Hyundai
86
176,834
Hidromek Excavator HMK 65ZT-5 Operation Maintenance Manual H347345401 EN
Brand: Hidromek
Type of Machine: Excavator
Type of Manual: Operation Maintenance Manual
Model: Hidromek HMK 65ZT-5 Stage V Excavator
Publication Number: H347345401
Publication Date: 2024
Number of Pages: 243 Pages
1. INTRODUCTION
1.1. FOREWORD​
1.2. OCCUPATIONAL SAFETY INFORMATION​
1.3. DESCRIPTION AND INTENDED USE​
1.4. CE, UKCA MARKING AND DECLARATION OF CONFORMITY​
1.5. SPECIFICATIONS OF THE MACHINE​
1.6. EXHAUST EMISSION REGULATION RELATED PARTS​
1.7. BREAK-IN OPERATION​
1.8. SPARE PARTS AND SERVICE​
1.9. COPYRIGHT​
1.10. DRIVING LICENSE​
1.11. IDENTIFICATION PLATES​
1.11.1. LOCATION OF THE MACHINE ID PLATE​
1.11.2. LOCATION OF ENGINE PLATES​
1.11.3. MAIN COMPONENT PLATES​
2. SAFETY
2.1. GENERAL PRECAUTIONS​
2.1.1. OPERATORS MUST HAVE CERTAIN QUALIFICATIONS​
2.1.2. OBSERVE ALL SAFETY RULES ON-SITE​
2.1.3. INSTALL ALL GUARDS AND SAFETY DEVICES​
2.1.4. WEAR PROTECTIVE CLOTHES AND SAFETY EQUIPMENT​
2.1.5. MODIFICATIONS​
2.1.6. DO NOT MODIFY THE ENGINE​
2.1.7. HANDLING ELECTRIC ACCESSORIES​
2.1.8. BEFORE LEAVING THE MACHINE​
2.1.9. USE HANDRAILS AND FOOTHOLDS TO GETTING ON/OFF THE MACHINE​
2.1.10. DO NOT ALLOW FIRE NEAR FUEL AND OIL​
2.1.11. PAY ATTENTION TO HOT FLUID​
2.1.12. DO NOT INHALE DUST CONTAINING ASBESTOS​
2.1.13. PAY ATTENTION TO MOVING PARTS​
2.1.14. MACHINE FIRE EXTINGUISHER AND FIRST-AID KIT​
2.1.15. PROTECTION FROM FALLING OR FLYING OBJECTS​
2.1.16. BEFORE WORKING IN THE VICINITY OF GAS LINES​
2.1.17. PRECAUTIONS FOR OPTIONAL WORKING ATTACHMENTS​
2.1.18. DO NOT REMOVE FRONT ATTACHMENT OR COUNTERWEIGHT​
2.1.19. PRECAUTIONS FOR POLYMERS AND ELASTOMERS​
2.1.20. HANDLING OF ACCUMULATOR​
2.2. EMISSION CONTROL SYSTEM​
2.2.1. DIESEL PARTICULATE FILTER (DPF)​
2.3. PRECAUTIONS DURING OPERATION​
2.3.1. BEFORE STARTING THE ENGINE​
2.3.2. AFTER STARTING THE ENGINE​
2.3.3. TRANSPORTATION​
2.3.4. BATTERY​
2.3.5. TOWING​
2.3.6. LIFTING OBJECTS​
2.4. PRECAUTIONS FOR MAINTENANCE​
2.4.1. BEFORE MAINTENANCE​
2.4.2. DURING MAINTENANCE​
2.5. LOCATIONS OF SAFETY LABELS​
2.5.1. LOCATIONS OF ATTACHED LABELS​
2.5.2. CONTENTS OF SAFETY DECALS​
3. DESCRIPTION
3.1. LOCATIONS OF MAIN PARTS​
3.2. DETAILS OF OPERATOR’S CAB​
