Hidromek Excavator HMK200C-3A to HMK360LC-3A Operation Maintenance Manual H34732C403 FR
Language: French
Brand: Hidromek
Type of Machine: Excavator
Type of Manual: Operation Maintenance Manual
Model: Hidromek
HMK 200 C-3A, HMK 230 LC-3A, HMK 230 NLC-3A, HMK 230 LC LR-3A,
HMK 310 LC-3A, HMK 310 LC LR-3A, HMK 360 LC-3A
Tier 3
Publication Number: H34732C403
Publication Date: 2024
Number of Pages: 278 Pages
1. INTRODUCTION
Language: French
Brand: Hidromek
Model: Hidromek
Tier 3
1. INTRODUCTION
1.1. AVANT PROPOS
1.2. INFORMATION DE SECURITE
1.3. DESCRIPTION ET UTILISATION PREVUE
1.4. CE MARKING AND DECLARATION DE CONFORMITE
1.5. CARACTERISTIQUES DE LA MACHINE
1.6. OPERATION DE RODAGE
1.7. PIECES DE RECHANGE ET SERVICE APRES-VENTES
1.8. COPYRIGHT
1.9. PERMIT DE CONDUITE
1.10. PLAQUE D’IDENTIFICATION
2. SECURITE2.1. PRECAUTIONS GENERALES
2.2. REMARQUES SUR OPERATION
2.3. REMARQUES SUR MAINTENANCE
2.4. POSITIONNES DES DECALCOMANIES
3. LES COMPOSANTS PRINCIPALES3.1. LOCATIONS DE COMPOSANTS PRINCIPALES
3.2. DÉTAIL DE LA CABINE DE L'OPÉRATEUR
3.3. TABLEAU DE BORD
3.4. OPTIONS DE MENU
3.5. MÉDIA
3.6. TABLEAU DE BORD OPERA
3.7. CONNEXIONS USB / AUX
3.8. PRISE DE COURANT EXTERNE (12V)
3.9. CLEF DU DÉMARREUR
3.10. PORT GOBELET MUG / CENDRIER
3.11. RANGEMENT
3.12. BOITE DE RANGEMENT
3.13. COMMUTATEURS
3.14. DISPOSITIF DE VERROUILLAGE DE SECURITE
3.15. AJUSTER L’HAUTEUR D’ACCOUDOIR
3.16. L’AJUSTEUR DE L’ANGLE D’ACCOUDOIR
3.17. AJUSTEUR D’ANGLE DE CONSOLE
3.18. LEVIER DE LEVAGE DE CONSOLE A COTE GAUCHE
3.19. LEVIERS DE COMMANDES
3.20. FUSIBLES ET RELAIS
3.21. COMMUTATEUR DE MODE AUTOMATIQUE/MANUEL
3.22. RELAIS DE BATTERIE
3.23. COMMUTATEUR PRINCIPAL DE LA BATTERIE
3.24. CHAUFFAGE ET ÉTAT DE L’AIR
3.25. ALLUME-CIGARE
3.26. PORTE-BOUTEILLE
3.27. COMPARTIMENT RÉFRIGÉRÉ
3.28. RANGEMENT ET COMPARTIMENT DE RANGEMENT PRATIQUES
3.29. SORTIE D’URGENCE
3.30. TROUSSE DE SECOURS
3.31. PARE-BRISE
3.32. PORT DE CABINE
3.33. VERROU DU PORT
3.34. FENETRE LATERALE
3.35. EXTINCTEUR (OPTIONNEL)
3.36. RIDEAU AVANT ET ARRIERE
3.37. TOIT OUVRANT
3.38. PARASOL
3.39. ECLAIRAGE INTERIEUR DE CABINE OPERATRICE
3.40. REGLAGE DES MIROIRS
3.41. REGLAGE DE SIEGE D'OPÉRATEUR
3.42. CEINTURE DE SECURITE
4. OPÉRATION4.1. VÉRIFIER AVANT DE DEMARRER LE MOTEUR
4.2. DÉMARRAGE DU MOTEUR
4.3. PRECHAUFFAGE
4.4. VERIFICATIONS APRÈS DEMARRAGE DU MOTEUR
4.5. OPERATION DE LA MACHINE
4.6. COMMAND DE DIRECTION DE TRANSLATION
4.7. ARRET ET PARKING DE LA MACHINE
4.8. ROTATION DE LA MACHINE
4.9. COMMAND DES ATTACHEMENTS
4.10. OPERATIONS DÉFENDUS PENDANT TRAVAIL
4.11. ATTENTION PENDANT OPERATION
4.12. AVERTISSEMENT PENDENT DEPLACEMENT SUR UNE PENTE
4.13. SAUVER DANS LE MARAIS ET BOUE
4.14. TRAVAUX ADDITIONNELLES EN UTILISANT L’EXCAVATEUR HYDRAULIQUE
4.15. LEVAGE
4.16. DEMONTER LE GODET
4.17. PARKAGE DE LA MACHINE
4.18. VERIFICATIONS APRES LE TRAVAIL
4.19. ARRETER LE MOTEUR
4.20. VERIFICATIONS APRES L’ARRET DU MOTEUR
