Momed80
150
35,046
Haulotte Vertical Mast STAR 6 STAR 13 Operators Manual 4001402980 03.2026 EN
Brand: Haulotte
Type of Machine: Vertical Mast
Model: Haulotte STAR 6, STAR 13 Vertical Mast
Part Number: 4001402980
Publication Date: 03.2026
Number of Pages: 144 Pages
Foreword
1 Foreword
2 Responsibilities
2.1 Owner's responsibility
2.2 Employer's responsibility
2.3 Trainer's responsibility
2.4 Operator's responsibility
3 Safety
3.1 Safety instructions
3.1.1 Incorrect use
3.1.2 Falling Hazards
3.1.3 Overturning / Tip-over Hazards
3.1.4 Risk of electric shock (electrocution)
3.1.5 Explosion / Fire Hazards
3.1.6 Crushing / Collision Hazards
3.1.7 Risk of involuntary movements
4 Safety inquiries
5 Incident notification
6 Compliance
6.1 Product modification
6.1.1 Implementing manufacturer safety campaigns
6.2 Product specifications
6.3 Change of Ownership Notification
6.4 Declaration of conformity
6.4.1 Declaration of conformity - All machines
6.4.2 Declaration of conformity - Electric platforms
Familiarization
1 General safety
1.1 Intended use
1.2 Decal content
1.3 Level of severity
1.4 Symbols legend and definitions
1.5 Symbols and colors
2 Models description
3 Primary machine components
3.1 Layout
3.2 Maintenance support
3.3 Extension deck (If fitted)
3.4 Ground control box - Service / Emergency station
3.4.1 Layout
3.4.2 HAULOTTE Activ'Screen
3.4.2.1 LCD screen
3.5 Platform control box - Main station
3.5.1 Layout
4 Performance Specifications
4.1 Technical characteristics
4.2 Working area / Range of motion
5 Decals and markings locations
Pre-operation inspection
1 Recommendations
2 Working area assessment
3 Inspection and Functional test
3.1 Daily inspection
4 Safety functional checks
4.1 Emergency Stop button check
4.2 Activation of controls
4.3 Fault detector
4.3.1 Buzzers test
4.4 Overload sensing system
4.5 Slope warning device
4.6 Travel speed limitation
4.7 Electronic variable speed drive
4.8 On-board electronics
4.9 Machine braking
4.10 Wheel motor brake release
4.11 Pothole protection system
4.12 On-board charger
4.13 Braking test
4.14 Overload test
Operation instructions
1 Operation
1.1 Introduction
1.2 Major description
1.3 Operation from the ground control box (Service / Emergency station)
1.4 Operation from the platform control box (Main station)
2 Ground control box - Service / Emergency station
2.1 To start and stop the machine
2.2 Movement control
2.3 Additional controls
3 Platform control box - Main station
3.1 To start and stop the machine
3.2 Drive and steer control
3.3 Movement control
3.4 Additional controls
4 Rescue and emergency procedures
4.1 In case of power loss
4.2 Mast manual lowering procedure
4.3 Exit from platform when elevated
5 Transportation
5.1 Transport configuration
5.2 Machine stowage for transport - STAR 6 - STAR 13 - STAR 8S - STAR 20
5.3 Unloading
5.4 Towing
5.4.1 Electric brake release
5.5 Storage
5.6 Loading by ramp
5.7 Unloading by ramp
5.8 Lifting operation
5.8.1 Lifting with spreaders
5.8.1.1 Safety precautions
5.8.1.2 Necessary equipment
5.8.1.3 Preliminary procedures
5.8.1.4 Procedure for the use of slings-with spreader
5.9 Loading and unloading with forklift
6 Cold Weather Recommendations
6.1 Environmental conditions
6.1.1 Hydraulic oil
7 Battery care and maintenance
7.1 Battery recharge
7.1.1 On-board charger
7.1.2 Battery charging
7.2 Battery care and maintenance
7.2.1 Filling batteries
7.2.1.1 Procedure to fill the batteries manually–Option
7.2.1.2 Procedure to fill the batteries automatically–Option
7.2.2 Desulfation charge
7.3 Optimise battery life
General Specifications
1 Machine dimensions
2 Major component masses
3 Acoustics and vibrations
4 Wheel/Tire assembly
4.1 Technical specifications
4.2 Inspection and maintenance
4.2.1 Procedure of replacement
Maintenance
1 General
2 Maintenance Schedule
3 Inspection program
3.1 General program
3.2 Daily inspection
3.3 Periodic inspection
3.4 Reinforced inspection
3.5 Major inspection
4 Repairs and adjustments
Options
1 Compatibility
2 Advanced Access Management - Access control and usage restriction
2.1 Description
2.1.1 Access control
2.1.2 Usage restriction
2.1.3 GEOFENCE
2.1.4 TIMEFENCE
2.1.5 Remote restriction
2.2 Additional functions
2.2.1 Access control and usage restriction combination
2.2.2 tracker default function
2.3 SUPER USER status
2.4 Code for removing restrictions
2.5 Operation
2.5.1 Using a machine with access control enabled
2.5.2 Starting a machine with usage restriction enabled
Other information
1 Conditions of warranty
2 Subsidiary contact information
2.1 California warning
Records
1 Intervention register