3.3. INSTRUMENT PANEL​
3.4. MENU ITEMS​
3.4.1. LANGUAGE​
3.4.2. STATUS INFO​
3.4.3. WORKING HOURS​
3.4.4. MAINTENANCE​
3.4.5. FAILURES​
3.4.6. MACHINE INFORMATION​
3.4.7. SETTINGS​
3.5. MEDIA​
3.5.1. RADIO​
3.5.2. USB​
3.5.3. AUX​
3.6. OPERA INSTRUMENT PANEL​
3.7. USB AND AUX CONNECTIONS​
3.8. EXTERNAL SOCKET (12V)​
3.9. STARTER KEY​
3.10. CUP HOLDER​
3.11. CONVENIENT STORAGE​
3.12. CONVENIENT STORAGE BOX​
3.13. SWITCHES​
3.14. SAFETY LOCKING DEVICE​
3.15. ADJUSTING ARMREST HEIGHT​
3.16. LEFT CONSOLE LIFTING LEVER​
3.17. LEVERS​
3.17.1. ATTACHMENT CONTROL LEVER​
3.17.2. ATTACHMENT CONTROL LEVER (PROPORTIONAL CONTROL) (OPTIONAL)​
3.17.3. DOZER BLADE CONTROL LEVER​
3.17.4. TRAVEL PEDAL / LEVER​
3.18. FUSE / RELAY BOX​
3.19. AUTOMATIC/MANUAL MODE SWITCH​
3.20. BATTERY RELAY​
3.21. BATTERY MASTER SWITCH​
3.22. HEATER AND AIR CONDITIONER​
3.22.1. HEATER AND AIR CONDITIONER VENTS​
3.22.2. CONTROL UNIT​
3.23. EMERGENCY EXIT​
3.24. FIRST-AID KIT​
3.25. FRONT WINDSHIELD​
3.26. DOOR​
3.27. DOOR LOCK MECHANISM​
3.28. SIDE WINDOW​
3.29. FIRE EXTINGUISHER (OPTIONAL)​
3.30. REAR CURTAIN​
3.31. SUN SHADE​
3.32. OPERATOR'S CAB INTERIOR LIGHTING​
3.33. ADJUSTING MIRRORS​
3.34. OPERATOR’S SEAT ADJUSTMENT​
3.35. SEAT BELT​
3.35.1. FASTENING THE SEAT BELT​
3.35.2. ADJUSTING LENGTH OF THE BELT​
4. OPERATION
4.1. INSPECTIONS BEFORE STARTING THE ENGINE​
4.2. STARTING THE ENGINE​
4.2.1. STARTING AT NORMAL TEMPERATURE​
4.2.2. STARTING IN COLD WEATHER​
4.3. WARM-UP OPERATION​
4.3.1. AUTOMATIC WARM-UP OPERATION​
4.3.2. WARMING-UP HYDRAULICS​
4.4. INSPECTIONS AFTER STARTING THE ENGINE​
4.4.1. ENGINE OIL PRESSURE​
4.4.2. ENGINE WARNING LIGHT​
4.4.3. BATTERY CHARGE WARNING LAMP​
4.4.4. ENGINE TEMPERATURE GAUGE​
4.4.5. HYDRAULIC OIL TEMPERATURE GAUGE​
4.4.6. FUEL LEVEL GAUGE​
4.4.7. AIR CLEANER IS CLOGGED INDICATOR​
4.4.8. AUTO WARM UP INDICATOR​
4.4.9. REDUCED ENGINE POWER INDICATOR LIGHT​
4.4.10. ABNORMAL NOISE OF ENGINE AND COLOR OF EXHAUST SMOKE​
4.4.11. COOLANT TEMPERATURE​
4.4.12. HOUR METER (CUMULATIVE OPERATING HOUR COUNTER)​
4.4.13. BE CAREFUL WITH THE TOO COLD ENGINE​
4.4.14. WHEN THE WARNING LIGHT COMES ON​
4.4.15. WHEN THE ENGINE COOLANT IS HOT​
4.4.16. DPF REGENERATION​
4.5. OPERATING THE MACHINE​
