Hino DX3 Ver 1.23.7 07.2023 Truck Diagnostic Program
Hino Diagnostic Explorer 3 Hino DXIII Ver.1.23.7 07.2023 Diagnostic Software
Size: 2.38 GB (Winrar Files)
Type of software: Hino DXIII diagnostic program for trucks Hino
Type of vehicle: Truck
Interface Languages: Japanese, Chinese, Spanish, Thai, English, Russian, French, Indonesian,
Database Languages: Only English
OS: Windows 7, Windows 8, Windows 10 32 & 64 bit (Tested on Windows 10 Pro v19045)
Date: 07.2023
Version: Ver.1.23.7
Installation: Multiple PCs
Instruction: Present
After downloading send to email "gallons@autorepairmanuals.ws, admin@autorepairmanuals.ws" to get the password
Changelog:
OS = Windows 10 Build: 19045
HinoDX3.exe = 1.23.7
DBFile = 1.23.7.0
CmdDbApi.dll = 0.21.0
CmdCom.dll = 0.21.0
Ver.1.23.7
-Updated the database.
-Fixed some bugs.
-Implemented a function conforming to "Past work information" of Hino DXII.
Follow the steps below to check.
HOME screen - Special working - Past work information list
-Since the repro work after replacing the supply engine is different for the ECU direct engine and the non-direct engine, the explanation of each work content is described in the "Notes" column.
Ver.1.23.6
-Fixed some bugs.
Ver.1.23.5
-Fixed some bugs.
Ver.1.23.4
-Fixed some bugs.
-Vehicle reconnection prevention function has been implemented.
1) If the connection with the vehicle cannot be confirmed for a certain period of time during the diagnosis, a confirmation screen will appear prompting you to check the connection status of the connectors and cables.
After the confirmation screen is displayed, screen operations are restricted until the connection with the vehicle is confirmed.
*The connection is checked when operating the screen, and if it can be confirmed, the operation will be executed, and if it cannot be confirmed, the confirmation screen will be displayed again.
2) When checking the connection after the confirmation screen is displayed, if a connection to another vehicle is detected, a warning screen will be displayed and the diagnosis will end.
-When accessing GSPS from the HINO DXⅢ screen, it is no longer necessary to enter the ID/PW on the browser side. (Digital certificate selection is still required)
This function is only compatible with Microsoft Edge.
If you are using a browser other than Microsoft Edge, please switch to Microsoft Edge.
-The screen display when referring to the device information installed in the vehicle learned in the past has been changed.
Before) Confirm the connection of only the referenced device, and display only the referenced device on the system selection screen
After) Confirm the connection of only the referenced device, and display it on the system selection screen including other devices than the referenced device
-Implemented the installer manual download function. (in the "Other" function)
User can check the installer version update status at any time.
Ver.1.23.3
-Fixed some bugs.
-Active test can now be performed even when the data monitor item is selected and the data monitor is not being executed.
*To start the data monitor, it is necessary to end the active test once.
-System information and memo contents of the played file are now displayed on the data monitor playback screen.
Ver.1.23.2
-Fixed some bugs.
Ver.1.23.1
-Fixed some bugs.
