Haulotte Vertical Mast STAR 6P 13P 8P Service Repair Manual 4001404000 03.2026 EN
Brand: Haulotte
Type of Machine: Vertical Mast
Type of Manual: Service Manual, Repair Manual, Wiring Diagram, Hydraulic Diagram
Model: Haulotte STAR 6P, STAR 13P, STAR 8P Vertical Mast
Part Number: 4001404000
Publication Date: 03.2026
Number of Pages: 156 Pages
Responsibilities And Commitments
1 Foreword
2 Responsibilities
2.1 Owner's Responsibility
2.1.1 Product Modification
2.2 Technician's Responsability
3 Haulotte® Commitments
3.1 Haulotte Services®
3.2 Training
3.3 Product Information
3.3.1 Implementing Manufacturer Safety Campaigns
4 Conditions Of Warranty
Safety
1 General Safety Rules
1.1 Uncontrolled Movement Hazard
1.2 Electric Shock Hazards
1.3 Explosion / Fire Hazards
2 Safety Rules Energy Source Motorization
2.1 General Safety And Specific Interventions On Energy Storage
Familiarization
1 Haulotte Activ'screen
1.1 Lcd Screen
2 List Of Actuators And Sensors
2.1 Sensors And Actuators
3 Consumables (Oils...)
3.1 Hydraulic Oil
3.2 Gear Motor Oil
3.3 Cylinder Storage Oil
3.4 Grease
3.5 Marine Protection
3.6 Consumables
4 Movement Speed
Machine Sheets
Machine Sheets
Ms0086 - Steering Cylinder Removal
1 You Will Need
2 Level Of Knowledge Required
3 Safety Instructions
4 Preliminary Operation
5 Removal
6 Reinstall
7 Checks
Ms0087 - Pothole Cylinder Replacement
1 You Will Need
5 Removal
6 Reinstall
Ms0097 - Calibration Steering
1 You Will Need
3 Preliminary Operation
4 Steering Calibration Procedure
5 Checks
Ms0101 - Removing The Cylinder
1 You Will Need
5 Removal
6 Reinstall
Ms0102 - Tires (Tyres) - Wheel Replacement
1 You Will Need
2 Preliminary Operation
3 Technical Specifications
4 Wheel And Tires/Tyres Inspections
5 Procedure Of Replacement
Ms0103 - Hydraulic Oil - Level Replacement
1 You Will Need
3 Level Control
4 Replacement Of Hydraulic Oil
4.1 Consumable
4.2 Filling
Ms0104 - Lubrication - Steering Cylinder - Lift Cylinder
1 You Will Need
3 Lubrication
Ms0106 - Haulotte Activ'screen
1 You Will Need
2 Simplified Menus
3 Detailed Menus
3.1 Screen Access Code Settings
3.1.1 Screen 0d
Ms0112 - Control-Lubrication
1 You Will Need
2 Preliminary Procedure
3 Lubrication
4 Check The Condition Of The Chains
5 Check The Tension Of The Chains
6 Replacing The Chains
Ms0133 - Universal Plug
1 You Will Need
2 Procedure
Ms0153 - Hydraulic Filter
1 You Will Need
5 Removal
6 Reinstall
7 Complementary Operations
8 Checks
Ms0155 - Removal - Replacement Of Mast
1 You Will Need
5 Removal
6 Reinstall
7 Checks
Ms0157 - Clearance Procedure
1 You Will Need
4 Procedure
Ms0242 - Check Of Tilt Sensor
1 Warning
2 Risk Prevention
3 You Will Need
4 Check Of Tilt Sensor
Ms0245 - Dismantling/Reassembling The Tilt Sensor
1 Warning
2 Risk Prevention
3 You Will Need
4 Dis-Assembly
5 Reassembly
6 Calibration
7 Additional Operations
Ms0314 - Maintenance Implementation
1 Placing In Configuration
Trouble Shooting
1 Trouble Shooting
1.1 Recommendations
1.2 Description
1.3 Requirements
1.4 Failures List
1.4.1 List Of Failures Per Category
Electric And Hydraulic Diagrams
1 Wiring Diagram
1.1 Electric Diagram
2 Hydraulic Diagram
2.1 Hydraulic Diagram
Records
1 Intervention Register
Brand: Haulotte
1 Foreword
2 Responsibilities
3.2 Training
Safety
Familiarization
1.1 Lcd Screen
3.1 Hydraulic Oil
3.2 Gear Motor Oil
3.4 Grease
3.6 Consumables
4 Movement Speed
Machine Sheets
Machine Sheets
1 You Will Need
5 Removal
6 Reinstall
7 Checks
1 You Will Need
5 Removal
6 Reinstall
1 You Will Need
5 Checks
1 You Will Need
5 Removal
6 Reinstall
1 You Will Need
1 You Will Need
3 Level Control
4.1 Consumable
4.2 Filling
1 You Will Need
3 Lubrication
1 You Will Need
2 Simplified Menus
3 Detailed Menus
3.1.1 Screen 0d
1 You Will Need
3 Lubrication
1 You Will Need
2 Procedure
1 You Will Need
5 Removal
6 Reinstall
8 Checks
1 You Will Need
5 Removal
6 Reinstall
7 Checks
1 You Will Need
4 Procedure
1 Warning
2 Risk Prevention
3 You Will Need
1 Warning
2 Risk Prevention
3 You Will Need
4 Dis-Assembly
5 Reassembly
6 Calibration
Trouble Shooting
1 Trouble Shooting
1.1 Recommendations
1.2 Description
1.3 Requirements
1.4 Failures List
1 Wiring Diagram
2 Hydraulic Diagram
Records
- Haulotte Articulated Boom Lift 4527A, HTA 16P Parts and Service Manual
- Haulotte Bil-Jax Articulated Boom Lift 5533A Parts and Service Manual
- Haulotte Scissor Lift Compact 8 Parts Manual
- Haulotte HA20PX HA26PX Self Propelled LIft Repair Manual
- Haulotte Articulated Boom Lift HA15IP-HA43JE Parts Manual_2420339510
- Haulotte Scissor Lift Compact 10, 2747E Parts Manual
- Haulotte 4527A HTA 16P Part Manual
- Haulotte Articulated Boom Lift HA16PX-HA18PX Parts Manual_2420344550
- Haulotte Scissor Lift Optimum 6, Optimum 8 Parts Manual
- Haulotte OPTIMUM 8 - 1931E_E04.20 Part Manual
- Haulotte Scissor Lift Optimum 1530E, 1930E Repair Manual_2420318690
- Haulotte Articulated Boom Lift HA20PX, HA80JRT Parts Manual_2420340850
- Haulotte Telescopic Boom HT21TX-HB62 Parts Manual_2420311040
- Haulotte Self Propelled Scissor Optimum 6,8 Operating and Maintenance Instructions
- Haulotte Articulated Boom Lift HA18-HA51 Parts Manual_4000415260
