Hyundai
86
176,834
Hidromek Backhoe Loader Maestro Series Operation Maintenance Manual FR
Language: French
Brand: Hidromek
Type of Machine: Backhoe Loader
Type of Manual: Operation Maintenance Manual
Model: Hidromek Maestro Series Backhoe Loader
Publication Date: 2015
Hidromek Backhoe Loader Maestro Series Operation Maintenance Manual Y10_12343 FR.pdf (198 Pages):
1.1. GENERALITES​
1.2. LE MARQUAGE "CE" ET LA DIRECTIVE "CEM".​
1.3. PLAQUE D’IDENTIFICATION​
1.4. DESCRIPTION DE LA CHARGEUSE PELLETEUSE​
1.5. CONSIGNES DE SECURITE​
1.6. AUTRES CONSIGNES​
1.7. NORMES ENVIRONMENTALE​
1.8. SYMBOLES D’AVERTISSEMENT​
1.9. COPYRIGHT (DROIT D’AUTHEUR)​
1.10. PIECES DE RECHANGE ET SERVICE APRES-VENTES​
2.1. INFORMATIONS GENERALES DE SECURITE​
2.2. PRECAUTIONS DE SECURITE​
2.3. MESURES DE SÉCURITÉ A OBSERVER AVANT LE DÉMARRAGE​
2.4. CONSIGNES DE SECURITE A RESPECTER PENDANT L’UTILATION​
2.5. MESURE DE SECURITE A OBSERVER PENDANT L’INSPECTION ET LA MAINTENANCE​
2.6. CONSIGNES DE SECURITE EN CAS DE MANIPULATION DE LA BATTERIE​
2.7. ETIQUETTES DE MISE EN GARDE ET VIGNETTES​
2.8. OPERATIONS INTERDITES​
2.9. MAINTENANCE & INSPECTION AU FIN DE TRAVAIL​
3.1. CONSOLE AVANT​
3.2. CONSOLE COTE DROITE​
3.3. CONSOLE DE GAUCHE​
3.4. SIÈGE DU CONDUCTEUR​
3.5. BOITE A OUTILS​
3.6. LEVIER DE COMMANDE DE LA PELLETEUSE​
3.7. FENETRE ARRIERE ET ESSUIE-GLACE DE LA FENETRE ARRIERE​
3.8. ECLAIRAGE INTERIEUR​
3.9. CINTRE​
3.10. LEVIERS DE COMMANDE DE LA RETROCAVEUSE (OPTIONNEL)​
3.11. TABLEAU DU BORD DU CLIMATISEUR​
3.12. PEDALE DE VALVE AUXILIAIRE​
4.1. GENERALITES​
4.2. AVANT DE DEMARRER LE MOTEUR​
4.3. DEMARRAGE DU MOTEUR​
4.4. CONDUITE DE L’ENGIN​
4.5. DEMARRER LE MOTEUR AVEC UN BATTERIE AUXILIER​
4.6. PRÉCAUTIONS DE BASE POUR EXPLOITATION DANS LE CLIMAT FROID ET CHAUD​
4.7. PREPARATION DE DEPLACEMENT​
4.8. ARRET ET STATIONNEMENT DE L’ENGIN​
4.9. ARRET NON INTENTIONNEL PENDANT LE DEPLACEMENT​
4.10. ESSAI SUR LE TERRAIN LA DIRECTION D’URGENCE:​
4.11. DIRECTION EN CAS D’URGENCE:​
4.12. ENGAGEMENT DES VERROUS DE SECURITE DES ACCESSOIRES​
4.13. CONTROLE DES VERINS DE​
4.14. DEPLACEMENT LATERAL DE LA RETROCAVEUSE​
4.15. LE BRAS TELESCOPIQUE (OPTIONNELLE)​
4.16. FREINAGE​
4.17. FONCTIONNEMENT DE LA CHARGEUSE​
4.18. FONCTIONNEMENT DE LA RÉTROCAVEUSE​
