Hyundai
86
176,834
Hidromek Excavator HMK140W-3 HMK200W-3 Operation Maintenance Manual H237322403 FR
Language: French
Brand: Hidromek
Type of Machine: Excavator
Type of Manual: Operation Maintenance Manual
Model: Hidromek HMK140W-3 HMK200W-3 Excavator
Tier 3 Series
Publication Number: H237322403
Publication Date: 2019
Number of Pages: 252 Pages
1. AVANT PROPOS
2. INFORMATION DE SECURITE
3. INFORMATION GENERAL
3.1. DESCRIPTION ET UTILISATION PREVUE​
3.2. CE MARKING AND DECLARATION DE CONFORMITE​
3.3. CARACTERISTIQUES DE LA MACHINE​
3.4. OPERATION DE RODAGE​
3.5. PIECES DE RECHANGE ET SERVICE APRES-VENTES​
3.6. COPYRIGHT​
4. PERMIT DE CONDUITE
5. PLAQUE D’IDENTIFICATION
5.1. LOCTION DE PLAQUE D’IDENTIFICATION DE LA MACHINE​
5.2. PLAQUE D’IDENTIFICATION DU MOTEUR​
5.3. IDENTIFICATION DE COMPOSANTS MAJEURS​
6. PREATTENTIONS GENERALES
7. REMARQUES SUR OPERATION
7.1. AVANT DE DEMARRER LE MOTEUR​
7.2. APRES DEMARRAGE DU MOTEUR​
7.3. DIAGRAMME DE SIGNALISATION MANUEL​
7.4. TRANSPORT DE LA MACHINE​
7.5. BATTERIE​
7.6. REMORQUAGE DE LA MACHINE​
7.7. LEVAGE D’OBJETS​
8. REMARQUES SUR MAINTENANCE
8.1. AVANT LA MAINTENANCE​
8.2. LORS DE MAINTENANCE​
9. POSITIONNES DES DECALCOMANIES
9.1. POSITIONS AFFICHEES​
9.2. VIGNETTES DES MESURES DE SÉCURITÉ​
10. LES COMPOSANTS PRINCIPALES
10.1. LOCATIONS DE COMPOSANTS PRINCIPALES​
10.2. DÉTAIL DE LA CABINE DE L'OPÉRATEUR​
11. CABINE DE L'OPÉRATEUR
11.1. TABLEAU DE BORD​
11.2. ÉLÉMENTS DU MENU​
11.3. TABLEAU DE BORD OPERA​
11.4. AUTORADIO​
11.5. CONNEXIONS USB / AUX​
11.6. PRISE DE COURANT EXTERNE (12V)​
11.7. CLEF DU DÉMARREUR​
11.8. HORAMETRE​
11.9. PORT GOBELET MUG / CENDRIER​
11.10. RANGEMENT​
11.11. BOITE DE RANGEMENT​
11.12. COMMUTATEURS​
11.13. LEVIER DE LAME DE DOSER ET STABILISATEURS​
11.14. DIRECTION​
11.15. DISPOSITIF DE VERROUILLAGE DE SECURITE​
11.16. AJUSTER L’HAUTEUR D’ACCOUDOIR​
11.17. L’AJUSTEUR DE L’ANGLE D’ACCOUDOIR​
11.18. AJUSTEUR D’ANGLE DE CONSOLE​
11.19. LEVIER DE LEVAGE DE CONSOLE A COTE GAUCHE​
11.20. LEVIERS DE COMMANDES​
11.21. AXE DE VERROU DE ROTATION​
11.22. PEDALES ACCELERATEUR ET FREIN​
11.23. FUSIBLES ET RELAIS​
11.24. COMMUTATEUR DE MODE AUTOMATIQE/MANUEL​
11.25. RELAIS DE BATTERIE​