4.21. MANIPULATION DU MOTEUR AVEC TURBOCOMPRESSEUR
4.22. VERIFICATION DE VERROUILLAGE
4.23. TRANSPORT
4.24. PRÉPARATION DE LA MACHINE SELON LES CONDITIONS MÉTÉOROLOGIQUES
4.25. STOCKAGE AU LONG DUREE
4.26. INSTRUCTIONS RELATIVES AU RETRAIT DE LA CIRCULATION ET DE L’EXPLOITATION
5. DEPANNAGE5.1. QUAND SOUPCONNER UNE PANNE
5.2. MÉTHODE DE REMORQUAGE
5.3. ORIFICE DE REMORQUAGE POUR LES OBJETS LÉGERS
5.4. PRECAUTIONS A PRENDRE DANS DES CIRCONSTANCES SPECIALES
5.5. DECHARGE ELECTRIQUE
5.6. MAUVAISE CHARGE DE LA BATTERIE
5.7. SURCHAUFFE
5.8. PRESSION D’HUILE ANORMALE (BASSE)
5.9. MOTEUR
5.10. SYSTEME HYDRAULIQUE
5.11. CIRCUIT ELECTRIQUE
5.12. AUTRES PANNES
6. MAINTENANCE6.1. PRECAUTIONS DE MAINTENANCE
6.2. CARBURANTE, REFRIGERANT, LUBRIFICATION ET FLUIDE D'ECHAPPEMENT DIESEL
6.3. REMPLACEMENT PERIODIQUE DES PIECES ESSENTIELLES
6.4. LISTE DE CONTRÔLE ET DE MAINTENANCE
6.5. TOUTES LES 10 HEURES (AVANT DE COMMENCER)
6.6. TOUTES LES 10 HEURES (APRÈS LE TRAVAIL)
6.7. TOUTES LES 50 HEURES (ENTRETIEN HEBDOMADAIRE)
6.8. LES 250 PREMIERES HEURES
6.9. TOUTES LES 250 HEURES (ENTRETIEN HEBDOMADAIRE)
6.10. TOUTES LES 250 HEURES D'EXPLOITATION DU BRISE-ROCHE HYDRAULIQUE
6.11. LES 500 PREMIERES HEURES
6.12. TOUTES LES 500 HEURES (ENTRETIEN DES 3 MOIS)
6.13. TOUTES LES 1000 HEURES (ENTRETIEN DES 6 MOIS)
6.14. TOUTES LES 1500 HEURES
6.15. TOUTES LES 2000 HEURES (ENTRETIEN ANNUEL)
6.16. TOUS LES DEUX ANS DE SERVICE
6.17. EN CAS DE BESOIN
7. SPECIFICATIONS7.1. SPECIFICATIONS TECHNIQUES DE HMK 200 C-3A
7.2. SPECIFICATIONS TECHNIQUES DE HMK 230 LC-3A, HMK 230 NLC-3A ET HMK 230 LC LR-3A
7.3. SPECIFICATIONS TECHNIQUES DE HMK 310 LC-3A, HMK 310 LC LR-3A, HMK 310 NLC-3A
7.4. SPECIFICATIONS TECHNIQUES DE HMK 360 LC-3A
8. PRECAUTIONS GENERALES8.1. SECURITE
8.2. PRECAUTIONS A PRENDRE LORS DU MONTAGE DU MATERIEL DE TRAVAIL
8.3. CHOIX DE L'ACCESSOIRE
8.4. PROTECTION CONTRE LES CHUTES OU LES OBJETS PROJETES
8.5. PROTECTION CONTRE CAPOTAGE et ECRASEMENT
8.6. CHOIX DES PATINS DE CHENILLE
8.7. CONCASSEUR HYDRAULIQUE
8.8. ATTACHE RACCORD RAPIDE (OPTIONNEL)
9. APPENDICE9.1. DIAGRAMME DE SIGNALISATION MANUEL
9.2. COMMUNICATION
10. INDEX ALPHABETIQUE
- Hidromek HMK 102B,102S Backhoe Loader Workshop Manual
- Hidromek 102B B-S Alfa Technical Traning Documents
- Hidromek HMK 102B,102S Backhoe Loader Operating & Maintenance Manual
- Hidromek 220LC-3 Full Training and Animation Manual
- Hidromek HMK 200W-3 Workshop Manual
- Hidromek Maestro 102B 102S Electric Diagram
- Hidromek HMK 102B-102S Maestro Hydraulic Diagram
- Hidromek 300LC-3 Full Training and Animation Manual
- Hidromek HMK 102 B-S Hydraulic Diagram
- Hidromek HMK 102S Backhoe Loader Parts Catalog 2004
- Hidromek 220LC-3 Hydraulic Diagram
- Hidromek HMK 102B Backhoe Loader Parts Catalog 2007
- Hidromek Backhoe Loader HMK 102B Spare Parts Catalogue Y10,12525
- Hidromek HMK 102B Backhoe Loader Parts Catalog 2006
- Hidromek HMK 102B Backhoe Loader Parts Catalog 2004
