: 4 PISTON)
SERVICE BRAKE (FULL AIR BRAKE)
AIR DRYER AND RESERVOIR SYSTEM (MODEL: BENDIX AD-IS)
EXHAUST BRAKE
EXHAUST BRAKE SYSTEM
PARKING BRAKE (BOSCH 12)
PARKING BRAKE ASSEMBLY
STEERING EQUIPMENT
STEERING SYSTEM
FRONT AXLE (MFS)
FRONT AXLE (MFS)
REAR AXLE
REAR AXLE
WHEEL AND TIRE
WHEEL AND TIRE
SUSPENSION
LEAF SUSPENSION ASSEMBLY
AIR SUSPENSION ASSEMBLY
CHASSIS FRAME
CHASSIS FRAME
CAB
CAB ASSEMBLY
AIR CONDITIONING SYSTEM
ELECTRICAL EQUIPMENT
ELECTRICAL PARTS
TROUBLE SHOOTING - ELECTRICAL CONTROL SYSTEMABOUT HINO-DX
About Hino-DX
BASIC PROCEDURE FOR TROUBLESHOOTING
SYMPTOM CONFIRMATION AND DIAGNOSTIC TROUBLE CODE
SYMPTOM SIMULATION
SYMPTOM SIMULATION
TROUBLE CODE DIAGNOSTIC INSPECTION FLOW CHART
ELECTRONIC CIRCUIT INSPECTION PROCEDURE
INSPECTION PROCEDURE FOR MULTIPLE DTCS
ENGINE CONTROL SYSTEM (J08E)ENGINE CONTROL SYSTEM
PRECAUTIONS FOR DIAGNOSIS
SYSTEM BLOCK DIAGRAM
SYSTEM DIAGRAM
PRECAUTIONS
SENSOR LOCATION
COMPUTER (ECU) PIN ASSIGNMENT
ENGINE ECU CONNECTOR
INSPECTION
DIAGNOSIS USING THE PC DIAGNOSIS TOOL
DIAGNOSTIC TROUBLE CODE (DTC) TABLE
GROUP SHARING THE SENSOR POWER SUPPLY TERMINAL
GROUP SHARING THE SENSOR GND TERMINAL
ENGINE BASIC INSPECTION SHEET (ENGINE INSPECTION CHECK SHEET)
NO DTC
DTC: P0016
DTC: P003A
DTC: P0045
DTC: P0047
DTC: P0048
DTC: P006E
DTC: P006F
DTC: P007B
DTC: P007C and P007D
DTC: P0088
DTC: P0096
DTC: P0097 and P0098
DTC: P00AF
DTC: P0101
DTC: P0104
DTC: P0106
DTC: P0108
DTC: P0112 and P0113
DTC: P0115
DTC: P0117 and P0118
DTC: P011A
DTC: P011C
DTC: P0122 and P0123
DTC: P0128
DTC: P016E and P016F
DTC: P0182 and P0183
DTC: P0191
DTC: P0192 and P0193
DTC: P01A5
DTC: P01A6
DTC: P0200
DTC: P0201, P0202, P0203, P0204, P0205 and P0206
DTC: P0217
DTC: P0219
DTC: P0222 and P0223
DTC: P0234
DTC: P0237
DTC: P0263, P0266, P0269, P0272, P0275 and P0278
DTC: P026C and P026D
DTC: P0299
DTC: P0300
DTC: P0301, P0302, P0303, P0304, P0305 and P0306
DTC: P0335
DTC: P0336
DTC: P0340
DTC: P0341
DTC: P0381
DTC: P0401
DTC: P0402
DTC: P0404
DTC: P0405 and P0406
DTC: P041B
DTC: P041C and P041D
DTC: P0420
DTC: P0489 and P0490
DTC: P049D
DTC: P04D5 and P04D6
DTC: P0500 and P0501
DTC: P0504
DTC: P0519
DTC: P0524
DTC: P0562 and P0563
DTC: P05F1
DTC: P0605
DTC: P0606
DTC: P0607
DTC: P0610
DTC: P0611
DTC: P0617
DTC: P0628 and P0629
DTC: P062F
DTC: P0630
DTC: P0642
DTC: P0643
DTC: P064C
DTC: P0652
DTC: P0653
DTC: P0671, P0672, P0675 and P0676
DTC: P0683
DTC: P0686
DTC: P06D3 and P06D4
DTC: P0704
DTC: P073D
- Hino Dutro Workshop Repair manual(INCLUDING WIRING DIAGRAM/GEARBOX OVERHAUL)
- Hino Series 500 Workshop Manual
- Hino Series 300 Workshop Manual
- Hino FD, FE, FF, SG Engine Service Manual 2002
- Hino Series 700 Workshop Manual
- Hino 300 Dutro S05C Workshop Manual
- Hino Diesel Engine W04D,W04C,W04C-TI Workshop Manual
- Hino E13C Engine Electrical Circuits
- HINO 238, 258LP, 268, 338 SERIES WORKSHOP MANUALS
- Common Rail System for HINO Dutro / TOYOTA Dyna N04C-T# Type Engine
- Hino DUTRO WU & XZU Series Repair Manual
- Hino E13C Type Engine Service Manual
- Specification Technical Motor Hino SO5C-TAJ08C-TT
- Catalog Hino Series 300,500,600,700
- Hino Truck Model 700 Series ABS System (English)
