Haulotte Vertical Mast STAR 10 STAR 26J Maintenance Manual 4001354550 06.2025 EN
Brand: Haulotte
Type of Machine: Vertical Mast
Type of Manual: Maintenance Manual, Wiring Diagram, Hydraulic Diagram
Model: Haulotte STAR 10, STAR 26J Vertical Mast
Part Number: 4001354550
Publication Date: 06.2025
Number of Pages: 122 Pages
Responsibilities And Commitments
1 Foreword
2 Responsibilities
2.1 Owner's Responsibility
2.1.1 Product Modification
2.2 Technician's Responsability
3 Haulotte Commitments
3.1 Haulotte Services
3.2 Training
3.3 Product Information
3.3.1 Implementing Manufacturer Safety Campaigns
4 Conditions Of Warranty
Safety
1 General Safety Rules
1.1 Uncontrolled Movement Hazard
1.2 Electric Shock Hazards
1.3 Explosion / Fire Hazards
2 Safety Rules Energy Source Motorization
2.1 General Safety And Specific Interventions On Energy Storage
Familiarization
1 Activ'screen
2 List Of Actuators And Sensors
2.1 Sensors And Actuators
3 Consumables (Oils...)
3.1 Hydraulic Oil
3.2 Gear Motor Oil
3.3 Cylinder Storage Oil
3.4 Grease
3.5 Marine Protection
3.6 Consumables
4 Movement Speed
Inspection And Maintenance Schedule
1 Inspection Program
2 Daily Inspection
3 Preventive Maintenance
3.1 Preventive Maintenance
4 Periodic Inspection
5 Major Inspection
Machine Sheets
Machine Sheets
Ms0001 - Structural Part Inspection
1 Warning
2 Risk Prevention
3 You Will Need
4 Control And Maintenance
4.1 Daily Inspection
4.2 Major Inspection
4.3 Functional Tests
4.4 Dynamic Tests
4.5 Structural Test
Ms0002 - Pins And Bearing Inspection
1 Warning
2 Risk Prevention
3 You Will Need
5 Criteria Of Replacement
6 Procedure Of Reassembly
6.1 Pins And Bushes
6.2 Bearings
Mp0002i - Wheel Reducer Level Procedure
1 Concerned Machines
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Consumables
7 Procedure
8 Additional Operations
Ms0003 - Cylinder Inspection
1 Warning
2 Risk Prevention
3 You Will Need
4.1 Visual Inspections
4.2 Functional Tests
4.3 Major Inspection
Ms0004 - Braking Test Procedure
1 Warning
2 Risk Prevention
3 You Will Need
4 Test Procedure
Ms0005 - Torque Values
1 Metric Torque Chart
2 Sae Fastener Torque Chart
3 Hydraulic Couplings And Hoses Tightening Torque Charts
4 Star 10 - Star 26j
Ms0010 - Slew Ring Inspection
1 You Will Need
2 Preliminary Operation
3 Lubrication
4 Tightening
5 Slew Ring Inspection
5.1 Visual And Sound Check
5.2 Measurement Of The Clearance
Ms0012 - Condition Of The Cables Inspection-Criteria Of Replacement
1 You Will Need
3 Control Wire Rope System
3.1 Daily Check
3.2 Periodic Control
4 Tension Checking
Ms0020 - Hoses Inspection - Replacement
1 You Will Need
2 Control And Inspections
3 Hoses Disassembling
4 Hoses Reassembly
Ms0042 - Inspection Of The Condition Of The Chains-Criteria Of Replacement
1 You Will Need
3 Lubrication
3.1 Check The Condition Of The Chains
3.2 Check The Tension Of The Chains
4 Replacing The Chains
Mp0043i - Draining The Wheel Reducer
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Consumables
7 Procedure
Ms0045 - Lubrication - Jib Cylinder - Steering Cylinder - Lift Cylinder
1 You Will Need
3 Lubrication
Ms0053 - Return Cables
1 You Will Need
2 Level Of Knowledge Required
3 Safety Instructions
4 Control
Ms0059 - Electrical Wiring
1 You Will Need
Ms0314 - Maintenance Implementation
1 Placing In Configuration
Electric And Hydraulic Diagrams
1 Wiring Diagram
1.1 Electric Diagram
2 Hydraulic Diagram
2.1 Hydraulic Diagram
Records
1 Intervention Register
Brand: Haulotte
1 Foreword
2 Responsibilities
3.2 Training
Safety
Familiarization
1 Activ'screen
3.1 Hydraulic Oil
3.2 Gear Motor Oil
3.4 Grease
3.6 Consumables
4 Movement Speed
2 Daily Inspection
5 Major Inspection
Machine Sheets
Machine Sheets
1 Warning
2 Risk Prevention
3 You Will Need
4.4 Dynamic Tests
4.5 Structural Test
1 Warning
2 Risk Prevention
3 You Will Need
6.1 Pins And Bushes
6.2 Bearings
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Consumables
7 Procedure
1 Warning
2 Risk Prevention
3 You Will Need
1 Warning
2 Risk Prevention
3 You Will Need
4 Test Procedure
1 You Will Need
3 Lubrication
4 Tightening
1 You Will Need
3.1 Daily Check
4 Tension Checking
1 You Will Need
4 Hoses Reassembly
1 You Will Need
3 Lubrication
2 Concerned Area
3 Warning
4 Risk Prevention
5 You Will Need
6 Consumables
7 Procedure
1 You Will Need
3 Lubrication
1 You Will Need
4 Control
1 You Will Need
1 Wiring Diagram
2 Hydraulic Diagram
Records
- Haulotte Articulated Boom Lift 4527A, HTA 16P Parts and Service Manual
- Haulotte Bil-Jax Articulated Boom Lift 5533A Parts and Service Manual
- Haulotte Scissor Lift Compact 8 Parts Manual
- Haulotte HA20PX HA26PX Self Propelled LIft Repair Manual
- Haulotte Articulated Boom Lift HA15IP-HA43JE Parts Manual_2420339510
- Haulotte Scissor Lift Compact 10, 2747E Parts Manual
- Haulotte 4527A HTA 16P Part Manual
- Haulotte Articulated Boom Lift HA16PX-HA18PX Parts Manual_2420344550
- Haulotte Scissor Lift Optimum 6, Optimum 8 Parts Manual
- Haulotte OPTIMUM 8 - 1931E_E04.20 Part Manual
- Haulotte Scissor Lift Optimum 1530E, 1930E Repair Manual_2420318690
- Haulotte Articulated Boom Lift HA20PX, HA80JRT Parts Manual_2420340850
- Haulotte Telescopic Boom HT21TX-HB62 Parts Manual_2420311040
- Haulotte Self Propelled Scissor Optimum 6,8 Operating and Maintenance Instructions
- Haulotte Articulated Boom Lift HA18-HA51 Parts Manual_4000415260
