Hyundai
86
176,684
Hidromek Backhoe Loader Maestro Series Operation Maintenance Manual Y10_13101
Brand: Hidromek
Type of Manual: Operation Maintenance Manual
Model: Hidromek Maestro Series Backhoe Loader
Serial Number: A19001 -
Part Number: Y10_13101
Publication Date: 2015
Number of Pages: 202 Pages
1. INTRODUCTION
1.1. FOREWORD​
1.2. CE MARKING AND EMC DIRECTIVE​
1.3. IDENTIFICATION PLATE​
1.4. BACKHOE LOADER​
1.4.1. DESCRIPTION OF THE MACHINE AND ITS ITENDED USE​
1.4.2. DESIGNATION OF “LEFT SIDE” and “RIGHT SIDE”​
1.5. SAFETY NOTICES​
1.6. OTHER NOTICES​
1.7. ENVIRONMENTAL STANDARDS​
1.8. WARNING SYMBOLS​
1.9. COPYRIGHT​
1.10. SPARE PARTS AND SERVICE​
2. SAFETY
2.1. GENERAL SAFETY INFORMATION​
2.2. SAFETY PRECAUTIONS​
2.2.1. WELDING​
2.2.2. MACHINE CONTROL LEVERS​
2.2.3. VISIBILITY​
2.2.4. ROPS / FOPS STRUCTURE​
2.2.5. SPARKS​
2.2.6. DRINKS AND DRUGS​
2.2.7. FAILURE OF ENGINE OR STEERING​
2.2.8. USA FEDERAL CLEAN AIR ACT​
2.2.9. RECOMMENDATIONS​
2.3. PRE-START SAFETY​
2.3.1. OBSERVE SAFETY PRECAUTIONS​
2.3.2. WEAR PROTECTIVE CLOTHING​
2.3.3. READ AND UNDERSTAND THE OPERATING MANUAL​
2.3.4. KEEP OPERATING MANUAL IN CABIN​
2.3.5. PAY ATTENTION TO EMERGENCIES​
2.3.6. SAFETY AT THE JOB SITE​
2.3.7. PRE-START INSPECTION​
2.3.8. 2.3.8 SIGNS, SIGNALS & FLAGMEN​
2.3.9. KEEP FIRE AWAY FROM FUEL & OIL​
2.3.10. TO GET ON AND OFF THE MACHINE.​
2.3.11. APPLY PARKING BRAKE BEFORE LEAVING THE MACHINE​
2.3.12. ENGAGE LEVER SAFETY LOCKS BEFORE LEAVING THE MACHINE​
2.3.13. HOT SURFACES & FLUIDS​
2.3.14. USE PROPER ATTACHMENT​
2.3.15. PREVENT FIRE​
2.4. SAFETY DURING OPERATION​
2.4.1. STARTING THE ENGINE​
2.4.2. PASSENGERS​
2.4.3. DRIVING​
2.4.4. ROLL-OVER PROTECTION​
2.4.5. SLEWING​
2.4.6. OPERATING ON HILLSIDES & SLOPES​
2.4.7. WORKING AROUND UTILITY LINES​
2.4.8. LIFTING​
2.4.9. ICE & SNOW ON THE JOB SITES​
2.4.10. UNSTABLE GROUND OR FILLING​
2.4.11. DANGER ZONE​
2.4.12. RESTRICTED WORKING AREAS​
2.4.13. LEGAL LIABILITY​
2.4.14. EXPERIMENTAL OPERATIONS​
2.4.15. PARKING THE MACHINE​
2.4.16. KEEP UNAUTHORIZED PEOPLE AWAY​
2.4.17. CHECK ATTACHMENT LOCK PINS​
2.4.18. STOWAGE OF ATTACHMENTS​
2.4.19. VENTILATION IN CLOSED AREA​
2.4.20. EMERGENCY EXIT​
2.4.21. UNINTENTIONAL SHUT-OFF DURING OPERATION​
2.4.22. UNINTENTIONAL SHUT-OFF DURING TRAVEL​
2.4.23. STEERING CONTROL IN EMERGENCY​
2.5. INSPECTION & MAINTENANCE SAFETY​
2.5.1. PREVENT UNAUTHORIZED START​
2.5.2. STOP THE ENGINE BEFORE SERVICING​
2.5.3. ENGAGE CONTROL LEVER SAFETY LOCKS​
2.5.4. ENGAGE ATTACHMENT LOCKS​
2.5.5. MAINTENANCE POSITION​
