Momed80
150
35,046
Haulotte Vertical Mast STAR 10 STAR 26J Operators Manual 4001354300 11.2025 EN
Brand: Haulotte
Type of Machine: Vertical Mast
Model: Haulotte STAR 10 STAR 26J Vertical Mast
Part Number: 4001354300
Publication Date: 11.2025
Number of Pages: 142 Pages
Foreword
1 Foreword
2 Responsibilities
2.1 Owner's Responsibility
2.2 Employer's Responsibility
2.3 Trainer's Responsibility
2.4 Operator's Responsibility
3 Safety
3.1 Safety Instructions
3.1.1 Incorrect Use
3.1.2 Falling Hazards
3.1.3 Overturning / Tip-Over Hazards
3.1.4 Risk Of Electric Shock (Electrocution)
3.1.5 Explosion / Fire Hazards
3.1.6 Crushing / Collision Hazards
3.1.7 Risk Of Involuntary Movements
4 Safety Inquiries
5 Incident Notification
6 Compliance
6.1 Product Modification
6.1.1 Implementing Manufacturer Safety Campaigns
6.2 Product Specifications
6.3 Change Of Ownership Notification
6.4 Declaration Of Conformity
6.4.1 Declaration Of Conformity - All Machines
6.4.2 Declaration Of Conformity - Electric Platforms
Familiarization
1 General Safety
1.1 Intended Use
1.2 Decal Content
1.3 Level Of Severity
1.4 Symbols Legend And Definitions
1.5 Symbols And Colors
2 Models Description
3 Primary Machine Components
3.1 Layout
3.2 Ground Control Box - Service / Emergency Station
3.2.1 Layout
3.2.2 Activ'screen
3.3 Platform Control Box - Main Station
3.3.1 Layout
4 Performance Specifications
4.1 Technical Characteristics
4.2 Working Area / Range Of Motion
5 Decals And Markings Locations
Pre-Operation Inspection
1 Recommendations
2 Working Area Assessment
3 Inspection And Functional Test
3.1 Daily Inspection
4 Safety Functional Checks
4.1 Emergency Stop Button Check
4.2 Activation Of Controls
4.3 Fault Detector
4.3.1 Buzzers Test
4.4 Overload Sensing System
4.5 Slope Warning Device
4.6 Travel Speed Limitation
4.7 Electronic Variable Speed Drive
4.8 Machine Braking
4.9 Pothole Protection System
4.10 On-Board Charger
4.11 Braking Test
4.12 Overload Test
Operation Instructions
1 Operation
1.1 Introduction
1.2 Major Description
1.3 Operation From The Ground Control Box (Service / Emergency Station)
1.4 Operation From The Platform Control Box (Main Station)
2.1 To Start And Stop The Machine
2.2 Movement Control
2.3 Additional Controls
3.1 To Start And Stop The Machine
3.2 Drive And Steer Control
3.3 Movement Control
3.4 Additional Controls
4 Rescue And Emergency Procedures
4.1 In Case Of Power Loss
4.2 To Rescue Operator In Platform
4.2.1 Operation Of Overriding System From Ground Control Box
4.3 Manual Emergency Lowering Procedure
4.3.1 Jib Manual Lowering Procedure
4.3.2 Mast Manual Lowering Procedure
4.3.3 Hand Pump
5 Transportation
5.1 Transport Configuration
5.2 Machine Stowage For Transport- Star 10 - Star 26j
5.3 Unloading
5.4 Towing
5.4.1 Electric Brake Release
5.5 Storage
5.6 Loading By Ramp
5.7 Unloading By Ramp
5.8 Lifting Operation
5.8.1 Loading And Unloading
5.8.1.1 Safety Precautions
5.8.1.2 Necessary Equipment
5.8.1.3 Preliminary Procedures
5.8.1.4 Procedure For The Use Of Slings
5.8.2 Lifting Operation With Tie-Down Points On The Mast
5.8.2.1 Safety Precautions
5.8.2.2 Necessary Equipment
5.8.2.3 Preliminary Procedures
5.8.2.4 Procedure For The Use Of Slings
5.9 Loading And Unloading With Forklift
6 Cold Weather Recommendations
6.1 Environmental Conditions
6.1.1 Hydraulic Oil
7 Battery Care And Maintenance
7.1 Battery Recharge
7.1.1 On-Board Charger
7.1.2 Battery Charging
7.2 Battery Care And Maintenance
7.2.1 Filling Batteries
7.2.1.1 Procedure To Fill The Batteries Automatically
7.2.2 Desulfation Charge
7.3 Optimise Battery Life
General Specifications
1 Machine Dimensions
2 Major Component Masses
3 Acoustics And Vibrations
4 Wheel/Tire Assembly
4.1 Technical Specifications
4.2 Inspection And Maintenance
5 Options
5.1 Compatibility
5.2 Advanced Access Management - Access Control And Usage Restriction
5.2.1 Description
5.2.1.1 Access Control
5.2.1.2 Usage Restriction
5.2.1.3 Geofence
5.2.1.4 Timefence
5.2.1.5 Remote Restriction
5.2.2 Additional Functions
5.2.2.1 Access Control And Usage Restriction Combination
5.2.2.2 Tracker Default Function
5.2.3 Super User Status
5.2.4 Code For Removing Restrictions
5.2.5 Operation
5.2.5.1 Using A Machine With Access Control Enabled
5.2.5.2 Starting A Machine With Usage Restriction Enabled
5.3 Activ' Shield Bar - Secondary Guarding System (If Fitted)
5.3.1 Description
5.3.2 Characteristics
5.3.3 Safety Precautions
5.3.4 Pre-Operation Inspection
5.3.5 Operation
5.3.6 Specific Decals
Maintenance
1 General
2 Maintenance Schedule
3 Inspection Program
3.1 General Program
3.2 Daily Inspection
3.3 Periodic Inspection
3.4 Reinforced Inspection
3.5 Major Inspection
4 Repairs And Adjustments
Other Information
1 Conditions Of Warranty
2 Subsidiary Contact Information
2.1 California Warning
Records
1 Intervention Register
