HBM-Nobas Motor Grader BG160T-4 Repair Manual and Schematic
Brand: HBM-Nobas
Type of Machine: Motor Grader
Type of Manual: Repair Manual, Electrical Schematic, Hydraulic Schematic
Model: HBM-Nobas BG160T-4 Motor Grader
List of Files:
HBM-Nobas Motor Grader BG110 BG130 BG160 BG190 BG240 Repair Manual.pdf
1 Overview of Illustrations
2 General Instructions
2.1 Notes on the Repair Manual
2.2 Liability Limitation
2.3 Qualified Personnel
2.4 Intended Use
3 Safety Instructions
3.1 Specific safety information and symbols used
3.2 Basic Safety Instructions
3.2.1 Residual risks
3.3 Fundamental safety measures for normal operation
3.4 Basic safety measures for service and maintenance
3.5 Environmental protection regulations
3.6 Preparing for repairs
3.6.1 Basic notes
3.6.2 Tools, measuring instruments, equipment
3.6.3 Tightening torques for screws and nuts
3.6.4 Weights and distance measurements
4 Overview of assemblies
4.1 Vehicle types
4.1.1 Grader BG 110 / BG130
4.1.2 Grader BG160 / BG 190
4.1.3 Grader BG 240
4.2 Main machine parts
5 Assembly change
5.1 Draw bar assembly
5.1.1 Replacing draw bar
5.1.1.1 Disassembling draw bar
5.1.1.2 Draw bar assembly
5.1.2 Changing slewing joint
5.1.2.1 Dismounting slewing joint
5.1.2.2 Assembling slewing joint
5.1.3 Replace slewing gear drive
5.1.3.1 Dismounting slewing gear drive
5.1.3.2 Assemblying slewing gear drive
5.1.4 Replacing slewing gear motor
5.1.4.1 Dismounting slewing gear motor
5.1.4.2 Assembling slewing gear motor
5.1.5 Changing ball bolt
5.1.5.1 Dismounting ball bolt BG 110 / BG 130
5.1.5.2 Dismounting ball bolt BG 160 / BG 190 / BG 240
5.1.5.3 Assemblying ball bolt BG 110 / BG 130
5.1.5.4 Assembling ball bolt BG 160 / BG 190 / BG 240
5.1.6 Change the slewing gear draw bar
5.1.6.1 Disassembling the draw bar from the slewing gear
5.1.6.2 Assembly of draw bar to slewing gear
5.1.7 Changing ball bearing slewing gear
5.1.7.1 Disassembling the ball bearing slewing gear from the draw bar
5.1.7.2 Assembling draw bar on ball bearing slewing gear
5.2 Cylinder assemblies
5.2.1 Replacing slewing cylinder
5.2.1.1 Dismounting slewing cylinder
5.2.1.2 Mounting slewing cylinder
5.2.2 Replacing lifting cylinder
5.2.2.1 Dismounting lifting cylinder
5.2.2.2 Mounting lifting cylinder
5.2.3 Change cutting angle cylinder
5.2.3.1 Dismounting cutting angle cylinder
5.2.3.2 Mounting cutting angle cylinder
5.2.4 Replacing blade sliding cylinder
5.2.4.1 Dismounting blade sliding cylinder
5.2.4.2 Mounting blade sliding cylinder
5.3 Swivelling bridge assembly
5.3.1 Replacing swivelling bridge
5.3.1.1 Dismounting swivelling bridge
5.3.1.2 Mounting swivelling bridge
5.4 Rear ripper assembly
5.4.1 Replacing rear ripper
5.4.1.1 Dismounting rear ripper
5.4.1.2 Mounting rear ripper
5.5 Dozer blade assembly
5.5.1 Replacing dozer blade
5.5.1.1 Dismounting dozer blade
5.5.1.2 Mounting dozer blade
5.6 Center pivot steering assembly
5.6.1 Center pivot steering overview
5.6.2 Centre pivot steering mounting sequence
5.6.3 Screwed connections on the pivot joint
5.6.4 Replacing center pivot steering
5.6.4.1 Dismounting center pivot steering
5.6.4.2 Mounting center pivot steering
5.6.5 Changing offset cylinder
5.6.5.1 Dismounting center pivot steering
5.6.5.2 Mounting offset cylinder
5.7 Front axle assembly
5.7.1 Replacing front axle
5.7.1.1 Dismounting front axle
5.7.1.2 Mounting front axle
5.8 Tandem axle assembly
5.8.1 Replacing planetary gear
5.8.1.1 Dismantle the tandem axle
5.8.1.2 Dismounting the wheel heads
5.8.1.3 Dismounting planetary gear from the flange
5.8.1.4 Assemble planetary gear on flange
5.8.1.5 Mounting wheel heads on the tandem axle
5.8.1.6 Mounting the tandem axle
5.8.2 Changing differential gear
5.8.2.1 Dismounting differential gear from axle carriers
5.8.2.2 Mounting differential gear onto axle carriers
5.8.3 Replacing tandem chain
5.8.3.1 Dismounting chain
5.8.3.2 Mounting the chain
HBM-Nobas Motor Grader BG160T-4 Electrical Schematics.pdf
HBM-Nobas Motor Grader BG160T-4 Hydraulic Schematics.pdf
Brand: HBM-Nobas
List of Files:
2.4 Intended Use
3.6.1 Basic notes
4.1 Vehicle types
4.1.3 Grader BG 240
5 Assembly change
- Ingersoll Rand SD-100 Schematic, Repair & Troubleshooting Manual 2022
- Kalmar Reach Stackers 40-45T DRF 400-450 Maintenance Manual
- Parts catalog Isuzu 3LA1, 3LB1, 3LD1
- Hamm 3516, 3518 ,3520 ,3516 P, 3518 P ,3520 P Spare parts List
- HATZ Diesel 2W35,3W35,3W35T,4W35,4W35T Workshop Manual
- Schwing Service Training - Training Manual
- HBM Motor Grader NOBAS BG160T-4
- Yuchai Diesel Engine YC4D Parts Catalog
- ZF – ERGOPOWER TRANSMISSION 4 WG-190/210 Service
- PALFINGER PK4501 PK5001 Hydraulic Crane Spare Parts List
- Tamrock Ranger 700-2 Operator and Maintenance Manual
- XGMA XG 955II Wheel Loader Parts Catalog
- MF 50H, MF 50HX, MF 60HX Turbo Operator Manual
- VOITH Retarder 115 Actors After Sales Service Manual
- O&K RH23.5 Crawler Excavator Hydraulics Schematics and Spare Parts Catalogue
