Hyundai
86
176,684
Hidromek Wheel Excavator HMK140W-3 HMK210W-3 Operation Maintenance Manual H23732B403 FR
Language: French
Brand: Hidromek
Type of Machine: Wheel Excavator
Type of Manual: Operation Maintenance Manual
Model: Hidromek HMK140W-3 HMK210W-3 Wheel Excavator
Tier 3 / Stage III
Publication Number: H23732B403
Publication Date: 2024
Number of Pages: 277 Pages
1. INTRODUCTION
1.1. AVANT PROPOS​
1.2. INFORMATION DE SECURITE​
1.3. DESCRIPTION ET UTILISATION PREVUE​
1.4. CE MARKING AND DECLARATION DE CONFORMITE​
1.5. CARACTERISTIQUES DE LA MACHINE​
1.6. RÉGLEMENTATION RELATIVE AUX ÉMISSIONS DE GAZ D'ÉCHAPPEMENT DES PIÈCES CONNEXES​
1.7. OPERATION DE RODAGE​
1.8. PIECES DE RECHANGE ET SERVICE APRES-VENTES​
1.9. COPYRIGHT​
1.10. PERMIT DE CONDUITE​
1.11. PLAQUE D’IDENTIFICATION​
1.12. IDENTIFICATION DE COMPOSANTS MAJEURS​
2. SECURITE
2.1. PREATTENTIONS GENERALES​
2.2. REMARQUES SUR OPERATION​
2.3. REMARQUES SUR MAINTENANCE​
2.4. POSITIONNES DES DECALCOMANIES​
3. LES COMPOSANTS PRINCIPALES
3.1. LOCATIONS DE COMPOSANTS PRINCIPALES​
3.2. DÉTAIL DE LA CABINE DE L'OPÉRATEUR​
3.3. TABLEAU DE BORD​
3.4. OPTIONS DE MENU​
3.5. MÉDIA​
3.6. TABLEAU DE BORD OPERA​
3.7. CONNEXIONS USB / AUX​
3.8. PRISE DE COURANT EXTERNE (12V)​
3.9. CLEF DU DÉMARREUR​
3.10. PORT GOBELET MUG / CENDRIER​
3.11. RANGEMENT​
3.12. BOITE DE RANGEMENT​
3.13. COMMUTATEURS​
3.14. LEVIER DE LAME DE DOSER ET STABILISATEURS​
3.15. DIRECTION​
3.16. DISPOSITIF DE VERROUILLAGE DE SECURITE​
3.17. AJUSTER L’HAUTEUR D’ACCOUDOIR​
3.18. L’AJUSTEUR DE L’ANGLE D’ACCOUDOIR​
3.19. AJUSTEUR D’ANGLE DE CONSOLE​
3.20. LEVIER DE LEVAGE DE CONSOLE A COTE GAUCHE​
3.21. LEVIERS DE COMMANDES​
3.22. AXE DE VERROU DE ROTATION​
3.23. PEDALES ACCELERATEUR ET FREIN​
3.24. FUSIBLES ET RELAIS​
3.25. COMMUTATEUR DE MODE AUTOMATIQE/MANUEL​
3.26. RELAIS DE BATTERIE​
3.27. COMMUTATEUR PRINCIPAL DE LA BATTERIE​
3.28. CHAUFFAGE ET ÉTAT DE L’AIR​
3.29. ALLUME-CIGARE​
3.30. PORTE-BOUTEILLE​
3.31. COMPARTIMENT RÉFRIGÉRÉ​
3.32. RANGEMENT ET COMPARTIMENT DE RANGEMENT PRATIQUES​
3.33. SORTIE D’URGENCE​
3.34. TROUSSE DE SECOURS​
3.35. PARE-BRISE​
3.36. PORT DE CABINE​
3.37. VERROU DU PORT​
3.38. FENETRE LATERALE​
3.39. EXTINCTEUR (OPTIONNEL)​
3.40. RIDEAU AVANT ET ARRIERE​
3.41. TOIT OUVRANT​
3.42. PARASOL​
3.43. ECLAIRAGE INTERIEUR DE CABINE OPERATRICE​
3.44. REGLAGE DES MIROIRS​
3.45. REGLAGE DE SIEGE D'OPÉRATEUR​
3.46. CEINTURE DE SECURITE​
4. OPÉRATION
4.1. VÉRIFIER AVANT DE DEMARRER LE MOTEUR​
4.2. DÉMARRAGE DU MOTEUR​
