Hiab Multilift Cable Roll-off Truck CLF3203W Spare Parts Catalog 8810059 2005
Brand: Hiab Multilift
Type of Machine: Cable Roll-off Truck
Type of Manual: Spare Parts Catalog, Electrical Diagram, Hydraulic Diagram
Model: Hiab Multilift CLF 3203W Cable Roll-off Truck
Part Number: 8810059
Publication Date: 2005
Number of Pages: 152 Pages
vo1_2005_clf3201w_3203w_en.pdf
1.03 CLF3201W/3801W/3203W FRONT FRAME ASSEMBLY
1.22 CLF3201W/3801W/3203W TWIN-MOTOR WINCH UNIT
1.32 CLF3201W/3801W/3203W TRANSMISSION OF WINCH UNIT, TWIN-MOTOR
1.41 CLF LATCH LINKAGE
1.42 CLF1901W/2501W/2601W/3201W/1903W/2603W/3203W LOCKABLE FRONT STOP
1.43 CLF NON-LOCKING FRONT STOP
vo2_2005_clf3203w_en.pdf
2.71 CLF3203W (CLF3201W) (CLF3801W) TIPPING UNIT ST 27 254/55 (6014 260)
2.72 CLF3203W (CLF3201W) (CLF3801W) TIPPING RAM ST 27 254/55 PV (N310 101 691)
2.81 CLF3203W (CLF3201W) (CLF3801W) TIPPING UNIT ST 32 254/55 (6014 322)
2.82 CLF3203W (CLF3201W) (CLF3801W) TIPPING RAM ST 32 254/55 PV (N310 101 858)
vo3_2005_clf3203w_en.pdf
3.33 CLF3203W TIPPING FRAME PARTS
3.34 CLF3203W TIPPING FRAME
3.41 CLF1903W/2603W/3203W TIPPING LOCK PARTS
3.51 CLF BODY SUPPORTS
3.61 CLF COMBI-LOCK
3.62 CLF LONGITUDINAL LOCK, equipment with combi-lock
3.63 CLF LONGITUDINAL LOCK, equipment without combi-lock
3.64 CLF1901W/2501W/2601W/3201W/380 MIDDLE LOCK, CLF380 INSIDE REAR BODY LOCK
3.72 CLF1903W/2603W/3203W REAR ROLLER
vo4_2005_clf1903w_2603w_3203w_en.pdf
4.21 CLF1903W/2603W/3203W SUBFRAME (H = 100 mm, W = 770 mm)
4.22 CLF1903W/2603W/3203W SUBFRAME (H = 100 mm, W = 850 mm)
4.23 CLF1903W/2603W/3203W SUBFRAME (H = 115 mm, W = 770 mm)
4.24 CLF1903W/2603W/3203W SUBFRAME (H = 115 mm, W = 850 mm)
4.25 CLF1903W/2603W/3203W SUBFRAME (H = 115 mm, W = 810 mm)
4.26 CLF1903W/2603W/3203W SUBFRAME (H = 160 / 200 mm, W = 770 / 850 mm)
4.27 CLF1903W/2603W/3203W SUBFRAME (H = 160 mm, W = 810 mm)
4.28 CLF1903W/2603W/3203W SUBFRAME (H = 200 mm, W = 810 mm)
4.41 CLF1903W/2603W/3203W SUBFRAME MOUNTINGS (except DK) AND TIPPING PROP
4.42 CLF1903W/2603W/3203W SUBFRAME MOUNTINGS (DK) AND TIPPING PROP
vo5_2005_clf1903w_2603w_3203w_en.pdf
5.02 CLF1903W/2603W/3203W LOWERING RAM
vo6_2005_clf3203w_en.pdf
6.0 HYDRAULIC DIAGRAMS
6.012 CLF3203W STANDARD HYDRAULIC except DK
6.013 CLF3203W 2-DRIVE HYDRAULIC except DK
6.014 CLF3203W 2-DRIVE HYDRAULIC except DK (one spool control valve for tipping unit)
6.018 CLF3203W STANDARD HYDRAULIC DK
6.019 CLF3203W 2-DRIVE HYDRAULIC DK
6.020 CLF HYDRAULIC OF BOGIE BLOCKING (option, CLF380 standard)
6.1 HYDRAULIC TUBING
6.101 CLF PUMP CIRCUIT, STANDARD HYDRAULIC
6.102 CLF PUMP CIRCUIT, 2-SPEED HYDRAULIC (optional fitting)
6.103 CLF PUMP CIRCUIT, 2-DRIVE SYSTEM
6.108 CLF 3W TUBING IN SUBFRAME - all except DK
6.109 CLF 3W TUBING IN SUBFRAME, 2-DRIVE SYSTEM - all except DK
6.110 CLF 3W TUBING FOR BOGIE BLOCKING IN SUBFRAME - all except DK
6.111 CLF 3W TUBING FOR BOGIE BLOCKING IN SUBFRAME, 2-DRIVE SYSTEM - all except DK
6.112 CLF 3W TUBING IN SUBFRAME - DK
6.113 CLF 3W TUBING IN SUBFRAME, 2-DRIVE SYSTEM - DK
6.115 CLF 3W TUBING IN TIPPING FRAME
6.2 VALVES
6.201 CLF SELECTION VALVE AND FREEWHEELING VALVE (RV 613)
6.211 CLF CONTROL VALVE (winch- and tipping units) HYV 40-2
6.212 CLF CONTROL VALVE (winch- and tipping units and bogie blocking) HYV 40-3 (except 3W DK)
6.213 CLF CONTROL VALVE (winch- and tipping units and two opt. equipments) HYV 40-4 (exc. 3W DK)
6.214 CLF 3W CONTROL VALVE (winch unit and truck and trailer tipping units) HYV 40-3 DK
6.217 CLF 2-DRIVE CONTROL VALVE (winch unit) HYV 40-1
