Momed80
150
35,046
Haulotte Vertical Mast STAR 10 STAR 26J Service Repair Manual 4001354610 06.2025 EN
Brand: Haulotte
Type of Machine: Vertical Mast
Type of Manual: Service Manual, Repair Manual, Wiring Diagram, Hydraulic Diagram
Model: Haulotte STAR 10 STAR 26J Vertical Mast
Part Number: 4001354610
Publication Date: 06.2025
Number of Pages: 158 Pages
Responsibilities And Commitments
1 Foreword
2 Responsibilities
2.1 Owner's Responsibility
2.1.1 Product Modification
2.2 Technician's Responsability
3 Haulotte Commitments
3.1 Haulotte Services
3.2 Training
3.3 Product Information
3.3.1 Implementing Manufacturer Safety Campaigns
4 Conditions Of Warranty
Safety
1 General Safety Rules
1.1 Uncontrolled Movement Hazard
1.2 Electric Shock Hazards
1.3 Explosion / Fire Hazards
2 Safety Rules Energy Source Motorization
2.1 General Safety And Specific Interventions On Energy Storage
Familiarization
1 Activ'screen
2 List Of Actuators And Sensors
2.1 Sensors And Actuators
3 Consumables (Oils...)
3.1 Hydraulic Oil
3.2 Gear Motor Oil
3.3 Cylinder Storage Oil
3.4 Grease
3.5 Marine Protection
3.6 Consumables
4 Movement Speed
Machine Sheets
Machine Sheets
Ms0044 - Tires (Tyres) And Pressures-Wheel Replacement
1 You Will Need
2 Preliminary Operation
3 Technical Specifications
4 Wheel And Tires/Tyres Inspections
5 Wheel Replacement
Ms0046 - Dismantling / Reassembling Wheels Reducer
1 You Will Need
2 Level Of Knowledge Required
3 Safety Instructions
4 Removal
5 Reinstall
6 Additional Operations
7 Checks
Ms0047 - Replacing The Wheel Pivot
1 You Will Need
4 Removal
5 Reinstall
5.1 Hub
5.2 Wheel Steering Pivots
6 Checks
Ms0048 - Steering Cylinder Removal
1 You Will Need
4 Removal
5 Reinstall
6 Checks
Ms0049 - Hydraulic Oil - Level Replacement
1 You Will Need
3 Level Control
4 Replacement Of Hydraulic Oil
4.1 Consumable
4.2 Filling
Ms0050 - Hydraulic Filter Cartridge Replacement
1 You Will Need
2 Hydraulic Filter Cartridge Replacement
Ms0052 - Battery (Ies)
1 You Will Need
4 Removal
5 Reinstall
6 Checks
Ms0054 - Specific Adjustment Procedure Star 10 - Star 26j
1 You Will Need
4 Inspection Of Chain Adjustment
5 Inspection Of Chain Adjustment
Ms0061 - Clearance Procedure
1 You Will Need
4 Procedure
Ms0062 - Inspection Of The Slack Chain Sensors
1 You Will Need
4 Procedure
5 Slack Chain Detector Adjustment Procedure
Ms0085 - Overriding Function Reset
1 You Will Need
3 Preliminary Operation
4 Overriding Function Reset
4.1 Procedure
Ms0097 - Calibration Steering
1 You Will Need
4 Steering Calibration Procedure
5 Checks
Ms0133 - Universal Plug
1 You Will Need
2 Procedure
Ms0242 - Check Of Tilt Sensor
1 Warning
2 Risk Prevention
3 You Will Need
4 Check Of Tilt Sensor
Ms0245 - Dismantling/Reassembling The Tilt Sensor
1 Warning
2 Risk Prevention
3 You Will Need
4 Dis-Assembly
5 Reassembly
6 Calibration
7 Additional Operations
Ms0314 - Maintenance Implementation
1 Placing In Configuration
Ms0343 - Visual Inspection Of The Baseplate Fastening Screws On The Casings Of Booms 1 And 2
1 Warning
2 Risk Prevention
3 You Will Need
4 Procedure
4.1 Inspection Of Fastening Screws On The Lifting Cylinder Baseplate Of Housing 1
4.2 Inspection Of The Fastening Screws Of The Baseplate Of Housing No 2
Trouble Shooting
1 Trouble Shooting
1.1 Recommendations
1.2 Description
1.3 Requirements
1.4 Failures List
1.4.1 List Of Failures Per Category
Electric And Hydraulic Diagrams
1 Wiring Diagram
1.1 Electric Diagram
2 Hydraulic Diagram
2.1 Hydraulic Diagram
Records
1 Intervention Register