4.5.1. FORWARD TRAVEL​
4.6. TRAVEL DIRECTION CONTROL​
4.7. STOPPING AND PARKING THE MACHINE​
4.8. SWINGING THE MACHINE​
4.9. OPERATING ATTACHMENTS​
4.10. PROHIBITIONS DURING OPERATION​
4.11. PRECAUTIONS DURING OPERATION​
4.11.1. CHECKING THE TRAVEL UNIT REDUCTION GEAR OIL​
4.12. PRECAUTIONS WHEN TRAVELING ON A SLOPE​
4.13. RESCUING THE MACHINE FROM SWAMP​
4.13.1. IF ONE TRACK IS STUCK​
4.13.2. IF BOTH TRACKS ARE STUCK​
4.14. ADDITIONAL WORKS USING HYDRAULIC EXCAVATORS​
4.14.1. BACKHOE WORK​
4.14.2. SHOVELING​
4.14.3. DITCHING​
4.14.4. LOADING​
4.15. LIFTING​
4.16. REPLACING THE BUCKET​
4.17. PARKING THE MACHINE​
4.18. CHECKS AFTER FINISHING WORK​
4.19. STOPPING THE ENGINE​
4.20. INSPECTION AFTER STOPPING THE ENGINE​
4.21. OPERATION OF OPERATOR'S CAB LIFTING FUNCTION​
4.22. HANDLING THE ENGINE WITH TURBOCHARGER​
4.22.1. PRECAUTIONS DURING STARTING THE ENGINE​
4.22.2. PRECAUTIONS DURING STOPPING THE ENGINE​
4.23. LOCKING SYSTEM​
4.24. TRANSPORTATION​
4.24.1. LOADING AND UNLOADING​
4.24.2. PRECAUTIONS ON LOADING​
4.24.3. PRECAUTIONS ON TRANSPORTATION​
4.24.4. LIFTING THE MACHINE​
4.24.5. SEA TRANSPORTATION​
4.25. PREPARING THE MACHINE BASED ON WEATHER CONDITIONS​
4.25.1. PREPARATIONS FOR COLD WEATHER​
4.25.2. PRECAUTIONS AFTER FINISHING WORK​
4.25.3. PREPARATIONS FOR HOT WEATHER​
4.26. LONG TERM STORAGE​
4.26.1. BEFORE LONG TERM STORAGE​
4.26.2. DURING LONG TERM STORAGE​
4.26.3. END OF LONG-TERM STORAGE​
4.27. INSTRUCTIONS ON WITHDRAWAL FROM USE AND UTILIZATION​
5. TROUBLESHOOTING
5.1. WHEN TO SUSPECT A TROUBLE CASE​
5.2. TOWING METHOD​
5.3. TOWING HOLE FOR LIGHT OBJECTS​
5.4. PRECAUTIONS UNDER SPECIAL CIRCUMSTANCES​
5.5. ELECTRIC DISCHARGE​
5.5.1. STARTING THE ENGINE WITH BOOSTER CABLES (JUMP START)​
5.6. POOR BATTERY CHARGING​
5.7. OVERHEATING​
5.8. ABNORMAL (LOW) OIL PRESSURE​
5.9. ENGINE TROUBLE​
5.10. HYDRAULIC SYSTEM​
5.10.1. HYDRAULIC PUMP​
5.10.2. TRAVELING, SWINGING AND ATTACHMENTS​
5.10.3. HYDRAULIC CYLINDERS​
5.11. ELECTRICAL SYSTEM​
5.12. OTHER TROUBLES​
6. MAINTENANCE
6.1. PRECAUTIONS FOR MAINTENANCE​
6.1.1. HİDROMEK GENUINE SPARE PARTS​
6.1.2. WINDOW WASHER FLUID​
6.1.3. OIL AND GREASE​
6.1.4. NEVER MIX OILS​
6.1.5. CHECK HOUR METER​
6.1.6. KEEP THE MACHINE CLEAN​
