Hyundai
86
176,684
Hidromek Backhoe Loader HMK62T Stage5 Operation Manual M219703401 2025
Brand: Hidromek
Type of Manual: Operation and Maintenance Manual
Model: Hidromek HMK62T Stage5 Backhoe Loader
From Serial Numbers D020001
Part Number: M219703401
Publication Date: 2025
Number of Pages: 141 Pages
1. INTRODUCTION
1.1. COPYRIGHT​
1.2. DRIVING LICENSE​
1.3. SPARE PARTS AND SERVICE​
1.4. ENVIRONMENTAL STANDARDS​
1.5. SAFETY NOTICES​
1.6. OTHER NOTICES​
1.7. IDENTIFICATION PLATE​
1.8. BACKHOE LOADER DESCRIPTION​
2. SAFETY
2.1. GENERAL SAFETY INFORMATION​
2.2. SAFETY PRECAUTIONS​
2.2.1. WELDING​
2.2.2. MACHINE CONTROL LEVERS​
2.2.3. VISIBILITY​
2.2.4. ROPS / FOPS STRUCTURE​
2.2.5. SPARKS​
2.2.6. DRINKS AND DRUGS​
2.2.7. FAILURE OF ENGINE OR STEERING​
2.2.8. USA FEDERAL CLEAN AIR ACT​
2.2.9. RECOMMENDATIONS​
2.3. PRE-START SAFETY​
2.3.1. SAFETY PRECAUTIONS​
2.3.2. PROTECTIVE CLOTHING​
2.3.3. OPERATION AND MAINTENANCE MANUAL​
2.3.4. OPERATION AND MAINTENANCE MANUAL LOCATION​
2.3.5. EMERGENCIES​
2.3.6. SAFETY AT THE JOB SITE​
2.3.7. SIGNS, SIGNALS & SIGNALMAN​
2.3.8. FIRE​
2.3.9. HOT SURFACES & FLUIDS​
2.3.10. USE PROPER ATTACHMENT​
2.3.11. TO GET ON AND OFF THE MACHINE​
2.3.12. VISIBILITY​
2.3.13. PRE-START INSPECTION​
2.4. SAFETY DURING OPERATION​
2.4.1. PASSENGERS​
2.4.2. STARTING THE ENGINE​
2.4.3. DRIVING​
2.4.4. ROLL-OVER PROTECTION​
2.4.5. SLEWING​
2.4.6. WORKING AROUND UTILITY LINES​
2.4.7. OPERATING ON HILLSIDES & SLOPES​
2.4.8. LIFTING​
2.4.9. ICE & SNOW ON THE JOB SITES​
2.4.10. UNSTABLE GROUND OR FILLING​
2.4.11. DANGER ZONE​
2.4.12. RESTRICTED WORKING AREAS​
2.4.13. LEGAL LIABILITY​
2.4.14. VENTILATION IN CLOSED AREA​
2.4.15. PARKING THE MACHINE​
2.4.16. EMERGENCY EXIT​
2.4.17. UNINTENTIONAL SHUT-OFF DURING OPERATION​
2.4.18. BEFORE LEAVING THE MACHINE​
2.5. INSPECTION & MAINTENANCE SAFETY​
2.5.1. PROTECTIVE CLOTHING​
2.5.2. STOP THE ENGINE​
2.5.3. ENGAGE JOYSTICKS SAFETY LOCKS​
2.5.4. PREVENT UNAUTHORIZED START​
2.5.5. CHECKING ATTACHMENT LOCK PINS​
2.5.6. SECURING ATTACHMENTS​
2.5.7. ENGAGE ATTACHMENT LOCKS​
2.5.8. MAINTENANCE POSITION​
2.5.9. KEEP THE MACHINE CLEAN​
2.5.10. PRESSURIZED FLUIDS​
2.5.11. SUPPORT THE MACHINE​
2.5.12. REFUELING​
