Hyundai
86
176,834
Hidromek Excavator HMK220LC-2 to HMK300LCLR Operation Maintenance Manual H347311401 EN
Brand: Hidromek
Type of Machine: Excavator
Type of Manual: Operation Maintenance Manual
Model: Hidromek HMK 220 LC-2, HMK 220 LC-2 LR, HMK 300 LC, HMK 300 NLC, HMK 300 LC LR
Tier 2 Series
Publication Number: H347311401
Publication Date: 2019
Number of Pages: 212 Pages
1. FOREWORD
2. SAFETY INFORMATION
3. GENERAL INFORMATION
3.1 DESCRIPTION AND INTENDED USE​
3.2 CE MARKING AND DECLARATION OF CONFORMITY​
3.3 CHARACTERISTICS OF THE MACHINE​
3.4 BREAK-IN OPERATION​
3.5 SPARE PARTS AND SERVICE​
3.6 COPYRIGHT​
4. DRIVING LICENSE
5. NAME PLATE
5.1 MACHINE NAME PLATE POSITION​
5.2 ENGINE NAME PLATE POSITION​
5.3 MAIN COMPONENTS PLATES​
6. GENERAL CAUTION
7. CAUTION ON OPERATING
7.1 BEFORE STARTING THE ENGINE​
7.2 AFTER STARTING THE ENGINE​
7.3 HAND SIGNALS​
7.4 TRANSPORTATION​
7.5 BATTERY​
7.6 TOWING​
7.7 LIFTING OBJECTS​
8. CAUTION ON MAINTENANCE
8.1 BEFORE MAINTENANCE​
8.2 UNDER MAINTENANCE​
9. LOCATIONS OF SAFETY LABELS
9.1 ATTACHED POSITIONS​
9.2 CONTENTS OF SAFETY DECAL​
10. MAIN COMPONENTS
10.1 LOCATION OF MAIN PARTS​
10.2 DETAIL OF OPERATOR’S CAB​
11. DESCRIPTION OF EACH DEVICE
11.1 INSTRUMENT PANEL​
11.2 MENU ITEMS​
11.3 OPERA INSTRUMENT PANEL​
11.4 MUSIC PLAYER​
11.5 USB / AUX CONNECTIONS​
11.6 EXTERNAL SOCKET (12V)​
11.7 STARTER KEY​
11.8 HOURMETER​
11.9 CUP HOLDER / ASH TRAY​
11.10 CONVENIENT STORAGE​
11.11 CONVENIENT STORAGE BOX​
11.12 SWITCHES​
11.13 SAFETY LOCKING DEVICE​
11.14 ADJUSTING ARMREST HEIGHT​
11.15 ARMREST ANGLE ADJUSTMENT​
11.16 CONSOLE ANGLE ADJUSTING LEVERS​
11.17 LEFT CONSOLE LIFTING LEVER​
11.18 LEVERS​
11.19 FUSE / RELAY BOX​
11.20 AUTOMATIC/MANUAL MODE SWITCH​
11.21 BATTERY MASTER SWITCH​
11.22 HEATER AND AIR CONDITION​
11.23 LIGHTER​
11.24 BOTTLE HOLDER​
11.25 COOL BOX​
11.26 CONVENIENT STORAGE AND CONVENIENT STORAGE BOX​
11.27. EMERGENCY EXIT​
11.28. FIRST-AID KIT​
11.29 FRONT WINDSHIELD​
11.30 DOOR​
11.31 DOOR LOCK MECHANISM​
11.32. SIDE WINDOW​
11.33. FIRE EXTINGUISHER (OPTIONAL)​
11.34 FRONT AND REAR CURTAIN​
11.35 SUNROOF​
11.36 SUN SHADE​
11.37 OPERATOR'S CAB INTERIOR LIGHTNING​
11.38 ADJUSTING MIRRORS​
11.39 OPERATOR’S SEAT ADJUSTMENT​
11.40 SEAT BELT​
12. STARTING THE MACHINE
12.1 CHECK BEFORE STARTING THE ENGINE​
12.2 STARTING THE ENGINE​
12.3 WARM-UP OPERATION​
12.4 OPERATING THE MACHINE​
12.5 TRAVEL DIRECTION CONTROL​
12.6 STOPPING AND PARKING THE MACHINE​
12.7 SWINGING THE MACHINE​
12.8 OPERATING ATTACHMENTS​
12.9 PROHIBITIONS DURING OPERATION​
12.10 CAUTIONS DURING OPERATION​
12.11 CAUTIONS WHEN TRAVELING ON A SLOPE​
12.12 ESCAPING FROM SWAMPY GROUND​
12.13 ADDITIONAL WORKS USING HYDRAULIC EXCAVATORS​
12.14 LIFTING​
12.15 REPLACING THE BUCKET​
12.16 PARKING THE MACHINE​
12.17 CHECKS AFTER FINISHING WORK​
12.18 STOPPING THE ENGINE​
12.19 CHECK AFTER STOPPING THE ENGINE​
12.20 LOCKING SYSTEM​
13. TRANSPORTATION
13.1 LOADING AND UNLOADING​
13.2 CAUTIONS ON LOADING​
13.3 CAUTIONS ON TRANSPORTATION​