-Added language support. (Vietnamese)
Primary Model:
700 series
600 series(Conventional)
500 series
300 series
Bus/Coach, Heavy
Bus/Coach, Medium
Bus/Coach, Light
Retro
Industrial Engine
Other
300 series(COE) (North America)
300 series (N engine)
300 series (J engine)
BUS
FC bus
Bus/Coach, Light(Liesse2)
200 series (GD engine)
Detail models:
700 series
Japan KC/KL
Japan PK/KS
Japan ADG/BDG/BKG
Japan LDG/LKG/QKG/QDG
Japan 2DG/2KG/2PG/2RG/2SG
国4/国5/国6
EURO2/EURO3/EURO4
EURO5 With VCS
EURO5 Without VCS
EURO6
Global
Japan FC
Global
North America (-10MY)
North America (11-14MY)
North America (15-19MY)
North America (20MY)
North America (21MY)
North America (22MY-)
500 series
Japan KK
Japan PB/PK/KS/VF
Japan ADG/BDG/BJG/BKG
Japan LDG/LKG/SKG/SDG/SJG/TKG/TQG/QKG
Japan 2DG/2KG/2PG
EURO3/EURO4/EURO5 Without VCS
EURO3/EURO4/EURO5 With VCS
EURO6
THAI CNG
Global
SRS 500k (Airbag)
300 series
Japan KK/PB/VF
Japan BDG/BKG/BJG/ABG/NBG
Japan SJG/SKG/SDG/TQG/TKG/TPG/TSG/TDG
Japan 2KG/2PG/2RG/2SG
2*G(1.5t)
EV
Bus/Coach, Heavy
Japan KL/VM/PJ
Japan BDG/BKG/PKG/PDG/BJG/ACG/ADG
Japan LDG/LKG/LJG/LNG/QPG/QRG/QQG/QSG/QTG
Japan 2DG/2KG/2RG/2SG/2TG
Articulated buses
Bus/Coach, Medium
Japan KK/KL
Japan PK/PB/PA
Japan BDG/BKG/PDG/PKG
Japan LDG/LKG/SKG/SDG/LNG
Japan 2DG
Bus/Coach, Light
Japan ADG/BDG/PDG/NBG
Japan KK
Japan PB/LD
Japan SDG/SKG
Japan 2DG
Retro Global
Industrial Engine
EURO3
EURO4
TIER3/TIER4/GB4
Komatsu Light Armored Vehicle / High Mobility Vehicle
BUS
FC bus
Other
Date: 07.2023
Version: Ver.1.23.7
Changelog:
DBFile = 1.23.7.0
CmdCom.dll = 0.21.0
Ver.1.23.7
-Fixed some bugs.
Ver.1.23.6
-Fixed some bugs.
Ver.1.23.5
-Fixed some bugs.
Ver.1.23.4
-Fixed some bugs.
Ver.1.23.3
-Fixed some bugs.
Ver.1.23.2
-Fixed some bugs.
Ver.1.23.1
-Fixed some bugs.
Primary Model:
700 series
500 series
300 series
Bus/Coach, Heavy
Bus/Coach, Medium
Bus/Coach, Light
Retro
Industrial Engine
Other
BUS
FC bus
Detail models:
700 series
Japan KC/KL
Japan PK/KS
Japan ADG/BDG/BKG
国4/国5/国6
EURO2/EURO3/EURO4
EURO5 With VCS
EURO5 Without VCS
EURO6
Global
Japan FC
Global
500 series
Japan KK
Japan PB/PK/KS/VF
Japan 2DG/2KG/2PG
EURO6
THAI CNG
Global
SRS 500k (Airbag)
300 series
Japan KK/PB/VF
2*G(1.5t)
EV
Bus/Coach, Heavy
Japan KL/VM/PJ
Articulated buses
Bus/Coach, Medium
Japan KK/KL
Japan PK/PB/PA
Japan 2DG
Bus/Coach, Light
Japan KK
Japan PB/LD
Japan SDG/SKG
Japan 2DG
Retro Global
Industrial Engine
EURO3
EURO4
TIER3/TIER4/GB4
BUS
FC bus
Other
- HINO Diagnostic eXplorer DX2 [10.2015]
- HINO Diagnostic eXplorer DX2 [2017]
- Hino Diagnostic Explorer 3.0 full
- Hino HIECHO-II EPC [09.2015] English
- Hino Diagnostic Explorer_3.0 full + How to install
- Hino Truck Full Set Manual DVD
- Hino Trucks / Buses HIECHO II Electronic Spare Parts Caralogue 2015
- HINO Diagnostic eXplorer DX2 [01.2016]
- HINO Trucks (LHD & RHD) Light Medium Heavy [01.2016]
- HINO Diagnostic eXplorer DX2 v1.1.18.6 [2018]
- HINO Truck 300 500 700 ML M XL Series Workshop Manual DVD New Update 2020
- HINO Truck Workshop Manuals [2001-2019] DVD
- Hino Truck Full Models 2000 - 2018 Wiring Diagrams DVD PDF
- HINO Diagnostic eXplorer DX2 2019 Full + Instruction Video
- HINO Trucks (LHD & RHD) Light Medium Heavy [05.2017]
