705,578
Hendrickson Softek Steertek NXT Airtek For International Vehicles Technical Procedure 17730-252
Brand: Hendrickson
Type of Machine: Steer Axle, Monoleaf Spring Suspension, Front Air Suspension
Type of Manual: Technical Procedure
Model:
Hendrickson SOFTEK Monoleaf Spring Suspension
Hendrickson STEERTEK NXT Steer Axle
Hendrickson AIRTEK Front Air Suspension
Part Number: 17730-252
Publication Date: 2011
Number of Pages: 124 Pages
Section 1 Introduction
Section 2 Product Description
Section 3 Important Safety Notice
Section 4 Special Tools
Section 5 Parts List
Section 6 Towing Procedures
Section 7 Preventive Maintenance
Component Inspection
Lubrication Intervals
Kingpin Lubrication
Tie Rod End Lubrication
Tie Rod End Inspection
Clamp Group Re-Torque Interval
Tire Inspection
Shock Absorber Inspection
Axle Wrap Liner (If equipped)
Steering Knuckle Inspection
Kingpin Bushing Inspection
AIRTEK Thrust Washer Inspection
Section 8 Alignment & Adjustments
Alignment Defi nitions
Inspection Prior to Alignment
Front Wheel Alignment
AIRTEK Single Ride Height Verifi cation
AIRTEK Dual Ride Height Verifi cation (If Equipped) 55
Steering Stop
Toe Setting
Section 9 Component Replacement
Fasteners
AIRTEK Height Control Valve
AIRTEK Air Spring
SOFTEK / AIRTEK Shock Absorber
AIRTEK Belly Band (If equipped)
AIRTEK – Rear Spring Hanger and
Thrust Washers (NEC)
SOFTEK Shackle Plate
AIRTEK Leaf Spring Assembly
SOFTEK Monoleaf Leaf Spring Assembly
AIRTEK Rear Spring Mount
Front Leaf Spring Eye Bushing
AIRTEK Bottom Axle Wrap
SOFTEK / STEERTEK Bottom Axle Wrap
(If equipped)
AIRTEK Top Axle Wrap (In Chassis)
SOFTEK / STEERTEK Top Axle Wrap (In Chassis)
(If equipped)
SOFTEK Monoleaf Front Axle Assembly
STEERTEK NXT Axle Removal
AIRTEK Front Axle Assembly
SOFTEK Front Axle Assembly
STEERTEK Axle Removal
Steering Knuckle Disassembly
Kingpin Preparation And Measurement
Kingpin Bushing Removal
Steering Knuckle Bore Measurement
Kingpin Bushing Installation
Kingpin Bushing Reaming
Kingpin Seal Installation
Steering Knuckle Assembly
Tie Rod End and Cross Tube
Single to Dual Height Control Valve Conversion
Section 10 AIRTEK Plumbing Diagrams
Section 11 Torque Specifications
Section 12 Troubleshooting Guide
Section 13 Alignment Specifications
Section 14 Reference Material
