Hyundai
86
176,834
Hidromek Soil Compactor HMK110CS to HMK160CS Operation Manual C117301401 2026
Brand: Hidromek
Type of Machine: Soil Compactor
Type of Manual: Operation and Maintenance Manual
Model: Hidromek HMK 110 CS, HMK 130 CS, HMK 160 CS Soil Compactor
Part Number: C117301401
Publication Date: 2026
Number of Pages: 219 Pages
1. INTRODUCTION
1.1. CONGRATULATIONS​
1.2. REGULATIONS AND RULES​
1.3. IDENTIFICATION PLATES​
1.3.1. MACHINE IDENTIFICATION PLATE​
1.3.2. ENGINE IDENTIFICATION PLATE​
1.3.3. SERIAL NUMBERS OF THE EXHAUST AFTERTREATMENT COMPONENTS​
1.3.4. IDENTIFICATION PLATES OF MAIN COMPONENTS​
1.4. NOISE AND VIBRATION​
1.4.1. NOISE​
1.4.2. VIBRATION​
1.5. RECORD SERIAL NUMBERS OF YOUR MACHINE​
1.6. DESCRIPTION AND INTENDED USE OF THE MACHINE​
1.6.1. DESCRIPTION OF THE MACHINE​
1.6.2. INTENDED USE OF THE MACHINE​
1.6.3. DESIGNATION OF “LEFT/RIGHT”, “FRONT/REAR”​
1.7. IDENTIFICATION AND LOCATION OF MAIN COMPONENTS​
1.8. SAFETY NOTICES​
1.9. OTHER NOTICES​
1.10. ENVIRONMENT PROTECTION​
1.11. OPERATOR LICENSE​
1.12. PRECAUTIONS FOR BREAK-IN​
1.13. SERVICE AND SPARE PARTS​
1.14. COPYRIGHT​
2. OCCUPATIONAL SAFETY
2.1. GENERAL OCCUPATIONAL SAFETY INFORMATION​
2.2. SAFETY BEFORE WORK​
2.2.1. OBSERVE SAFETY PRECAUTIONS​
2.2.2. USE PROTECTIVE EQUIPMENT​
2.2.3. TRAINING​
2.2.4. READ AND UNDERSTAND INSTRUCTION MANUAL​
2.2.5. KEEP OPERATION AND MAINTENANCE MANUAL IN OPERATOR'S CABIN​
2.2.6. EMERGENCY EQUIPMENT​
2.2.7. SAFETY AT WORKPLACE​
2.2.8. PRE-START INSPECTION​
2.2.9. OPERATOR'S CABIN​
2.2.10. SIGNS, SIGNALS AND SIGNALMAN​
2.2.11. KEEP FIRE AWAY FROM FUEL AND FLUIDS​
2.2.12. TO GET ON AND OFF THE MACHINE​
2.3. SAFETY DURING OPERATION​
2.3.1. STARTING THE ENGINE​
2.3.2. VISIBILITY​
2.3.3. PASSENGERS​
2.3.4. RIGHT AFTER STARTING THE ENGINE​
2.3.5. DO NOT USE THE MACHINE OUT OF INTENDED USE​
2.3.6. DRIVING​
2.3.7. CHECK SECURITY SYSTEMS AND BRAKES​
2.3.8. IN CASE OF FIRE​
2.3.9. BEFORE LEAVING THE MACHINE​
2.3.10. PROTECTION AGAINST TIPPING OVER​
2.3.11. WORKING ON A SLOPE​
2.3.12. WORKING AREA CONDITIONS​
2.3.13. TRENCHES & BACKFILL PILES​
2.3.14. EXPERIMENTAL OPERATIONS​
2.3.15. DANGER ZONE​
2.3.16. VENTILATION IN CLOSED AREAS​
2.3.17. PARKING THE MACHINE​
2.3.18. EMERGENCY EXIT​
2.3.19. UNINTENTIONAL STOP OF THE ENGINE DURING OPERATION​
