Hyundai
86
176,834
Hidromek Excavator HMK140W-3 HMK200W-3 Operation Maintenance Manual H237322401 EN
Brand: Hidromek
Type of Machine: Excavator
Type of Manual: Operation Maintenance Manual
Model: Hidromek HMK140W-3 HMK200W-3 Excavator
Tier 3 Series
Serial Number:
HMK 140 W-3 (From serial number 8120001)
HMK 200 W-3 (From serial number 9123501)
Publication Number: H237322401
Publication Date: 2019
Number of Pages: 256 Pages
1. FOREWORD
2. SAFETY INFORMATION
3. GENERAL INFORMATION
3.1. DESCRIPTION AND INTENDED USE​
3.2. CE MARKING AND DECLARATION OF CONFORMITY​
3.3. CHARACTERISTICS OF THE MACHINE​
3.4. BREAK-IN OPERATION​
3.5. SPARE PARTS AND SERVICE​
3.6. COPYRIGHT​
4. DRIVING LICENSE
5. IDENTIFICATION PLATE
5.1. LOCATION OF THE MACHINE ID PLATE​
5.2. ENGINE NAME PLATE POSITION​
5.3. MAIN COMPONENTS PLATES​
6. GENERAL PRECAUTIONS
6.1. OPERATORS MUST HAVE CERTAIN QUALIFICATIONS​
6.2. OBSERVE ALL SAFETY RULES ON-SITE​
6.3. INSTALL ALL GUARDS AND SAFETY DEVICES​
6.4. WEAR PROTECTIVE CLOTHES AND SAFETY EQUIPMENT​
6.5. MODIFICATIONS​
6.6. BEFORE LEAVING THE MACHINE​
6.7. USE HANDRAILS AND FOOTHOLDS TO GET ON/OFF THE MACHINE​
6.8. DO NOT ALLOW FIRE NEAR FUEL AND OIL​
6.9. HANDLE WITH CARE UNDER HIGH TEMPERATURE​
6.10. DO NOT INHALE DUST CONTAINING ASBESTOS​
6.11. PAY ATTENTION TO MOVING PARTS​
6.12. MACHINE FIRE EXTINGUISHER AND FIRST-AID KIT​
6.13. PROTECTION FROM FALLING OR FLYING OBJECTS​
6.14. BEFORE WORKING IN THE VICINITY OF GAS LINES​
6.15. CAUTION FOR OPTIONAL WORKING ATTACHMENT​
6.16. DO NOT REMOVE FRONT ATTACHMENT OR COUNTERWEIGHT​
6.17. CAUTION FOR POLYMERS AND ELASTOMERS​
7. CAUTION DURING OPERATING
7.1. BEFORE STARTING THE ENGINE​
7.2. AFTER STARTING THE ENGINE​
7.3. HAND SIGNALS​
7.4. TRANSPORTATION​
7.5. BATTERY​
7.6. TOWING​
7.7. LIFTING OBJECTS​
8. PRECAUTIONS FOR MAINTENANCE
8.1. BEFORE MAINTENANCE​
8.2. DURING MAINTENANCE​
9. ATTACHED POSITION OF SAFETY LABELS
9.1. ATTACHED POSITIONS​
9.2. CONTENTS OF SAFETY DECAL​
10. NAME OF EACH PART
10.1. LOCATION OF MAIN PARTS​
10.2. DETAIL OF OPERATOR’S CAB​
11. OPERATOR'S CAB
11.1. INSTRUMENT PANEL​
11.2. MENU ITEMS​
13.3. OPERA INSTRUMENT PANEL​
11.3. MUSIC PLAYER​
11.4. USB / AUX CONNECTIONS​
11.5. EXTERNAL SOCKET (12V)​
11.6. STARTER KEY​
11.7. HOURMETER​
11.8. CUP HOLDER / ASH TRAY​
11.9. CONVENIENT STORAGE​
11.10. CONVENIENT STORAGE BOX​
11.11. SWITCHES​
11.12. DOZER BLADE AND OUTRIGGER CONTROL LEVER​
