Hyundai
86
176,834
Hidromek Excavator HMK140W-3 HMK200W-3 Operation Maintenance Manual H237322411 NL
Language: Dutch
Brand: Hidromek
Type of Machine: Excavator
Type of Manual: Operation Maintenance Manual
Model: Hidromek HMK140W-3 HMK200W-3 Tier 3 Excavator
Serial Number:
HMK 140 W-3 (From serial number 8120001 - )
HMK 200 W-3 (From serial number 9123501 - )
Publication Number: H237322411
Publication Date: 2014
Number of Pages: 239 Pages
1. INLEIDING
2. VEILIGHEIDSINFORMATIE
3. ALGEMENE INFORMATIE
3.1 OMSCHRIJVING EN BEDOELD GEBRUIK​
3.2 CE-MARKERING EN CONFORMITEITSVERKLARING​
3.3 EIGENSCHAPPEN VAN DE MACHINE​
3.4 INRIJDEN​
3.5 VERVANGINGSONDERDELEN EN DIENST-NA-VERKOOP​
3.6 COPYRIGHT​
4. RIJBEWIJS
5. TYPEPLAATJE
5.1 PLAATS VAN HET TYPEPLAATJE​
5.2 PLAATS VAN HET MOTORPLAATJE​
5.3 TYPEPLAATJES VAN DE BELANGRIJKSTE ONDERDELEN​
6. ALGEMENE VOORZORGSMAATREGELEN
7. VOORZICHTIGHEID BIJ HET BEDIENEN VAN DE MACHINE
7.1 ALVORENS DE MOTOR TE STARTEN​
7.2 NA HET STARTEN VAN DE MOTOR​
7.3 HANDGEBAREN​
7.4 TRANSPORTEREN​
7.5 ACCU​
7.6 SLEPEN​
7.7 VOORWERPEN TILLEN​
8. WAARSCHUWINGEN TIJDENS HET ONDERHOUD
8.1 WAARSCHUWINGEN VÓÓR HET ONDERHOUD​
8.2 IN ONDERHOUD​
9. PLAATS VAN DE VEILIGHEIDSSTICKERS
9.1 LOCATIES VEILIGHEIDSSTICKERS​
9.2 BETEKENIS VAN DE​
VEILIGHEIDSPICTOGRAMMEN​
10. BENAMING VAN IEDER ONDERDEEL
10.1 PLAATS VAN DE BELANGRIJKSTE ONDERDELEN​
10.2 DE BESTUURDERSCABINE IN DETAIL​
11. BESTUURDERSCABINE
11.1 INSTRUMENTENBORD​
11.2 MENU-ELMENTEN​
11.3 OPERA-INSTRUMENTENBORD​
11.4 MUZIEKSPELER​
11.5 USB / AUX -AANSLUITINGEN​
EXTERNE ELEKTRISCHE AANSLUITING (12 V)​
11.7 CONTACTSLEUTEL​
11.8 UURMETER​
11.9 BEKERHOUDER / ASBAK​
11.10 HANDIGE OPBERGRUIMTE​
11.11 HANDIG OPBERGCOMPARTIMENT​
11.13 STUURINRICHTING​
11.14 VEILIGHEIDSVERGRENDELING​
11.15 IN DE HOOGTE VERSTELLEN VAN DE ARMSTEUN​
11.16 HOEK VAN ARMSTEUN VERSTELLEN​
11.17 HENDELS VOOR HOEKVERSTELLING VAN DE CONSOLES​
11.8 HEFHENDEL LINKER CONSOLE​
11.19 HENDELS​
11.20. ZWENKVERGRENDELSPIL​
11.21 GAS- EN REMPEDALEN​
11.22 ZEKERINGEN-/RELAISKAST​
11.23 KEUZESCHAKELAAR AUTOMATISCHE/MANUELE MODUS​
11.24 ACCURELAIS​
11.26 VERWARMING EN AIR CONDITIONING​
11.27 SIGARETTENAANSTEKER​
11.28 FLESSENHOUDER​
11.29 THERMOBOX​