2.5.6. KEEP THE MACHINE CLEAN​
2.5.7. PRESSURIZED FLUIDS​
2.5.8. SUPPORT THE MACHINE​
2.5.9. REFUELING​
2.5.10. HYDRAULIC PRESSURE​
2.5.11. TYRE INFLATION & WHEEL NUTS​
2.5.12. ROTATING PARTS IN THE ENGINE​
2.5.13. ELECTRICAL SYSTEM​
2.5.14. SAFE LIGHTING​
2.5.15. WASTE MATERIALS​
2.5.16. CLEANERS​
2.5.17. SEALS​
2.6. BATTERY SAFETY​
2.6.1. WEAR PROTECTIVE EQUIPMENT​
2.6.2. KEEP AWAY FROM FIRE AND FLAMES​
2.6.3. CHARGING BATTERY​
2.6.4. STARTING WITH A BOOSTER BATTERY​
2.7. WARNING LABELS & DECALS​
2.7.1. “READ THE OPERATING AND MAINTENANCE MANUAL” WARNING LABEL​
2.7.2. “LIFT CYLINDER LOCK” WARNING​
2.7.3. “AIR FILTER CLOGGED” LABEL​
2.7.4. “KEEP CLEAR OF WORKING AREA” WARNING FOR BACKHOE​
2.7.5. “SAFE WORKING LOAD” LABEL​
2.7.6. “BEFORE PERFORMING ANY MAINTENANCE or INSPECTION STOP THE ENGINE, REMOVE IGNITION KEY AND READ OPERATING MANUAL” WARNING FOR ROTATING AND HOT PARTS AND SURFACES.​
2.7.7. “BATTERY” WARNING​
2.7.8. "TRANSMISSION OIL CONTROL" CAUTION​
2.7.9. “FUEL SPECIFICATIONS” WARNING LABEL​
2.7.10. "FUEL TANK” CAUTION​
2.7.11. “ELECTRICAL EQUIPMENT” WARNING​
2.7.12. “BATTERY CUT-OFF RELAY” WARNING LABEL​
2.7.13. "DO NOT PINCH YOUR FOOT" WARNING LABEL​
2.7.14. “KEEP CLEAR OF WORKING AREA” WARNING FOR LOADER​
2.7.15. “DO NOT PINCH YOUR HANDS” WARNING​
2.7.16. TELESCOPIC DIPPER - HYDRAULIC BREAKER SELECTING VALVE​
2.7.17. “HYDRAULIC BREAKER AND AUGER OPERATION” LABEL​
2.7.18. "BACKHOE BOOM SLEW LOCK PIN" CAUTION​
2.7.19. "EMERGENCY EXIT" CAUTION​
2.7.20. “HYDRAULIC OIL TANK” CAUTION​
2.8. PROHIBITED MACHINE OPERATION​
2.8.1. DO NOT USE THE SLEWING FORCE OF THE BACKHOE FOR GRADING​
2.8.2. DO NOT HAMMER WITH THE BUCKET​
2.8.3. NEVER USE THIS MACHINE OTHER THAN ITS INTENDED USE​
2.8.4. DO NOT USE THE BACKHOE LOADER FOR LIFTING PEOPLE​
2.8.5. DO NOT IMPACT HYDRAULIC CYLINDERS TO STROKE END REPEATEDLY​
2.8.6. NEVER EXCEED THE CAPACITY OF THE MACHINE​
2.8.7. DO NOT USE BUCKET TO BREAK OR CUT​
2.8.8. DO NOT DRIVE WITH THE STABILIZERS EXTENDED​
2.9. END OF WORKSHIFT MAINTENANCE & INSPECTION​
3. DESCRIPTION
3.1. FRONT INSTRUMENT PANEL​
3.1.1. THROTTLE PEDAL​
3.1.2. DOUBLE PEDAL BRAKE SYSTEM​
3.1.3. DRIVE CONTROL LEVER​
3.1.4. RIGHT HAND SIDE MULTIFUNCTIONAL SWITCH​
3.1.5. STEERING WHEEL ADJUSTMENT LEVER​
3.1.6. COMPARTMENTS AND STOWAGE PLACES FOR OBJECTS​
3.1.7. INSTRUMENT PANEL​
3.1.8. HAZARD WARNING LIGHT SWITCH​
3.1.9. HEADLIGHTS & TAIL LIGHTS SWITCH​
3.1.10. MOTION STABILIZER SYSTEM (MSS) SWITCH (OPTIONAL)​
3.1.11. DIFFERENTIAL LOCK (If exists)​