11.13. STEERING​
11.14. SAFETY LOCKING DEVICE​
11.15. ADJUSTING ARMREST HEIGHT​
11.16. ARMREST ANGLE ADJUSTMENT​
11.17. CONSOLE ANGLE ADJUSTING LEVERS​
11.18. LEFT CONSOLE LIFTING LEVER​
11.19. LEVERS​
11.20. SWING LOCK​
11.21. ACCELERATOR AND BRAKE PEDALS​
11.22. FUSE / RELAY BOX​
11.23. AUTOMATIC/MANUAL MODE SWITCH​
11.24. BATTERY RELAY​
11.25. HEATER AND AIR CONDITION​
11.26. LIGHTER​
11.27. BOTTLE HOLDER​
11.28. COOL BOX​
11.29. CONVENIENT STORAGE AND CONVENIENT STORAGE BOX​
11.30. EMERGENCY EXIT​
11.31. FIRST-AID KIT​
11.32. FRONT WINDSHIELD​
11.33. DOOR​
11.34. DOOR LOCK MECHANISM​
11.35. SIDE WINDOW​
11.36. FIRE EXTINGUISHER (OPTIONAL)​
11.37. FRONT AND REAR CURTAIN​
11.38. SUNROOF​
11.39. SUN SHADE​
11.40. OPERATOR'S CAB INTERIOR LIGHTING​
11.41. ADJUSTING MIRRORS​
11.42. OPERATOR’S SEAT ADJUSTMENT​
11.43. SEAT BELT​
12. STARTING THE MACHINE
12.1. CHECK BEFORE STARTING THE ENGINE​
12.2. STARTING THE ENGINE​
12.3. WARM-UP OPERATION​
12.4. OPERATING THE MACHINE​
12.5. TRAVEL DIRECTION CONTROL​
12.6. SWINGING THE MACHINE​
12.7. OPERATING ATTACHMENTS​
12.8. OPERATING DOZER BLADE AND OUTRIGGERS​
12.9. CRUISE FUNCTION​
12.10. PROHIBITIONS DURING OPERATION​
12.11. CAUTIONS DURING OPERATION​
12.12. CAUTIONS WHEN TRAVELING ON A SLOPE​
12.13. ADDITIONAL WORKS USING HYDRAULIC EXCAVATORS​
12.14. LIFTING​
12.15. REPLACING THE BUCKET​
12.16. CHECKS AFTER FINISHING WORK​
12.17. STOPPING THE ENGINE​
12.18. CHECK AFTER STOPPING THE ENGINE​
12.19. LOCKING SYSTEM​
13. TRANSPORTATION
13.1. LOADING AND UNLOADING​
13.2. CAUTIONS ON LOADING​
13.3. CAUTIONS ON TRANSPORTATION​
13.4. LIFTING THE MACHINE​
13.5. SEA TRANSPORT​
14. HANDLING IN COLD WEATHER
14.1. PREPARATION FOR COLD WEATHER​
14.2. CAUTIONS AFTER FINISHING WORK​
14.3. HOT WEATHER​
15. LONG TERM STORAGE
15.1. BEFORE LONG TERM STORAGE​
15.2. DURING LONG TERM STORAGE​
15.3. END OF THE LONG TERM STORAGE​
15.4. INSTRUCTIONS ON WITHDRAWAL FROM USE AND UTILIZATION​
16. TROUBLESHOOTING
16.1. WHEN TO SUSPECT A TROUBLE CASE​
16.2. TOWING METHOD​
16.3. TOWING HOLE FOR LIGHT OBJECTS​
16.4. CAUTIONS UNDER SPECIAL CIRCUMSTANCES​
16.5. ELECTRIC DISCHARGE​
16.6. POOR BATTERY CHARGING​
16.7. OVERHEATING​
16.8. ABNORMAL (LOW) OIL PRESSURE​
16.9. ENGINE​
16.10. HYDRAULIC SYSTEM​
16.11. ELECTRIC SYSTEM​
16.12. OTHER TROUBLES​
17. CAUTIONS IN MAINTENANCE
17.1.1.1. CHECK HOUR METER​
17.1.1.2. HİDROMEK GENUINE SPARE PARTS​