11.30 HANDIGE OPBERGRUIMTE EN HANDIGE OPBERGBOX​
11.31 KLEDINGHAAK​
11.32 NOODUITGANG​
11.33 VOORRUIT​
11.34 DEUR​
11.35 OPEN-STANDVERGRENDELING​
11.36 ZIJRUIT​
11.37 BRANDBLUSSER (OPTIONEEL)​
11.38 GORDIJN VOOR- EN ACHTERAAN​
11.40 ZONNESCHERM​
11.41 BINNENVERLICHTING IN DE BESTUURDERSCABINE​
11.42 AFSTELLEN VAN DE SPIEGELS​
11.43 AFSTELLEN BESTUUDERSSTOEL​
11.44 VEILIGHEIDSGORDEL​
12. STARTEN VAN DE MACHINE
12.1 CONTROLE ALVORENS DE MOTOR TE STARTEN​
12.2 STARTEN VAN DE MOTOR​
12.3 OPWARMEN​
12.4 BEDIENEN VAN DE MACHINE​
12.5 RIJSTURING​
12.6 ZWENKEN VAN DE MACHINE​
12.7 BEDIENEN VAN EEN AANBOUWDEEL​
12.8 BEDIENEN VAN HET DOZERBLAD (DUWBLAD) EN DE STABLISATOREN (STEMPELS)​
12.9 CRUISE CONTROL-FUNCTIE​
12.10 VERBODEN HANDELINGEN MET DE MACHINE​
12.11 AANDACHTSPUNTEN TIJDENS HET GEBRUIK​
AANDACHTSPUNTEN VOOR HET RIJDEN OP EEN HELLING​
12.13 BIJKOMENDE WERKZAAMHEDEN MET BEHULP VAN HYDRAULISCHE GRAAFMACHINES​
12.14 HIJSEN​
12.15 VERVANGEN VAN DE BAK​
12.16 CONTROLES NA HET UITVOEREN VAN WERKZAAMHEDEN​
12.17 UITZETTEN VAN DE MOTOR​
12.18 CONTROLE NA HET UITZETTEN VAN DE MOTOR​
12.19 VERGRENDELINGSSYSTEEM​
13. VERVOEREN VAN DE MACHINE
13.1 LADEN EN LOSSEN​
13.2 AANDACHTSPUNTEN BIJ HET LADEN​
13.3 AANDACHTSPUNTEN BIJ HET VERVOEREN​
13.4 HIJSEN VAN DE MACHINE​
13.5 VERVOER OVER ZEE​
14. DE MACHINE GEBRUIKEN BIJ KOUD WEER
14.1 VOORBEREIDING BIJ KOUD WEER​
14.2 AANDACHTSPUNTEN NA HET UITVOEREN VAN WERKZAAMHEDEN​
14.3 WARM WEER​
15. LANGDURIG STALLEN
15.1 ALVORENS TE STALLEN​
15.2 WHILE IN STORAGE​
15.3 NÁ HET STALLEN​
16. STORINGSDIAGNOSE
16.1 WANNEER IS ER SPRAKE VAN EEN PROBLEEM ?​
16.3 SLEEPOOG VOOR HET SLEPEN VAN LICHTE VOORWERPEN​
16.4 EXTRA AANDACHT VOOR SPECIALE SITUATIES​
16.5 ELEKTRISCHE ONTLADING​
16.6 GERINGE LADING VAN DE ACCU​
16.7 OVERVERHITTTING​
16.8 ABNORMALE (LAGE) OLIEDRUK​
16.9 MOTOR​
16.10 HYDRAULISCH SYSTEEM​
16.11 ELEKTRISCH SYSTEEM​
16.12 ANDERE PROBLEMEN​
17. BELANGRIJKE AANDACHTSPUNTEN BIJ ONDERHOUD
AFLEZEN VAN DE UURMETER​
GEBRUIKEN VAN ORIGINELE WISSELSTUKKEN VAN HIDROMEK​
RUITENSPROEIERVLOEISTOF​
OLIE EN VET​
SCHOONHOUDEN VAN DE MACHINE​
OPLETTEN VOOR HETE OLIE EN HEET WATER​
CONTROLEREN VAN FILTERS​
OPLETTEN TIJDENS HET BIJVULLEN VAN OLIE​
VOORKOMEN DAT ONDERDELEN VERVUILD RAKEN​