3.1.12. FORWARD/REAR DIRECTION SELECTION (FNR) LOCKING SWITCH​
3.2. RIGHT HAND SIDE INSTRUMENT PANEL​
3.2.1. LOADER JOYSTICK​
3.2.2. LOADER JOYSTICK SAFETY LOCK​
3.2.3. HAND (PARKING) BRAKE​
3.2.4. THROTTLE LEVER​
3.2.5. RIGHT HAND SIDE INSTRUMENT AND CONTROL PANEL​
3.2.6. ASHTRAY / GLASS HANDLER​
3.2.7. BOOK POCKET​
3.2.8. BOOM LOCK HANDLE​
3.2.9. STABILIZER CONTROL LEVER (Only on machines with joystick type backhoe control levers)​
3.3. LEFT HAND SIDE CONSOLE​
3.3.1. BACK AND FRONT GLASS HANDLER​
3.3.2. COOLER STOWAGE BOX​
3.4. OPERATOR’S SEAT​
3.5. TOOLBOX​
3.6. BACKHOE CONTROL CONSOLE​
3.7. REAR WINDOW AND REAR WINDOW WIPER​
3.7.1. OPENING THE REAR WINDOW​
3.7.2. CLOSING THE REAR WINDOW​
3.8. INTERIOR LIGHT​
3.9. COAT HANGER​
3.10. BACKHOE JOYSTICKS (OPTIONAL)​
3.11. AIR CONDITION CONTROL PANEL (OPTIONAL)​
3.11.1. USING THE AIR CONDITION​
3.12. AUXILIARY VALVE PEDAL​
4. OPERATION
4.1. GENERAL​
4.1.1. BEFORE STARTING​
4.1.2. CLEANLINESS INSPECTION​
4.1.3. DAMAGE INSPECTION​
4.1.4. TYRE INSPECTION​
4.1.5. GETTING IN AND OUT OF THE CAB​
4.2. BEFORE STARTING THE ENGINE​
4.3. STARTING THE ENGINE​
4.4. DRIVING THE MACHINE​
4.4.1. TRAVELING IN REVERSE DIRECTION​
4.5. JUMP STARTING THE ENGINE​
4.6. BASIC PRECAUTIONS FOR OPERATION IN COLD AND HOT CLIMATE​
4.6.1. IN COLD WEATHER​
4.6.2. IN HOT WEATHER​
4.7. PREPARATIONS FOR TRAVEL​
4.7.1. TESTING THE PARKING BRAKE​
4.8. STOPPING and PARKING THE MACHINE​
4.9. UNINTENTIONAL SHUT DOWN DURING TRAVEL​
4.10. STEERING IN CASE OF EMERGENCY​
4.11. FIELD TEST OF THE EMERGENCY STEERING​
4.12. ENGAGING ATTACHMENT SAFETY LOCKS​
4.12.1. ENGAGING LOADER ARM SAFETY STRUT​
4.12.2. DISENGAGING SAFETY STRUT​
4.12.3. ENGAGING BACKHOE BOOM LOCK​
4.12.4. DISENGAGING BACKHOE BOOM LOCK​
4.12.5. BACKHOE SLEW LOCK​
4.12.6. STABILIZER SHOE LOCK​
4.13. CONTROLLING HYDRAULIC CLAMP CYLINDERS​
4.14. SIDESHIFTING THE BACKHOE​
4.14.1. MANUAL​
4.14.2. AUTOMATIC (OPTIONAL)​
4.15. TELESCOPIC DIPPER (OPTIONAL)​
4.15.1. EXTENDING THE TELESCOPIC DIPPER​
4.15.2. RETRACTING AND LOCKING THE TELESCOPIC DIPPER​
4.15.3. TELESCOPIC DIPPER SAFETY LOCK​
4.15.4. TELESCOPIC DIPPER - HYDRAULIC BREAKER SELECTING VALVE​
4.16. BRAKING​
4.17. THE LOADER OPERATION​
4.17.1. LOADER OPERATION IN BANKS AND STOCKPILES​
4.17.2. LOADING TRUCKS​
4.17.3. RESCUING A STUCK MACHINE​
4.17.4. GRADING WITH LOADER​
4.18. THE BACKHOE OPERATION​
4.18.1. HINTS ON OPERATION OF BACKHOE​
4.18.2. CORRECT DIGGING METHOD​
4.18.3. EXCAVATION ON SLOPES​
4.18.4. LOWERING THE ATACHMENTS IN CASE OF UNEXPECTED POWER CUT-OFF​