4.3. PRECHAUFFAGE​
4.4. VERIFICATIONS APRÈS DEMARRAGE DU MOTEUR​
4.5. OPERATION DE LA MACHINE​
4.6. COMMAND DE SENS DE MARCHE​
4.7. ROTATION DE LA MACHINE​
4.8. COMMAND DES ATTACHEMENTS​
4.9. FONCTIONNEMENT DE LA LAME DE BOUTEUR​
4.10. FONCTION DE REGULATEUR DE VITESSE (CRUISE)​
4.11. OPERATIONS DÉFENDUS PENDANT TRAVAIL​
4.12. ATTENTION PENDANT OPERATION​
4.13. AVERTISSEMENT PENDENT DEPLACEMENT SUR UNE PENTE​
4.14. TRAVAUX ADDITIONNELLES EN UTILISANT L’EXCAVATEUR HYDRAULIQUE​
4.15. LEVAGE​
4.16. DEMONTER LE GODET​
4.17. VERIFICATIONS APRES LE TRAVAIL​
4.18. ARRETER LE MOTEUR​
4.19. VERIFICATIONS APRES L’ARRET DU MOTEUR​
4.20. MANIPULATION DU MOTEUR AVEC TURBOCOMPRESSEUR​
4.21. VERIFICATION DE VERROUILLAGE​
4.22. TRANSPORT​
4.23. MANIPULATION PAR TEMPS FROID​
4.24. STOCKAGE AU LONG DUREE​
4.25. INSTRUCTIONS RELATIVES AU RETRAIT DE LA CIRCULATION ET DE L’EXPLOITATION​
5. DEPANNAGE
5.1. QUAND SOUPCONNER UNE PANNE​
5.2. PRUDENCE SOUS CIRCONSTANCES SPECIAUX​
5.3. METHODE DE REMORQUAGE​
5.4. DECHARGE ELECTRIQUE​
5.5. MAUVAISE CHARGE DE LA BATTERIE​
5.6. SURCHAUFFE​
5.7. PRESSION D’HUILE ANORMALE (BASSE)​
5.8. MOTEUR​
5.9. SYSTEME HYDRAULIQUE​
5.10. CIRCUIT ELECTRIQUE​
5.11. AUTRES PANNES​
6. PREATTENTIONS DE MAINTENANCE
6.1. PRECAUTIONS DE MAINTENANCE​
6.2. UTILISATION DE L’HUILE ET CARBURANTES SELON LA TEMPERATURE​
6.3. REMPLACEMENT PERIODIQUE DES PIECES ESSENTIELLES​
6.4. LISTE DE CONTRÔLE ET DE MAINTENANCE​
6.5. TOUTES LES 10 HEURES (AVANT DE COMMENCER)​
6.6. TOUTES LES 50 HEURES (ENTRETIEN HEBDOMADAIRE)​
6.7. LES 250 PREMIERES HEURES​
6.8. TOUTES LES 250 HEURES (ENTRETIEN HEBDOMADAIRE)​
6.9. TOUTES LES 250 HEURES D'EXPLOITATION DU BRISE-ROCHE HYDRAULIQUE.​
6.10. TOUTES LES 500 HEURES (ENTRETIEN DES 3 MOIS)​
6.11. TOUTES LES 1000 HEURES (ENTRETIEN DES 6 MOIS)​
6.12. TOUTES LES 1500 HEURES​
6.13. TOUTES LES 2000 HEURES (ENTRETIEN ANNUEL)​
6.14. TOUS LES 2 ANS​
6.15. EN CAS DE BESOIN​
7. SPECIFICATIONS
7.1. SPECIFICATIONS TECHNIQUES DE HMK 140 W-3​
7.2. SPECIFICATIONS TECHNIQUES DE HMK 210 W-3​
8. PREATTENTIONS GENERALES
8.1. SECURITE​
8.2. PREATTENTIONS A PRENDRE LORS DU MONTAGE DU MATERIEL DE TRAVAIL​
8.3. CHOIX DE L'ACCESSOIRE​
8.4. PROTECTION CONTRE LES CHUTES OU LES OBJETS PROJETES​
8.5. PROTECTION CONTRE CAPOTAGE et ECRASEMENT​
8.6. TRAVAILLER AVEC LES ROUES​
8.7. CONCASSEUR HYDRAULIQUE​
8.8. ATTACHE RACCORD RAPIDE (OPTIONNEL)​
9. APPENDIX
9.1. DIAGRAMME DE SIGNALISATION MANUEL​
9.2. COMMUNICATION​
10. INDEX ALPHABETIQUE