13.4 LIFTING THE MACHINE​
13.5 SEA TRANSPORT​
14. HANDLING IN COLD WEATHER
14.1 PREPARATION FOR COLD WEATHER​
14.2 CAUTIONS AFTER FINISHING WORK​
14.3 HOT WEATHER​
15. LONG TERM STORAGE
15.1. BEFORE LONG TERM STORAGE​
15.2. DURING LONG TERM STORAGE​
15.3. END OF THE LONG TERM STORAGE​
15.4. INSTRUCTIONS ON WITHDRAWAL FROM USE AND UTILIZATION​
16. TROUBLESHOOTING
16.1 WHEN TO SUSPECT A TROUBLE CASE​
16.2 TOWING METHOD​
RELEASING THE PARKING BRAKE​
16.3 TOWING HOLE FOR LIGHT OBJECTS​
16.4 CAUTIONS UNDER SPECIAL CIRCUMSTANCES​
16.5 ELECTRIC DISCHARGE​
16.6 POOR BATTERY CHARGING​
16.7 OVERHEATING​
16.8 ABNORMAL (LOW) OIL PRESSURE​
16.9 ENGINE​
16.10 HYDRAULIC SYSTEM​
16.11 ELECTRIC SYSTEM​
16.12 OTHER TROUBLES​
17. CAUTIONS IN MAINTENANCE
CHECK HOUR METER​
HİDROMEK GENUINE SPARE PARTS​
WINDOW WASHER FLUID​
OIL AND GREASE​
KEEP THE MACHINE CLEAN​
CAUTION ON HOT OIL AND WATER​
CHECK FILTER​
CAUTION WHEN ADDING OIL​
KEEP CONTAMINATION AWAY​
ATTACH WARNING TAG​
OBSERVE ALL WARNINGS AND CAUTIONS​
CAUTION WHEN WELDING​
CAUTION ON FIRE​
CLEANING MACHINED SURFACES​
CHECKING THE TRACK​
CAUTION WHEN WASHING THE MACHINE​
CHECK BEFORE AND AFTER WORKING​
CAUTION DURING WORK IN DUSTY CONDITIONS​
NEVER MIX HYDRAULIC OILS​
18. GENERAL MAINTENANCE
18.1 OIL, FUEL AND COOLANT​
18.2 ELECTRONIC PARTS​
18.3 HYDRAULIC UNITS​
19. CONSUMABLE PARTS
20. FUEL AND LUBRICATION USAGE ACCORDING TO TEMPERATURE
20.1 FUEL, COOLANT AND LUBRICATION​
20.2 RECOMMENDED LUBRICATION OIL​
20.3 RECOMMENDED FUEL​
20.4 COOLANT​
21. PERIODIC REPLACEMENT OF MAIN PARTS
22. INSPECTION AND MAINTENANCE LIST
23. PERIODIC INSPECTION AND MAINTENANCE
23.1 EVERY 10 HOURS (BEFORE STARTING)​
23.2 FIRST 50 HOURS​
23.4 FIRST 250 HOURS​
23.3 EVERY 50 HOURS (WEEKLY SERVICE)​
23.5 EVERY 250 HOURS (MONTHLY SERVICE)​
23.6 FIRST 500 HOURS​
23.7 EVERY 500 HOURS (3 MONTHS SERVICE)​
23.8 EVERY 1000 HOURS (6 MONTHS SERVICE)​
23.9 EVERY 2000 HOURS (ANNUALLY SERVICE)​
23.10 EVERY 2 YEARS SERVICE​
23.11 WHEN REQUIRED​
24. TECHNICAL SPECIFICATIONS
24.1 TECHNICAL SPECIFICATIONS OF HMK 220 LC-2, HMK 220LC-2 LR​
24.2 TECHNICAL SPECIFICATIONS OF HMK 300 LC, HMK 300NLC, 300 LC LR​
25. GENERAL PRECAUTIONS
25.1 SAFETY​
25.2 CAUTION WHEN FITTING THE WORKING EQUIPMENT​
25.3 SELECTION OF ATTACHMENT​
25.4 PROTECTION AGAINST FALLING OR FLYING OBJECTS (FOPS)​
25.5 PROTECTION AGAINST TIPPING AND ROLLING OVER​
26. SELECTION OF TRACK SHOE
26.1 METHOD OF SHOE SELECTION​
27. HYDRAULIC BREAKER
27.1 MAINLY AVAILABLE WORKS​
27.2 INCORRECT OPERATION METHODS​
27.3 ADJUSTMENT FOR BREAKER​
27.4 MAINTENANCE FOR HYDRAULIC BREAKER​
28. QUICK COUPLING ATTACHMENT
28.1 MOUNTING THE BUCKET​
28.2 DISMOUNTING THE BUCKET​
29. OPTIONAL ATTACHMENT-2 SETTINGS
29.1 OPTIONAL ATTACHMENT-2 CURRENT SETTINGS​
29.2. OP.ATTACHMENT-2 ENGINE SPEED SETTINGS​
29.3 SELECTED ATTACHMENT​
29.4 POSITIONING 3-WAY BALL VALVE​
29.5 ADDITIONAL HYDRAULIC LINE (OPTIONAL) (300 SERIES)​
30. CONTACTS
30.1 FACTORY AND SERVICE DEPARTMENT​
31. ALPHABETICAL INDEX
32. NOTES
