Momed80
150
35,046
Hiab Multilift Cable Roll-off Truck CLF260 Spare Parts Catalog 8810059 2005
Brand: Hiab Multilift
Type of Machine: Cable Roll-off Truck
Type of Manual: Spare Parts Catalog, Hydraulic Diagram, Electrical Diagram
Model: Hiab Multilift CLF260 Cable Roll-off Truck
Part Number: 8810059
Publication Date: 2005
Number of Pages: 145 Pages
vo1_2005_clf2601w_2603w_en.pdf
1.02 CLF2601W/2603W FRONT FRAME ASSEMBLY
1.21 CLF1901W/(2501W)/2601W/1903W/2603W SINGLE-MOTOR WINCH UNIT
1.31 CLF1901W/2501W1/2601W/1903W/2603W TRANSMISSION OF WINCH UNIT, SINGLE-MOTOR
1.41 CLF *** LATCH LINKAGE
1.42 CLF1901W/2501W/2601W/3201W/1903W/2603W/3203W LOCKABLE FRONT STOP
1.43 CLF *** NON-LOCKING FRONT STOP
vo2_2005_clf2601w_en.pdf
2.11 CLF2501W CLF2601W (CLF1901W) (CLF3201W) TIPPING UNIT RT 59 132/55
2.12 CLF2501W CLF2601W (CLF1901W) (CLF3201W) TIPPING RAM RT 59 132/55 (6014 202)
2.21 CLF3201W CLF3801W (CLF2601W) TIPPING UNIT RT 59 152/55
2.22 CLF3201W CLF3801W (CLF2601W) TIPPING RAM RT 59 152/55 (6014 203)
2.41 CLF1903W CLF2603W (CLF1901W) (CLF2601W) TIPPING UNIT ST 22 254/55 (6014 267)
2.42 CLF1903W CLF2603W (CLF1901W) (CLF2601W) TIPPING RAM ST 22 254/55 (N310 101 666)
2.51 CLF1903W (CLF2603W) (CLF1901W) (CLF2601W) TIPPING UNIT ST 22 219/40 (6014 325)
2.52 CLF1903W (CLF2603W) (CLF1901W) (CLF2601W) TIPPING RAM ST 22 219/40 PV (N310 103 430)
2.61 CLF2603W (CLF2601W) TIPPING UNIT ST 27 219/55 (6014 261)
2.62 CLF2603W (CLF2601W) TIPPING RAM ST 27 219/55 PV (N310 101 690)
vo3_2005_clf2601w_en.pdf
3.01 CLF1901W/(2501W)/2601W/3201W TIPPING FRAME PARTS
3.22 CLF2601W REAR FRAME
3.51 CLF *** BODY SUPPORTS
3.61 CLF *** COMBI-LOCK
3.62 CLF *** LONGITUDINAL LOCK, equipment with combi-lock
3.63 CLF *** LONGITUDINAL LOCK, equipment without combi-lock
3.64 CLF1901W/2501W/2601W/3201W/380 MIDDLE LOCK, CLF380 INSIDE REAR BODY LOCK
3.71 CLF1901W/2501W/2601W/3201W/380 REAR ROLLER
vo4_2005_clf1901w_2601w_3201w_en.pdf
4.01 CLF1901W/2601W/3201W SUBFRAME PARTS
4.02 CLF1901W/(2501W)/2601W/3201W SUBFRAME PARTS
4.31 CLF1901W/2601W/3201W SUBFRAME MOUNTINGS AND TIPPING PROP
vo5_2005_clf1901w_2601w_3201w_en.pdf
5.01 CLF1901W/2601W/3201W LOWERING RAM
vo6_2005_clf1901w_2601w_en.pdf
6.0 HYDRAULIC DIAGRAMS
6.001 CLF1901W/2601W STANDARD HYDRAULIC
6.002 CLF1901W/2601W 2-SPEED HYDRAULIC
6.003 CLF1901W/2601W 2-DRIVE HYDRAULIC
6.004 CLF1901W/2601W 2-DRIVE HYDRAULIC (one spool control valve for tipping unit)
6.020 CLF *** HYDRAULIC OF BOGIE BLOCKING (option, CLF380 standard)
6.1 HYDRAULIC TUBING
6.101 CLF *** PUMP CIRCUIT, STANDARD HYDRAULIC
6.102 CLF *** PUMP CIRCUIT, 2-SPEED HYDRAULIC (optional fitting)
6.103 CLF *** PUMP CIRCUIT, 2-DRIVE SYSTEM
6.104 CLF *** 1W TUBING IN SUBFRAME
6.105 CLF *** 1W TUBING IN SUBFRAME, 2-DRIVE SYSTEM
6.106 CLF *** 1W TUBING FOR BOGIE BLOCKING IN SUBFRAME
6.107 CLF *** 1W TUBING FOR BOGIE BLOCKING IN SUBFRAME, 2-DRIVE SYSTEM
6.114 CLF *** 1W TUBING IN TIPPING FRAME
6.2 VALVES
6.201 CLF *** SELECTION VALVE AND FREEWHEELING VALVE (RV 613)