4.19. REPLACING ATTACHMENTS​
4.19.1. LOADER BUCKET​
4.19.2. BACKHOE BUCKET​
4.19.3. REPLACING BUCKET TEETH​
4.20. TRANSPORTING THE MACHINE​
4.21. TOWING PROCEDURE FOR A DISABLED MACHINE​
4.22. LIFTING BY A CRANE​
4.23. PRESERVING THE MACHINE FOR STORAGE​
4.23.1. MAINTENANCE OF THE MACHINE DURING AND AFTER STORAGE​
5. MAINTENANCE
5.1. GENERAL INFORMATION​
5.2. GENERAL SAFETY​
5.2.1. DISPOSAL OF HAZARDOUS WASTE​
5.2.2. STOP THE ENGINE AND PARK THE MACHINE​
5.2.3. KEEP THE MACHINE CLEAN​
5.2.4. HOT SURFACES & FLUIDS​
5.2.5. WARM UP THE ENGINE OIL​
5.2.6. ATTACH “DO NOT OPERATE” WARNING​
5.2.7. INSPECT WASTE OILS & FILTERS​
5.2.8. PREVENT CONTAMINATION​
5.2.9. SEALS & ‘O-RINGS’​
5.2.10. WEAR PROTECTIVE CLOTHING​
5.2.11. CLEANING PARTS​
5.2.12. RELEASE RESIDUAL HYDRAULIC OIL PRESSURE​
5.2.13. ENGAGE ATTACHMENT SAFETY LOCKS​
5.2.14. HANDLING POLYMERS AND ELASTOMERS CONTAINING FLUORO-CARBON​
5.2.15. PRECAUTIONS WHEN WORKING WITH A/C REFRIGERANTS​
5.2.16. PRECAUTIONS TO BE TAKEN DURING WORKING WITH EXHAUST PIPE​
5.2.17. DISPOSAL OF WASTES AND PROTECTION OF THE ENVIRONMENT​
5.2.18. USE OF BIODEGRADABLE SYNTHETIC OILS​
5.3. INSPECTION & MAINTENANCE CHART​
5.4. ENGINE DESCRIPTION​
5.4.2. RECORD ENGINE SERIAL NUMBER​
5.4.3. ENGINE OPTION CODES​
5.5. PERIODIC MAINTENANCE​
5.5.1. FIRST 50 HOURS MAINTENANCE​
5.6. TABLE of LUBRICANTS & FLUIDS​
5.7. PRE-START (EVERY 8 HOURS) INSPECTION & MAINTENANCE​
5.7.1. CHECKING ENGINE OIL LEVEL​
5.7.2. CHECKING COOLANT LEVEL​
5.7.3. CHECKING FUEL FILTERS​
5.7.4. CHECKING ENGINE FLUID LEAKS​
5.7.5. CHECKING & CLEANING THE ENGINE AIR PRE-CLEANER (DUST SEPARATOR)​
5.7.6. CLEANING THE AIR PRE-CLEANER​
5.7.7. CHECKING AIR CLEANER​
5.7.8. CHECKING FUEL LEVEL​
5.7.9. CHECKING TRANSMISSION OIL LEVEL​
5.7.10. CHECKING HYDRAULIC OIL LEVEL​
5.7.11. HYDRAULIC OIL TANK CAP​
5.7.12. CHECKING THE TYRE PRESSURE​
5.7.13. GREASING​
5.8. WEEKLY (EVERY 50 HOURS) INSPECTION & MAINTENANCE​
5.8.1. DRAINING THE FUEL TANK​
5.8.2. CHECKING THE CLEARANCE OF INNER PLATES OF THE STABILIZERS​
5.8.3. CHECKING THE ELECTROLYTE LEVEL OF BATTERY​
5.8.4. CHECKING THE ROPS/FOPS OPERATOR’S CABIN​
5.8.5. CHECKING AND READJUSTING WEAR PADS OF TELESCOPIC ARM​
5.9. EVERY 100 HOURS INSPECTION & MAINTENANCE​
5.9.1. CHECKING AND LUBRICATING THE PARKING BRAKE​
5.10. EVERY 250 HOURS INSPECTION & MAINTENANCE​
5.10.1. CHECKING THE DIFFERENTIAL OIL LEVEL OF THE AXLES​
5.10.2. CHECKING THE OIL LEVEL IN HUBS​
5.10.3. CHANGING ENGINE OIL AND REPLACING FILTER​