6.1.7. CAUTIONS FOR HOT OIL AND WATER​
6.1.8. CHECK FILTER​
6.1.9. CAUTIONS WHEN ADDING OIL​
6.1.10. KEEP CONTAMINATION AWAY​
6.1.11. ATTACH WARNING TAG​
6.1.12. OBSERVE ALL WARNINGS AND CAUTIONS​
6.1.13. PRECAUTIONS WHEN WELDING​
6.1.14. PRECAUTIONS ON FIRE​
6.1.15. CLEANING MACHINED SURFACES​
6.1.16. CHECKING THE TRACK​
6.1.17. PRECAUTIONS WHEN WASHING THE MACHINE​
6.1.18. CHECK BEFORE AND AFTER WORK​
6.1.19. PRECAUTIONS DURING WORK IN DUSTY CONDITIONS​
6.1.20. DISCARDED PARTS, OILS AND OTHER LIQUIDS​
6.1.21. HİDROMEK RECOMMENDED OILS AND GREASE​
6.1.22. OIL​
6.1.23. FUEL​
6.1.24. COOLANT​
6.1.25. GREASE​
6.1.26. STORING OIL AND FUEL​
6.1.27. FILTERS​
6.1.28. ELECTRONIC PARTS​
6.1.29. HYDRAULIC SYSTEM​
6.2. OIL, FUEL, COOLANT AND DIESEL EXHAUST FLUID​
6.2.1. CAPACITIES OF OIL, FUEL, COOLANT AND DIESEL EXHAUST FLUID​
6.2.2. RECOMMENDED OIL, GREASE AND COOLANT​
6.2.3. RECOMMENDED FUEL​
6.2.4. COOLANT​
6.3. PERIODIC REPLACEMENT OF MAIN PARTS​
6.4. INSPECTION AND MAINTENANCE LIST​
6.5. EVERY 10 HOURS (BEFORE STARTING)​
6.5.1. WALK-AROUND INSPECTION (VISUAL INSPECTION)​
6.5.2. INSPECTING ENGINE STARTABILITY AND ABNORMAL NOISE​
6.5.3. INSPECTING CONDITION OF THE ENGINE AT LOW SPEEDS AND DURING ACCELERATION​
6.5.4. COOLANT LEVEL CHECK​
6.5.5. ENGINE OIL LEVEL CHECK​
6.5.6. FUEL LEVEL CHECK​
6.5.7. HYDRAULIC OIL LEVEL CHECK​
6.5.8. ELECTRIC WIRING CHECK​
6.5.9. CLEANING THE FILTER OF HYDRAULIC TANK BREATHER​
6.5.10. CHECKING AND REPLACING THE BUCKET TEETH​
6.5.11. FAN BELT​
6.5.12. GREASING ATTACHMENT PINS​
6.5.13. TIGHTENING TRACK SHOE BOLT​
6.5.14. DRAINING SEDIMENT AND WATER FROM FUEL FILTERS​
6.6. EVERY 10 HOURS (AFTER WORKSHIFT)​
6.6.1. CLEANING THE MACHINE​
6.7. FIRST 50 HOURS​
6.7.1. REPLACING ENGINE OIL AND OIL FILTER​
6.7.2. REPLACING THE OIL FILTER​
6.8. EVERY 50 HOURS (WEEKLY SERVICE)​
6.8.1. GREASING SWING GEAR BEARING (at 3 points)​
6.8.2. REMOVING SEDIMENT FROM FUEL TANK​
6.8.3. INSPECTING AND ADJUSTING TRACK TENSION​
6.9. FIRST 250 HOURS​
6.9.1. GREASING SWING UNIT REDUCTION GEAR​
6.9.2. REPLACING SWING UNIT REDUCTION GEAR OIL​
6.9.3. REPLACING TRAVEL UNIT REDUCTION GEAR OIL​
6.10. EVERY 250 HOURS (MONTHLY SERVICE)​
6.10.1. ADJUSTING FAN BELT TENSION​
6.10.2. CHECKING SWING RING GEAR GREASE​