2.5.13. HYDRAULIC PRESSURE​
2.5.14. RUBBER TRACKS​
2.5.15. ROTATING PARTS IN THE ENGINE​
2.5.16. ELECTRICAL SYSTEM​
2.5.17. SAFE LIGHTING​
2.5.18. WASTE MATERIALS​
2.5.19. CLEANERS​
2.5.20. SEALS​
2.6. BATTERY SAFETY, MAINTENANCE AND WARNINGS​
2.7. WARNING LABELS & DECALS​
2.7.1. “READ THE OPERATING AND MAINTENANCE MANUAL” LABEL​
2.7.2. “KEEP AWAY FROM WORKING AREA” WARNING LABEL FOR BACKHOE​
2.7.3. “KEEP AWAY FROM WORKING AREA” WARNING LABEL FOR LOADER​
2.7.4. LOADER LIFT CYLINDER LOCK WARNING LABEL​
2.7.5. “DO NOT PINCH YOUR HANDS” WARNING LABEL​
2.7.6. “DO NOT PINCH YOUR FEET” WARNING LABEL​
2.7.7. "STOP THE ENGINE, REMOVE THE IGNITION KEY AND READ THE OPERATION MANUAL BEFORE CHECKING AND SERVICING HOT AND ROTATING PARTS" WARNING LABEL​
2.7.8. ELECTRICAL EQUIPMENT WARNING LABEL​
2.7.9. BACKHOE LOCK WARNING LABEL​
2.7.10. FUEL TANK LABEL​
2.7.11. HYDRAULIC OIL TANK LABEL​
2.7.12. BATTERY CUT-OFF RELAY WARNING LABEL​
2.7.13. SAFE WORKING LOAD WARNING LABEL​
2.7.14. EMERGENCY EXIT WARNING LABEL​
2.7.15. ANTI-FRIEZE WARNING LABEL​
2.7.16. BATTERY WARNING LABEL​
2.7.17. AIR FILTER WARNING LABEL​
2.7.18. “CHECK TRACK TENSION” WARNING LABEL (LEFT)​
2.7.19. “CHECK TRACK TENSION” WARNING LABEL (RIGHT)​
2.7.20. EMISSION CONTROL SYSTEM INFORMATION AND WARNING LABEL​
2.8. PROHIBITED MACHINE OPERATION​
2.8.1. DO NOT USE THE SLEWING FORCE OF THE BACKHOE FOR GRADING​
2.8.2. DO NOT HAMMER WITH THE BUCKET​
2.8.3. NEVER USE THIS MACHINE OTHER THAN ITS INTENDED USE​
2.8.4. DO NOT USE THE BACKHOE LOADER FOR LIFTING PEOPLE​
2.8.5. DO NOT IMPACT HYDRAULIC CYLINDERS TO STROKE END REPEATEDLY​
2.8.6. NEVER EXCEED THE CAPACITY OF THE MACHINE​
2.8.7. DO NOT USE BUCKET TO BREAK OR CUT​
2.8.8. DO NOT DRIVE WITH THE STABILIZERS EXTENDED​
2.8.9. END OF WORKSHIFT MAINTENANCE & INSPECTION​
3. DESCRIPTION
3.1. A/C CONSOLE​
3.2. STARTER SWITCH​
3.3. RIGHT HAND SIDE CONSOLE​
3.3.1. FRONT ATTACHMENT SWITCH​
3.3.2. PARKING (HAND) BRAKE SWITCH​
3.3.3. HAZARD WARNING LIGHT SWITCH​
3.3.4. FRONT WINDOW WIPER AND WASHER SWITCH​
3.3.5. HIGH FLOW / LOW FLOW ATTACHMENT SWITCH (OPTIONAL)​
3.3.6. REAR WINDOW WIPER AND WASHER SWITCH​
3.3.7. ROTATING BEACON SWITCH​
3.3.8. FRONT & REAR WORKING LIGHTS SWITCH​