5.10.4. OIL CHANGE INTERVALS​
5.10.5. OIL VISCOSITY GRADE​
5.10.6. REPLACING FUEL FILTER ELEMENTS​
5.11. EVERY 500 HOURS INSPECTION & MAINTENANCE​
5.11.1. CHECKING CRANKCASE VENT SYSTEM​
5.11.2. CHECKING AIR INTAKE SYSTEM​
5.11.3. CHECKING BELT TENSIONER SPRING AND BELT WEAR(AUTOMATIC TENSIONER)​
5.11.4. CHECKING ENGINE ELECTRICAL GROUND CONNECTIONS​
5.11.5. CHECKING COOLING SYSTEM​
5.11.6. PRESSURE TESTING COOLING SYSTEM​
5.11.7. CHECKING AND ADJUSTING ENGINE SPEEDS​
5.11.8. CHANGING THE HYDRAULIC RETURN FILTER​
5.11.9. CHANGING THE TRANSMISSION OIL FILTER​
5.11.10. CLEANING AND CHANGING OPERATOR’S CABIN HEATER AIR FILTER​
5.12. EVERY 1000 HOURS INSPECTION & MAINTENANCE​
5.12.1. CHANGING TRANSMISSION OIL​
5.12.2. CHANGING THE DIFFERENTIAL OIL OF THE AXLES​
5.12.3. CHANGING THE OIL OF HUBS​
5.12.4. CHANGING THE HYDRAULIC OIL​
5.12.5. CHANGING & CLEANING THE SUCTION STRAINER​
5.13. 2000 HOURS MAINTENANCE​
5.13.1. DESCRIPTION OF COOLANT​
5.13.2. COOLANT FILLING CAP​
5.13.3. FLUSHING AND REFILLING COOLING SYSTEM​
5.13.4. TESTING THERMOSTATS OPENING TEMPERATURE​
5.13.5. CHECK AND ADJUST VALVE CLEARANCE​
5.14. MISCELLANEOUS​
5.14.1. REPLACING FUSES​
5.14.2. BLEEDING THE FUEL SYSTEM​
5.14.3. MAINTENANCE OF AIR-CONDITIONER (OPTIONAL)​
5.14.4. REPLACING LIGHT BULBS​
6. SPECIFICATIONS
6.1. TECHNICAL SPECIFICATIONS OF HMK 102B​
6.2. LIFTING REGULATIONS AND SAFE WORKING LOADS (SWL)​
6.2.1. LIFTING REGULATIONS​
6.2.2. SAFE WORKING LOADS​
6.3. SOUND and VIBRATION​
6.3.1. SOUND​
6.3.2. VIBRATION​
7. OPTIONAL EQUIPMENT
7.1. GENERAL​
7.2. TILTING FORKS​
7.2.1. SETTING FORKS UP FOR OPERATION​
7.2.2. STOWING THE FORKS​
7.2.3. SPACING THE FORKS​
7.2.4. MAINTENANCE​
7.3. HYDRAULIC BREAKER​
7.3.1. PROCEDURE FOR INSTALLATION OF HYDRAULIC BREAKER​
7.3.2. ADJUSTING HYDRAULIC BREAKER​
7.4. HYDRAULIC AUGER​
7.4.1. PROCEDURE FOR INSTALLATION OF HYDRAULIC AUGER​
7.4.2. HINTS ON THE OPERATION OF HYDRAULIC AUGER​
7.4.3. MAINTENANCE OF THE PLANETARY REDUCER GEAR BOX​
7.4.4. PERIODIC MAINTENANCE​
7.4.5. RECOMMENDED OIL FOR LUBRICATION​
7.5. LOG GRAB​
7.6. GRADING BLADE​
7.7. AIR COMPRESSOR​
7.8. FORKLIFT ATTACHMENT & CLAMSHELL BUCKET​
7.9. TRAPEZOID DITCH BUCKET​
7.10. RIPPER​
7.11. SIDE SHIFT BUCKET​
7.12. CLAMSHELL GRAB​
7.13. WINCH​
7.14. STREET SWEEPER​
7.15. QUICK COUPLER​
7.15.1. MOUNTING TO THE MACHINE​
7.15.2. DISMOUNTING FROM THE MACHINE​
8. APPENDIX
8.1. HAND SIGNALS​
8.2. TABLE OF TORQUE VALUES FOR FASTENERS​
8.3. CONTACTS​
8.3.1. FACTORY AND SERVICE DEPARTMENT​
8.4. NOTES​
9. ALPHABETICAL INDEX