6.211 CLF *** CONTROL VALVE (winch- and tipping units) HYV 40-2
6.212 CLF *** CONTROL VALVE (winch- and tipping units and bogie blocking) HYV 40-3 (except 3W DK)
6.213 CLF *** CONTROL VALVE (winch- and tipping units and two opt. equipments) HYV 40-4 (exc. 3W DK)
6.217 CLF *** 2-DRIVE CONTROL VALVE (winch unit) HYV 40-1
6.218 CLF *** 2-DRIVE CONTROL VALVE (truck tipping unit) HYV 40-1
6.220 CLF *** 2-DRIVE CONTROL VALVE (tipping unit and bogie blocking) HYV 40-2 (except 3W DK)
6.231 CLF *** CONTROL VALVE HYV 40, CONTROL SETS
6.3 OIL TANKS AND FILTERS
6.301 CLF *** OIL TANK, MULTILIFT
6.302 CLF *** OIL TANK, FINN-FILTER -> 042004
6.303 CLF *** OIL TANK, FINN-FILTER 052004 ->
6.311 CLF *** FILTERS 1
6.312 CLF *** FILTERS 2
6.4 BOGIE BLOCKING
6.401 CLF *** BOGIE BLOCKING CYLINDER
6.5 PIPE JOINTS
6.501 CLF *** PIPE JOINTS AND CLAMPS, page 1
6.502 CLF *** PIPE JOINTS AND CLAMPS, page 2
vo7_2005_clf1901w_2601w_en.pdf
7.0 PNEUMATIC DIAGRAMS
7.011 PNEUMATIC DIAGRAM - CLF -1W version 1
7.012 PNEUMATIC DIAGRAM - CLF -1W version 2
7.013 PNEUMATIC DIAGRAM - CLF -1W version 3 (DK)
7.014 PNEUMATIC DIAGRAM - CLF -1W version 4
7.015 PNEUMATIC DIAGRAM - CLF -1W version 5
7.016 PNEUMATIC DIAGRAM - CLF -1W version 6
7.1 WIRING DIAGRAMS - controller cables
7.101 WIRING DIAGRAM controller cables - version 1
7.102 WIRING DIAGRAM controller cables - version 2
7.103 WIRING DIAGRAM controller cables - version 3 (DK)
7.104 WIRING DIAGRAM controller cables - version 4
7.105 WIRING DIAGRAM controller cables - version 5
7.106 WIRING DIAGRAM controller cables - version 6
7.2 WIRING DIAGRAMS - main harness and emergency stop
7.201 WIRING DIAGRAM main harness and emergency stop
7.202 WIRING DIAGRAM main harness and emergency stop
7.203 WIRING DIAGRAM main harness and emergency stop
7.204 WIRING DIAGRAM main harness and emergency stop
7.205 WIRING DIAGRAM main harness and emergency stop
7.206 WIRING DIAGRAM main harness and emergency stop
7.207 WIRING DIAGRAM, main harness with two hands rear control unit
7.208 WIRING DIAGRAM MULTILIFT emergency stop system with one stop switch
7.209 WIRING DIAGRAM MULTILIFT emergency stop system with two stop switches
7.3 CONTROL SYSTEMS AND PULL LIMITERS
7.301 CONTROL SYSTEM CLF1901W/2501W/2601W
7.311 CONTROL SYSTEM, DETAILS
7.312 PULL LIMITERS
7.4 CONTROL UNITS
7.411 CONTROLLER 1, assembly
7.421 CONTROLLER 2, assembly - version 1
7.422 CONTROLLER 2, assembly - version 2
7.423 CONTROLLER 2, assembly - version 3 (DK)
7.424 CONTROLLER 2, assembly - version 4
7.425 CONTROLLER 2, assembly - version 5
7.426 CONTROLLER 2, assembly - version 6
7.431 REAR CONTROL UNITS (standard)
7.432 TWO HANDS REAR CONTROL UNIT
7.5 MAIN CONNECTION BOX´S
7.501 MAIN CONNECTION BOX - version 1
7.502 MAIN CONNECTION BOX - version 2
7.503 MAIN CONNECTION BOX - version 3 (DK)
7.504 MAIN CONNECTION BOX - version 4
7.505 MAIN CONNECTION BOX - version 5
7.506 MAIN CONNECTION BOX - version 6
7.6 EMERGENCY STOP UNITS
7.601 EMERGENCY STOP KITS