3.3.9. HEADLIGHTS & TAIL LIGHTS SWITCH​
3.3.10. “DIG&TRAVEL” / “DIG ONLY” / “LOAD&TRAVEL” MODE SELECTION SWITCH​
3.3.11. “DPF REGENERATION INHIBIT” SWITCH​
3.3.12. INSTRUMENT PANEL​
3.4. THROTTLE DIAL​
3.5. LEFT HAND SIDE CONSOLE​
3.5.1. RIGHT / LEFT STABILIZER SWITCHES​
3.5.3. HYDRAULIC CLAMPING SWITCH​
3.5.4. CONTROL LEVERS (JOYSTICK) LOCK SWITCH​
3.5.5. ENGINE EMERGENCY STOP SWITCH​
3.6. OPERATOR’S SEAT​
3.7. CONTROL LEVERS​
3.7.1. TRAVEL AND LOADER POSITION​
3.7.2. BACKHOE POSITION​
3.8. THROTTLE PEDAL​
3.9. WINDOWS​
3.9.1. SIDE WINDOWS​
3.9.2. REAR WINDOW​
3.10. INTERIOR LIGHT​
3.10.1.1. OPENING THE ENGINE HOOD​
3.11. TOOLBOX​
4. OPERATION
4.1. GENERAL CONTROL​
4.1.1. GETTING IN AND OUT OF THE CAB​
4.2. ENGINE​
4.2.1. BEFORE STARTING THE ENGINE​
4.2.2. STARTING THE ENGINE​
4.3. AFTERTREATMENT SYSTEM OPERATION​
4.3.1. REMOVAL OF ASH FROM DPF​
4.3.2. DPF REGENERATION INHIBIT​
4.3.3. DPF REGENERATION​
4.3.4. DPF REGENERATION ESCALATION LEVELS​
4.4. BASIC PRECAUTIONS FOR OPERATION IN COLD WEATHER​
4.5. DRIVING THE MACHINE​
4.5.1. TRAVELING IN REVERSE DIRECTION​
4.6. PREPARATIONS FOR TRAVEL​
4.6.1. TESTING THE PARKING BRAKE​
4.7. STOPPING AND PARKING THE MACHINE​
4.8. ENGAGING ATTACHMENT SAFETY LOCKS​
4.8.1. LOADER ARM SAFETY STRUT​
4.8.2. ENGAGING LOADER ARM SAFETY STRUT​
4.8.3. DISENGAGING SAFETY STRUT​
4.8.4. ENGAGING BACKHOE BOOM LOCK​
4.8.5. DISENGAGING BACKHOE BOOM LOCK​
4.8.6. STABILIZER SHOE LOCK​
4.9. CONTROLLING HYDRAULIC CLAMP CYLINDERS​
4.10. SIDESHIFTING THE BACKHOE​
4.11. TELESCOPIC ARM (OPTIONAL)​
4.11.1. TELESCOPIC ARM SAFETY LOCK​
4.11.2. CONTROLLING THE TELESCOPIC ARM​
4.11.3. TELESCOPIC ARM - HYDRAULIC BREAKER SELECTING VALVE​
4.12. THE LOADER OPERATION​
4.12.1. LOADING TRUCKS​
4.12.2. LEVELING WITH A LOADER​
4.13. THE BACKHOE OPERATION​
4.13.1. HINTS ON OPERATION OF BACKHOE​
4.13.2. CORRECT DIGGING METHOD​
4.13.3. EXCAVATION ON SLOPES​
4.13.4. LOWERING THE ATTACHMENTS IN CASE OF UNEXPECTED POWER CUT-OFF​
4.14. REPLACING ATTACHMENTS​
4.14.1. LOADER ATTACHMENT (QUICK COUPLER)​
4.14.2. BACKHOE ATTACHMENT​
4.14.3. REPLACING BUCKET TEETH​
4.15. TRANSPORTING THE MACHINE​
4.16. TOWING PROCEDURE FOR A DISABLED MACHINE​