AANBRENGEN VAN EEN WAARSCHUWINGSBORD​
OPVOLGEN VAN ALLE WAARSCHUWINGEN EN AANDACHTSPUNTEN​
OPLETTEN TIJDENS HET LASSEN​
OPLETTEN VOOR BRAND​
SCHOONMAKEN VAN PASVLAKKEN​
OPLETTEN BIJ HET WASSEN VAN DE MACHINE​
CONTROLES VÓÓR EN NÁ HET WERKEN​
OPLETTEN MET WERKEN IN STOFRIJKE OMGEVINGEN​
NOOIT VERSCHILLENDE SOORTEN HYDRAULISCHE OLIËN MET ELKAAR MENGEN​
18. ALGEMEEN ONDERHOUD
18.1 OLIE, BRANDSTOF EN KOELVLOEISTOF​
18.2 ELEKTRONISCHE COMPONENTEN​
18.3 HYDRAULISCHE COMPONENTEN​
18.4 AFSTELLEN VAN DE SPELING VAN DE BAK​
19. VERBRUIKSONDERDELEN
20. KEUZE VAN BRANDSTOF EN SMEERMIDDEL NAAR GELANG DE TEMPERATUUR
20.1 BRANDSTOF, KOELVLOEISTOF EN SMEEROLIE​
20.2 AANBEVOLEN SMEEROLIE​
20.3.2 AANBEVOLEN BRANDSTOF​
20.4 KOELVLOEISTOF​
21. PERIODIEKE VERVANGING VAN DE BELANGRIJKSTE ONDERDELEN
22. OVERZICHT INSPECTIE- EN ONDERHOUDSWERKZAAMHEDEN
22.1 ONDERHOUDSLIJST IN FUNCTIE VAN DE ONDERHOUDSINTERVALLEN​
23. PERIODIEKE CONTROLE- EN ONDERHOUDSWERKZAAMHEDEN
23.1 ELKE 10 UUR (VÓÓR HET STARTEN)​
23.2 ELKE 500 UUR (WEKELIJKS ONDERHOUD)​
23.3 NA DE EERSTE 250 UUR​
23.4 ELKE 250 UUR (MAANDELIJKS ONDERHOUD)​
23.6 ELKE 500 UUR (3-MAANDELIJKS ONDERHOUD)​
23.7 ELKE 1000 UUR (6-MAANDELIJKS ONDERHOUD)​
23.8 ELKE 2000 UUR (JAARLIJKS ONDERHOUD)​
23.9 INDIEN NODIG​
24. TECHNISCHE GEGEVENS
24.1 TECHNISCHE GEGEVENS VAN DE HMK 140 W-3​
24.2 TECHNISCHE GEGEVENS VAN DE HMK 200 W-3​
25. ALGEMENE VOORZORGSMAATREGELEN
25.1 VEILIGHEID​
25.2 AANDACHTSPUNTEN BIJ HET AANKOPPELEN VAN EEN WERKUITRUSTING​
25.3. KIEZEN VAN EEN AANBOUWDEEL​
25.4. BESCHERMING TEGEN VALLENDE OF RONDVLIEGENDE VOORWERPEN​
26. BEHANDELING VAN BANDEN
26.1. HOE EEN BAND VERVANGEN ?​
26.2 BANDENWISSEL​
27. HYDRAULISCHE BREEKHAMER
27.1 VOORNAAMSTE WERKZAAMHEDEN​
27.2 VERKEERDE METHODES​
27.3 AFSTELLINGEN VOOR DE BREEKHAMER​
27.4 ONDERHOUD BIJ GEBRUIK VAN HAMER​
28. SNELKOPPELAANBOUWDEEL
29. INSTELLINGEN VAN OPTIONEEL AANBOUWDEEL 2
29.1 INSTELLINGEN VAN DE STROOM VOOR OPTIONEEL AANBOUWDEEL 2​
29.2. MOTORTOERENTALINSTELLINGEN VOOR OPTIONEEL AANBOUWDEEL 2​
29.3 GESELECTEERD AANBOUWDEEL​
29.4 POSITIE VAN DE 3-WEG KOGELKRAAN​
29.5 EXTRA HYDRAULISCHE LEIDING (OPTIONEEL)​
30. CONTACT
30.1 FABRIEK EN SERVICEAFDELING​
31. ALFABETISCHE INDEX
32. NOTITIES