11.26. CHAUFFAGE ET ÉTAT DE L’AIR​
11.27. ALLUME-CIGARE​
11.28. PORTE-BOUTEILLE​
11.29. COMPARTIMENT RÉFRIGÉRÉ​
11.30. RANGEMENT ET COMPARTIMENT DE RANGEMENT PRATIQUES​
11.31. SORTIE D’URGENCE​
11.32. TROUSSE DE SECOURS​
11.33. PARE-BRISE​
11.34. PORT DE CABINE​
11.35. VERROU DU PORT​
11.36. FENETRE LATERALE​
11.37. EXTINCTEUR (OPTIONNEL)​
11.38. RIDEAU AVANT ET ARRIERE​
11.39. TOIT OUVRANT​
11.40. PARASOL​
11.41. ECLAIRAGE INTERIEUR DE CABINE OPERATRICE​
11.42. REGLAGE DES MIROIRS​
11.43. REGLAGE DE SIEGE D'OPÉRATEUR​
11.44. CEINTURE DE SECURITE​
12. DEMARRER LA MACHINE
12.1. VÉRIFIER AVANT DE DEMARRER LE MOTEUR​
12.2. DEMARRER LE MOTEUR​
12.3. PRECHAUFFAGE​
12.4. OPERATION DE LA MACHINE​
12.5. COMMAND DE SENS DE MARCHE​
12.6. ROTATION DE LA MACHINE​
12.7. COMMAND DES ATTACHEMENTS​
12.8. OPERATION DE LAME DE DOSER ET LES STABILISATEURS​
12.9. FONCTİON DE REGULATEUR DE VITESSE (CRUISE)​
12.10. OPERATIONS DÉFENDUS PENDANT TRAVAIL​
12.11. ATTENTION PENDANT OPERATION​
12.12. AVERTISSEMENT PENDENT DEPLACEMENT SUR UNE PENTE​
12.13. TRAVAUX ADDITIONNELLES EN UTILISANT L’EXCAVATEUR HYDRAULIQUE​
12.14. LEVAGE​
12.15. DEMONTER LE GODET​
12.16. VERIFICATIONS APRES LE TRAVAIL​
12.17. ARRETER LE MOTEUR​
12.18. VERIFICATIONS APRES L’ARRET DU MOTEUR​
12.19. VERIFICATION DE VERROUILLAGE​
13. TRANSPORT
13.1. CHARGEMENT ET DÉCHARGEMENT​
13.2. PREATTENTIONS DE CHARGEMENT​
13.3. MISE EN GARDE RELATIVE AU TRANSPORT​
13.4. LEVAGE DE L’ENGIN​
13.5. TRANSPORT MARITIME​
14. MANIPULATION PAR TEMPS FROID
14.1. PREPARATION POUR LE DEMARRAGE PAR TEMPS FROID​
14.2. PREATTENTIONS A PRENDRE APRES AVOIR TERMINER LES TRAVAUX​
14.3. TEMPS CHAUD​
15. STOCKAGE AU LONG DUREE
15.1. AVANT LE STOCKAGE​
15.2. PENDANT LE STOCKAGE​
15.3. APRES STOCKAGE​
15.4. INSTRUCTIONS RELATIVES AU RETRAIT DE LA CIRCULATION ET DE L’EXPLOITATION​
16. DEPANNAGE
16.1. QUAND SOUPCONNER UNE PANNE​
16.2. METHODE DE REMORQUAGE​
16.3. L’OEIL DE REMORQUAGE POUR DES CHARGES LEGERES​
16.4. PRUDENCE SOUS CIRCONSTANCES SPECIAUX​
16.5. DECHARGE ELECTRIQUE​
16.6. MAUVAISE CHARGE DE LA BATTERIE​
16.7. SURCHAUFFE​
16.8. PRESSION D’HUILE ANORMALE (BASSE)​
16.9. MOTEUR​
16.10. SYSTEME HYDRAULIQUE​
