Hyundai
86
176,834
Hidromek Excavator HMK145LC-4SR to HMK500LC-4 Operation Maintenance Manual H347324403 FR
Language: French
Brand: Hidromek
Type of Machine: Excavator
Type of Manual: Operation Maintenance Manual
Model: Hidromek
HMK 145 LC-4 SR, HMK 230 LC-4, HMK 230 NLC-4,
HMK 230 LC-4 LR, HMK 310 LC-4, HMK 310 NLC-4,
HMK 310 LC-4 LR, HMK 390 LC-4, HMK 390 NLC-4,
HMK 390 LC-4 LR, HMK 500 LC-4
Tier 4 / Stage IV Series
Publication Number: H347324403
Publication Date: 2024
Number of Pages: 293 Pages
1. INTRODUCTION
1.1. AVANT PROPOS​
1.2. INFORMATION DE SECURITE​
1.3. DESCRIPTION ET UTILISATION PREVUE​
1.4. CE MARKING AND DECLARATION DE CONFORMITE​
1.5. CARACTERISTIQUES DE LA MACHINE​
1.6. RÉGLEMENTATION RELATIVE AUX ÉMISSIONS DE GAZ D'ÉCHAPPEMENT DES PIÈCES CONNEXES​
1.7. OPERATION DE RODAGE​
1.8. PIECES DE RECHANGE ET SERVICE APRES-VENTES​
1.9. COPYRIGHT​
1.10. PERMIT DE CONDUITE​
1.11. PLAQUE D’IDENTIFICATION​
1.12. IDENTIFICATION DE COMPOSANTS MAJEURS​
2. SECURITE
2.1. PRECAUTIONS GENERALES​
2.2. REMARQUES SUR OPERATION​
2.3. REMARQUES SUR MAINTENANCE​
2.4. POSITIONNES DES DECALCOMANIES​
3. LES COMPOSANTS PRINCIPALES
3.1. LOCATIONS DE COMPOSANTS PRINCIPALES​
3.2. DÉTAIL DE LA CABINE DE L'OPÉRATEUR​
3.3. TABLEAU DE BORD​
3.4. OPTIONS DE MENU​
3.5. MÉDIA​
3.6. TABLEAU DE BORD OPERA​
3.7. CONNEXIONS USB / AUX​
3.8. PRISE DE COURANT EXTERNE (12V)​
3.9. CLEF DU DÉMARREUR​
3.10. HORAMETRE​
3.11. PORT GOBELET MUG / CENDRIER​
3.12. RANGEMENT​
3.13. BOITE DE RANGEMENT​
3.14. COMMUTATEURS​
3.15. DISPOSITIF DE VERROUILLAGE DE SECURITE​
3.16. AJUSTER L’HAUTEUR D’ACCOUDOIR​
3.17. L’AJUSTEUR DE L’ANGLE D’ACCOUDOIR​
3.18. AJUSTEUR D’ANGLE DE CONSOLE​
3.19. LEVIER DE LEVAGE DE CONSOLE A COTE GAUCHE​
3.20. LEVIERS DE COMMANDES​
3.21. FUSIBLES ET RELAIS​
3.22. COMMUTATEUR DE MODE AUTOMATIQUE/MANUEL​
3.23. RELAIS DE BATTERIE​
3.24. COMMUTATEUR PRINCIPAL DE LA BATTERIE​
3.25. CHAUFFAGE ET ÉTAT DE L’AIR​
3.26. ALLUME-CIGARE​
3.27. PORTE-BOUTEILLE​
3.28. COMPARTIMENT RÉFRIGÉRÉ​
3.29. RANGEMENT ET COMPARTIMENT DE RANGEMENT PRATIQUES​
3.30. SORTIE D’URGENCE​
3.31. TROUSSE DE SECOURS​
3.32. PARE-BRISE​
3.33. PORT DE CABINE​
3.34. VERROU DU PORT​
3.35. FENETRE LATERALE​
3.36. EXTINCTEUR (OPTIONNEL)​
3.37.​
3.36. RIDEAU AVANT ET ARRIERE​
3.37. TOIT OUVRANT​
3.38. PARASOL​
3.39. ECLAIRAGE INTERIEUR DE CABINE OPERATRICE​
3.40. REGLAGE DES MIROIRS​
3.41. REGLAGE DE SIEGE D'OPÉRATEUR​
3.42. CEINTURE DE SECURITE​
4. OPÉRATION
4.1. VÉRIFIER AVANT DE DEMARRER LE MOTEUR​
4.2. DÉMARRAGE DU MOTEUR​
4.3. PRECHAUFFAGE​
4.4. VERIFICATIONS APRÈS DEMARRAGE DU MOTEUR​
4.5. SYSTÈME DE RÉDUCTION CATALYTIQUE SÉLECTIVE (RCS) À L’URÉE​
4.6. OPERATION DE LA MACHINE​
4.7. COMMAND DE DIRECTION DE TRANSLATION​
4.8. ARRET ET PARKING DE LA MACHINE​
4.9. ROTATION DE LA MACHINE​