6.10.3. CHANGING SWING GEAR BEARING GREASE (at 3 points)​
6.10.4. TENSION ADJUSTMENT OF AIR CONDITIONER BELT​
6.11. EVERY 500 HOURS (3 - MONTH SERVICE)​
6.11.1. CHANGING FUEL FILTER ELEMENTS​
6.11.2. REPLACING ENGINE OIL AND OIL FILTER​
6.11.3. REPLACING THE OIL FILTER​
6.11.4. CHECKING ANTIFREEZE DENSITY​
6.11.5. CHECKING AND CLEANING RADIATOR, OIL COOLER AND CONDENSER FIN​
6.11.6. GREASING SWING UNIT REDUCTION GEAR​
6.12. EVERY 1000 HOURS (6-MONTHS SERVICE)​
6.12.1. ENGINE VALVE CLEARANCE CHECK​
6.12.2. STARTER AND ALTERNATOR CHECK AND CLEANING​
6.12.3. REPLACING SWING UNIT REDUCTION GEAR OIL​
6.12.4. CHECKING AIR CONDITIONER REFRIGERANT AMOUNT​
6.12.5. REPLACING TRAVEL UNIT REDUCTION GEAR OIL​
6.12.6. CHECKING AND REPLACING THE FILTER ELEMENT OF HYDRAULIC TANK BREATHER​
6.12.7. REPLACING THE RETURN FILTER ELEMENT OF HYDRAULIC TANK​
6.12.8. REPLACING OR IF NECESSARY, CLEANING AIR FILTER OUTER ELEMENT​
6.12.9. REPLACING AIR CONDITIONER FILTERS​
6.12.10. OPERATOR CAB FILTER​
6.13. EVERY 1500 HOURS​
6.13.1. CHANGING OIL SEPARATOR ELEMENT​
6.13.2. CHECKING & CLEANING PCV VALVE (POSITIVE CRANKCASE VENTILATION VALVE)​
6.13.3. CHECKING INJECTION PRESSURE AT FUEL INJECTION NOZZLE​
6.13.4. CHECKING EGR COOLER​
6.14. EVERY 2000 HOURS (ANNUAL SERVICE)​
6.14.1. REPLACING THE OIL AND FILTER ELEMENTS OF HYDRAULIC TANK​
6.15. EVERY TWO YEARS OF SERVICE​
6.15.1. CLEANING COOLING SYSTEM AND REPLACING COOLANT​
6.16. WHEN REQUIRED​
6.16.1. FILLING FUEL (FUEL TRANSFER PUMP)​
6.16.2. BLEEDING FUEL SYSTEM​
6.16.3. BLEEDING HYDRAULIC SYSTEM​
6.16.4. REPLACEMENT OF THE FUEL PIPING​
7. SPECIFICATIONS
7.1. TECHNICAL SPECIFICATIONS OF HMK 65ZT-5​
8. EQUIPMENT AND ATTACHMENTS
8.1. GENERAL PRECAUTIONS​
8.2. PRECAUTIONS WHEN FITTING THE WORK EQUIPMENT​
8.3. SELECTION OF ATTACHMENT​
8.4. PROTECTION AGAINST FALLING OR FLYING OBJECTS (FOPS)​
8.5. PROTECTION AGAINST TIPPING AND ROLLING OVER​
8.6. SELECTION OF TRACK SHOES​
8.7. HYDRAULIC BREAKERS (OPTIONAL)​
8.7.1. PERMISSIBLE WORKS​
8.7.2. INCORRECT OPERATION METHODS​
8.7.3. MAINTENANCE FOR HYDRAULIC BREAKER​
8.7.4. WORKING IN THE TUNNEL​
9. APPENDIX
9.1. HAND SIGNALS​
9.2. COMMUNICATION INFORMATION​
9.2.1. PLANTS AND AFTER SALES SERVICES​
10. ALPHABETICAL INDEX