6.218 CLF 2-DRIVE CONTROL VALVE (truck tipping unit) HYV 40-1
6.219 CLF 3W 2-DRIVE CONTROL VALVE (truck and trailer tipping units) HYV 40-2 (DK)
6.220 CLF 2-DRIVE CONTROL VALVE (tipping unit and bogie blocking) HYV 40-2 (except 3W DK)
6.231 CLF CONTROL VALVE HYV 40, CONTROL SETS
6.3 OIL TANKS AND FILTERS
6.301 CLF OIL TANK, MULTILIFT
6.302 CLF OIL TANK, FINN-FILTER -> 042004
6.303 CLF OIL TANK, FINN-FILTER 052004 ->
6.311 CLF FILTERS 1
6.312 CLF FILTERS 2
6.4 BOGIE BLOCKING
6.401 CLF BOGIE BLOCKING CYLINDER
6.5 PIPE JOINTS
6.501 CLF PIPE JOINTS AND CLAMPS, page 1
6.502 CLF PIPE JOINTS AND CLAMPS, page 2
vo7_2005_clf3203w_en.pdf
7.0 PNEUMATIC DIAGRAMS
7.031 PNEUMATIC DIAGRAM - CLF -3W version 1
7.032 PNEUMATIC DIAGRAM - CLF -3W version 2
7.033 PNEUMATIC DIAGRAM - CLF -3W version 3 (DK)
7.034 PNEUMATIC DIAGRAM - CLF -3W version 4
7.035 PNEUMATIC DIAGRAM - CLF -3W version 5
7.036 PNEUMATIC DIAGRAM - CLF -3W version 6
7.1 WIRING DIAGRAMS - controller cables
7.101 WIRING DIAGRAM controller cables - version 1
7.102 WIRING DIAGRAM controller cables - version 2
7.103 WIRING DIAGRAM controller cables - version 3 (DK)
7.104 WIRING DIAGRAM controller cables - version 4
7.105 WIRING DIAGRAM controller cables - version 5
7.106 WIRING DIAGRAM controller cables - version 6
7.2 WIRING DIAGRAMS - main harness and emergency stop
7.201 WIRING DIAGRAM main harness and emergency stop
7.202 WIRING DIAGRAM main harness and emergency stop
7.203 WIRING DIAGRAM main harness and emergency stop
7.204 WIRING DIAGRAM main harness and emergency stop
7.205 WIRING DIAGRAM main harness and emergency stop
7.206 WIRING DIAGRAM main harness and emergency stop
7.207 WIRING DIAGRAM, main harness with two hands rear control unit
7.208 WIRING DIAGRAM MULTILIFT emergency stop system with one stop switch
7.209 WIRING DIAGRAM MULTILIFT emergency stop system with two stop switches
7.3 CONTROL SYSTEMS AND PULL LIMITERS
7.304 CONTROL SYSTEM CLF3203W
7.311 CONTROL SYSTEM, DETAILS
7.312 PULL LIMITERS
7.4 CONTROL UNITS
7.411 CONTROLLER 1, assembly
7.421 CONTROLLER 2, assembly - version 1
7.422 CONTROLLER 2, assembly - version 2
7.423 CONTROLLER 2, assembly - version 3 (DK)
7.424 CONTROLLER 2, assembly - version 4
7.425 CONTROLLER 2, assembly - version 5
7.426 CONTROLLER 2, assembly - version 6
7.431 REAR CONTROL UNITS (standard)
7.432 TWO HANDS REAR CONTROL UNIT
7.5 MAIN CONNECTION BOX´S
7.501 MAIN CONNECTION BOX - version 1
7.502 MAIN CONNECTION BOX - version 2
7.503 MAIN CONNECTION BOX - version 3 (DK)
7.504 MAIN CONNECTION BOX - version 4
7.505 MAIN CONNECTION BOX - version 5
7.506 MAIN CONNECTION BOX - version 6
7.6 EMERGENCY STOP UNITS
7.601 EMERGENCY STOP KITS
3.61 CLF COMBI-LOCK
6.2 VALVES
6.311 CLF FILTERS 1
6.312 CLF FILTERS 2
6.4 BOGIE BLOCKING
6.5 PIPE JOINTS
7.312 PULL LIMITERS
7.4 CONTROL UNITS
- HIAB LOADER CRANE SERVICE MANUAL
- HIAB SPACE 4000 System Error Codes Service Manual_EN
- HIAB LOADER CRANE 022 / 32 / 35/ 2700 HYDRAULIC DIAGRAMS
- HIAB LOADER CRANE SERIE 144XS HYDRAULIC DIAGRAMS
- HIAB LOADER CRANE SERIE 071 HYDRAULIC DIAGRAMS
- HIAB SPACE 3000 Service Manual_EN
- HIAB SPACE 4000 Electronic Control Systems_EN
- HIAB LOADER CRANE SERIE 095 HYDRAULIC DIAGRAMS
- HIAB LOADER CRANE SERIE 166XS HYDRAULIC DIAGRAMS
- Hiab Model: BZ 20-152 (S) SPARE-PARTS BOOK
- HIAB LOADER CRANE SERIE 195XS HYDRAULIC DIAGRAMS
- Hiab Model: ZL 250-135 SPARE-PARTS BOOK
- HIAB LOADER CRANE SERIE 102 HYDRAULIC DIAGRAMS
- Hiab Model: BZZ 250-135 SPARE-PARTS BOOK
- HIAB LOADER CRANE SERIE 220XS HYDRAULIC DIAGRAMS