2.4. SAFETY DURING LOADING, UNLOADING AND TRANSPORTATION​
2.5. SAFETY DURING INSPECTION AND MAINTENANCE​
2.5.1. CHOCKING THE MACHINE​
2.5.2. STOP THE ENGINE BEFORE MAINTENANCE​
2.5.3. WASTE MATERIALS​
2.5.4. AVOID ACCIDENTAL START OF THE MACHINE​
2.5.5. KEEP THE MACHINE CLEAN​
2.5.6. SECURITY LIGHTING​
2.5.7. REFUELING​
2.5.8. HOT SURFACES AND LIQUIDS​
2.5.9. PRESSURIZED LIQUIDS​
2.5.10. INFLATING TIRES AND CHECKING WHEELNUTS​
2.5.11. ENGINE INSPECTION AND MAINTENANCE​
2.5.12. ELECTRICAL SYSTEM AND BATTERY​
2.6. SAFETY LABELS AND WARNING STICKERS​
2.6.1. EMERGENCY EXIT WARNING LABEL. EMERGENCY HAMMER​
2.6.2. FIRE RISK WHEN REFUELING WARNING LABEL​
2.6.3. PRESSURIZED HYDRAULIC OIL OR REFRIGERANT WARNING LABEL​
2.6.4. HYDRAULIC OIL TANK WARNING LABEL​
2.6.5. HANDLING BATTERIES WARNING LABEL​
2.6.6. HOT SURFACES WARNING LABEL​
2.6.7. GENERAL PRECAUTIONS WARNING LABEL​
2.6.8. ENGINE FILTER ELEMENTS WARNING LABEL​
2.6.9. ELECTRICAL CIRCUIT WARNING LABEL​
2.6.10. DO NOT STEP ON ENGINE HOOD WARNING LABEL​
2.6.11. READING AND UNDERSTANDING OPERATION AND MAINTENANCE MANUAL WARNING LABEL​
2.6.12. DANGER OF FALLING OFF WARNING LABEL​
2.6.13. STAY AWAY FROM WORK AREA WARNING LABEL​
2.6.14. ANTIFREEZE WARNING LABEL​
2.6.15. CRUSHING AREA WARNING LABEL​
2.6.16. TIRE WARNING LABEL​
2.6.17. CRUSHING RISK WHEN ARTICULATION NOT BLOCKED WARNING LABEL​
2.6.18. LIFTING POINT WARNING LABEL​
2.6.19. TIE POINT WARNING LABEL​
2.6.20. COMPARTMENT OF OPERATION AND MAINTENANCE MANUAL WARNING LABEL​
2.6.21. TIRE PRESSURE LABEL​
2.6.22. MAXIMUM HEIGHT OF THE MACHINE WARNING LABEL​
2.6.23. BEFORE WELDING, READ OPERATION AND MAINTENANCE MANUAL WARNING LABEL​
2.6.24. BEFORE CLEANING THE MACHINE WITH PRESSURE WATER, READ OPERATION AND MAINTENANCE MANUAL WARNING LABEL​
2.6.25. HIGH PRESSURE RISK WARNING LABEL​
2.6.26. FUEL SPECIFICATION WARNING LABEL​
2.6.27. BATTERY DISCONNECTOR WARNING LABEL​
2.6.28. HYDRAULIC OIL LEVEL WARNING LABEL​
2.6.29. COOLANT LEVEL WARNING LABEL​
2.6.30. OIL DRAINING PLUG WARNING LABEL​
2.6.31. COOLANT EMPTYING PLUG WARNING LABEL​
2.6.32. BATTERY SWITCH LABEL​
2.6.33. ROTATING PARTS OF THE ENGINE WARNING LABEL​
2.6.34. ENGINE OVERSPEED WARNING LABEL​
3. INTRODUCTION OF THE MACHINE
3.1. LOCATIONS OF MAIN PARTS​
3.2. OPERATOR’S CAB​
3.2.1. FRONT PANEL​
3.2.2. RIGHT HAND SIDE CONSOLE​
