Hyundai
86
176,834
Hidromek Wheel Excavator HMK140LC-3 to HMK520LCLR-3 Operation Maintenance Manual H34732B403 FR
Language: French
Brand: Hidromek
Type of Machine: Wheel Excavator
Type of Manual: Operation Maintenance Manual
Model: Hidromek
HMK 140 LC-3, HMK 145 LC SR-3, HMK 230 LC-3,
HMK 230 NLC-3, HMK 230 LC LR-3, HMK 310 LC-3,
HMK 310 LC LR-3, HMK 390 LC-3, HMK 390 LC LR-3,
HMK 410 LC-3, HMK 500 LC-3, HMK 500 LC R-3,
HMK 520 LC-3, HMK 520 LC LR-3
Tier 3 / Stage III
Publication Number: H34732B403
Publication Date: 2024
Number of Pages: 358 Pages
1. INTRODUCTION
1.1. AVANT PROPOS​
1.2. INFORMATION DE SECURITE​
1.3. DESCRIPTION ET UTILISATION PREVUE​
1.4. CE MARKING AND DECLARATION DE CONFORMITE​
1.5. CARACTERISTIQUES DE LA MACHINE​
1.6. OPERATION DE RODAGE​
1.7. PIECES DE RECHANGE ET SERVICE APRES-VENTES​
1.8. COPYRIGHT​
1.9. PERMIT DE CONDUITE​
1.10. PLAQUE D’IDENTIFICATION​
2. SECURITE
2.1. PRECAUTIONS GENERALES​
2.2. REMARQUES SUR OPERATION​
2.3. REMARQUES SUR MAINTENANCE​
2.4. POSITIONNES DES DECALCOMANIES​
3. LES COMPOSANTS PRINCIPALES
3.1. LOCATIONS DE COMPOSANTS PRINCIPALES​
3.2. DÉTAIL DE LA CABINE DE L'OPÉRATEUR​
3.3. TABLEAU DE BORD​
3.4. OPTIONS DE MENU​
3.5. MÉDIA​
3.6. TABLEAU DE BORD OPERA​
3.7. CONNEXIONS USB / AUX​
3.8. PRISE DE COURANT EXTERNE (12V)​
3.9. CLEF DU DÉMARREUR​
3.10. PORT GOBELET MUG / CENDRIER​
3.11. RANGEMENT​
3.12. BOITE DE RANGEMENT​
3.13. COMMUTATEURS​
3.14. DISPOSITIF DE VERROUILLAGE DE SECURITE​
3.15. AJUSTER L’HAUTEUR D’ACCOUDOIR​
3.16. L’AJUSTEUR DE L’ANGLE D’ACCOUDOIR​
3.17. AJUSTEUR D’ANGLE DE CONSOLE​
3.18. LEVIER DE LEVAGE DE CONSOLE A COTE GAUCHE​
3.19. LEVIERS DE COMMANDES​
3.20. FUSIBLES ET RELAIS​
3.21. COMMUTATEUR DE MODE AUTOMATIQUE/MANUEL​
3.22. RELAIS DE BATTERIE​
3.23. COMMUTATEUR PRINCIPAL DE LA BATTERIE​
3.24. CHAUFFAGE ET ÉTAT DE L’AIR​
3.25. ALLUME-CIGARE​
3.26. PORTE-BOUTEILLE​
3.27. COMPARTIMENT RÉFRIGÉRÉ​
3.28. RANGEMENT ET COMPARTIMENT DE RANGEMENT PRATIQUES​
3.29. SORTIE D’URGENCE​
3.30. TROUSSE DE SECOURS​
3.31. PARE-BRISE​
3.32. PORT DE CABINE​
3.33. VERROU DU PORT​
3.34. FENETRE LATERALE​
3.35. EXTINCTEUR (OPTIONNEL)​
3.36. RIDEAU AVANT ET ARRIERE​
3.37. TOIT OUVRANT​
3.38. PARASOL​
3.39. ECLAIRAGE INTERIEUR DE CABINE OPERATRICE​
3.40. REGLAGE DES MIROIRS​
3.41. REGLAGE DE SIEGE D'OPÉRATEUR​
3.42. CEINTURE DE SECURITE​
3.43. TRAIN DE ROULEMENT EXTENSIBLE (HMK 520LC)​
4. OPÉRATION
4.1. VÉRIFIER AVANT DE DEMARRER LE MOTEUR​
4.2. DÉMARRAGE DU MOTEUR​
4.3. PRECHAUFFAGE​
4.4. VERIFICATIONS APRÈS DEMARRAGE DU MOTEUR​
4.5. OPERATION DE LA MACHINE​
4.6. COMMAND DE DIRECTION DE TRANSLATION​
4.7. ARRET ET PARKING DE LA MACHINE​
4.8. ROTATION DE LA MACHINE​
4.9. COMMAND DES ATTACHEMENTS​
4.10. OPERATIONS DÉFENDUS PENDANT TRAVAIL​
4.11. ATTENTION PENDANT OPERATION​
