Hyundai
86
176,684
Hidromek Transmission Workshop Manual
Brand: Hidromek
Type of Machine: Transmission
Type of Manual: Workshop Manual
Model: Hidromek Transmission
Number of Pages: 136 Pages
UNIT IDENTIFICATION
TORQUE SETTINGS
SERVICE TOOLS NUMERICAL LIST
SERVICE TOOLS
SEALING and RETAINING COMPOUNDS
LUBRICANTS & CAPACITIES
TRANSMISSION OIL FILL PROCEDURE
TRANSMISSION DIPSTICK DETAILS
SERVICE SCHEDULES
POWERSHIFT TRANSMISSION
- CHECK LEVEL
- RENEW FILTER
- CHANGE OIL & CLEAN STRAINER
TECHNICAL DATA
SOLENOID DATA
RELAY REQUIREMENTS
COLUMN CONTROL LEVER CONNECTIONS (EARLIER GEARBOXES)
CONNECTOR MOUNTING DETAILS (EARLIER GEARBOXES)
COLUMN CONTROL LEVER CONNECTIONS (LATER GEARBOXES)
CONNECTOR MOUNTING DETAILS (LATER GEARBOXES)
TRANSMISSION TECHNICAL DATA
TOWING PROCEDURE
DESCRIPTIONS
- GENERAL DESCRIPTION
- SCHEMATIC HYDRAULIC FLOW DIAGRAM
- HYDRAULIC CIRCUIT – 1st GEAR FORWARD SELECTION
- HYDRAULIC OPERATION
- POWERSHIFT DRIVEPATHS
GEARBOX
CLUTCH OPERATION
- 2 / 4 WHEEL DRIVE OPERATION
- 4 WHEEL DRIVE OPERATION (SPRING ON / PRESSURE OFF)
- 2 WHEEL DRIVE OPERATION (SPRING ON / PRESSURE OFF)
- 4 WHEEL DRIVE OPERATION (PRESSURE ON / SPRING OFF)
- 2 WHEEL DRIVE OPERATION (PRESSURE ON / SPRING OFF)
SOLENOID VALVE
DISMANTLING and ASSEMBLY
PROPSHAFTS
REMOVAL and REPLACEMENT
TRANSMISSION
GEARBOX
SECTIONAL VIEWS and TORQUE FIGURES
SUMMARY OF CHANGES
DISMANTLING
ASSEMBLY
INSTALLING A COLLAPSIBLE SPACER
OUTPUT SHAFT REMOVAL – LARGE DIAMETER GEAR
HYDRAULIC 2/4 WHEEL DRIVE UNIT (SPRING ON / PRESSURE OFF)
PRESSURE TESTING THE 2 / 4 WD CLUTCH
HYDRAULIC 2/4 WHEEL DRIVE UNIT (PRESSURE ON / SPRING OFF)
INPUT CLUTCH & REVERSER CLUTCH (PS 750)
DISMANTLING
ASSEMBLY
MAINSHAFT (PS 750)
DISMANTLING
ASSEMBLY
LAYSHAFT (PS 750)
DISMANTLING
ASSEMBLY
INPUT CLUTCH & REVERSER CLUTCH (PS 700)
DISMANTLING
ASSEMBLY
MAINSHAFT (PS 700)
DISMANTLING
ASSEMBLY
LAYSHAFT (PS 700)
DISMANTLING
ASSEMBLY
TORQUE CONVERTER
TORQUE CONVERTER STALL TEST
TESTING FOR CLUTCH LEAKAGE
PRESSURE & FLOW TESTING
POLYTETRAFLUOROETHENE (PTFE) PISTON RING SEALS
FITTING PROCEDURE
TROUBLE SHOOTING
OIL COOLER FAILURE
FLUSH PROCEDURE