3.2.3. SIDE PANEL​
3.2.4. CABIN INTERIOR LIGHTING​
3.2.5. EXTERNAL POWER OUTPUT (12 V)/ LIGHTER​
3.2.6. COMPARTMENTS FOR STORAGE​
3.2.7. DOOR​
3.2.8. SIDE WINDOWS​
3.2.9. CURTAINS​
3.2.10. FIRE EXTINGUISHER (OPTIONAL)​
3.2.11. HOUR METER (IF EQUIPPED)​
3.2.12. OPERATOR'S SEAT​
3.3. WASHER TANK​
3.4. BATTERY SWITCH​
3.5. DIODES AND RELAYS IN CABIN​
3.5.1. OVERRIDE SWITCH (TEMPORARY CANCELLATION OF DIESEL ENGINE FAILURES)​
3.5.2. MANUAL-AUTO SWITCH (CONTROL SWITCH IN CASE OF MCU FAILURE)​
3.6. FUSES AND RELAYS IN CHASSIS​
3.7. OPENING AND CLOSING THE HOOD​
4. OPERATION
4.1. BEFORE STARTING​
4.1.1. CLEANING INSPECTION​
4.1.2. DAMAGE INSPECTION​
4.1.3. INSPECTION OF FLUID LEVELS AND FILTERS​
4.1.4. TIRE INSPECTION​
4.1.5. BATTERY DISCONNECT SWITCH​
4.1.6. GETTING ON AND OFF THE CABIN​
4.2. INSPECTION BEFORE STARTING THE ENGINE​
4.2.1. CHECK LEVERS​
4.2.2. INSPECTION INSIDE THE CABIN​
4.2.3. ADJUST MIRRORS​
4.2.4. ADJUST POSITION OF SEAT AND STEERING WHEEL​
4.3. STARTING THE ENGINE​
4.3.1. CONDITIONS NECESSARY TO START THE ENGINE​
4.3.2. STARTING THE ENGINE​
4.4. EXHAUST GAS AFTERTREATMENT SYSTEM​
4.4.1. WARNING STRATEGY OF SCR SYSTEM​
4.4.2. DIESEL OXIDATION CATALYST (DOC)​
4.4.3. DIESEL PARTICLE FILTER (DPF)​
4.5. DRIVING THE MACHINE (TRAVELING)​
4.5.1. SELECTING TRAVEL SPEED​
4.5.2. SELECTING ENGINE SPEED​
4.5.3. ENGINE OVERSPEED PREVENTION SYSTEM​
4.5.4. CHECKING STEERING WHEEL​
4.5.5. SELECTING TRAVEL DIRECTION​
4.5.6. CHECKING REVERSE HORN​
4.5.7. CHECKING CONDITION OF BRAKES​
4.5.8. CHECKING “OPERATOR'S SEAT NOT OCCUPIED” SYSTEM​
4.5.9. CHECKING EMERGENCY STOP SYSTEM​
4.6. BRAKING​
4.7. VIBRATION​
4.7.1. VIBRATION OPERATION MODE SELECTION​
4.7.2. HIGH-LOW VIBRATION MODE SELECTION​
4.8. STOPPING ENGINE AND MACHINE​
4.9. DISCONNECTING BATTERY​
4.10. PARKING THE MACHINE​
4.11. LONG-TERM STORAGE OF THE MACHINE​
4.11.1. DURING LONG-TERM STORAGE​
4.11.2. AFTER LONG-TERM STORAGE​
4.12. TOWING​
4.12.1. STUCK MACHINE​
4.12.2. TOWING PROCEDURE FOR BROKEN MACHINE​
4.13. TRANSPORTATION OF MACHINE​
4.14. INSTRUCTIONS ON WITHDRAWAL OF MACHINE FROM USE​
4.15. LIFTING THE MACHINE​
4.16. COMPACTION WORK​
4.16.1. HIGH VIBRATION MODE​
4.16.2. LOW VIBRATION MODE​
4.16.3. COMPACTION QUALITY​
4.16.4. CLASSIFICATION OF SOILS​
4.16.5. APPLICATIONS WITH HİDROMEK SOIL COMPACTOR​