4.16.1. MANUAL DEACTIVATION OF PARKING BRAKE​
4.17. LIFTING BY A CRANE​
4.18. PRESERVING THE MACHINE FOR STORAGE​
4.18.1. MAINTENANCE OF THE MACHINE DURING AND AFTER STORAGE​
4.19. INSTRUCTIONS ON WITHDRAWAL FROM USE AND UTILIZATION​
5. TROUBLESHOOTING
5.1. ENGINE MALFUNCTIONS​
5.2. HYDRAULIC SYSTEM MALFUNCTIONS​
5.3. ELECTRICAL SYSTEM MALFUNCTIONS​
6. MAINTENANCE
6.1. MAINTENANCE PRECAUTIONS​
6.1.1. STOP THE ENGINE AND PARK THE MACHINE​
6.1.2. ATTACH “DO NOT OPERATE” WARNING​
6.1.3. ENGAGE ATTACHMENT SAFETY LOCKS​
6.1.4. WEAR PROTECTIVE CLOTHING​
6.1.5. KEEP THE MACHINE CLEAN​
6.1.6. PREVENT CONTAMINATION​
6.1.7. HOT SURFACES & FLUIDS​
6.1.8. WARM UP THE ENGINE OIL​
6.1.9. DISPOSAL OF HAZARDOUS WASTE​
6.1.10. SEALS & O–RINGS​
6.1.11. RELEASE RESIDUAL HYDRAULIC OIL PRESSURE​
6.1.12. HANDLING POLYMERS AND ELASTOMERS CONTAINING FLUORO-CARBON​
6.1.13. PRECAUTIONS WHEN WORKING WITH A/C REFRIGERANTS​
6.1.14. PRECAUTIONS TO BE TAKEN DURING WORKING WITH EXHAUST PIPE​
6.1.15. USE OF BIODEGRADABLE SYNTHETIC OILS​
6.1.16. DISPOSAL OF WASTES AND PROTECTION OF THE ENVIRONMENT​
6.2. PERIODIC MAINTENANCE​
6.2.1. FIRST 50 HOURS MAINTENANCE​
6.3. INSPECTION & MAINTENANCE CHART​
6.4. ENGINE PARTS​
6.5. TABLE of LUBRICANTS & FLUIDS​
6.5.1. COOLANT​
6.5.2. DIESEL FUEL​
6.6. PRE-START INSPECTION &MAINTENANCE (EVERY 8 HOURS)​
6.6.1. INSPECT THE ENGINE FOR LEAKS AND FOR LOOSE CONNECTIONS​
6.6.2. CHECKING ENGINE OIL LEVEL​
6.6.3. CHECKING COOLANT LEVEL​
6.6.4. CHECKING FUEL LEVEL​
6.6.5. CHECKING HYDRAULIC OIL LEVEL​
6.6.6. CHECKING THE RUBBER TRACKS CONDITION​
6.6.7. CHECKING THE DRIVE BELT TENSION​
6.6.8. GREASING​
6.7. WEEKLY (EVERY 50 HOURS) INSPECTION & MAINTENANCE​
6.7.1. DRAINING THE FUEL TANK​
6.7.2. CHECKING THE FUEL PIPES AND CLAMP BANDS​
6.7.3. DRAINING THE FUEL TANK WATER AND SEDIMENT​
6.7.4. CHECKING AND READJUSTING WEAR PADS OF TELESCOPIC ARM​
6.7.5. CHECKING THE CLEARANCE OF INNER PLATES OF THE STABILIZERS​
6.7.6. CHECKING THE ROPS/FOPS OPERATOR’S CABIN​
6.7.7. CHECKING THE ELECTROLYTE LEVEL OF BATTERY​
6.7.8. INSPECTING AND ADJUSTING TRACK TENSION​
6.8. EVERY 250 HOURS INSPECTION & MAINTENANCE​
6.8.1. REPLACING PILOT LINE FILTER​