4.19. DEPOSE DES ATTACHMENTS​
4.20. TRANSPORT DE L’ENGIN​
4.21. PROCEDURE DE REMORQUAGE D’UN ENGIN EN PANNE​
4.22. LEVAGE AVEC GRUE​
4.23. PROTEGER L’ENGIN POUR LE STOKAGE​
5.1. INFORMATIONS GENERALES​
5.2. SECURITE GENERALE​
5.3. TABLEAU D’ INSPECTION & DE MAINTENANCE​
5.4. DESCRIPTION DU MOTEUR​
5.5. MAINTENANCE PERIODIQUE​
5.6. TABLEAU DES LUBRIFIANTS ET DES FLUIDES​
5.7. INSPECTION & MAINTENANCE DE PRE-DEMARRAGE (TOUTES LES 8 HEURES)​
5.8. INSPECTION & MAINTENANCE DES 50 HEURES​
5.9. INSPECTION & MAINTENANCE TOUTES LES 100 HEURES​
5.10. INSPECTION & MAINTENANCE TOUTES LES 250 HEURES​
5.11. INSPECTION & MAINTENANCE TOUTES LES 500 HEURES​
5.12. INSPECTION & MAINTENANCE TOUTES LES 1000 HEURES​
5.13. INSPECTION & MAINTENANCE TOUTES LES 2000 HEURES​
5.14. DIVERS​
6.1. ESPECIFICACIONES TECNICAS DE HMK 102B​
6.2. REGLEMENTATION EN MATIERE DE LEVAGE ET CHARGE MAXIMALE D’UTILISATION (SWL)​
6.3. SON et VIBRATIONS​
7.1. GENERALITES​
7.2. FOURCHE BASCULANT​
7.3. LE MARTEAU HYDRAULIQUE​
7.4. TARIERE HYDRAULIQUE​
7.5. FOURCHE À PINCES​
7.6. LAME NIVELEUSE​
7.7. COMPRESSEUR D’AIR​
7.8. ADAPTATEUR POUR CHARIOT ELEVATEUR A FOURCHE & BENNE PRENEUSE​
7.9. GODET TRAPEZOIDAL DE CURAGE/CREUSAGE DE FOSSES​
7.10. RIPPEUR​
7.11. BENNE A DEPLACEMENT LATERAL​
7.12. BENNE PRENEUSE​
7.13. TREUIL​
7.14. BALAYEUSE MECANIQUE​
7.15. ATTELAGE RAPID​
8.1. DIAGRAMME DE SIGNALISATION MANUELLE​
8.2. TABLE DE COUPLES DE SERRAGE POUR VISSERIE​
Hidromek Backhoe Loader Maestro Series Operation Maintenance Manual Y10_12344 FR.pdf (204 Pages):
1.1. GENERALITES​
3.1. CONSOLE AVANT​
3.3. . CONSOLE DE GAUCHE​
3.6. . LEVIER DE COMMANDE DE LA PELLETEUSE​
3.9. CINTRE​
4.1. GENERALITES​
4.16. SYSTEME A QUATRE ROUES DIRECTRICES (MODELE HMK 102S)​
4.17. FREINAGE​
4.18. FONCTIONNEMENT DE LA CHARGEUSE​
4.19. FONCTIONNEMENT DE LA RÉTROCAVEUSE​
4.20. DEPOSE DES ATTACHMENTS​
4.21. TRANSPORT DE L’ENGIN​
4.22. PROCEDURE DE REMORQUAGE D’UN ENGIN EN PANNE​
4.23. LEVAGE AVEC GRUE​
4.24. PROTEGER L’ENGIN POUR LE STOKAGE​
5.3. TABLEAU D’INSPECTION & DE MAINTENANCE​
5.14. DIVERS​
6.2. ESPECIFICACIONES TECNICAS DE HMK 102S​
6.3. REGLEMENTATION EN MATIERE DE LEVAGE ET CHARGE MAXIMALE D’UTILISATION (SWL)​
6.4. SON et VIBRATIONS​
7.1. GENERALITES​
7.10. RIPPEUR​
7.13. TREUIL​