4.16.6. WORKING RECOMMENDATIONS​
5. TROUBLESHOOTING
5.1. ENGINE​
5.2. HYDRAULIC PUMP​
6. MAINTENANCE
6.1. GENERAL INFORMATION​
6.2. INFORMATION ABOUT IMPORTANT COMPONENTS​
6.2.1. OIL​
6.2.2. FUEL​
6.2.3. COOLANT​
6.2.4. GREASE​
6.2.5. STORAGE OF OIL AND FUEL​
6.2.6. FILTERS​
6.2.7. ELECTRIC COMPONENTS​
6.2.8. HYDRAULIC COMPONENTS​
6.2.9. DIESEL EXHAUST FLUID (DEF/AdBlue®)​
6.3. SAFETY DURING INSPECTION AND MAINTENANCE​
6.3.1. BEFORE MAINTENANCE​
6.3.2. KEEP MACHINE CLEAN​
6.3.3. CLEANING PARTS​
6.3.4. PREVENT CONTAMINATION​
6.3.5. WARMING ENGINE AND HYDRAULIC OIL​
6.3.6. EXHAUST LINE COMPONENTS​
6.3.7. PREVENTING FIRES​
6.3.8. INSPECTION OF RESIDUAL OIL AND FILTERS​
6.3.9. SEALS AND O-RINGS​
6.3.10. HANDLING FLUOROCARBONATED POLYMERS AND ELASTOMETERS​
6.3.11. DISPOSAL OF HAZARDOUS WASTE AND ENVIRONMENTAL PROTECTION​
6.3.12. HANDLING REFRIGERANTS FOR AIR CONDITIONING​
6.3.13. HANDLING OILS​
6.3.14. HANDLING FUELS​
6.3.15. PRECAUTIONS FOR WELDING​
6.3.16. IN DUSTY CONDITIONS​
6.3.17. OPERATION IN DIFFERENT CLIMATES​
6.4. OIL, FUEL, COOLANT AND GREASE​
6.4.1. FILLING CAPACITIES OF OIL, FUEL, REFRIGERANT AND GREASE​
6.4.2. ENGINE OIL​
6.4.3. FUEL​
6.4.4. DIESEL EXHAUST FLUID (DEF/AdBlue®)​
6.4.5. COOLANT​
6.4.6. HYDRAULIC OIL​
6.4.7. GEAR TRANSMISSION OIL​
6.4.8. GREASE​
6.5. SERVICE AND MAINTENANCE POINTS​
6.6. INSPECTION AND MAINTENANCE TABLES​
6.6.1. INSPECTION AND MAINTENANCE TABLE DURING BREAK-IN​
6.6.2. PERIODIC INSPECTION AND MAINTENANCE TABLES​
6.7. MAINTENANCE AND INSPECTION WORK​
6.7.1. VISUAL INSPECTION OF MACHINE AND HYDRAULIC EQUIPMENT BY WALKING AROUND THE MACHINE​
6.7.2. VISUAL INSPECTION OF DIESEL ENGINE​
6.7.3. CHECKING ENGINE OIL LEVEL​
6.7.4. WATER FUEL / SEPARATOR PREFILTER DRAIN​
6.7.5. CHECKING FUEL LEVEL​
6.7.6. CHECKING HYDRAULIC OIL LEVEL​
6.7.7. CHECKING COOLANT LEVEL​
6.7.8. CHECKING DENSITY OF COOLANT​
6.7.9. CHECKING AND CLEANING AIR FILTER DUST EXTRACTION VALVE​
6.7.10. CHECKING PRESSURE OF TIRES​
6.7.11. CHECKING DIFFERENTIAL OIL LEVEL​
6.7.12. CHECKING OIL LEVEL OF ROLLER REDUCER​
6.7.13. CHECKING OIL LEVEL OF VIBRATION SHAFT BEARINGS​
6.7.14. CHANGING DIFFERENTIAL OIL​
6.7.15. CHANGING ROLLER REDUCER OIL​
6.7.16. CHANGING VIBRATION AXLE BEARINGS OIL​
6.7.17. CHANGING ENGINE OIL AND ENGINE OIL FILTER​
6.7.18. CHANGING FUEL PREFILTER​