4.12. AVERTISSEMENT PENDENT DEPLACEMENT SUR UNE PENTE​
4.13. SAUVER DANS LE MARAIS ET BOUE​
4.14. TRAVAUX ADDITIONNELLES EN UTILISANT L’EXCAVATEUR HYDRAULIQUE​
4.15. LEVAGE​
4.16. DEMONTER LE GODET​
4.17. PARKAGE DE LA MACHINE​
4.18. VERIFICATIONS APRES LE TRAVAIL​
4.19. ARRETER LE MOTEUR​
4.20. VERIFICATIONS APRES L’ARRET DU MOTEUR​
4.21. MANIPULATION DU MOTEUR AVEC TURBOCOMPRESSEUR​
4.22. VERIFICATION DE VERROUILLAGE​
4.23. TRANSPORT​
4.24. PRÉPARATION DE LA MACHINE SELON LES CONDITIONS MÉTÉOROLOGIQUES​
4.25. STOCKAGE AU LONG DUREE​
4.26. INSTRUCTIONS RELATIVES AU RETRAIT DE LA CIRCULATION ET DE L’EXPLOITATION​
5. DEPANNAGE
5.1. QUAND SOUPCONNER UNE PANNE​
5.2. MÉTHODE DE REMORQUAGE​
5.3. ORIFICE DE REMORQUAGE POUR LES OBJETS LÉGERS​
5.4. PRECAUTIONS A PRENDRE DANS DES CIRCONSTANCES SPECIALES​
5.5. DECHARGE ELECTRIQUE​
5.6. MAUVAISE CHARGE DE LA BATTERIE​
5.7. SURCHAUFFE​
5.8. PRESSION D’HUILE ANORMALE (BASSE)​
5.9. MOTEUR​
5.10. SYSTEME HYDRAULIQUE​
5.11. CIRCUIT ELECTRIQUE​
5.12. AUTRES PANNES​
6. MAINTENANCE
6.1. PRECAUTIONS DE MAINTENANCE​
6.2. CARBURANTE, REFRIGERANT, LUBRIFICATION ET FLUIDE D'ECHAPPEMENT DIESEL​
6.3. REMPLACEMENT PERIODIQUE DES PIECES ESSENTIELLES​
6.4. LISTE DE CONTRÔLE ET DE MAINTENANCE​
6.5. TOUTES LES 10 HEURES (AVANT DE COMMENCER)​
6.6. TOUTES LES 10 HEURES (APRÈS LE TRAVAIL)​
6.7. TOUTES LES 50 HEURES (ENTRETIEN HEBDOMADAIRE)​
6.8. LES 250 PREMIERES HEURES​
6.9. TOUTES LES 250 HEURES (ENTRETIEN HEBDOMADAIRE)​
6.10. TOUTES LES 250 HEURES D'EXPLOITATION DU BRISE-ROCHE HYDRAULIQUE​
6.11. LES 500 PREMIERES HEURES​
6.12. TOUTES LES 500 HEURES (ENTRETIEN DES 3 MOIS)​
6.13. TOUTES LES 1000 HEURES (ENTRETIEN DES 6 MOIS)​
6.14. TOUTES LES 1500 HEURES​
6.15. TOUTES LES 2000 HEURES (ENTRETIEN ANNUEL)​
6.16. TOUS LES DEUX ANS DE SERVICE​
6.17. EN CAS DE BESOIN​
7. SPECIFICATIONS
7.1. SPECIFICATIONS TECHNIQUES DE HMK 140 LC-3​
7.2. SPECIFICATIONS TECHNIQUES DE HMK 145 LC SR-3​
7.3. SPECIFICATIONS TECHNIQUES DE HMK 230 LC-3, HMK 230 NLC-3 ET HMK 230 LC LR-3​
7.4. SPECIFICATIONS TECHNIQUES DE HMK 310 LC-3, HMK 310 NLC-3, HMK 310 LC LR-3​
7.5. SPECIFICATIONS TECHNIQUES DE HMK 390 LC-3, HMK 390 NLC-3, HMK 390 LC LR-3​
7.6. SPECIFICATIONS TECHNIQUES DE HMK 410 LC-3​
7.7. SPECIFICATIONS TECHNIQUES DE HMK 500 LC-3, HMK 500 LC R-3​
7.8. SPECIFICATIONS TECHNIQUES DE HMK 520 LC-3, HMK 520 LC LR-3​
8. PRECAUTIONS GENERALES
8.1. SECURITE​
8.2. PRECAUTIONS A PRENDRE LORS DU MONTAGE DU MATERIEL DE TRAVAIL​
8.3. CHOIX DE L'ACCESSOIRE​
8.4. PROTECTION CONTRE LES CHUTES OU LES OBJETS PROJETES​
8.5. PROTECTION CONTRE CAPOTAGE et ECRASEMENT​
8.6. CHOIX DES PATINS DE CHENILLE​
8.7. CONCASSEUR HYDRAULIQUE​
8.8. ATTACHE RACCORD RAPIDE (OPTIONNEL)​
9. APPENDICE
9.1. DIAGRAMME DE SIGNALISATION MANUEL​
9.2. COMMUNICATION​
10. INDEX ALPHABETIQUE