16.11. CIRCUIT ELECTRIQUE​
16.12. AUTRES PANNES​
17. PREATTENTIONS DE MAINTENANCE
18. ENTRETIEN GENERAL
18.1. HUILE, CARBURANT ET LIQUIDE DE REFROIDISSEMENT​
18.2. LES COMPOSANTS ELECTRONIQUES​
18.3. LES UNITES HYDRAULIQUES​
19. PIECES CONSUMABLES
20. UTILISATION DE L’HUILE ET CARBURANTES SELON LA TEMPERATURE
20.1. CARBURANTE, REFRIGERANT ET LUBRIFICATION​
20.2. LUBRIFICATION RECOMMENDEE​
20.3. CARBURANT RECOMMANDE​
20.4. LE LIQUIDE DE REFROIDISSEMENT​
21. REMPLACEMENT PERIODIQUE DES PIECES ESSENTIELLES
22. LISTE DE CONTRÔLE ET DE MAINTENANCE
22.1. LISTE DE MAINTENANCE SUIVANT L’INTERVALLE DE SERVICE​
23. CONTRÔLE ET ENTRETIEN PÉRIODIQUES
23.1. TOUTES LES 10 HEURES (AVANT DE COMMENCER)​
23.2. TOUTES LES 50 HEURES (ENTRETIEN HEBDOMADAIRE)​
23.3. LES 250 PREMIERES HEURES​
23.4. TOUTES LES 250 HEURES (ENTRETIEN HEBDOMADAIRE)​
23.5. TOUTES LES 250 HEURES D'EXPLOITATION DU BRISE-ROCHE HYDRAULIQUE.​
23.6. TOUTES LES 500 HEURES (ENTRETIEN DES 3 MOIS)​
23.7. TOUTES LES 1000 HEURES (ENTRETIEN DES 6 MOIS)​
23.8. TOUTES LES 2000 HEURES (ENTRETIEN ANNUEL)​
23.9. EN CAS DE BESOIN​
24. SPECIFICATIONS
24.1. SPECIFICATIONS TECHNIQUES DE HMK 140 W-3​
24.2. SPECIFICATIONS TECHNIQUES DE HMK 200 W-3​
25. PREATTENTIONS GENERALES
25.1. SECURITE​
25.2. PREATTENTIONS A PRENDRE LORS DU MONTAGE DU MATERIEL DE TRAVAIL​
25.3. CHOIX DE L'ACCESSOIRE​
25.4. PROTECTION CONTRE LES CHUTES OU LES OBJETS PROJETES​
25.5. PROTECTION CONTRE CAPOTAGE et ECRASEMENT​
26. TRAVAILLER AVEC LES ROUES
26.1. PROCEDURE DE CHANGEMENT DES ROUES​
26.2. ROTATION DE ROUES​
27. CONCASSEUR HYDRAULIQUE
27.1. PRINCIPAUX TRAVAUX DISPONIBLES​
27.2. METHODES INCORRECTES​
27.3. REGLAGE DU CONCASSEUR​
27.4. ENTRETIEN DES CONCASSEURS​
28. SELLETTE D'ATTELAGE RAPIDE
28.1. MONTAGE DU GODET​
28.2. DEMONTAGE DU GODET​
29. PARAMETRES DE L'ACCESSOIRE EN OPTION-2
29.1. PARAMETRES DU COURANT DE L'ACCESSOIRE EN OPTION-2​
29.2.​
29.3. PARAMETRES DE LA VITESSE DU MOTEUR DE L'ACCESSOIRE EN OPTION-2​
29.4. ACCESSOIRE SELECTIONNE​
29.5. POSITIONNEMENT DE LA VANNE A BILLE 3 VOIES​
29.6. CONDUIT HYDRAULIQUE SUPPLEMENTAIRE (EN OPTION)​
30. COMMUNICATION
30.1. L’USINE ET SERVICE APRES-VENTE​
31. INDEX ALPHABETIQUE