6.7.19. CHANGING FUEL FILTERS​
6.7.20. AIR FILTER MAINTENANCE​
6.7.21. DRAINING FUEL TANK​
6.7.22. BATTERY MAINTENANCE​
6.7.23. JUMP STARTING THE ENGINE​
6.7.24. MAINTENANCE OF HVAC UNIT (HEATING + AIR CONDITIONING)​
6.7.25. MAINTENANCE OF DIESEL ENGINE BELT​
6.7.26. MAINTENANCE OF CRANKCASE BREATHER VALVE​
6.7.27. GENERAL CHECK OF MACHINE (CHECKING DIESEL ENGINE, HYDRAULIC COMPONENTS AND REGULATION PARAMETERS)​
6.7.28. CHECKING ENGINE VALVE ADJUSTMENT​
6.7.29. REPLACING TIRES​
6.7.30. CHECKING ROPS OPERATOR'S CAB​
6.7.31. MAINTENANCE OF OPERATOR’S SEAT AND SEAT BELT​
6.7.32. CHANGING HYDRAULIC OIL AND SUCTION PREFILTERS​
6.7.33. CHANGING HYDRAULIC OIL FILTER​
6.7.34. CHANGING COOLANT​
6.7.35. ADJUSTING ROLLER SCRAPERS​
6.7.36. MAINTENANCE OF DIFFERENTIAL BRAKE (WEAR CONTROL OF BRAKE DISCS)​
6.7.37. LUBRICATION OF ARTICULATION JOINT​
6.7.38. CHECKING AND REPLACING SHOCK ABSORBERS​
6.7.39. REPLACING FUSES, RELAYS AND DIODES​
6.7.40. PURGING AIR FROM FUEL SYSTEM​
6.7.41. CLEANING THE MACHINE​
6.7.42. CLEANING DIESEL ENGINE​
6.7.43. CLEANING RADIATORS AND FAN​
6.7.44. CHECKING AND MAINTENANCE OF SAFETY SYSTEMS​
6.7.45. DRAINING LUBRICATING OIL AND WATER CONDENSATION FROM INTERCOOLER​
6.7.46. TIGHTENING WHEEL NUTS​
6.7.47. LUBRICATING HINGES OF OPERATOR’S CABIN DOOR​
6.7.48. CHECKING PADFOOT ROLLER ATTACHMENT (OPTIONAL ATTACHMENT)​
6.7.49. REPLACEMENT OF AIR VALVE OF ROLLER​
6.7.50. REPLACING RADIATOR CAP​
6.7.51. REPLACING FUEL FILLING PLUG​
6.7.52. REPLACING HYDRAULIC OIL FILLING PLUG​
6.7.53. REPLACING DEF PUMP FILTER​
6.7.54. DEF/AdBlue® LEVEL CONTROL​
6.7.55. FILLING DEF/AdBlue® TANK​
7. TECHNICAL SPECIFICATIONS
7.1. TECHNICAL SPECIFICATIONS OF HMK 1xxCS SERIES​
7.2. DIESEL ENGINE​
7.3. DIMENSIONS​
8. OPTIONAL EQUIPMENT
8.1. GENERAL​
8.2. MOUNTING PADFOOT ROLLER ATTACHMENT​
8.3. COMPACTIMETER​
8.3.1. ANALOG COMPACTION DISPLAY (ACD)​
8.3.2. COMPACTION APPLICATION​
9. MISCELLANEOUS
9.1. MANUAL SIGNALS​
9.2. TABLES OF TIGHTENING TORQUES​
9.2.1.1. TIGHTENING SAE HYDRAULIC FLANGES OF 4 DRILLS AND 6000 PSI​
9.2.1.2. TIGHTENING JIC 37º FITTINGS AND ADAPTERS​
9.2.1.3. TIGHTENING SPHERICAL SCREWS​
9.2.1.4. TIGHTENING THE DIFFERENTIAL SHAFT SCREWS​
9.2.1.5. TIGHTENING THE SCREW REDUCER SCREWS​
9.2.1.6. TIGHTENING DIESEL ENGINE SCREWS​
9.3. CONTACT INFORMATION​
