Momed80
150
35,046
Haulotte Vertical Mast STAR 6 C STAR 13 C Service Repair Manual 4001413290 03.2026 EN
Brand: Haulotte
Type of Machine: Vertical Mast
Type of Manual: Service Manual, Repair Manual, Wiring Diagram, Hydraulic Diagram
Model: Haulotte STAR 6 C STAR 13 C Vertical Mast
Part Number: 4001413290
Publication Date: 03.2026
Number of Pages: 156 Pages
Responsibilities And Commitments
1 Foreword
2 Responsibilities
2.1 Owner's Responsibility
2.1.1 Product Modification
2.2 Technician's Responsability
3 Haulotte Commitments
3.1 Haulotte Services
3.2 Training
3.3 Product Information
3.3.1 Implementing Manufacturer Safety Campaigns
4 Conditions Of Warranty
Safety
1 General Safety Rules
1.1 Uncontrolled Movement Hazard
1.2 Electric Shock Hazards
1.3 Explosion / Fire Hazards
2 Safety Rules Energy Source Motorization
2.1 General Safety And Specific Interventions On Energy Storage
Familiarization
1 Haulotte Activ'screen
1.1 Lcd Screen
2 List Of Actuators And Sensors
2.1 Sensors And Actuators
3 Consumables (Oils...)
3.1 Hydraulic Oil
3.2 Gear Motor Oil
3.3 Cylinder Storage Oil
3.4 Grease
3.5 Marine Protection
3.6 Consumables
4 Movement Speed
Machine Sheets
Machine Sheets
Ms0103 - Hydraulic Oil - Level Replacement
1 You Will Need
2 Preliminary Operation
3 Level Control
4 Replacement Of Hydraulic Oil
4.1 Consumable
4.2 Filling
Ms0106 - Haulotte Activ'screen
1 You Will Need
2 Simplified Menus
3 Detailed Menus
3.1 Screen Access Code Settings
3.1.1 Screen 0d
Ms0133 - Universal Plug
1 You Will Need
2 Procedure
Ms0155 - Removal - Replacement Of Mast
1 You Will Need
2 Level Of Knowledge Required
3 Safety Instructions
4 Preliminary Operation
5 Removal
6 Reinstall
7 Checks
Ms0157 - Clearance Procedure
1 You Will Need
4 Procedure
Ms0161 - Inspection And Replacement Of Tracks
1 You Will Need
4 Inspection And Replacement Of Tracks
4.1 Inspect The Track Wear
4.2 Rubber Tracks Dismantling
4.3 Reassembly Of Rubber Tracks
Ms0162 - Motor Replacement
1 You Will Need
4 Motor Replacement
4.1 Removing The Motor
4.2 Reinstalling The Motor
Ms0235 - Disassembly - Assembly - Weight Sensor (Strain Gauge)
1 Warning
2 Risk Prevention
3 You Will Need
4 Dis-Assembly
5 Reassembly
6 Checks
Ms0246 - Check Of Tilt Sensor
1 Warning
2 Risk Prevention
3 You Will Need
4 Check Of Tilt Sensor
Ms0247 - Dismantling/Reassembling The Tilt Sensor
1 Warning
2 Risk Prevention
3 You Will Need
4 Dis-Assembly
5 Reassembly
6 Calibration
7 Additional Operations
Ms0248 - Wiring Loom
1 You Will Need
5 Removal
6 Reinstall
7 Checks
Ms0282 - Removing The Platform
1 You Will Need
5 Removal
6 Reinstall
Ms0314 - Maintenance Implementation
1 Placing In Configuration
Trouble Shooting
1 Trouble Shooting
1.1 Recommendations
1.2 Description
1.3 Requirements
1.4 Failures List
1.4.1 List Of Failures Per Category
Electric And Hydraulic Diagrams
1 Wiring Diagram
1.1 Electric Diagram
2 Hydraulic Diagram
2.1 Hydraulic Diagram
Records
1 Intervention Register