4.10. COMMAND DES ATTACHEMENTS​
4.11. OPERATIONS DÉFENDUS PENDANT TRAVAIL​
4.12. ATTENTION PENDANT OPERATION​
4.13. AVERTISSEMENT PENDENT DEPLACEMENT SUR UNE PENTE​
4.14. SAUVER DANS LE MARAIS ET BOUE​
4.15. TRAVAUX ADDITIONNELLES EN UTILISANT L’EXCAVATEUR HYDRAULIQUE​
4.16. LEVAGE​
4.17. DEMONTER LE GODET​
4.18. PARKAGE DE LA MACHINE​
4.19. VERIFICATIONS APRES LE TRAVAIL​
4.20. ARRETER LE MOTEUR​
4.21. VERIFICATIONS APRES L’ARRET DU MOTEUR​
4.22. MANIPULATION DU MOTEUR AVEC TURBOCOMPRESSEUR​
4.23. VERIFICATION DE VERROUILLAGE​
4.24. TRANSPORT​
4.25. PRÉPARATION DE LA MACHINE SELON LES CONDITIONS MÉTÉOROLOGIQUES​
4.26. STOCKAGE AU LONG DUREE​
4.27. INSTRUCTIONS RELATIVES AU RETRAIT DE LA CIRCULATION ET DE L’EXPLOITATION​
5. DEPANNAGE
5.1. QUAND SOUPCONNER UNE PANNE​
5.2. METHODE DE REMORQUAGE​
5.3. TROU DE REMORQUAGE POUR OBJETS LEGERS​
5.4. PRECAUTIONS A PRENDRE DANS DES CIRCONSTANCES SPECIALES​
5.5. DECHARGE ELECTRIQUE​
5.6. MAUVAISE CHARGE DE LA BATTERIE​
5.7. SURCHAUFFE​
5.8. PRESSION D’HUILE ANORMALE (BASSE)​
5.9. MOTEUR​
5.10. SYSTEME HYDRAULIQUE​
5.11. CIRCUIT ELECTRIQUE​
5.12. AUTRES PANNES​
6. MAINTENANCE
6.1. PRECAUTIONS DE MAINTENANCE​
6.2. CARBURANTE, REFRIGERANT, LUBRIFICATION ET FLUIDE D'ECHAPPEMENT DIESEL​
6.3. REMPLACEMENT PERIODIQUE DES PIECES ESSENTIELLES​
6.4. LISTE DE CONTRÔLE ET DE MAINTENANCE​
6.5. TOUTES LES 10 HEURES (AVANT DE COMMENCER)​
6.6. TOUTES LES 10 HEURES (APRÈS LE TRAVAIL)​
6.7. TOUTES LES 50 HEURES (ENTRETIEN HEBDOMADAIRE)​
6.8. LES 250 PREMIERES HEURES​
6.9. TOUTES LES 250 HEURES (ENTRETIEN HEBDOMADAIRE)​
6.10. TOUTES LES 250 HEURES D'EXPLOITATION DU BRISE-ROCHE HYDRAULIQUE​
6.11. LES 500 PREMIERES HEURES​
6.12. TOUTES LES 500 HEURES (ENTRETIEN DES 3 MOIS)​
6.13. TOUTES LES 1000 HEURES (ENTRETIEN DES 6 MOIS)​
6.14. TOUTES LES 2000 HEURES (ENTRETIEN ANNUEL)​
6.15. TOUTES LES 2500 HEURES​
6.16. TOUS LES DEUX ANS DE SERVICE​
6.17. TOUTES LES 4500 HEURES​
6.18. TOUTES LES 5000 HEURES​
6.19. EN CAS DE BESOIN​
7. SPECIFICATIONS
7.1. SPECIFICATIONS TECHNIQUES DE HMK 145 LC-4 SR​
7.2. SPECIFICATIONS TECHNIQUES DE HMK 230 LC-4, HMK 230 NLC-4 ET HMK 230 LC-4 LR​
7.3. SPECIFICATIONS TECHNIQUES DE HMK 310 LC-4, HMK 310 LC-4 LR, HMK 310 NLC-4​
7.4. SPECIFICATIONS TECHNIQUES DE HMK 390 LC-4, HMK 390 LC-4 LR, HMK 390 NLC-4​
7.5. SPECIFICATIONS TECHNIQUES DE HMK 500 LC-4​
8. PRECAUTIONS GENERALES
8.1. SECURITE​
8.2. PRECAUTIONS A PRENDRE LORS DU MONTAGE DU MATERIEL DE TRAVAIL​
8.3. CHOIX DE L'ACCESSOIRE​
8.4. PROTECTION CONTRE LES CHUTES OU LES OBJETS PROJETES​
8.5. PROTECTION CONTRE CAPOTAGE et ECRASEMENT​
8.6. CHOIX DES PATINS DE CHENILLE​
8.7. CONCASSEUR HYDRAULIQUE​
8.8. SELLETTE D'ATTELAGE RAPIDE​
9. APPENDICE
9.1. DIAGRAMME DE SIGNALISATION MANUEL​
9.2. COMMUNICATION​
10. INDEX ALPHABETIQUE