17.1.1.3. WINDOW WASHER FLUID​
17.1.1.4. OIL AND GREASE​
17.1.1.5. KEEP THE MACHINE CLEAN​
17.1.1.6. CAUTION ON HOT OIL AND WATER​
17.1.1.7. CHECK FILTER​
17.1.1.8. CAUTION WHEN ADDING OIL​
17.1.1.9. KEEP CONTAMINATION AWAY​
17.1.1.10. ATTACH WARNING TAG​
17.1.1.11. OBSERVE ALL WARNINGS AND CAUTIONS​
17.1.1.12. CAUTION WHEN WELDING​
17.1.1.13. CAUTION ON FIRE​
17.1.1.14. CLEANING MACHINED SURFACES​
17.1.1.15. CAUTION WHEN WASHING THE MACHINE​
17.1.1.16. CHECK BEFORE AND AFTER WORKING​
17.1.1.17. CAUTION DURING WORK IN DUSTY CONDITIONS​
17.1.1.18. NEVER MIX HYDRAULIC OILS​
18. GENERAL MAINTENANCE
18.1. OIL, FUEL AND COOLANT​
18.2. ELECTRONIC PARTS​
18.3. HYDRAULIC UNITS​
19. CONSUMABLE PARTS
20. FUEL AND LUBRICATION USAGE ACCORDING TO TEMPERATURE
20.1. FUEL, COOLANT AND LUBRICATION​
20.2. RECOMMENDED LUBRICATION OIL​
20.3. RECOMMENDED FUEL​
20.4. COOLANT​
21. PERIODIC REPLACEMENT OF MAIN PARTS
22. INSPECTION AND MAINTENANCE LIST
22.1. MAINTENANCE LIST ACCORDING TO SERVICE INTERVAL​
23. PERIODIC INSPECTION AND MAINTENANCE
23.1. EVERY 10 HOURS (BEFORE STARTING)​
23.2. EVERY 50 HOURS (WEEKLY SERVICE)​
23.3. FIRST 250 HOURS​
23.4. EVERY 250 HOURS (MONTHLY SERVICE)​
23.5. EVERY 250 HOURS HYDRAULIC BREAKER HOURS​
23.6. EVERY 500 HOURS (3 MONTHS SERVICE)​
23.7. EVERY 1000 HOURS (6 MONTHS SERVICE)​
23.8. EVERY 2000 HOURS (ANNUALLY) SERVICE​
23.9. EVERY TWO YEARS​
23.10. WHEN REQUIRED​
24. SPECIFICATIONS
24.1. TECHNICAL SPECIFICATIONS OF HMK 140 W-3​
24.2. TECHNICAL SPECIFICATIONS OF HMK 200 W-3​
25. GENERAL PRECAUTIONS
25.1. SAFETY​
25.2. CAUTION WHEN FITTING THE WORKING EQUIPMENT​
25.3. SELECTION OF ATTACHMENT​
25.4. PROTECTION AGAINST FALLING OR FLYING OBJECTS (FOPS)​
25.5. PROTECTION AGAINST TIPPING AND ROLLING OVER​
26. HANDLING TIRES
26.1. TIRE CHANGING PROCEDURE​
26.2. TIRE ROTATION​
27. HYDRAULIC BREAKERS
27.1. MAINLY AVAILABLE WORKS​
27.2. INCORRECT METHODS​
27.3. ADJUSTMENT FOR HYDRAULIC BREAKER​
27.4. MAINTENANCE FOR HYDRAULIC BREAKER​
28. QUICK COUPLING ATTACHMENT
28.1. MOUNTING THE BUCKET​
28.2. DISMOUNTING THE BUCKET​
29. OPTIONAL ATTACHMENT-2 SETTINGS
29.1. OPTIONAL ATTACHMENT-2 CURRENT SETTINGS​
29.2. OP.ATTACHMENT-2 ENGINE SPEED SETTINGS​
29.3. SELECTED ATTACHMENT​
29.4. POSITIONING 3-WAY BALL VALVE​
29.5. ADDITIONAL HYDRAULIC LINE (OPTIONAL)​
30. CONTACTS
30.1. FACTORY AND SERVICE DEPARTMENT​
31. ALPHABETICAL INDEX
31. NOTES