6.8.2. CHECKING RADIATOR HOSES AND CLAMP BANDS​
6.8.3. CHECK INTAKE AIR LINE​
6.9. EVERY 500 HOURS INSPECTION & MAINTENANCE​
6.9.1. CHANGING ENGINE OIL​
6.9.2. CHANGING ENGINE OIL FILTER​
6.9.3. REPLACING FUEL FILTER ELEMENTS​
6.9.4. CLEANING SEDIMENT IN THE FUEL TANK​
6.9.5. CLEANING COOLING SYSTEM RADIATOR INTERIOR​
6.9.6. REPLACING THE FAN BELT​
6.9.7. REPLACING THE HYDRAULIC RETURN FILTER​
6.9.8. REPLACING AIR-CONDITIONER FILTER​
6.9.9. REPLACING WATER SEPARATOR FILTER​
6.10. EVERY 1000 HOURS INSPECTION & MAINTENANCE​
6.10.1. CHECKING AND ADJUSTING ENGINE VALVE CLEARANCE​
6.10.2. CHANGING THE HYDRAULIC OIL AND THE SUCTION STRAINER​
6.11. EVERY 1500 HOURS INSPECTION & MAINTENANCE​
6.11.1. CHANGING OIL SEPARATOR ELEMENT​
6.11.2. CHECKING & CLEANING PCV VALVE (POSITIVE CRANKCASE VENTILATION VALVE)​
6.11.3. CHECKING INJECTION PRESSURE AT FUEL INJECTION NOZZLE​
6.11.4. CHECKING EGR COOLER​
6.12. EVERY 3000 HOURS INSPECTION & MAINTENANCE​
6.13. ANNUAL INSPECTION & MAINTENANCE​
6.13.1. CHECKING INTAKE AIR LINE​
6.13.2. CHECKING EXHAUST MANIFOLD FOR CRACKS OR GAS LEAK AND FOR LOOSENESS OR DAMAGE​
6.13.3. COOLANT​
6.14. BIENNIAL INSPECTION & MAINTENANCE​
6.15. CONTROLS TO BE PERFORMED WHEN NECESSARY​
6.15.1. CHANGING AIR FILTER​
6.15.2. BLEEDING THE FUEL SYSTEM​
6.15.3. REPLACING FUSES​
6.15.4. REPLACING BATTERY​
6.15.5. DISCONNECTING BATTERY OR BATTERY CABLE​
6.15.6. REPLACING LIGHT BULBS​
7. SPECIFICATIONS
7.1. HMK 62 T WORKING RANGES & DIMENSIONS​
7.2. LIFTING REGULATIONS AND SAFE WORKING LOADS (SWL)​
7.2.1. LIFTING REGULATIONS​
7.2.2. SAFE WORKING LOADS (LOADER)​
7.2.3. SAFE WORKING LOADS (BACKHOE)​
7.3. SOUND and VIBRATION​
7.3.1. SOUND​
7.3.2. VIBRATION​
8. OPTIONAL EQUIPMENT
8.1. LOADER GROUP​
8.1.1. MULTI PURPOSE BUCKET​
8.1.2. GENERAL PURPOSE BUCKET​
8.1.3. LEVELLING BLADE​
8.1.4. FORK​
8.1.5. HIGH FLOW HYDRAULIC LINE​
8.2. BACKHOE GROUP​
8.2.1. BUCKET​
8.2.2. EXTENDABLE ARM (TELESCOPIC ARM)​
8.2.3. HYDRAULIC BREAKER​
8.2.4. STABILIZER RUBBER PAD​
8.2.5. SWING LOCKING SYSTEM​
8.2.6. DOUBLE ACTING BACKHOE LINE​
9. APPENDIX
9.1. USAGE OF HAND SIGNALS​
9.2. TABLE OF TORQUE VALUES FOR FASTENERS​
9.3. COMMUNICATION INFORMATION​
9.3.1. PLANTS AND AFTER SALES SERVICES​
